Hello there !!
In new kde version there has been an update to choose between (Small, Normal and Large) as a panel icon spacing for system-tray icons. I find the large to be too large and normal to be too small for me.
Is there a way with which I can increase the space a little bit for normal which suits for me ?
Hi @Unbeknownst,
Right-click on the panel, select Enter edit mode.
From there, you should be able to adjust panel height, which should in theory adjust the icon size as well:
It works for me AFAIK. Or at least, mine is perfect like this.
Hope it helps!
Right !!
Thanks a lot but is there a way to increase the sys-tray space via some configuration file method and edit the space there like say from space = 1.5 to 1.6, like that ?
I want the same height but little more space for the system-tray icons
While still in Edit Mode you can tweak the System Tray Settings and set the size to scale and the spacing to large, instead of normal.
Yeah ! IK but my question is something else.
I said the panel icon spacing for system-tray is either too large or too small when I choose Large or Normal respectively. I want to go to some specific file that has the spacing configuration to edit it from lets say: 1.5 to 1.6 For this I want to know the way to increase the panel icon spacing apart from three option via configuration file because I know I don’t have manual spacing option in Panel icon spacing.
This Normal option is too small for me and
This Large option is way to large for me.
I want to either increase the default spacing of Normal or decrease the default spacing of Large
which is going to be suitable as per my need.
I hope my question was clear and has a solution.
Thanks in advance,
Yours,
Unbeknownst
You can open up a feature request to KDE Plasma team via https://bugs.kde.org/ to implement such feature.
Okay !!
I ,after knowing how to increase the size, will let this Thread know on how to do it
Thanks
So I followed the blog but the contents of that post and mine are so different I didn’t know what to do.
So my had sort of rowSpacing and column attibute
I tried changing those but the only thing it did was increase the spacing with just the main hidden icon rather between icons in the entire system tray icons.
Please provide the output of:
cat ~/.local/share/plasma/plasmoids/org.kde.plasma.private.systemtray/ \
contents/ui/main.qml
And please, remember to provide it according to:
Providing terminal output
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
SPDX-FileCopyrightText: 2011 Marco Martin <mart@kde.org>
SPDX-FileCopyrightText: 2020 Konrad Materka <materka@gmail.com>
SPDX-License-Identifier: LGPL-2.0-or-later
import QtQuick 2.5
import QtQuick.Layouts 1.1
import QtQuick.Window 2.15
import org.kde.plasma.core 2.1 as PlasmaCore
import org.kde.plasma.plasmoid 2.0
import org.kde.draganddrop 2.0 as DnD
import org.kde.kirigami 2.5 as Kirigami // For Settings.tabletMode
import "items"
MouseArea {
readonly property bool vertical: Plasmoid.formFactor === PlasmaCore.Types.Vertical
Layout.minimumWidth: vertical ? PlasmaCore.Units.iconSizes.small : mainLayout.implicitWidth + PlasmaCore.Units.smallSpacing
Layout.minimumHeight: vertical ? mainLayout.implicitHeight + PlasmaCore.Units.smallSpacing : PlasmaCore.Units.iconSizes.small
LayoutMirroring.enabled: !vertical && Qt.application.layoutDirection === Qt.RightToLeft
LayoutMirroring.childrenInherit: true
readonly property alias systemTrayState: systemTrayState
readonly property alias itemSize: tasksGrid.itemSize
readonly property alias visibleLayout: tasksGrid
readonly property alias hiddenLayout: expandedRepresentation.hiddenLayout
readonly property bool oneRowOrColumn: tasksGrid.rowsOrColumns === 1
onWheel: {
// Don't propagate unhandled wheel events
wheel.accepted = true;
SystemTrayState {
//being there forces the items to fully load, and they will be reparented in the popup one by one, this item is *never* visible
Item {
visible: false
CurrentItemHighLight {
parent: root
DnD.DropArea {
anchors.fill: parent
preventStealing: true
/** Extracts the name of the system tray applet in the drag data if present
* otherwise returns null*/
function systemTrayAppletName(event) {
if (event.mimeData.formats.indexOf("text/x-plasmoidservicename") < 0) {
return null;
const plasmoidId = event.mimeData.getDataAsByteArray("text/x-plasmoidservicename");
if (!Plasmoid.nativeInterface.isSystemTrayApplet(plasmoidId)) {
return null;
return plasmoidId;
onDragEnter: {
if (!systemTrayAppletName(event)) {
event.ignore();
onDrop: {
const plasmoidId = systemTrayAppletName(event);
if (!plasmoidId) {
event.ignore();
return;
if (Plasmoid.configuration.extraItems.indexOf(plasmoidId) < 0) {
const extraItems = Plasmoid.configuration.extraItems;
extraItems.push(plasmoidId);
Plasmoid.configuration.extraItems = extraItems;
//Main Layout
GridLayout {
rowSpacing: 0
columnSpacing: 0
flow: vertical ? GridLayout.TopToBottom : GridLayout.LeftToRight
GridView {
Layout.alignment: Qt.AlignCenter
interactive: false //disable features we don't need
flow: vertical ? GridView.LeftToRight : GridView.TopToBottom
// The icon size to display when not using the auto-scaling setting
readonly property int smallIconSize: PlasmaCore.Units.iconSizes.smallMedium
// Automatically use autoSize setting when in tablet mode, if it's
// not already being used
readonly property bool autoSize: Plasmoid.configuration.scaleIconsToFit || Kirigami.Settings.tabletMode
readonly property int gridThickness: root.vertical ? root.width : root.height
// Should change to 2 rows/columns on a 56px panel (in standard DPI)
readonly property int rowsOrColumns: autoSize ? 1 : Math.max(1, Math.min(count, Math.floor(gridThickness / (smallIconSize + PlasmaCore.Units.smallSpacing))))
// Add margins only if the panel is larger than a small icon (to avoid large gaps between tiny icons)
readonly property int cellSpacing: PlasmaCore.Units.smallSpacing * (Kirigami.Settings.tabletMode ? 6 : Plasmoid.configuration.iconSpacing)
readonly property int smallSizeCellLength: gridThickness < smallIconSize ? smallIconSize : smallIconSize + cellSpacing
cellHeight: {
if (root.vertical) {
return autoSize ? itemSize + (gridThickness < itemSize ? 0 : cellSpacing) : smallSizeCellLength
} else {
return autoSize ? root.height : Math.floor(root.height / rowsOrColumns)
cellWidth: {
return autoSize ? root.width : Math.floor(root.width / rowsOrColumns)
} else {
//depending on the form factor, we are calculating only one dimension, second is always the same as root/parent
implicitHeight: root.vertical ? cellHeight * Math.ceil(count / rowsOrColumns) : root.height
implicitWidth: !root.vertical ? cellWidth * Math.ceil(count / rowsOrColumns) : root.width
readonly property int itemSize: {
if (autoSize) {
return PlasmaCore.Units.roundToIconSize(Math.min(Math.min(root.width, root.height) / rowsOrColumns, PlasmaCore.Units.iconSizes.enormous))
} else {
return smallIconSize
model: PlasmaCore.SortFilterModel {
sourceModel: Plasmoid.nativeInterface.systemTrayModel
filterRole: "effectiveStatus"
filterCallback: (source_row, value) => value === PlasmaCore.Types.ActiveStatus
delegate: ItemLoader {
// We need to recalculate the stacking order of the z values due to how keyboard navigation works
// the tab order depends exclusively from this, so we redo it as the position in the list
// ensuring tab navigation focuses the expected items
Component.onCompleted: {
let item = tasksGrid.itemAtIndex(index - 1);
if (item) {
Plasmoid.nativeInterface.stackItemBefore(delegate, item)
} else {
item = tasksGrid.itemAtIndex(index + 1);
if (item) {
Plasmoid.nativeInterface.stackItemAfter(delegate, item)
add: Transition {
enabled: itemSize > 0
NumberAnimation {
property: "scale"
to: 1
easing.type: Easing.InOutQuad
duration: PlasmaCore.Units.longDuration
displaced: Transition {
//ensure scale value returns to 1.0
//https://doc.qt.io/qt-5/qml-qtquick-viewtransition.html#handling-interrupted-animations
NumberAnimation {
property: "scale"
to: 1
move: Transition {
NumberAnimation {
properties: "x,y"
ExpanderArrow {
Layout.fillWidth: vertical
Layout.fillHeight: !vertical
Layout.alignment: vertical ? Qt.AlignVCenter : Qt.AlignHCenter
iconSize: tasksGrid.itemSize
visible: root.hiddenLayout.itemCount > 0
Timer {
interval: 100
onTriggered: systemTrayState.expanded = dialog.visible;
//Main popup
PlasmaCore.Dialog {
objectName: "popupWindow"
visualParent: root
flags: Qt.WindowStaysOnTopHint
hideOnWindowDeactivate: !Plasmoid.configuration.pin
visible: systemTrayState.expanded
// visualParent: implicitly set to parent
backgroundHints: (Plasmoid.containmentDisplayHints & PlasmaCore.Types.DesktopFullyCovered) ? PlasmaCore.Dialog.SolidBackground : PlasmaCore.Dialog.StandardBackground
type: PlasmaCore.Dialog.AppletPopup
appletInterface: Plasmoid.self
onVisibleChanged: {
if (!visible) {
expandedSync.restart();
} else {
if (expandedRepresentation.plasmoidContainer.visible) {
expandedRepresentation.plasmoidContainer.forceActiveFocus();
} else if (expandedRepresentation.hiddenLayout.visible) {
expandedRepresentation.hiddenLayout.forceActiveFocus();
mainItem: ExpandedRepresentation {
Keys.onEscapePressed: {
systemTrayState.expanded = false
// Draws a line between the applet dialog and the panel
PlasmaCore.SvgItem {
// Only draw for popups of panel applets, not desktop applets
visible: [PlasmaCore.Types.TopEdge, PlasmaCore.Types.LeftEdge, PlasmaCore.Types.RightEdge, PlasmaCore.Types.BottomEdge]
.includes(Plasmoid.location)
anchors {
top: Plasmoid.location === PlasmaCore.Types.BottomEdge ? undefined : parent.top
left: Plasmoid.location === PlasmaCore.Types.RightEdge ? undefined : parent.left
right: Plasmoid.location === PlasmaCore.Types.LeftEdge ? undefined : parent.right
bottom: Plasmoid.location === PlasmaCore.Types.TopEdge ? undefined : parent.bottom
topMargin: Plasmoid.location === PlasmaCore.Types.BottomEdge ? undefined : -dialog.margins.top
leftMargin: Plasmoid.location === PlasmaCore.Types.RightEdge ? undefined : -dialog.margins.left
rightMargin: Plasmoid.location === PlasmaCore.Types.LeftEdge ? undefined : -dialog.margins.right
bottomMargin: Plasmoid.location === PlasmaCore.Types.TopEdge ? undefined : -dialog.margins.bottom
height: (Plasmoid.location === PlasmaCore.Types.TopEdge || Plasmoid.location === PlasmaCore.Types.BottomEdge) ? PlasmaCore.Units.devicePixelRatio : undefined
width: (Plasmoid.location === PlasmaCore.Types.LeftEdge || Plasmoid.location === PlasmaCore.Types.RightEdge) ? PlasmaCore.Units.devicePixelRatio : undefined
z: 999 /* Draw the line on top of the applet */
elementId: (Plasmoid.location === PlasmaCore.Types.TopEdge || Plasmoid.location === PlasmaCore.Types.BottomEdge) ? "horizontal-line" : "vertical-line"
svg: PlasmaCore.Svg {
imagePath: "widgets/line"
LayoutMirroring.enabled: Qt.application.layoutDirection === Qt.RightToLeft
OK, I changed
columnSpacing: 0
to
columnSpacing: 20
So try it now:
import QtQuick 2.5
import "items"
MouseArea {
onWheel: {
SystemTrayState {
Item {
visible: false
parent: root
DnD.DropArea {
return null;
return null;
return plasmoidId;
onDragEnter: {
event.ignore();
onDrop: {
if (!plasmoidId) {
event.ignore();
return;
//Main Layout
GridLayout {
rowSpacing: 0
columnSpacing: 20
GridView {
cellHeight: {
} else {
cellWidth: {
} else {
if (autoSize) {
} else {
if (item) {
} else {
if (item) {
add: Transition {
NumberAnimation {
property: "scale"
to: 1
NumberAnimation {
property: "scale"
to: 1
move: Transition {
NumberAnimation {
properties: "x,y"
ExpanderArrow {
Timer {
interval: 100
//Main popup
PlasmaCore.Dialog {
visualParent: root
onVisibleChanged: {
if (!visible) {
} else {
anchors {
Because rows are horizontal and columns are vertical, which is between the icons, according to me.
Edit:
Remember to restart plasmashell afterwards:
killall plasmashell && kstart plasmashell
Sorry for posting messy post
Yeah i tried it and the result is :
The spacing increased but as you can see only of this arrowed section but not of other.
No worries, ma’an. Relax. That’s why we help to actually help.
Anyway, try this:
import QtQuick 2.5
import "items"
MouseArea {
onWheel: {
SystemTrayState {
Item {
visible: false
parent: root
DnD.DropArea {
return null;
return null;
return plasmoidId;
onDragEnter: {
event.ignore();
onDrop: {
if (!plasmoidId) {
event.ignore();
return;
//Main Layout
GridLayout {
rowSpacing: 0
columnSpacing: 0
GridView {
readonly property int cellSpacing: 20
cellHeight: {
} else {
cellWidth: {
} else {
if (autoSize) {
} else {
if (item) {
} else {
if (item) {
add: Transition {
NumberAnimation {
property: "scale"
to: 1
NumberAnimation {
property: "scale"
to: 1
move: Transition {
NumberAnimation {
properties: "x,y"
ExpanderArrow {
Timer {
interval: 100
//Main popup
PlasmaCore.Dialog {
visualParent: root
onVisibleChanged: {
if (!visible) {
} else {
anchors {
I only changed:
…to
As a test so we can see what happens.
Remember to restart plasmashell:
wow !!
It worked
Thank you so much @Mirdarthos
Actually, thinking about it, this might be a better option:
import QtQuick 2.5
import "items"
MouseArea {
onWheel: {
SystemTrayState {
Item {
visible: false
parent: root
DnD.DropArea {
return null;
return null;
return plasmoidId;
onDragEnter: {
event.ignore();
onDrop: {
if (!plasmoidId) {
event.ignore();
return;
//Main Layout
GridLayout {
rowSpacing: 0
columnSpacing: 0
GridView {
readonly property int cellSpacing: (PlasmaCore.Units.smallSpacing * (Kirigami.Settings.tabletMode ? 6 : Plasmoid.configuration.iconSpacing)) * 1.5
cellHeight: {
} else {
cellWidth: {
} else {
if (autoSize) {
} else {
if (item) {
} else {
if (item) {
add: Transition {
NumberAnimation {
property: "scale"
to: 1
NumberAnimation {
property: "scale"
to: 1
move: Transition {
NumberAnimation {
properties: "x,y"
ExpanderArrow {
Timer {
interval: 100
//Main popup
PlasmaCore.Dialog {
visualParent: root
onVisibleChanged: {
if (!visible) {
} else {
anchors {
I replace the
with
…perhaps making it more…adaptable. Or something.
Test and let me know. If it doesn’t work, you can always revert to the previous version.
