Headphones mic doesn’t get detected.
I have dual booted with windows. Same headphones mic works in that.
Bluetooth headset mic and speaker works just fine. Internal mic works fine.
I’ve tried adding these to make it work.
Tried switching kernels to 5.4 lts, 5.8, 5.9, 5.10, 5.11. Restarted before verifying each ofcoarse.
/etc/pulse/default.pa
load-module module-alsa-source device=hw:0,0 #<<<- THIS LINE I ADDED
# the line above should be somewhere before the line below
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
/etc/modprobe.d/alsa-base.conf
options snd-intel-dspcfg dsp_driver=1
sudo dmesg | egrep -i ‘(snd|sound|sof|alsa|hda)’
[ 0.584048] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.835406] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.835409] software IO TLB: mapped [mem 0x00000000711fe000-0x00000000751fe000] (64MB)
[ 3.458213] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.552108] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC233: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 3.552109] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.552110] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 3.552111] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.552111] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.552112] snd_hda_codec_realtek hdaudioC0D0: Mic=0x12
[ 3.631773] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ 3.631816] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ 3.631854] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ 3.631892] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ 3.631930] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ 3.631972] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
inxi -Faz
System: Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=80600993-862a-4954-bd73-8ca82f953daf ro quiet apparmor=1
security=apparmor resume=UUID=8b11817b-7fff-4e2f-8a74-cb9d4bcc3a8f udev.log_priority=3
Desktop: KDE Plasma 5.21.80 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <filter> UEFI: American Megatrends v: FX505GT.310 date: 11/26/2020
Battery: ID-1: BAT0 charge: 28.0 Wh condition: 45.6/48.1 Wh (95%) volts: 11.8/11.7 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: Unknown cycles: 41
CPU: Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: DE L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38408
Speed: 4085 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4085 2: 3817 3: 4090 4: 4074 5: 4074 6: 4092 7: 4096
8: 4079
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
class ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 460.39
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91 class ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-11:3 chip ID: 13d3:56a2
class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting,nvidia display ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.7x14.4") s-diag: 748mm (29.4")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348 class ID: 0403
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
chip ID: 8086:a370 class ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: 3000
bus ID: 03:00.0 chip ID: 10ec:8168 class ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus ID: 1-14:4
chip ID: 8087:0aaa class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 942.7 GiB used: 59 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: P1MA0V4 temp: 29.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 023 scheme: GPT
Partition: ID-1: / raw size: 84 GiB size: 82.18 GiB (97.84%) used: 24.94 GiB (30.3%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%) used: 25.6 MiB (10.0%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 100 GiB size: 97.93 GiB (97.93%) used: 34.04 GiB (34.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2 maj-min: 8:2
Sensors: System Temperatures: cpu: 54.0 C mobo: 27.8 C gpu: nvidia temp: 48 C
Fan Speeds (RPM): cpu: 2700
Info: Processes: 281 Uptime: 1h 34m wakeups: 1 Memory: 7.63 GiB used: 2.67 GiB (35.0%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1389 pacman: 1367 lib: 393 flatpak: 16 snap: 6 Shell: Zsh v: 5.8 running in: konsole
inxi: 3.3.01
I’m planning to install Arch vanilla and see if all media hardware works out of the box, with Manjaro I’ve tried searching a lot on the internet. I’m somewhat of a noob, I’ve used ubuntu before.
Thank you for your time
), it didn’t. It has the same problem, only one device (internal mic) gets detected. I’m going to delete it, it’s much work to set it up again and it’s not really any different from what I have now with Manjaro.
, you arrived to precisely what I had to do.
