[HowTo] Btrfs and Snapper
Difficulty: ★★★☆☆
How-To BTRFS and SNAPSHOTS for N@@bs
  1. Install system in BTRFS format on a sdd disk
  • Partitions
    • boot:
      • File System: FAT32
      • Mount point: /boot/efi
      • Size: 512M
      • Partition flags: EFI, BOOT
    • root:
      • File System: BTRFS
      • Mount point: /
      • Size: 48GB for normal user, 64GB for power user
      • Mount options: noatime,sdd,clear_cache,commit=120,compress=zstd,subvolid=256
    • home:
      • Mount point: /home
      • Size: 64GB for small user, 128GB for power user, the rest of your disk -10% for super-user
      • Mount Options: noatime,sdd,clear_cache,commit=120,compress=zstd,subvolid=256
  • Subvolumes
    • @Ugin /home
  1. Snapper
  • Create config files for each Partition
    • We need root acces
    • snapper -c root create-config /
    • snapper -c home create-config /home
  • Config the snapper config files
    • The method is the same for any config file (I.E. / and /home)
    • nano /etc/snapper/configs/root
    • Set the variable ALLOW_USERS="@USER" in /etc/environment
    • Set limits for timeline cleanup to:
      #this is my own
      Hourly=“0”
      Daily=“2”
      Weekly=“4”
      Monthly=“12”
      Yearly=“1”
  • Adding @USER permissions to the snapshots directories:
    chmod a+rw /.snapshots/
    chmod a+rw /home/.snapshots/
  • Enable and start snapper services:
    • We need root access
      systemctl start snapper-timeline.timer
      systemctl enable snapper-timeline.timer
      systemctl start snapper-cleanup.timer
      systemctl enable snapper-cleanup.timer
  • Enable grub-btrfs services
    • Install grub-btrfs:
      pamac install grub-btrfs
      systemctl start grub-btrfs.path
      systemctl enable grub-btrfs.path
  • List the snapshots created
    • As @USER
      snapper -c list
  • Create a snapshot manually:
    • As @USER
        snapper -c create -c timeline --description
  • Changing permissions of snapshots
    • By default all snapshots are set as Read-Only
    • Check snapshops permissions as @USER:
      btrfs property list -ts /.snapshots//snapshot/ # for @
      btrfs property list -ts /home/.snapshops//snapshot # for @Ugin
    • Changing snaphots permissions to Write
        btrfs property set -ts /.snapshots//snapshot/ ro false #for @
        btrfs property set -ts /home/.snaphots//snapshot/ ro false #for @Ugin
How-To Convert an ext2/3/4 filesystem in a BTRFS system
  1. Do a full backup of your system, / and /home with Timeshift or other application who use RSYNC
  2. Boot up with a live system
  3. Do the partitioning using btrfs; in my case, I created /boot/efi, / and /home
  • Checking subvolumes
      btrfs subvolume list
  • Mount / partition
    mount /dev/sdXN /mnt
    btrfs subvolume list /mnt
  1. Creating other subvolumes
  • Create BTRFS subvolume for /home
  • With our / partition mounted in /mnt, we’re going to delete the EXT4 /home folder
    rm -rf /mnt/home
  • Create the @Ugin subvolume
    btrfs subvolume create /mnt/@Ugin
  • Now we can mount the /home partition into the subvolume
    mount /dev/sdXN /mnt/@Ugin
  1. Restoring the backup
    • You could use any application or you could use rsync to do it.
  2. Edit /etc/fstab
  • Change the old UUID to the news, the partitions format and mount options
    sudo nano --backup /mnt/etc/fstab
  1. Reinstall Grub
    sudo update-grub
Source for documentation:
Btrfs Arch Wiki
Snapper Arch Wiki
Please have a look at my edits and disregard anything you don’t like… :wink: (:heart: and :+1: will remain in place even if you revert completely, but this way it’s easier on the :eyes:…)
Hi!
Like you said, It’s easy to see this way. Nothing to add, just Thanks!!!1
Hi,
I have some issues with Snapper setup.
Atm I stucked here :
  • systemctl start grub-btrfs.path  1 ✘
    Failed to start grub-btrfs.path: Unit \x2esnapshots.mount not found.
Also can not create snapshot manually … What I did wrong ? :slight_smile:
A post was split to a new topic: BTRFS Snapper help needed
But this is old.
There is snapper GUI btrfs-assistant good for beginner, but it is still in development and testing.
Forum:
I tried it in Manjaro, it works fine with creating new snapshots and restoring snapshot via GUI.
  • One point is missing:
    Grub-btrfs can not boot any read-only snapshot.
    There is a trick:
    You need to edit /etc/mkinitcpio.conf to add grub-btrfs-overlayfs in HOOK, then you create a new read-only snapshot including the ability grub-btrfs-overlayfs to boot it into RAM like the behavior of Live USB/CD. Then you restore a snapshot.
Because .snapshots is the directory, but not subvolume. Try to create a new subvolume @snapshots then edit /etc/fstab to mount it with .snapshots
Total noob questions:
  1. What’s @Ugin? I tried googling but even on the wiki I couldn’t find anything about it.
  2. Is the /home partition necessary? I come from Garuda and I didn’t have a /home partition. My / usage is kinda unpredictable, especially with docker/podman/distrobox. Speaking of:
Current Subvolumes on Garuda
sudo btrfs subvolume list /mnt
ID 256 gen 187528 top level 5 path @
ID 257 gen 187528 top level 5 path @home
ID 258 gen 186167 top level 5 path @root
ID 259 gen 175719 top level 5 path @srv
ID 260 gen 187502 top level 5 path @cache
ID 261 gen 187528 top level 5 path @log
ID 262 gen 186845 top level 5 path @tmp
ID 263 gen 186610 top level 256 path .snapshots
ID 396 gen 179152 top level 256 path var/lib/docker/btrfs/subvolumes/21b99aa1976242e860da5be90a706225222041dc9d28e9a4aa2961878fd157df
ID 397 gen 10614 top level 256 path var/lib/docker/btrfs/subvolumes/ba18748cababfedc54a6e5c49b6609a93279574caa467421b61871cab5d1c0a0-init
ID 398 gen 10614 top level 256 path var/lib/docker/btrfs/subvolumes/ba18748cababfedc54a6e5c49b6609a93279574caa467421b61871cab5d1c0a0
ID 1392 gen 184269 top level 263 path .snapshots/1122/snapshot
ID 1393 gen 184271 top level 263 path .snapshots/1123/snapshot
ID 1394 gen 184275 top level 263 path .snapshots/1124/snapshot
ID 1395 gen 184276 top level 263 path .snapshots/1125/snapshot
ID 1396 gen 184280 top level 263 path .snapshots/1126/snapshot
ID 1397 gen 184281 top level 263 path .snapshots/1127/snapshot
ID 1398 gen 184284 top level 263 path .snapshots/1128/snapshot
ID 1399 gen 184285 top level 263 path .snapshots/1129/snapshot
ID 1400 gen 184335 top level 263 path .snapshots/1130/snapshot
ID 1401 gen 184337 top level 263 path .snapshots/1131/snapshot
ID 1402 gen 186271 top level 263 path .snapshots/1132/snapshot
ID 1403 gen 186274 top level 263 path .snapshots/1133/snapshot
ID 1404 gen 186569 top level 263 path .snapshots/1134/snapshot
ID 1405 gen 186570 top level 263 path .snapshots/1135/snapshot
ID 1406 gen 186607 top level 263 path .snapshots/1136/snapshot
ID 1407 gen 186608 top level 263 path .snapshots/1137/snapshot
  1. The suggested subvolumes is kinda different from what I saw on the Arch wiki and my own subvolumes. Plus, my Garuda one seems to account for docker as well?
  2. Do I have to do all these at install? At which point is it alright to install? After the first partition and subvolume creation?
  3. Is there a video or visual guide that does it that aren’t for manjaro-architect?
Sorry for the questions, but I am a total noob at btrfs. and not sure what a lot of it means because there’s a lot of jargon I’m still not familiar with (and probably won’t be until I’ve done the process because that’s how I learn best).
  1. @Ugin is just name which he typed himself what he wants. You do not need to know it.
  2. Yes, the subvolume @home is mounted to /home by default after installation .
    You can check the fstab file /etc/fstab
  3. You are using the default layout of Snapper, that is fine. You can use btrfs-assistant GUI that supports it well.
  4. These subvolumes are default by Garuda installation, they are ok, but not nice for me (IMO)
  5. I think there is no video.
Docker automatically created its own subvolumes, if it detected BTRFS. That is Docker’s job.
If you turn off Docker service manually, then Docker’s subvolumes are gone.
A post was merged into an existing topic: Help to choose partition root
