[How to] Setting up QEMU/KVM with virt-manager
Note: QEMU/KVM is more complicated to run and maintain than Virtualbox and VMware. This tutorial is for experienced users, and I do not take any responsibility for damage caused by this post.
1. Install KVM packages:
sudo pacman -Syu qemu virt-manager virt-viewer dnsmasq vde2 bridge-utils openbsd-netcat ebtables iptables
2. Start KVM libvirt service
sudo systemctl enable libvirtd.service
sudo systemctl start libvirtd.service
# Check that the service is running (press 'q' to quit):
systemctl status libvirtd.service
3. Allow low-level users to use KVM
Edit the /etc/libvirt/libvirtd.conf file with your preferred editor (nano is used in this example):
sudo nano /etc/libvirt/libvirtd.conf
  1. Navigate to around line 85 and uncomment the following lines:
unix_sock_group = "libvirt"
  1. And then navigate to around line 108 and uncomment:
unix_sock_rw_perms = "0770"
  1. Add your user to the libvirt group
sudo usermod -G libvirt -a `whoami`
# If you get the "usermod: group 'libvirt' does not exist" error, create the group by
# running the following command, and then try adding your user again.
newgrp libvirt
  1. Restart libvirt deamon:
sudo systemctl restart libvirtd.service
4. Enable Nested Virtualization (Optional)
Nested Virtualization is the ability to run virtual machines inside virtual machines.
- Intel:
echo "options kvm-intel nested=1" | sudo tee /etc/modprobe.d/kvm-intel.conf
- AMD:
echo "options kvm-amd nested=1" | sudo tee /etc/modprobe.d/kvm-amd.conf
5. All Done!
Now you can run the virt-manager command to open the GUI virtual machine manger, or you can open it through your DE application menu.
To create a virtual machine, check this post out.
To open the .qcow2 file in your host, check out libguestfs.
To convert .vdi files to .qcow2:
qemu-img convert -f vdi -O qcow2 input.vdi output.qcow2
To convert .vmdk files to .qcow2:
qemu-img convert -f vmdk -O qcow2 input.vmdk output.qcow2
Sources:
good stuff, i would also like suggest setting ACL on VM image directories. absolute PIA when you run into it.
refer; https://sysguides.com/install-kvm-on-linux#9-10-set-acl-on-the-images-directory
6 posts were split to a new topic: Comments about Setting up QEMU/KVM with Virt-manager
