I would like to boot into a live USB session with a specific kernel parameter, that disables AER messages spamming and freezing my pc. I know the parameter: pci=nomsi, but i dont know how to boot the usb session with it. Thanks.
In the GRUB menu, press E, then add your parameter to the linux cmdline.
Then press, I guess is was, F10 to start…
thanks that worked
heres the screenshot where exactly i put the parameter - its underlined with orange
