I am using Manjaro up to date. The top bar of Emacs, Claws mail, Skype windows has become transparent. This confuses me, how to disable? Other applications not affected : Chrome, gedit, Nautilus and other Gnome apps.
The problem has disappeared.
I am having the same issue. Do you know how you fixed it?
Apparently,
…as if by magic…
Hi @ploca14 and welcome to the Manjaro community.
I do not have a solution to your apparent issue, and after 7 months I’m guessing the OP also has no clue. My best suggestion is to start (your own) new thread and detail your problem so that others can help more effectively.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
I hope this helps. Cheers.
Will do, thank you!
