Hibernate problem, laptop just locking screen
Hello, I have laptop Dell E5400 with 16GB of RAM and during installation I’ve created swap file on setup window, but it’s not works, when I click to Hibernate it’s just locking screen, Please help to fix this problem.
I’ve checked configurations and here is results:
swapon --show         ✔
NAME           TYPE       SIZE USED PRIO
/dev/nvme0n1p5 partition 16,6G   0B   -2
sudo blkid | grep swap         2 ✘
/dev/nvme0n1p5: UUID="07c01f9f-26ea-4df0-bbf5-a5b080b64895" TYPE="swap" PARTUUID="4ae7ce00-f503-4b69-906d-b68b740f10ae"
/etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash resume=UUID=07c01f9f-26ea-4df0-bbf5-a5b080b64895 udev.log_priority=3"
Hi @Levan, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hello, I’ve changed post, does others can see it for assistance?
Hello @Levan, and thank you!
Although, please don’t paste screenshots or images if possible. Please see:
And regarding the SWAP file, all I can offer you is:
https://wiki.archlinux.org/title/Swap
Do you have resume (or systemd) among your HOOKS in /etc/mkinitcpio.conf ?
Also … I dont see a resume_offset flag.
Please see:
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Acquire_swap_file_offset
Another idea is with systemd freeze user sessions described in both stable and testing updates.
This swap file got automatically incorporated into the Grub configuration when you installed the system?
Or did you do this yourself?
I’d guess the latter.
If so, you need to give a resume_offset as well, like @cscs said.
It would work with a swap partition, but with a swap file, the system needs to know
where on the partition the swap file starts (resume_offset).
I’ve checked HOOKS:
also I do not have /swapfile,
swapon --show         ✔
so I run
filefrag -v /dev/nvme0n1p5
and got this output
sudo filefrag -v /dev/nvme0n1p5         ✔
[sudo] password for lvn:
Filesystem type is: 1021994
File size of /dev/nvme0n1p5 is 0 (0 blocks of 4096 bytes)
/dev/nvme0n1p5: 0 extents found
No system is just installed, I have dual boot, win11 and manjaro
If the installer did this, then it is faulty.
But:
we don’t know whether this actually is the reference to the swap file or a reference to a swap partition.
We have not yet seen:
inxi -zv8
(your system information)
You have a swap partition.
But initially you said you have a swap file.
This prompted the responses about a missing resume_offset parameter.
Much confusion can be avoided by giving system information.
This would all have been clear and obvious with that information.
sharing system information
  Kernel: 6.10.6-10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=81ce66fa-5f81-40a7-893b-b39c6902e5b0 rw quiet splash
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Laptop System: Dell product: Latitude 5400 v: N/A
  Mobo: Dell model: 0PD9KD v: A00 serial: <superuser required> part-nu: 08B8
    uuid: <superuser required> UEFI: Dell v: 1.13.0 date: 10/06/2021
  ID-1: BAT0 charge: 37.7 Wh (70.3%) condition: 53.6/68.0 Wh (78.9%)
    volts: 8.2 min: 7.6 model: LGC-LGC8.948 DELL X77XY96 type: Li-ion
    serial: <filter> status: charging
  System RAM: total: 16 GiB available: 15.43 GiB used: 3.63 GiB (23.5%)
  Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB speed:
    spec: 3200 MT/s actual: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: 802C0000802C
    part-no: 8ATF1G64HZ-3G2J1 serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB speed:
  Info: model: Intel Core i5-8365U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xFC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 700 min/max: 400/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 5: 700 6: 700 7: 700
    8: 700 bogomips: 30409
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
    ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0bda:5539
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x14e7 built: 2018 res: 1920x1080
    dpi: 158 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329 y: 0.557
    blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL
    GT2) device-ID: 8086:3ea0 memory: 7.54 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics 620 (WHL GT2) driver: mesa intel v: 24.1.6-arch1.1
    device-ID: 8086:3ea0 surfaces: xcb,xlib
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bd class-ID: 0200
  IF: eno2 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
  Local Storage: total: 465.76 GiB used: 9.31 GiB (2.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.C temp: 48.9 C
    scheme: GPT
  ID-1: / raw-size: 154.73 GiB size: 151.24 GiB (97.75%) used: 9.31 GiB (6.2%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 81ce66fa-5f81-40a7-893b-b39c6902e5b0
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 6545-2E3A
  ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 07c01f9f-26ea-4df0-bbf5-a5b080b64895
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 1428-55D7
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 293.08 GiB fs: ntfs label: N/A
    uuid: 20FC31C6FC31974E
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 768 MiB fs: ntfs label: N/A
    uuid: 986C9F156C9EED6E
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Realtek Integrated_Webcam_HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5539 class-ID: 0e02
    serial: <filter>
  Device-2: 1-8:3 info: Broadcom 58200 type: smart card driver: N/A
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 100mA chip-ID: 0a5c:5842 class-ID: 0b00 serial: <filter>
  Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  System Temperatures: cpu: 50.0 C pch: 49.0 C mobo: 43.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: pm: pacman pkgs: 1212 libs: 353 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    2: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    3: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    4: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    5: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    6: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    7: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    8: http://manjaro.mirror.ac.za/stable/$repo/$arch
    9: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    10: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    11: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    12: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    13: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    14: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    15: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    16: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    17: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    18: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    19: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    20: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    21: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    22: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    23: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    24: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    25: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    26: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    28: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    29: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    30: https://manjaro.ynh.ovh/stable/$repo/$arch
    31: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    32: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    33: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    34: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    35: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    36: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    37: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    39: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    41: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    42: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    43: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    44: https://manjaro.kurdy.org/stable/$repo/$arch
    45: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    46: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    47: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    48: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    49: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    50: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    51: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    52: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    53: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    54: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    55: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    57: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    58: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    59: https://mirror.init7.net/manjaro/stable/$repo/$arch
    60: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    61: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    62: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    63: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    64: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    65: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    66: https://linorg.usp.br/manjaro/stable/$repo/$arch
    67: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    68: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    69: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    70: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    71: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    72: https://repos.silknet.com/manjaro/stable/$repo/$arch
    73: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    74: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    75: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    76: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    77: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    78: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    79: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    80: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    81: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    82: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    83: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    84: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    85: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    86: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    87: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    88: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    89: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    90: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    91: http://manjaro.grena.ge/stable/$repo/$arch
    92: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    93: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    94: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    95: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    96: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    97: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    98: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    99: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    100: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    101: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    102: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    103: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    104: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    105: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    106: https://mirrors2.manjaro.org/stable/$repo/$arch
    107: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    108: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    109: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    110: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    111: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    112: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    113: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    114: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    115: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    116: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    117: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    118: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    119: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    120: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    121: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    122: https://mirror.23m.com/manjaro/stable/$repo/$arch
    123: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    124: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    125: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    126: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    127: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    128: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    129: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    130: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    131: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 248
  1: cpu: 14.9% command: plasma-systemmonitor pid: 30228
    mem: 282.8 MiB (1.7%)
  2: cpu: 9.4% command: firefox pid: 1054 mem: 420.8 MiB (2.6%)
  3: cpu: 5.4% command: kwin_x11 pid: 767 mem: 179.5 MiB (1.1%)
  4: cpu: 4.7% command: Xorg pid: 599 mem: 80.5 MiB (0.5%)
  5: cpu: 3.9% command: ksgrd_network_helper pid: 30256 mem: 6.30 MiB (0.0%)
  Memory top: 5 of 248
  1: mem: 420.8 MiB (2.6%) command: firefox pid: 1054 cpu: 9.4%
  2: mem: 343.7 MiB (2.1%) command: plasmashell pid: 795 cpu: 0.9%
  3: mem: 282.8 MiB (1.7%) command: plasma-systemmonitor pid: 30228
    cpu: 14.9%
  4: mem: 237.6 MiB (1.5%) command: firefox pid: 1534 cpu: 2.7%
  5: mem: 221.9 MiB (1.4%) command: manjaro-hello started-by: python3
    pid: 1037 cpu: 0.2%
  Processes: 248 Power: uptime: 23m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.16 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.32
    running-in: konsole inxi: 3.3.36
I suspect your SWAP partition is too full.
Also, this is a swap partition, as can clearly be seen:
…not a swap file.
I don’t know how to resize a swap file and I don’t know if resizing a swap partition is even possible. I suspect you’ll have to delete the current swap partition and create a new, bigger one. I’d recommend about 150% of your RAM size, 24GB in this case. See here for more 'bout that:
https://wiki.archlinux.org/title/Swap#Swap_partition
It’s not - it’s 0% used at the time this command was run.
16 GB RAM and 16 GB swap - no shortage there.
Hibernation should work, but it doesn’t.
I have no idea why - checking logs might bring up helpful hints as to the cause.
I know, but when trying to hibernate it will obviously get full, and that’s what I was talkin’ 'bout.
@OP
Finding errors for specific boot
journalctl --priority=warning..crit --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth.
Check the resume UUID in /etc/default/grub
cat /etc/default/grub | grep resumecat /etc/default/grub | grep resume
GRUB_CMDLINE_LINUX_DEFAULT="resume=UUID=1xxxxd4b-4xxd-491e-8xxx-b1xxxe2xx706
and /etc/fstab
cat /etc/fstab | grep swap
UUID=1xxxxd4b-4xxd-491e-8xxx-b1xxxe2xx706 swap           swap    defaults,noatime 0 2
# /dev/sda7: UUID="1xxxxd4b-4xxd-491e-8xxxx-b1xxxe2xx706" TYPE="swap" PARTUUID="3xxxxxxxxx-2cxxxx4ce7-98x1-a1bbd12fea22"
Examples from my system; use the appropriate partitions and UUIDs for yours.
They match - see system info (inxi).
And the swap is active/used.
I see. :smiley: I might suggest trying a Wayland session though; no Nvidia seen there.
On my old laptop with same 16GB of RAM on linux mint hibernated worked fine with 17GB of swapfile, but here I think maybe problem is on laptop model or manjaro installation package, if there no other solution I’ll create swapfile and remove swap partition.
Thanks for support.
16 GB of (unused) swap to back 16 GB of RAM is not a problem.
This is not your problem!
Check the logs.
you have not even started to diagnose the problem
you / we have no idea about “the solution”.
At this point, you are just assuming things.
Waste of your time.
but: go ahead and try anyway …
it’s your time …
Don’t remove the swap partition; expand it if you have space you can spare elsewhere on the disk. I’d give it a bit more than physical RAM as programs like Firefox eat memory for breakfast. Maybe an extra 4GB at least, for good measure.
I see a few potential issues in your inxi results.
— the <missing: xandr> might be as a result of the next bit:
Means the display is not being detected correctly.
 SMART Message: Required tool smartctl not installed.
That should be an easy fix; sudo pacman -Syu smartmontools
Are you sure your Win11 is completely shut-down, not in its usual default hybrid sleep state, or hibernation, or whatever they want to call it? … This can cause all sorts of issues with hardware not working properly under Linux, because it hasn’t been shut off properly by the other OS.
In windows, open an elevated command prompt and run powercfg -h off and see if that helps. This apparently also gets rid of the hiberfil.sys file.
