PC always "hangs" for 4 minutes after rebooting & entering the password, happens after installing Virt-Manager
This happens every time after I install:
[How to] Setting up QEMU/KVM with virt-manager
whether I install using:
sudo pacman -Syy ...
sudo pacman -Syu ...
or
su
then
I always end up waiting for ca. 4 minutes after rebooting and typing the password :frowning:
NB!
I have to wait that much after every reboot!
I restarted to get a “clean” journalctl report. Here I have rebooted my PC around 23:49:00, the system boots up nicly, until it is time to enter the password, which I did around:
mai 08 23:50:25
then, and after staring at the desktop background, my PC “comes to life” at around:
mai 08 23:54:40
I do not know what to look for to try and fix this problem :confused:
Any and all tips are much appreciated :slight_smile:
$ journalctl --since="2024-05-08 23:50:10"
Summary - 521 Lines
mai 08 23:50:10 YZ systemd[1]: Received SIGRTMIN+21 from PID 668 (plymouthd).
mai 08 23:50:10 YZ systemd[1]: Finished Hold until boot process finishes up.
mai 08 23:50:10 YZ kernel: igb 0000:44:00.0 enp68s0: igb: enp68s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
mai 08 23:50:10 YZ systemd[1]: Finished Terminate Plymouth Boot Screen.
mai 08 23:50:10 YZ systemd[1]: Reached target Multi-User System.
mai 08 23:50:10 YZ systemd[1]: Starting Light Display Manager...
mai 08 23:50:10 YZ systemd[1]: Started Light Display Manager.
mai 08 23:50:10 YZ systemd[1]: Reached target Graphical Interface.
mai 08 23:50:10 YZ systemd[1]: Startup finished in 15.820s (firmware) + 5.976s (loader) + 1.775s (kernel) + 5.853s (userspace) = 29.426s.
mai 08 23:50:10 YZ systemd[1]: Reached target User and Group Name Lookups.
mai 08 23:50:10 YZ systemd[1]: Starting Accounts Service...
mai 08 23:50:10 YZ accounts-daemon[1469]: started daemon version 23.13.0
mai 08 23:50:10 YZ systemd[1]: Started Accounts Service.
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8479] device (enp68s0): carrier: link connected
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8482] device (enp68s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8494] policy: auto-activating connection 'Wired connection 1' (5ce1c62e-8fed-3a34-b3a9-988841c49cce)
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8497] device (enp68s0): Activation: starting connection 'Wired connection 1' (5ce1c62e-8fed-3a34-b3a9-988841c49cce)
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8498] device (enp68s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8500] manager: NetworkManager state is now CONNECTING
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8501] device (enp68s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8512] device (enp68s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
mai 08 23:50:10 YZ NetworkManager[1183]: <info>  [1715205010.8524] dhcp4 (enp68s0): activation: beginning transaction (timeout in 45 seconds)
mai 08 23:50:10 YZ avahi-daemon[1185]: Joining mDNS multicast group on interface enp68s0.IPv6 with address fe80::a303:cbec:2002:7810.
mai 08 23:50:10 YZ avahi-daemon[1185]: New relevant interface enp68s0.IPv6 for mDNS.
mai 08 23:50:10 YZ avahi-daemon[1185]: Registering new address record for fe80::a303:cbec:2002:7810 on enp68s0.*.
mai 08 23:50:10 YZ kernel: resource: resource sanity check: requesting [mem 0x00000000000c0000-0x00000000000fffff], which spans more than PCI Bus 0000:00 [mem 0x000a0000-0x000dffff window]
mai 08 23:50:10 YZ kernel: caller _nv000720rm+0x1ad/0x200 [nvidia] mapping multiple BARs
mai 08 23:50:11 YZ kernel: NVRM: GPU at PCI:0000:01:00: GPU-49d87ce3-c971-5f9e-e261-dc97148f3691
mai 08 23:50:11 YZ kernel: NVRM: Xid (PCI:0000:01:00): 125, pid=1468, InfoROM FS corrupt on initial load. Recovery steps required.
mai 08 23:50:11 YZ kernel: Xorg[1468]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
mai 08 23:50:11 YZ portmaster-start[1187]: 240508 23:50:11.743 dbus_linux:065 ▶ WARN 019 failed to get nameserver: failed to access /:org.freedesktop.NetworkManager.Connection.Active.Ip4Config: Object does not exist at path “/”
mai 08 23:50:11 YZ portmaster-start[1187]: 240508 23:50:11.744 dbus_linux:072 ▶ WARN 021 failed to get nameserver: failed to access /:org.freedesktop.NetworkManager.Connection.Active.Ip6Config: Object does not exist at path “/”
mai 08 23:50:11 YZ portmaster-start[1187]: 240508 23:50:11.751 er/resolve:460 ▶ WARN 023 resolver: query to dot://dns.quad9.net:853#config failed: query failed: failed to connect to Quad9 (dot://dns.quad9.net:853#config): dial tcp :1289>
mai 08 23:50:11 YZ portmaster-start[1187]: 240508 23:50:11.751 er/resolve:460 ▶ WARN 025 resolver: query to dot://cloudflare-dns.com:853#config failed: query failed: failed to connect to Cloudflare (dot://cloudflare-dns.com:853#config):>
mai 08 23:50:11 YZ portmaster-start[1187]: 240508 23:50:11.751 er/resolve:460 ▶ WARN 027 resolver: query to dns://192.168.10.1:53#system failed: dial udp :14131->192.168.10.1:53: connect: network is unreachable
mai 08 23:50:11 YZ portmaster-start[1187]: 240508 23:50:11.751 ine-status:560 ▶ WARN 029 netenv: dns query check failed: all 3 query-compliant resolvers failed, last error: dial udp :14131->192.168.10.1:53: connect: network is unreachab>
mai 08 23:50:11 YZ ModemManager[1269]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:05.0/0000:44:00.0': not supported by any plugin
mai 08 23:50:11 YZ ModemManager[1269]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:40/0000:40:03.1/0000:49:00.0': not supported by any plugin
mai 08 23:50:12 YZ lightdm[1485]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=964) by (uid=0)
mai 08 23:50:12 YZ systemd-logind[1189]: New session c1 of user lightdm.
mai 08 23:50:12 YZ systemd[1]: Created slice User Slice of UID 964.
mai 08 23:50:12 YZ systemd[1]: Starting User Runtime Directory /run/user/964...
mai 08 23:50:12 YZ systemd[1]: Finished User Runtime Directory /run/user/964.
mai 08 23:50:12 YZ systemd[1]: Starting User Manager for UID 964...
mai 08 23:50:12 YZ kernel: usb 7-6: 19:0: cannot get min/max values for control 12 (id 19)
mai 08 23:50:12 YZ dbus-broker-launch[1181]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mai 08 23:50:12 YZ (systemd)[1492]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
mai 08 23:50:12 YZ (systemd)[1492]: pam_unix(systemd-user:session): session opened for user lightdm(uid=964) by lightdm(uid=0)
mai 08 23:50:12 YZ kernel: usbcore: registered new interface driver snd-usb-audio
mai 08 23:50:12 YZ systemd-logind[1189]: Watching system buttons on /dev/input/event14 (Generic USB Audio Consumer Control)
mai 08 23:50:12 YZ mtp-probe[1504]: checking bus 7, device 4: "/sys/devices/pci0000:40/0000:40:01.1/0000:41:00.0/0000:42:08.0/0000:45:00.1/usb7/7-6"
mai 08 23:50:12 YZ mtp-probe[1504]: bus: 7, device: 4 was not an MTP device
mai 08 23:50:12 YZ systemd[1]: libvirtd.service: Got notification message from PID 1448, but reception only permitted for main PID 1324
mai 08 23:50:12 YZ systemd[1492]: Queued start job for default target Main User Target.
mai 08 23:50:12 YZ systemd[1492]: Requested transaction contradicts existing jobs: Resource deadlock avoided
mai 08 23:50:12 YZ systemd[1]: libvirtd.service: Got notification message from PID 1508, but reception only permitted for main PID 1324
mai 08 23:50:12 YZ systemd[1492]: Created slice User Application Slice.
mai 08 23:50:12 YZ systemd[1492]: Reached target Paths.
mai 08 23:50:12 YZ systemd[1492]: Reached target Timers.
mai 08 23:50:12 YZ systemd[1492]: Starting D-Bus User Message Bus Socket...
mai 08 23:50:12 YZ systemd[1492]: Listening on GnuPG network certificate management daemon.
mai 08 23:50:12 YZ systemd[1492]: Starting GCR ssh-agent wrapper...
mai 08 23:50:12 YZ systemd[1492]: Listening on GNOME Keyring daemon.
mai 08 23:50:12 YZ systemd[1492]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
mai 08 23:50:12 YZ systemd[1492]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
mai 08 23:50:12 YZ systemd[1492]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
mai 08 23:50:12 YZ systemd[1492]: Listening on GnuPG cryptographic agent and passphrase cache.
mai 08 23:50:12 YZ systemd[1492]: Listening on GnuPG public key management service.
mai 08 23:50:12 YZ systemd[1492]: Listening on p11-kit server.
mai 08 23:50:12 YZ systemd[1492]: Listening on PipeWire PulseAudio.
mai 08 23:50:12 YZ systemd[1492]: Listening on PipeWire Multimedia System Sockets.
mai 08 23:50:12 YZ systemd[1]: libvirtd.service: Got notification message from PID 1511, but reception only permitted for main PID 1324
mai 08 23:50:12 YZ systemd[1492]: Listening on D-Bus User Message Bus Socket.
mai 08 23:50:12 YZ systemd[1492]: Listening on GCR ssh-agent wrapper.
mai 08 23:50:12 YZ systemd[1492]: Reached target Sockets.
mai 08 23:50:12 YZ systemd[1492]: Reached target Basic System.
mai 08 23:50:12 YZ systemd[1]: Started User Manager for UID 964.
mai 08 23:50:12 YZ systemd[1492]: Starting Update XDG user dir configuration...
mai 08 23:50:12 YZ systemd[1]: Started Session c1 of User lightdm.
mai 08 23:50:12 YZ systemd[1492]: Finished Update XDG user dir configuration.
mai 08 23:50:12 YZ systemd[1492]: Reached target Main User Target.
mai 08 23:50:12 YZ systemd[1492]: Startup finished in 199ms.
mai 08 23:50:12 YZ libvirtd[1324]: libvirt version: 10.1.0
mai 08 23:50:12 YZ libvirtd[1324]: hostname: ii
mai 08 23:50:12 YZ libvirtd[1324]: cannot open directory '/home/ii/Downloads/Share': No such file or directory
mai 08 23:50:12 YZ libvirtd[1324]: internal error: Failed to autostart storage pool 'pool__Downloads__Share': cannot open directory '/home/ii/Downloads/Share': No such file or directory
mai 08 23:50:12 YZ systemd[1492]: Created slice User Core Session Slice.
mai 08 23:50:12 YZ systemd[1492]: Starting D-Bus User Message Bus...
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
mai 08 23:50:12 YZ systemd[1492]: Started D-Bus User Message Bus.
mai 08 23:50:12 YZ dbus-broker-launch[1524]: Ready
mai 08 23:50:12 YZ systemd[1492]: Starting Accessibility services bus...
mai 08 23:50:12 YZ systemd[1492]: Started Accessibility services bus.
mai 08 23:50:12 YZ at-spi-bus-launcher[1532]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +15: Eavesdropping is deprecated and ignored
mai 08 23:50:12 YZ at-spi-bus-launcher[1532]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +17: Eavesdropping is deprecated and ignored
mai 08 23:50:12 YZ dbus-broker-launch[1532]: Ready
mai 08 23:50:12 YZ systemd[1492]: Starting Virtual filesystem service...
mai 08 23:50:12 YZ systemd[1492]: Started Virtual filesystem service.
mai 08 23:50:12 YZ dbus-broker-launch[1181]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mai 08 23:50:12 YZ NetworkManager[1183]: <info>  [1715205012.8655] dhcp4 (enp68s0): state changed new lease, address=192.168.10.150, acd pending
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0070] dhcp4 (enp68s0): state changed new lease, address=192.168.10.150
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0073] policy: set 'Wired connection 1' (enp68s0) as default for IPv4 routing and DNS
mai 08 23:50:13 YZ dnsmasq[1446]: reading /etc/resolv.conf
mai 08 23:50:13 YZ dnsmasq[1446]: using nameserver 192.168.10.1#53
mai 08 23:50:13 YZ avahi-daemon[1185]: Joining mDNS multicast group on interface enp68s0.IPv4 with address 192.168.10.150.
mai 08 23:50:13 YZ avahi-daemon[1185]: New relevant interface enp68s0.IPv4 for mDNS.
mai 08 23:50:13 YZ avahi-daemon[1185]: Registering new address record for 192.168.10.150 on enp68s0.IPv4.
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0339] device (enp68s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0350] device (enp68s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0352] device (enp68s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0355] manager: NetworkManager state is now CONNECTED_SITE
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.0357] device (enp68s0): Activation: successful, device activated.
mai 08 23:50:13 YZ systemd[1492]: Created slice Slice /app/dbus-:1.4-org.a11y.atspi.Registry.
mai 08 23:50:13 YZ systemd[1492]: Started dbus-:1.4-org.a11y.atspi.Registry@0.service.
mai 08 23:50:13 YZ at-spi2-registryd[1563]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.1307] manager: NetworkManager state is now CONNECTED_GLOBAL
mai 08 23:50:13 YZ systemd[1]: systemd-rfkill.service: Deactivated successfully.
mai 08 23:50:13 YZ portmaster-start[1187]: 240508 23:50:13.679 les/worker:109 ▶ ERRO 031 resolver: service-worker ip info delayed cache writer failed (1): could not start database cache (type bbolt): timeout - restarting in 2s
mai 08 23:50:13 YZ NetworkManager[1183]: <info>  [1715205013.6965] manager: startup complete
mai 08 23:50:13 YZ portmaster-start[1187]: 240508 23:50:13.991 les/worker:109 ▶ ERRO 033 interception: service-worker ebpf connection listener failed (1): ebpf: failed to remove ebpf memlock: failed to set memlock rlimit: operation not >
mai 08 23:50:14 YZ portmaster-start[1187]: 240508 23:50:13.991 les/worker:109 ▶ ERRO 035 interception: service-worker ebpf bandwidth stats monitor failed (1): ebpf: failed to remove memlock: failed to set memlock rlimit: operation not p>
mai 08 23:50:14 YZ lightdm[1562]: gkr-pam: unable to locate daemon control file
mai 08 23:50:14 YZ lightdm[1562]: gkr-pam: stashed password to try later in open session
mai 08 23:50:14 YZ systemd[1]: Stopping Session c1 of User lightdm...
mai 08 23:50:14 YZ lightdm[1485]: pam_unix(lightdm-greeter:session): session closed for user lightdm
mai 08 23:50:14 YZ systemd[1]: session-c1.scope: Deactivated successfully.
mai 08 23:50:14 YZ systemd[1]: Stopped Session c1 of User lightdm.
mai 08 23:50:14 YZ systemd-logind[1189]: Removed session c1.
mai 08 23:50:14 YZ lightdm[1562]: pam_unix(lightdm:session): session opened for user ii(uid=1000) by ii(uid=0)
mai 08 23:50:14 YZ systemd-logind[1189]: New session 2 of user ii.
mai 08 23:50:14 YZ systemd[1]: Created slice User Slice of UID 1000.
mai 08 23:50:14 YZ systemd[1]: Starting User Runtime Directory /run/user/1000...
mai 08 23:50:14 YZ systemd[1]: Finished User Runtime Directory /run/user/1000.
mai 08 23:50:14 YZ systemd[1]: Starting User Manager for UID 1000...
mai 08 23:50:14 YZ (systemd)[1659]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[ii] ruser=[<unknown>] rhost=[<unknown>]
mai 08 23:50:14 YZ (systemd)[1659]: pam_unix(systemd-user:session): session opened for user ii(uid=1000) by ii(uid=0)
mai 08 23:50:14 YZ systemd[1659]: Queued start job for default target Main User Target.
mai 08 23:50:14 YZ systemd-journald[744]: /var/log/journal/debc1dfdcfb8408aa68828f21bab483f/user-1000.journal: Journal file uses a different sequence number ID, rotating.
mai 08 23:50:14 YZ lightdm[1562]: gkr-pam: unlocked login keyring
mai 08 23:50:14 YZ systemd[1659]: Created slice User Application Slice.
mai 08 23:50:14 YZ systemd[1659]: Reached target Paths.
mai 08 23:50:14 YZ systemd[1659]: Reached target Timers.
mai 08 23:50:14 YZ systemd[1659]: Starting D-Bus User Message Bus Socket...
mai 08 23:50:14 YZ systemd[1659]: Listening on GnuPG network certificate management daemon.
mai 08 23:50:14 YZ gnome-keyring-daemon[1672]: GNOME_KEYRING_CONTROL=/run/user/1000/keyring
mai 08 23:50:14 YZ systemd[1659]: Starting GCR ssh-agent wrapper...
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
mai 08 23:50:14 YZ systemd[1659]: Listening on GNOME Keyring daemon.
mai 08 23:50:14 YZ systemd[1659]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
mai 08 23:50:14 YZ systemd[1659]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
mai 08 23:50:14 YZ systemd[1659]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
mai 08 23:50:14 YZ systemd[1659]: Listening on GnuPG cryptographic agent and passphrase cache.
mai 08 23:50:14 YZ systemd[1659]: Listening on GnuPG public key management service.
mai 08 23:50:14 YZ systemd[1659]: Listening on p11-kit server.
mai 08 23:50:14 YZ systemd[1659]: Listening on PipeWire PulseAudio.
mai 08 23:50:14 YZ systemd[1659]: Listening on PipeWire Multimedia System Sockets.
mai 08 23:50:14 YZ systemd[1659]: Listening on D-Bus User Message Bus Socket.
mai 08 23:50:14 YZ systemd[1659]: Listening on GCR ssh-agent wrapper.
mai 08 23:50:14 YZ systemd[1659]: Reached target Sockets.
mai 08 23:50:14 YZ systemd[1659]: Reached target Basic System.
mai 08 23:50:14 YZ systemd[1]: Started User Manager for UID 1000.
mai 08 23:50:14 YZ systemd[1659]: Starting Update XDG user dir configuration...
mai 08 23:50:14 YZ systemd[1]: Started Session 2 of User ii.
mai 08 23:50:14 YZ systemd[1659]: Started GNOME Keyring daemon.
mai 08 23:50:14 YZ systemd[1659]: Finished Update XDG user dir configuration.
mai 08 23:50:14 YZ systemd[1659]: Reached target Main User Target.
mai 08 23:50:14 YZ systemd[1659]: Startup finished in 173ms.
mai 08 23:50:14 YZ systemd[1659]: Created slice User Core Session Slice.
mai 08 23:50:14 YZ systemd[1659]: Starting D-Bus User Message Bus...
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Service file '/usr/share//dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
mai 08 23:50:14 YZ systemd[1659]: Started D-Bus User Message Bus.
mai 08 23:50:14 YZ dbus-broker-launch[1677]: Ready
mai 08 23:50:14 YZ portmaster-start[1187]: 240508 23:50:14.987 v/location:303 ▶ WARN 037 netenv: failed to get IPv4 device location from traceroute: did not receive any actionable ICMP reply
mai 08 23:50:15 YZ NetworkManager[1183]: <info>  [1715205015.6794] policy: set 'Wired connection 1' (enp68s0) as default for IPv6 routing and DNS
mai 08 23:50:15 YZ dnsmasq[1446]: reading /etc/resolv.conf
mai 08 23:50:15 YZ dnsmasq[1446]: using nameserver 192.168.10.1#53
mai 08 23:50:15 YZ dnsmasq[1446]: using nameserver fe80::5ee2:8cff:fe57:3263%enp68s0#53
mai 08 23:50:15 YZ avahi-daemon[1185]: Leaving mDNS multicast group on interface enp68s0.IPv6 with address fe80::a303:cbec:2002:7810.
mai 08 23:50:15 YZ avahi-daemon[1185]: Joining mDNS multicast group on interface enp68s0.IPv6 with address 2a01:799:324:3b00:b224:5c43:5925:c6a6.
mai 08 23:50:15 YZ avahi-daemon[1185]: Registering new address record for 2a01:799:324:3b00:b224:5c43:5925:c6a6 on enp68s0.*.
mai 08 23:50:15 YZ avahi-daemon[1185]: Withdrawing address record for fe80::a303:cbec:2002:7810 on enp68s0.
mai 08 23:50:15 YZ portmaster-start[1187]: 240508 23:50:15.991 les/worker:109 ▶ ERRO 039 interception: service-worker ebpf bandwidth stats monitor failed (2): ebpf: failed to remove memlock: failed to set memlock rlimit: operation not p>
mai 08 23:50:16 YZ portmaster-start[1187]: 240508 23:50:15.991 les/worker:109 ▶ ERRO 041 interception: service-worker ebpf connection listener failed (2): ebpf: failed to remove ebpf memlock: failed to set memlock rlimit: operation not >
mai 08 23:50:17 YZ systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mai 08 23:50:19 YZ portmaster-start[1187]: 240508 23:50:19.991 les/worker:109 ▶ ERRO 043 interception: service-worker ebpf bandwidth stats monitor failed (3): ebpf: failed to remove memlock: failed to set memlock rlimit: operation not p>
mai 08 23:50:20 YZ portmaster-start[1187]: 240508 23:50:19.991 les/worker:109 ▶ ERRO 045 interception: service-worker ebpf connection listener failed (3): ebpf: failed to remove ebpf memlock: failed to set memlock rlimit: operation not >
mai 08 23:50:24 YZ systemd[1]: Stopping User Manager for UID 964...
mai 08 23:50:24 YZ systemd[1492]: Activating special unit Exit the Session...
mai 08 23:50:24 YZ systemd[1492]: Stopped target Main User Target.
mai 08 23:50:24 YZ systemd[1492]: Stopping Accessibility services bus...
mai 08 23:50:24 YZ systemd[1492]: Stopping dbus-:1.4-org.a11y.atspi.Registry@0.service...
mai 08 23:50:24 YZ dbus-broker[1533]: Dispatched 20 messages @ 5(±7)μs / message.
mai 08 23:50:24 YZ systemd[1492]: Stopping Virtual filesystem service...
mai 08 23:50:24 YZ systemd[1492]: Stopped dbus-:1.4-org.a11y.atspi.Registry@0.service.
mai 08 23:50:24 YZ systemd[1]: run-user-964-gvfs.mount: Deactivated successfully.
mai 08 23:50:24 YZ systemd[1492]: Stopped Virtual filesystem service.
mai 08 23:50:24 YZ systemd[1492]: Stopped Accessibility services bus.
mai 08 23:50:24 YZ systemd[1492]: Removed slice Slice /app/dbus-:1.4-org.a11y.atspi.Registry.
mai 08 23:50:24 YZ systemd[1492]: Stopped target Basic System.
mai 08 23:50:24 YZ systemd[1492]: Stopped target Paths.
mai 08 23:50:24 YZ systemd[1492]: Stopped target Sockets.
mai 08 23:50:24 YZ systemd[1492]: Stopped target Timers.
mai 08 23:50:24 YZ systemd[1492]: Closed GnuPG network certificate management daemon.
mai 08 23:50:24 YZ systemd[1492]: Closed GCR ssh-agent wrapper.
mai 08 23:50:24 YZ systemd[1492]: Closed GNOME Keyring daemon.
mai 08 23:50:24 YZ systemd[1492]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
mai 08 23:50:24 YZ systemd[1492]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
mai 08 23:50:24 YZ systemd[1492]: Closed GnuPG cryptographic agent (ssh-agent emulation).
mai 08 23:50:24 YZ systemd[1492]: Closed GnuPG cryptographic agent and passphrase cache.
mai 08 23:50:24 YZ systemd[1492]: Closed GnuPG public key management service.
mai 08 23:50:24 YZ systemd[1492]: Closed p11-kit server.
mai 08 23:50:24 YZ systemd[1492]: Closed PipeWire PulseAudio.
mai 08 23:50:24 YZ systemd[1492]: Closed PipeWire Multimedia System Sockets.
mai 08 23:50:24 YZ dbus-broker[1525]: Dispatched 392 messages @ 1(±3)μs / message.
mai 08 23:50:24 YZ systemd[1492]: Stopping D-Bus User Message Bus...
mai 08 23:50:24 YZ systemd[1492]: Stopped D-Bus User Message Bus.
mai 08 23:50:24 YZ systemd[1492]: Removed slice User Core Session Slice.
mai 08 23:50:24 YZ systemd[1492]: Closed D-Bus User Message Bus Socket.
mai 08 23:50:24 YZ systemd[1492]: Removed slice User Application Slice.
mai 08 23:50:24 YZ systemd[1492]: Reached target Shutdown.
mai 08 23:50:24 YZ systemd[1492]: Finished Exit the Session.
mai 08 23:50:24 YZ systemd[1492]: Reached target Exit the Session.
mai 08 23:50:24 YZ (sd-pam)[1494]: pam_unix(systemd-user:session): session closed for user lightdm
mai 08 23:50:24 YZ systemd[1]: user@964.service: Deactivated successfully.
mai 08 23:50:24 YZ systemd[1]: Stopped User Manager for UID 964.
mai 08 23:50:24 YZ systemd[1]: Stopping User Runtime Directory /run/user/964...
mai 08 23:50:24 YZ systemd[1]: run-user-964.mount: Deactivated successfully.
mai 08 23:50:24 YZ systemd[1]: user-runtime-dir@964.service: Deactivated successfully.
mai 08 23:50:24 YZ systemd[1]: Stopped User Runtime Directory /run/user/964.
mai 08 23:50:24 YZ systemd[1]: Removed slice User Slice of UID 964.
mai 08 23:50:25 YZ portmaster-start[1187]: 240508 23:50:25.992 les/worker:109 ▶ ERRO 047 interception: service-worker ebpf connection listener failed (4): ebpf: failed to remove ebpf memlock: failed to set memlock rlimit: operation not >
mai 08 23:50:26 YZ portmaster-start[1187]: 240508 23:50:25.992 les/worker:109 ▶ ERRO 049 interception: service-worker ebpf bandwidth stats monitor failed (4): ebpf: failed to remove memlock: failed to set memlock rlimit: operation not p>
mai 08 23:50:33 YZ portmaster-start[1187]: 240508 23:50:33.992 /interface:032 ▶ WARN 051 ebpf: failed to remove memlock 5 times, giving up with error failed to set memlock rlimit: operation not permitted
mai 08 23:50:34 YZ portmaster-start[1187]: 240508 23:50:33.992 ner/worker:030 ▶ WARN 053 ebpf: failed to remove memlock 5 times, giving up with error failed to set memlock rlimit: operation not permitted
mai 08 23:50:37 YZ systemd[1]: systemd-timedated.service: Deactivated successfully.
mai 08 23:50:38 YZ systemd[1]: systemd-hostnamed.service: Deactivated successfully.
mai 08 23:50:40 YZ snapd[1188]: stateengine.go:149: state ensure error: Get "https://api.snapcraft.io/api/v1/snaps/sections": dial tcp 0.0.0.17:443: connect: no route to host
mai 08 23:50:42 YZ snapd[1188]: daemon.go:519: gracefully waiting for running hooks
mai 08 23:50:42 YZ snapd[1188]: daemon.go:521: done waiting for running hooks
mai 08 23:50:45 YZ snapd[1188]: overlord.go:515: Released state lock file
mai 08 23:50:45 YZ snapd[1188]: daemon stop requested to wait for socket activation
mai 08 23:50:45 YZ systemd[1]: snapd.service: Deactivated successfully.
mai 08 23:52:08 YZ systemd[1]: libvirtd.service: Deactivated successfully.
mai 08 23:52:08 YZ systemd[1]: libvirtd.service: Unit process 1446 (dnsmasq) remains running after unit stopped.
mai 08 23:52:08 YZ systemd[1]: libvirtd.service: Unit process 1447 (dnsmasq) remains running after unit stopped.
mai 08 23:53:02 YZ dnsmasq[1446]: reading /etc/resolv.conf
mai 08 23:53:02 YZ dnsmasq[1446]: using nameserver 192.168.10.1#53
mai 08 23:53:02 YZ avahi-daemon[1185]: Registering new address record for fe80::a303:cbec:2002:7810 on enp68s0.*.
mai 08 23:53:03 YZ NetworkManager[1183]: <info>  [1715205183.8893] policy: set 'Wired connection 1' (enp68s0) as default for IPv6 routing and DNS
mai 08 23:53:03 YZ dnsmasq[1446]: reading /etc/resolv.conf
mai 08 23:53:03 YZ dnsmasq[1446]: using nameserver 192.168.10.1#53
mai 08 23:53:03 YZ dnsmasq[1446]: using nameserver fe80::5ee2:8cff:fe57:3263%enp68s0#53
mai 08 23:53:03 YZ avahi-daemon[1185]: Withdrawing address record for fe80::a303:cbec:2002:7810 on enp68s0.
mai 08 23:54:40 YZ systemd[1659]: Starting Virtual filesystem service...
mai 08 23:54:40 YZ systemd[1659]: Started Virtual filesystem service.
mai 08 23:54:40 YZ systemd[1659]: Starting Accessibility services bus...
mai 08 23:54:40 YZ systemd[1659]: Started Accessibility services bus.
mai 08 23:54:40 YZ at-spi-bus-launcher[1785]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +15: Eavesdropping is deprecated and ignored
mai 08 23:54:40 YZ at-spi-bus-launcher[1785]: Policy to allow eavesdropping in /usr/share/defaults/at-spi2/accessibility.conf +17: Eavesdropping is deprecated and ignored
mai 08 23:54:40 YZ dbus-broker-launch[1785]: Ready
mai 08 23:54:40 YZ systemd[1659]: Created slice Slice /app/dbus-:1.2-org.xfce.Xfconf.
mai 08 23:54:40 YZ systemd[1659]: Started dbus-:1.2-org.xfce.Xfconf@0.service.
mai 08 23:54:40 YZ systemd[1659]: Created slice Slice /app/dbus-:1.11-org.a11y.atspi.Registry.
mai 08 23:54:40 YZ systemd[1659]: Started dbus-:1.11-org.a11y.atspi.Registry@0.service.
mai 08 23:54:40 YZ at-spi2-registryd[1793]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
mai 08 23:54:40 YZ systemd[1659]: Started GnuPG cryptographic agent and passphrase cache.
mai 08 23:54:40 YZ gpg-agent[1805]: gpg-agent (GnuPG) 2.4.4 starting in supervised mode.
mai 08 23:54:40 YZ gpg-agent[1805]: using fd 3 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
mai 08 23:54:40 YZ gpg-agent[1805]: using fd 4 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
mai 08 23:54:40 YZ gpg-agent[1805]: using fd 5 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
mai 08 23:54:40 YZ gpg-agent[1805]: using fd 6 for std socket (/run/user/1000/gnupg/S.gpg-agent)
mai 08 23:54:40 YZ gpg-agent[1805]: listening on: std=6 extra=4 browser=5 ssh=3
mai 08 23:54:40 YZ gpg-agent[1809]: gpg-agent (GnuPG) 2.4.4 starting in supervised mode.
mai 08 23:54:40 YZ gpg-agent[1809]: using fd 3 for ssh socket (/run/user/1000/gnupg/S.gpg-agent.ssh)
mai 08 23:54:40 YZ gpg-agent[1809]: using fd 4 for extra socket (/run/user/1000/gnupg/S.gpg-agent.extra)
mai 08 23:54:40 YZ gpg-agent[1809]: using fd 5 for browser socket (/run/user/1000/gnupg/S.gpg-agent.browser)
mai 08 23:54:40 YZ gpg-agent[1809]: using fd 6 for std socket (/run/user/1000/gnupg/S.gpg-agent)
mai 08 23:54:40 YZ gpg-agent[1809]: listening on: std=6 extra=4 browser=5 ssh=3
mai 08 23:54:41 YZ systemd[1659]: Started PipeWire Multimedia Service.
mai 08 23:54:41 YZ systemd[1659]: Started Multimedia Service Session Manager.
mai 08 23:54:41 YZ systemd[1659]: Started PipeWire PulseAudio.
mai 08 23:54:41 YZ systemd[1]: Starting RealtimeKit Scheduling Policy Service...
mai 08 23:54:41 YZ systemd[1]: Started RealtimeKit Scheduling Policy Service.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully called chroot.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully dropped privileges.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully limited resources.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Canary thread running.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Running.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Watchdog thread running.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 0 threads of 0 processes of 0 users.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully made thread 1818 of process 1818 owned by '1000' high priority at nice level -11.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 1 threads of 1 processes of 1 users.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully made thread 1830 of process 1818 owned by '1000' RT at priority 20.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 2 threads of 1 processes of 1 users.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully made thread 1823 of process 1823 owned by '1000' high priority at nice level -11.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 3 threads of 2 processes of 1 users.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully made thread 1831 of process 1823 owned by '1000' RT at priority 20.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 4 threads of 2 processes of 1 users.
mai 08 23:54:41 YZ wireplumber[1822]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
mai 08 23:54:41 YZ wireplumber[1822]: [0:04:38.302873406] [1822] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
mai 08 23:54:41 YZ wireplumber[1822]: [0:04:38.302887101] [1822] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
mai 08 23:54:41 YZ wireplumber[1822]: [0:04:38.302918350] [1822]  INFO Camera camera_manager.cpp:284 libcamera v0.2.0
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully made thread 1822 of process 1822 owned by '1000' high priority at nice level -11.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 5 threads of 3 processes of 1 users.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Successfully made thread 1828 of process 1822 owned by '1000' RT at priority 20.
mai 08 23:54:41 YZ rtkit-daemon[1825]: Supervising 6 threads of 3 processes of 1 users.
mai 08 23:54:41 YZ systemd[1659]: Starting XFCE notifications service...
mai 08 23:54:41 YZ systemd[1659]: Started XFCE notifications service.
mai 08 23:54:41 YZ spice-vdagent[1897]: vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0 does not exist, exiting
mai 08 23:54:41 YZ systemd[1659]: Starting Thumbnailing service...
mai 08 23:54:41 YZ systemd[1]: Starting Manage, Install and Generate Color Profiles...
mai 08 23:54:41 YZ systemd[1659]: Starting Portal service...
mai 08 23:54:41 YZ wireplumber[1822]: Unable to load mixer: Broken pipe
mai 08 23:54:41 YZ wireplumber[1822]: Unable to determine open mixer device '_ucm0003.hw:ALC1220VBDT' for jack Front Headphone
mai 08 23:54:41 YZ kernel: usb 7-6: 19:0: cannot get min/max values for control 12 (id 19)
mai 08 23:54:41 YZ wireplumber[1822]: Unable to determine open mixer device '_ucm0003.hw:ALC1220VBDT' for jack Speaker
mai 08 23:54:41 YZ wireplumber[1822]: Unable to determine open mixer device '_ucm0003.hw:ALC1220VBDT' for jack Front Mic
mai 08 23:54:41 YZ wireplumber[1822]: Unable to determine open mixer device '_ucm0003.hw:ALC1220VBDT' for jack Mic
mai 08 23:54:41 YZ wireplumber[1822]: Unable to determine open mixer device '_ucm0003.hw:ALC1220VBDT' for jack Line
mai 08 23:54:41 YZ systemd[1659]: Starting flatpak document portal service...
mai 08 23:54:41 YZ tumblerd[1892]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
mai 08 23:54:41 YZ colord[1973]: failed to get edid data: EDID length is too small
mai 08 23:54:41 YZ systemd[1]: Started Manage, Install and Generate Color Profiles.
mai 08 23:54:41 YZ systemd[1659]: Starting sandboxed app permission store...
mai 08 23:54:41 YZ systemd[1659]: Started sandboxed app permission store.
mai 08 23:54:41 YZ systemd[1659]: Started flatpak document portal service.
mai 08 23:54:41 YZ systemd[1]: Starting Daemon for power management...
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
mai 08 23:54:41 YZ systemd[1659]: Starting Portal service (GTK/GNOME implementation)...
mai 08 23:54:41 YZ polkitd[1186]: Registered Authentication Agent for unix-session:2 (system bus name :1.45 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_GB>
mai 08 23:54:41 YZ systemd[1659]: Starting Virtual filesystem service - disk device monitor...
mai 08 23:54:41 YZ systemd[1659]: Started Portal service (GTK/GNOME implementation).
mai 08 23:54:41 YZ systemd[1]: Starting Disk Manager...
mai 08 23:54:41 YZ udisksd[2047]: udisks daemon version 2.10.1 starting
mai 08 23:54:41 YZ xdg-desktop-por[1979]: No skeleton to export
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.FileChooser as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.AppChooser as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Print as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Notification as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Inhibit as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Access as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Account as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.Email as a last-resort fallback
mai 08 23:54:41 YZ xdg-desktop-por[1979]: Choosing gtk.portal for org.freedesktop.impl.portal.DynamicLauncher as a last-resort fallback
mai 08 23:54:41 YZ systemd[1659]: Started Portal service.
mai 08 23:54:41 YZ NetworkManager[1183]: <info>  [1715205281.7198] agent-manager: agent[bc9f55cf2c2f86d8,:1.46/org.freedesktop.nm-applet/1000]: agent registered
mai 08 23:54:41 YZ kernel: block nvme0n1: No UUID available providing old NGUID
mai 08 23:54:41 YZ systemd[1]: Started Daemon for power management.
mai 08 23:54:41 YZ systemd[1]: Started Disk Manager.
mai 08 23:54:41 YZ udisksd[2047]: Acquired the name org.freedesktop.UDisks2 on the system message bus
mai 08 23:54:41 YZ systemd[1659]: Started Virtual filesystem service - disk device monitor.
mai 08 23:54:41 YZ systemd[1659]: Starting Virtual filesystem service - digital camera monitor...
mai 08 23:54:41 YZ systemd[1]: Starting Bluetooth management mechanism...
mai 08 23:54:41 YZ systemd[1659]: Started Virtual filesystem service - digital camera monitor.
mai 08 23:54:41 YZ systemd[1659]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
mai 08 23:54:41 YZ systemd[1659]: Started Virtual filesystem service - Media Transfer Protocol monitor.
mai 08 23:54:41 YZ systemd[1659]: Starting Virtual filesystem service - Apple File Conduit monitor...
mai 08 23:54:41 YZ systemd[1659]: Started Virtual filesystem service - Apple File Conduit monitor.
mai 08 23:54:41 YZ systemd[1659]: Started Thumbnailing service.
mai 08 23:54:41 YZ systemd[1]: Started Bluetooth management mechanism.
mai 08 23:54:41 YZ gvfsd-trash[2248]: GFileInfo created without standard::name
mai 08 23:54:41 YZ gvfsd-trash[2248]: file ../glib/gio/gfileinfo.c: line 1699 (g_file_info_get_name): should not be reached
mai 08 23:54:41 YZ systemd[1659]: Starting Virtual filesystem metadata service...
mai 08 23:54:41 YZ systemd[1659]: Started Virtual filesystem metadata service.
mai 08 23:54:42 YZ wireplumber[1822]: Unable to load mixer: Broken pipe
mai 08 23:54:42 YZ wireplumber[1822]: Failed to find a working mixer device (_ucm0003.hw:ALC1220VBDT).
mai 08 23:54:42 YZ kernel: usb 7-6: 19:0: cannot get min/max values for control 12 (id 19)
mai 08 23:54:42 YZ kernel: Bluetooth: RFCOMM TTY layer initialized
mai 08 23:54:42 YZ kernel: Bluetooth: RFCOMM socket layer initialized
mai 08 23:54:42 YZ kernel: Bluetooth: RFCOMM ver 1.11
mai 08 23:54:42 YZ wireplumber[1822]: <WpSiAudioAdapter:0x556dd0d6d030> Object activation aborted: proxy destroyed
mai 08 23:54:42 YZ wireplumber[1822]: <WpSiAudioAdapter:0x556dd0d6d030> failed to activate item: Object activation aborted: proxy destroyed
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/ldac
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/aptx_hd
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_hd
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/aac
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aac
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/sbc
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/sbc
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/sbc_xq
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/sbc_xq
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_1
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_0
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/faststream
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/faststream_duplex
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/opus_05
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/opus_05
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/opus_05_duplex
mai 08 23:54:42 YZ bluetoothd[1427]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/opus_05_duplex
mai 08 23:54:46 YZ kernel: logitech-hidpp-device 0003:046D:4085.0008: HID++ 4.2 device connected.
mai 08 23:55:05 YZ gnome-keyring-daemon[1672]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
mai 08 23:55:05 YZ gnome-keyring-d[1672]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
mai 08 23:55:12 YZ systemd[1]: blueman-mechanism.service: Deactivated successfully.
mai 08 23:55:13 YZ NetworkManager[1183]: <info>  [1715205313.0455] manager: NetworkManager state is now CONNECTED_SITE
mai 08 23:55:13 YZ systemd[1]: Starting Network Manager Script Dispatcher Service...
mai 08 23:55:13 YZ systemd[1]: Started Network Manager Script Dispatcher Service.
mai 08 23:55:23 YZ systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mai 08 23:56:52 YZ NetworkManager[1183]: <warn>  [1715205412.8681] platform-linux: do-change-link[2]: failure 23 (Too many open files in system) (assume success changing address)
mai 08 23:56:52 YZ NetworkManager[1183]: <info>  [1715205412.8682] device (wlp73s0): set-hw-addr: set MAC address to 7A:00:55:1A:F6:8C (scanning)
mai 08 23:56:52 YZ NetworkManager[1183]: <info>  [1715205412.9364] device (wlp73s0): supplicant interface state: disconnected -> inactive
$ inxi -v8azy
Summary - 363 Lines
  Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=a2f7bc98-00e5-4ee9-bbc3-aec33bb9f2da rw rd.driver.pre=vfio-pci
    amd_iommu=on quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: PC v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: PRIME TRX40-PRO v: Rev 1.xx
    serial: <superuser required> part-nu: 12345 uuid: <superuser required>
    UEFI: American Megatrends v: 2102 date: 02/16/2024
  Device-1: hidpp_battery_0 model: Logitech G604 Wireless Gaming Mouse
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 128 GiB available: 125.64 GiB used: 5.25 GiB (4.2%)
  Array-1: capacity: 512 GiB slots: 8 modules: 8 EC: None
    max-module-size: 64 GiB note: est.
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KHX3200C18D4/16G serial: <filter>
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Device-5: Channel-C DIMM 0 type: DDR4 detail: synchronous unbuffered
  Device-6: Channel-C DIMM 1 type: DDR4 detail: synchronous unbuffered
  Device-7: Channel-D DIMM 0 type: DDR4 detail: synchronous unbuffered
  Device-8: Channel-D DIMM 1 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen Threadripper 3970X bits: 64 type: MT MCP arch: Zen 2
    gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x31 (49) stepping: 0 microcode: 0x830107B
  Topology: cpus: 1x cores: 32 tpc: 2 threads: 64 smt: enabled cache:
    L1: 2 MiB desc: d-32x32 KiB; i-32x32 KiB L2: 16 MiB desc: 32x512 KiB
    L3: 128 MiB desc: 8x16 MiB
  Speed (MHz): avg: 2199 high: 2200 min/max: 2200/4549 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
    12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200
    20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200
    28: 2200 29: 2196 30: 2200 31: 2200 32: 2200 33: 2200 34: 2200 35: 2200
    36: 2200 37: 2200 38: 2200 39: 2200 40: 2200 41: 2200 42: 2200 43: 2200
    44: 2200 45: 2200 46: 2200 47: 2200 48: 2200 49: 2200 50: 2200 51: 2200
    52: 2200 53: 2200 54: 2200 55: 2200 56: 2200 57: 2200 58: 2156 59: 2200
    60: 2200 61: 2200 62: 2200 63: 2200 64: 2200 bogomips: 472954
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GK110 [GeForce GTX 780] vendor: eVga.com. driver: nvidia
    v: 470.239.06 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1004
    class-ID: 0300
  Device-2: NVIDIA TU104GL [Quadro RTX 4000] driver: vfio-pci v: N/A
    alternate: nouveau,nvidia_drm,nvidia non-free: 550.xx+ status: current (as
    of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 21:00.0
    chip-ID: 10de:1eb1 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.12 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: nvidia gpu: nvidia,vfio-pci display-ID: :0.0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.239.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 780/PCIe/SSE2
    memory: 2.93 GiB
  Device-1: NVIDIA GK110 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:0e1a class-ID: 0403
  Device-2: NVIDIA TU104 HD Audio driver: vfio-pci alternate: snd_hda_intel
    pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s
    bus-ID: 21:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: vfio-pci
    alternate: snd_hda_intel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 23:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-6:4
    chip-ID: 0b05:1918 class-ID: 0300
  API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 44:00.0
  IF: enp68s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
    vendor: ASUSTeK PCE-AC56 Dual-Band driver: wl v: kernel modules: bcma pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 49:00.0 chip-ID: 14e4:43b1
    class-ID: 0280
  IF: wlp73s0 state: dormant mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-3:2 chip-ID: 0b05:190e
  Local Storage: total: 4.36 TiB used: 42.2 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T8
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 36.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 46.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT750MX300SSD1
    size: 698.64 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: R011 scheme: MBR
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 42.2 GiB (2.3%)
    fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:5 label: N/A
    uuid: a2f7bc98-00e5-4ee9-bbc3-aec33bb9f2da
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4 label: N/A
    uuid: E058-8014
  ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 953.86 GiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:3 size: 953.86 GiB
    fs: <superuser required> label: N/A uuid: N/A
  ID-3: /dev/sda1 maj-min: 8:1 size: 698.64 GiB fs: ext4 label: N/A
    uuid: bb1778d9-fb1c-42c7-9dc3-5bc4a846cc87
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 7-3:2 info: ASUSTek ASUS USB-BT500 type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Hub-8: 7-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 7-5.3:5 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
    serial: <filter>
  Device-2: 7-6:4 info: ASUSTek USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Hub-9: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-11: 9-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 9-2.1:3 info: Microsoft 2.4GHz Transceiver v8.0 used by mouse
    Wireless Desktop 900 type: keyboard,mouse,HID driver: hid-generic,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 045e:07b2 class-ID: 0300
  Device-2: 9-2.4:4 info: Logitech Lightspeed Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c539 class-ID: 0300
  Hub-12: 10-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-13: 10-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 47 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 28%
  Packages: 1307 pm: pacman pkgs: 1300 libs: 345 tools: pamac,yay pm: flatpak
    pkgs: 7
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    3: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    4: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    5: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    6: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    7: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    8: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    9: https://manjaro.ynh.ovh/stable/$repo/$arch
    10: https://mirrors2.manjaro.org/stable/$repo/$arch
    11: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
    12: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    13: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    14: https://mirror.init7.net/manjaro/stable/$repo/$arch
    15: https://mirror.23m.com/manjaro/stable/$repo/$arch
    16: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    17: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    18: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    19: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    20: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    21: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    22: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    23: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    24: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    25: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    26: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    27: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    28: http://manjaro.grena.ge/stable/$repo/$arch
    29: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    33: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    35: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    38: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    39: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    40: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    41: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    44: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    45: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    48: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    49: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    51: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    52: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    53: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    54: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    55: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    56: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    57: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    58: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    59: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    60: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    61: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    62: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    63: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    64: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    65: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    66: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    67: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    68: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    69: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    70: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    71: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 805
  1: cpu: 11.6% command: chromium pid: 2555 mem: 129.3 MiB (0.1%)
  2: cpu: 9.3% command: chromium pid: 2288 mem: 408.3 MiB (0.3%)
  3: cpu: 7.2% command: chromium pid: 3864 mem: 303.7 MiB (0.2%)
  4: cpu: 4.1% command: chromium pid: 2601 mem: 305.7 MiB (0.2%)
  5: cpu: 3.7% command: Xorg pid: 1468 mem: 101.0 MiB (0.0%)
  Memory top: 5 of 805
  1: mem: 579.0 MiB (0.4%) command: portmaster-core_v1-6-5 pid: 1282
    cpu: 0.5%
  2: mem: 408.3 MiB (0.3%) command: chromium pid: 2288 cpu: 9.3%
  3: mem: 305.7 MiB (0.2%) command: chromium pid: 2601 cpu: 4.1%
  4: mem: 303.7 MiB (0.2%) command: chromium pid: 3864 cpu: 7.2%
  5: mem: 268.0 MiB (0.2%) command: chromium pid: 2711 cpu: 1.2%
  Processes: 805 Power: uptime: 1h 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 50.25 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
    running-in: xfce4-terminal inxi: 3.3.34
You better revisit the steps in the guide you mention - by looking at this one:
Virt-manager - ArchWiki
A few minor steps are different/missing - the fact that you should be a member of the “libvirt” group, for instance.
and that the configuration file:
/etc/libvirt/libvirtd.conf
needs editing.
There is also a huge gap here:
Not the whole delay is due to the startup of libvirtd.service
something may not be right with your network (dnsmasq) configuration
If you use NetworkManager, setup and explicit startup of dnsmasq is not needed - that is done within the NetworkManager configuration.
Thanks for the reply.
The libvirt grouping and config file are correct.
I have two users, one is: ii & one is YZ
I would not know what to do with the NetworkManager, so I do not dare touch that.
I don’t do much configuration for libvirt to function.
Only adding my user to libvirt and libvirt-quemu groups, enable libvirtd and reboot.
So it must be your configuration or closely related configuration.
Not that I know much about it - I know that gamers has a habit of doing it - so the question is:
  • Have you been setting up gpu passthrough?
I do believe you have done so - but nonetheless - I have to ask:
  • Did you enable AMD-v in the firmware?
Part of your issue is related to network therefore I suggest you start with disabling and stopping portmaster.
Other issues which may cause hang is missing devices or perhaps network service - in any case the target mountpoint does not exist - could be network related - you will likely know.
Since libvirt creates a virtual network - your issue becomes more visible after installing virtmanager and libvirt.
But it is difficult to guess - try going over my suggestions - hopefully you can narrow down where it happens.
This should be seen in the CPU flags in the inxi output - but I can’t find it.
It is therefore likely that it is not enabled in Bios/Uefi.
It also looks like the libvirtd.service gets deactivated for some reason - perhaps for this reason
and quite some time elapses before and after
snippet from the journal
Hi and thank you @anon33601770 &@linux-aarhus for the replies :slight_smile:
I was on a nightmare fueled BIOS ride!
Yes, I first tried:
After installing QEMU, it takes 5+ minutes before desktop appears, and GPU passthrough does not work
I got to know that I had to have 2 Graphics cards to be able to do it.
I also learned to always stick to the wiki, tutorials wherever you find them are nothing more than simple guides.
I found an old graphics card, and used it as my main one, and left the Quadro for the virtual machine.
That’s why I was away for so long!
I went to Asus’s site hoping to find some answers, and it helped:
[Motherboard]How to set VT(Virtualization Technology) in BIOS and install Virtual Machine in Windows
New users "can/should" not post post links to site as per the rules if I remember correctly
https://www.asus.com/us/support/faq/1045141/
It is not AMD-v! It is SVM mode & “IOMMU”, both of which were enabled.
I changed some other settings in the BIOS & ended up messing a lot of things, hence why I did not reply!
And then there was portmaster-stub. I uninstalled it, and every package started crashing. sudo pacman -Rs and manually deleting what’s in the .config file kind of helped.
That fixed it. After booting & entering the password, the desktop “comes on” quickly.
I moved on to using “yay opensnitch-git” & “yay switchhosts-bin”
I will always try to avoid tweaking stuff with the network because I am not “practiced” enough to diagnose & solve any issues, so I’ll try to solve everything while keeping the installation of Virt-Manager as “default” as possible.
It did :smiley:
Neither do I, but I have my Windows 10 Virtual machin working very well!
Removing portmaster-stub fixed it.
Thank you for the support :smiley:
The idea “of all of this text” is so that if someone might benefit if they were to have a similar issue.
I have no problem with libvirt and portmaster-stub, both start automatically on every reboot and suspend & wakeup. :person_shrugging:
I do not think portmaster-stub with default config causes the problem.
Neither do I - but I needed to suggest looking into network based on the log provided.
On portmaster seemed a likely candidate to interfere with the network availability.
I was running portmaster-stub with its default config!
Really do not know how to fix this in any other way!
What should I be looking for, for example?
Troubleshooting a network is a needle in a haystack.
When you have weird issues with network - the best approach is to remove any and all applications which may alter or filter your network traffic.
That includes portmaster, firewalld, ufw, little snitch, vpn providers and possibly some I don’t know about.
I would look into how my name resolution is working - using ping and traceroute.
I would look into which provider for name resolution - openresolv or systemd.
And check which services are running on your system:
$ systemctl list-units --state=active --no-pager
and
$ systemctl list-units --state=active --no-pager --user
and
systemctl list-dependencies --after network.target
systemctl list-dependencies --before network.target
Bookmarked, good tip.
Exactly, Linux have been using a lot of my time “months & I am not at all exaggerating”, and I really do not wish to tweak any more. I could do some tests in VM’s perhaps!
What’s that?
openresolv
https://wiki.archlinux.org/title/Openresolv
systemd
https://wiki.archlinux.org/title/Systemd
I keep commands like this in my bookmarks :smiley:
Thank you for sharing.
And thank you all for all the tips & help <3
