Hi, i want to ask how to install or enable xdebug php extension in manjaro?. I have followed the documentation but it still doesn’t work. Thank you.
Hi @FitoPietro,
You’ll need to give us more info to work with:
- What version of PHP is it? This is important as there isn’t only one version.
- How did you install it? What guide did you follow? Because there are packages, both in the AUR as well as the
community
repository both for version7
as well as version8
$ pamac search xdebug
webgrind-git 20110421-1 AUR
Xdebug Profiling Web Frontend in PHP.
webgrind 1.6.1-1 AUR
pugdebug-git 1.1.0.r1.gddb1193-2 AUR
PugDebug is a standalone debugging client for PHP applications that uses XDebug as the debugging engine
php81-xdebug 3.1.2-1 AUR
Xdebug is an extension for PHP to assist with debugging and development for php81
php80-xdebug 3.1.3-1 AUR
xdebug module for php 8.0
php74-xdebug 3.1.3-1 AUR
PHP debugging extension
php73-xdebug 3.0.4-1 AUR
php72-xdebug 3.1.1-2 AUR
Xdebug is an extension for PHP to assist with debugging and development.
php71-xdebug 2.6.0-1 AUR
PHP extension module that aids debugging and profiling
php70-xdebug 2.6.0-1 AUR
php56-xdebug 2.5.5-1 AUR
php56 debugging extension
php55-xdebug 2.5.5-1 AUR
php55 debugging extension
xdebug7 3.1.0-1 AUR
PHP debugging extension. For PHP7 package.
xdebug-zts 3.0.2-2 AUR
PHP debugging extension (for ZTS enabled PHP)
xdebug 3.1.2-2 community
Also, have a look here:
- [HowTo] Provide System Information,
- [HowTo] post screenshots and links,
- [HowTo] Make support easier, and
- [HowTo] Use preformatting in a forum post.
Hope you manage!
