The microphone input when using the combined headphone/microphone jack for a headset does not get recognised.
The internal mic is just garbage, it does pick up, but it sounds like a really bad robot with noise. It might be broken, i don’t mind, as long as i can get the combined headphone/microphone jack to work on headsets, however, if anyone has an idea about that, that would also be appreciated.
I found something that sounds very similar here: Headphone Mic doesn’t get detected
but I am not sure if i actually should make the same changes, since I have a different acer product. Basically i am a noob and don’t know how to check if the input is also for me a dummy output, namely Node 0x19.
Here is my inxi -Faz
Kernel: 5.15.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ac9dcd69-e8e8-4af5-9d6b-2ed3b9ff862d rw quiet apparmor=1
security=apparmor resume=UUID=a645d087-a3d4-4ef8-a1a5-4dccaa9bf484
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: Acer product: Spin SP515-51GN v: V1.14
serial:
Mobo: KBL model: Buzz_KL v: V1.14 serial:
UEFI: Insyde v: 1.14 date: 01/09/2019
ID-1: BAT0 charge: 32.8 Wh (80.4%) condition: 40.8/48.9 Wh (83.4%)
volts: 16.9 min: 15.2 model: LGC AC14B8K type: Li-ion serial:
status: charging
Device-1: hid-0003:04F3:253E.0003-battery model: ELAN Touchscreen
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 843 high: 1164 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 795 3: 789 4: 800
5: 800 6: 800 7: 1164 8: 800 bogomips: 32012
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.104.05 non-free: 535.xx+
status: current (as of 2023-09) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Chicony Integrated HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b5f7
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. glxinfo is missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
API: ALSA v: k5.15.131-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 50.0 C
IF: wlp2s0 state: up mac:
IF-ID-1: anbox0 state: down mac:
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 04ca:3016 class-ID: e001
Local Storage: total: 1.38 TiB used: 146.18 GiB (10.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
tech: HDD rpm: 5400 serial: fw-rev: ACM2 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 MTFDDAV512TBN
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: fw-rev: A020 scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 143.55 GiB (31.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 8.8 GiB used: 2.63 GiB (29.8%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 52.0 C pch: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 295 Uptime: 7h 25m wakeups: 7 Memory: total: 8 GiB
available: 7.68 GiB used: 5.32 GiB (69.3%) Init: systemd v: 254
Packages: 1664 pm: pacman pkgs: 1654 libs: 427 tools: pamac pm: flatpak
pkgs: 10 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.30
Alsa-info
http://alsa-project.org/db/?f=09e3a5afbf2af6dcad09c060d067564b1b72fdf2
