Hi all, I have laptop HP Envy x360 13-ar0022nn AMD Ryzen 5 3500U ,with 8 /gb RAM.
I used Manjaro for last 6 months, but last 2 weeks i switched back to Win10 because i need my full sound system. Only problem , I have Bang & Olufsen, quad speakers,
but sound comming only from bottom, so 2 speakers…
More info:
inxi -Fxxxz output:
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Convertible System: HP
product: HP ENVY x360 Convertible 13-ar0xxx v: N/A serial: <filter>
Chassis: type: 31 serial: <filter>
Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.19
date: 12/26/2019
ID-1: BAT0 charge: 38.2 Wh condition: 52.7/52.7 Wh (100%)
volts: 15.8/15.4 model: 333-2B-49-A KC04053XL type: Li-ion
serial: <filter> status: Discharging
Topology: Quad Core
model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB
bogomips: 33550
Speed: 1222 MHz min/max: 1400/2100 MHz boost: disabled
Core speeds (MHz): 1: 1222 2: 1222 3: 1231 4: 1275 5: 1266 6: 1223
7: 1259 8: 1248
Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 04:00.0 chip ID: 1002:15d8
Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 3-1:2 chip ID: 04ca:709d
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 04:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
bus ID: 04:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A port: f000
bus ID: 02:00.0 chip ID: 10ec:b822
Local Storage: total: 942.70 GiB used: 6.97 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0
scheme: GPT
ID-2: /dev/sda type: USB vendor: HGST (Hitachi) model: HTS725050A7E630
size: 465.76 GiB rotation: 7200 rpm serial: <filter> scheme: GPT
ID-1: / size: 457.16 GiB used: 6.97 GiB (1.5%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 34.8 C mobo: 32.0 C gpu: amdgpu temp: 34 C
Processes: 235 Uptime: 9m Memory: 5.74 GiB used: 1.28 GiB (22.4%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1161
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
aplay --list-pcms output:
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=Generic,DEV=0
HD-Audio Generic, HDMI 0
HDMI Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
sysdefault:CARD=Generic_1
HD-Audio Generic, ALC285 Analog
Default Audio Device
front:CARD=Generic_1,DEV=0
Front output / input
surround21:CARD=Generic_1,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic_1,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic_1,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic_1,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic_1,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic_1,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic_1
HD-Audio Generic
USB Stream Output
usbstream:CARD=acp
acp
USB Stream Output
speaker-test 1.2.3 output:
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 192 to 2097152
Period size range from 64 to 699051
Using max buffer size 2097152
Periods = 4
was set period_size = 524288
was set buffer_size = 2097152
0 - Front Left
Time per period = 10,952330
0 - Front Left
Time per period = 10,950214
0 - Front Left
Time per period = 10,949573
0 - Front Left
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ inxi --audio
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel
> marko@marko-hpenvyx360convertible13ar0xxx ~]$ pulseaudio --dump-conf
### Read from configuration file: /etc/pulse/daemon.conf ###
daemonize = no
fail = yes
high-priority = yes
nice-level = -11
realtime-scheduling = yes
realtime-priority = 5
allow-module-loading = yes
allow-exit = yes
use-pid-file = yes
system-instance = no
local-server-type = user
cpu-limit = no
enable-shm = yes
flat-volumes = no
lock-memory = no
exit-idle-time = 20
scache-idle-time = 20
dl-search-path = /usr/lib/pulse-13.0/modules
default-script-file = /etc/pulse/default.pa
load-default-script-file = yes
log-target =
log-level = notice
resample-method = auto
avoid-resampling = no
enable-remixing = yes
remixing-use-all-sink-channels = yes
enable-lfe-remixing = no
lfe-crossover-freq = 0
default-sample-format = s16le
default-sample-rate = 44100
alternate-sample-rate = 48000
default-sample-channels = 2
default-channel-map = front-left,front-right
default-fragments = 4
default-fragment-size-msec = 25
enable-deferred-volume = yes
deferred-volume-safety-margin-usec = 8000
deferred-volume-extra-delay-usec = 0
shm-size-bytes = 0
log-meta = no
log-time = no
log-backtrace = 0
rlimit-fsize = -1
rlimit-data = -1
rlimit-stack = -1
rlimit-core = -1
rlimit-rss = -1
rlimit-as = -1
rlimit-nproc = -1
rlimit-nofile = 256
rlimit-memlock = -1
rlimit-locks = -1
rlimit-sigpending = -1
rlimit-msgqueue = -1
rlimit-nice = 31
rlimit-rtprio = 9
rlimit-rttime = 200000
amixer --card=0 output:
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ amixer --card=1
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Limits: Playback 0 - 87
Mono: Playback 0 [0%] [-65.25dB] [on]
Simple mixer control 'Speaker CLFE',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 52 [60%] [-26.25dB] [on]
Front Right: Playback 52 [60%] [-26.25dB] [on]
Simple mixer control 'Speaker Surround',0
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 124 [49%] [-26.20dB]
Front Right: Playback 124 [49%] [-26.20dB]
Simple mixer control 'Line Out',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Is it possible to fix that ? I really want to use Manjaro as my main OS, but this is the only thing holding me back.
but it should at least get you closer to a full working solution
