Difficulty: ★★★☆☆
Important things
- Make sure that you have installed working fine for your hardware LTS kernel or lastest stable kernel
- Since 4.12 kernel you have to create a
/etc/udev/rules.d/60-ioschedulers.ruleswith setup about I/O schedulers for different types storage. HowTo is described in this article. - Make sure that you have installed for your CPU Microcode
- Make sure that you have added the appropriate entries in the GRUB configuration file
- Make sure you have installed all of the updates
- See Bumblebee/PRIME Troubleshooting
- See Qualcomm Atheros Troubleshooting
- See Dropping all legacy and older Nvidia drivers thread
Kernel
In default Manjaro ISOs provides lastest stable kernel release. If you have any issues/regressions hardware, you can simply change kernel to previous version.
Please check official announcements forum threads to find out.
Check out https://www.kernel.org/category/releases.html for list of currently at the moment supported and maintained official kernel list.
You can simply use Manjaro Settings Manager for switch to another kernel branch OR using
mhwd-kerneltool in terminal as root .
Current available list of
kernel parametersis always available on https://www.kernel.org/doc/html/latest/admin-guide/kernel-parameters.html
CPUs Microcode
AMD CPU’s users should have installed lastest
amd-ucodepackage.
Intel CPU’s users should have installed lastestintel-ucodepackage.
Adding advanced flags to the GRUB configuration file
This section IS NOT FOR NEWBIES. You need to know what hardware you’ve and set properly setup.
You can check what exactly flags are available for your hardware via commandmodinfo $MODULE_NAME | grep '^parm:'.
Make backup a default grub file:
sudo cp /etc/default/grub /etc/default/grub.bak
Edit grub file in Your favorite text editor. For this HowTo I used nano.
sudo nano /etc/default/grub
Find line:
GRUB_CMDLINE_LINUX=""
Paste the appropriate flags ‘‘between the quotation marks’’ as described below.
For more information on what these flags do, please read The Arch Wiki .
The story of _OSI(Linux)
ACPI OSI Linux Obsolete/legacy for OLDER devices with mostly BIOS FW.
acpi_osi="Linux"
From pre-history through Linux-2.6.22, Linux responded TRUE upon a BIOS OSI(Linux) query. Unfortunately, reference BIOS writers got wind of this and put OSI(Linux) in their example code, quickly exposing this string as ill-conceived and opening the door to an un-bounded number of BIOS incompatibilities.
For example, OSI(Linux) was used on resume to re-POST a video card on one system, because Linux at that time could not do a speedy restore in its native driver. But then upon gaining quick native restore capability, Linux has no way to tell the BIOS to skip the time-consuming POST – putting Linux at a permanent performance disadvantage.
On another system, the BIOS writer used OSI(Linux) to infer native OS support for IPMI! On other systems, OSI(Linux) simply got in the way of Linux claiming to be compatible with other operating systems, exposing BIOS issues such as skipped device initialization.
So “Linux” turned out to be a really poor chose of
OSI string, and from Linux-2.6.23 onward we respond FALSE.
BIOS writers should NOT query _OSI(Linux) on future systems.
Linux will complain on the console when it sees it, and return FALSE.
To get Linux to return TRUE for your system will require
a kernel source update to add a DMI entry,
or boot with “acpi_osi=Linux”.
Source: linux/osi.c at master · torvalds/linux · GitHub
STRONGLY PLEASE READ this before going forward: How to Choose the Proper ACPI Kernel Argument made by @linesma
GRUB Flags
ACPI LM SENSORS Issues
WARNING : Users with modern devices (FW UEFI based) should not using ANY of additional flags EXCEPT really need them for resolving issues with lm-sensors, heating for example.
HP users should not useacpi=force acpi_enforce_resources=laxagainst ELAN Touchpad can missed from available devices.
See thread: https://archived.forum.manjaro.org/t/solved-touchpad-suddenly-not-recognised/142053/19
When not working backlight control function keys
acpi=force acpi_enforce_resources=lax drm.vblankoffdelay=1 acpi_backlight=vendor
ACPI - for the modern models of laptops with UEFI (2011 year production or newer) please adding after acpi_osi=Linux :
acpi_osi='!Windows 2012'
ACPI - for the modern models of laptops with UEFI (2014 year production or newer) please using:
This workaround is dedicated for Intel Skylike Laptops with NVIDIA Optimus freezes issue. See: Bumblebee GH-764 :
acpi_osi=! acpi_osi="Windows 2009"
or
acpi_osi=! acpi_osi='Windows 2015'
On some laptops, when Fn keys or display backlight Fn keys does not works at all use blank acpi_osi value:
acpi_osi=
AMD - enable DPM for the graphics cards AMD Radeon. Flag Only for Linux Kernel built-in radeon module driver. [legacy]
radeon.dpm=1
AMD - enable HDMI Audio for the graphics cards AMD Radeon. Flag Only for Linux Kernel built-in radeon module driver. [legacy]
radeon.audio=1
INTEL - Enable Early Kernel Mode Setting for i915 module.
- Edit
/etc/mkinitcpio.conffile and inMODULESsection add i915 .
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=(i915)
- Regenerate boot images:
sudo mkinitcpio -P
- Add to
GRUB_CMDLINE_LINUXin grub conf file and update grub configuration:
i915.modeset=1
Install X.org framebuffer video driver package:
sudo pacman -S xf86-video-fbdev --noconfirm --needed
Reboot for apply changes.
Disable IPv6 - don’t load required kernel modules for IPv6 working
NOTE: be sure you have disabled IPv6 support for external network apps and services like
ufwfirewall tool,ntpdNetwok Time Sync Daemon ordhcpd. Otherwise app services will not working properly. You have been warned.
More details and samples are available in this ArchWiki article .
For disable whole IPv6 stack add this setting to grub command line:
ipv6.disable=1
Disabling Consistent Network Device Naming
Simplify this setting restore legacy network interfaces names like
ath0wlan1and so on.
net.ifnames=0
Don’t print systemd version during boot
rd.udev.log-priority=3
Disabling audit
audit=0
Disabling PCIE ASPM Power Savings against issues
pcie_aspm=off
Disabling Watchdog feature
nowatchdog
NOTE: blacklist Watchdogs modules too:
/etc/modprobe.d/blacklist.confblacklist iTCO_wdt blacklist iTCO_vendor_support
Forcing enable power saving mode for Atheros WLAN devices
In default
ath9kmodule don’t switch to power saving mode under battery power mode.
ath9k.ps_enable=1
Disable all current mitigations to regain the maximum possible lost performance
UPDATE NOTICE 2020-04-09 from @FadeMind
Since discovering a lot of FW Intel Microcode CVE’s Linux kernel slowed down a lot (multicore 15% down, single core 25% down).
See https://www.reddit.com/r/linux/comments/b1ltnr/disabling_kernel_cpu_vulnerabilities_mitigations/
On site https://make-linux-fast-again.com/ they are available flags for disabling ALL of fixes maded in lastest kernel.
mitigations=off does not disabling all of them.
THERE IS a flag sentence.
mitigations=off noibrs noibpb no_stf_barrier tsx=on
After applying changes in grub AND REBOOT you can check status of mitigations via command:
sudo spectre-meltdown-checker
Disable Synaptics RMI4 spam in some Lenovo ThinkPads.
If you have spam message rmi4_phisical rmi4-00: Failed to read irqs, code=-6 or similar you can disable it via grub flag:
psmouse.synaptics_intertouch=0
Save applied changes to a file. Execute the command in a terminal:
sudo update-grub
Installing additionals for TLP
TLP is installed, customized and enabled in Manjaro ISOs. You can install additional recommended tools for boost/extend power saving.
In a terminal, run the following command:
sudo pacman -S --needed tlp tlp-rdw iw smartmontools ethtool x86_energy_perf_policy
Disable RFKILL services:
sudo systemctl mask systemd-rfkill.socket systemd-rfkill.service
Reboot.
Check current settings of TLP via
sudo tlp-stat
# /etc/tlp.conf - TLP user configuration
# See full explanation: https://linrunner.de/en/tlp/docs/tlp-configuration.html
# New configuration scheme (TLP 1.3). Settings are read in the following order:
# 1. Intrinsic defaults
# 2. /etc/tlp.d/*.conf - Drop-in customization snippets
# 3. /etc/tlp.conf - User configuration (this file)
# Notes:
# - In case of identical parameters, the last occurence has precedence
# - This also means, parameters enabled here will override anything else
# - IMPORTANT: all parameters here are disabled, remove the leading '#'
# to enable them; shown values may be suggestions rather than defaults
# - Default *: intrinsic default that is effective when the parameter is missing
# or disabled by a leading '#'; use PARAM="" to disable an intrinsic default
# - Default <none>: do nothing or use kernel/hardware defaults
WARNING :
After made changes in /etc/tlp.conf file restart systemd tlp servicesudo systemctl restart tlp
Installing Linux Thermal Daemon
NOTE: thermald working only with Intel CPUs with P-State govenor
Before install thermald please install and configure propertly lm_sensors by command
sudo pacman -S lm_sensors && sudo sensors-detect
Install, enable and run thermald daemon by following command:
NOTE - for now, the package
thermaldis in the AUR. We will useyayas an example here
yay -S thermald --needed
Manually enable and launch thermald systemd service:
sudo systemctl enable thermald && \
sudo systemctl start thermald
REQUIRED FOR 4.12 and NEWER. Dynamically changing the scheduler I/O disks.
Manjaro using in default mq-deadline . For customize I/O scheduler since 4.12 kernel YOU HAVE TO create a 60-ioschedulers.rules UDEV rule file. They are available new optionals schedulers.
Higher read/write performance for the solid state drives (SSD) have mq-deadline scheduler. You can automate the process of change scheduler disk I/O, depending on whether the disk is rotating (HDD) or not (SSD).
Create a new file:
sudo nano /etc/udev/rules.d/60-ioschedulers.rules
Paste this code into it:
# set scheduler for NVMe
ACTION=="add|change", KERNEL=="nvme[0-9]*", ATTR{queue/scheduler}="none"
# set scheduler for SSD and eMMC
ACTION=="add|change", KERNEL=="sd[a-z]|mmcblk[0-9]*", ATTR{queue/rotational}=="0", ATTR{queue/scheduler}="mq-deadline"
# set scheduler for rotating disks
ACTION=="add|change", KERNEL=="sd[a-z]", ATTR{queue/rotational}=="1", ATTR{queue/scheduler}="bfq"
Update grub via sudo update-grub and restart the computer.
You can check current using scheduler for all connected disks by command:
cat /sys/block/sd*/queue/scheduler
Summary
This topic is just BASIC guide for tweaks and improving performance. Since lastest major update this topic a lot were changed in hardware and software code self.
I encourage you to read the documentation TLP. You can customize the service to suit your needs. This topic contains the basic configuration to work properly.
See Also
- TLP Homepage
- Arch Wiki: TLP
- Arch Wiki: SSD I/O Scheduler
- Phoronix Benchmark Results
- ArchWiki|Improving performance > Changing_I/O_scheduler
- thomas-krenn.com: Linux Multi-Queue Block IO Queueing Mechanism (blk-mq)
- https://yarondar.wordpress.com/2018/07/29/have-you-tried-blk-mq/
- Ubuntu Wiki: IO Schedulers
- Arch Wiki: Improving Performance
- Linux Thermal Daemon
- Linux Kernel Parameters
- https://make-linux-fast-again.com/
- https://www.kernel.org/category/releases.html
Thanks for TIP!
