Hardware error on boot using new hardware
Hey Guys,
I’m getting the following messages every time I boot my Pc. It doesn’t seem to impact anything, but it worries me nonetheless. I just bought the cpu and motherboard, so I don’t think that it is actually damaged hardware. Does someone know how to fix this?
My specs
KDE Plasma Version: 5.21.3
KDE Frameworks Version: 5.80.0
Qt Version: 5.15.2
Kernel Version: 5.11.6-1-MANJARO
OS Type: 64-bit
Graphics Platform: X11
Processors: 12 × Intel® Core™ i5-10400F CPU @ 2.90GHz
Memory: 15.5 GiB of RAM
Graphics Processor: GeForce GTX 1060 6GB/PCIe/SSE2
if same result with boot on USB iso live manjaro ?
it come from microcode
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. Please also read this:
    [HowTo] Post screenshots and links
    Especially these bits:
    and:
  4. It looks like one of your RAM chips has failed / is failing / is about to fail. Have you done a memtest from grub yet?
:+1:
Ok, here is the ouput of inxi --admin --verbosity=7 --filter --no-host --width:
  Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=4ead3640-ed8d-4a0e-920e-28ee6c42fab4 ro quiet apparmor=1
  Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASRock model: H570 Phantom Gaming 4 serial: <filter>
  UEFI: American Megatrends LLC. v: P1.30 date: 01/29/2021
  RAM: total: 15.51 GiB used: 4.36 GiB (28.1%)
  Info: 6-Core model: Intel Core i5-10400F bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 5 microcode: E2
  cache: L2: 12 MiB bogomips: 69629
  Speed: 2702 MHz min/max: 800/4300 MHz Core speeds (MHz): 1: 2702 2: 800
  3: 800 4: 800 5: 800 6: 801 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 460.56
  alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c03
  class-ID: 0300
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  Screen-1: 0 s-res: 3840x1080 s-dpi: 91 s-size: 1070x301mm (42.1x11.9")
  s-diag: 1112mm (43.8")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
  diag: 609mm (24")
  Monitor-2: DP-4 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
  diag: 604mm (23.8")
  OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
  direct render: Yes
  Device-1: Intel vendor: ASRock driver: snd_hda_intel v: kernel
  bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-3: Microsoft LifeCam HD-3000 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-7:4 chip-ID: 045e:0779 class-ID: 0102
  Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
  port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: 3000
  bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
  IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
  Message: Output throttled. IPs: 19; Limit: 10; Override: --limit [1-x;-1 all]
  bus-ID: 1-9:6 chip-ID: 8087:0a2b class-ID: e001
  Message: No LVM data was found.
  Local Storage: total: 2.73 TiB used: 340.46 GiB (12.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
  rotation: SSD serial: <filter> rev: 033 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EZRZ-00Z5HB0
  rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
  ID-1: / raw-size: 465.45 GiB size: 457.14 GiB (98.22%)
  used: 340.44 GiB (74.5%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: 4ead3640-ed8d-4a0e-920e-28ee6c42fab4
  used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 3823-3631
  ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 465.45 GiB fs: ntfs label: N/A
  uuid: FA5E244B5E24034D
  ID-3: /dev/sda4 maj-min: 8:4 size: 515 MiB fs: ntfs label: N/A
  uuid: 100CAAA00CAA8078
  ID-4: /dev/sdb1 maj-min: 8:17 size: 976.56 GiB fs: ext4 label: N/A
  uuid: 6ad50a4e-89f1-4ac0-a3e6-3a6ee5350648
  ID-5: /dev/sdb2 maj-min: 8:18 size: 886.45 GiB fs: ntfs
  label: WindowsDateien uuid: 3486DF9D86DF5DC4
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-4:3 info: ROCCAT Kone Pure SE type: Mouse,HID
  driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 1e7d:2dca class-ID: 0300 serial: <filter>
  Device-2: 1-7:4 info: Microsoft LifeCam HD-3000 type: Video,Audio
  power: 500mA chip-ID: 045e:0779 class-ID: 0102
  Device-3: 1-8:5 info: Holtek USB Keyboard type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 04d9:a09c class-ID: 0300
  Device-4: 1-9:6 info: Intel Bluetooth wireless interface type: Bluetooth
  Device-5: 1-11:7 info: Alcor Micro AU6477 Card Reader Controller
  type: Mass Storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
  rev: 2.0 speed: 480 Mb/s power: 250mA chip-ID: 058f:6364 class-ID: 0300
  serial: <filter>
  Device-6: 1-13:8 info: ASRock LED Controller type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 7 rev: 3.1 speed: 10 Gb/s
  Hub-4: 2-6:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
  System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 39 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
  Processes: 313 Uptime: 41m wakeups: 0 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1454 lib: 421
  flatpak: 0 Shell: fish v: 3.1.2 default: Bash v: 5.1.0 running-in: konsole
  inxi: 3.3.03
No, how do I do this? Simply boot into grub, go to the console and enter memtest?
Edit: Ok so I read through a view posts and it seems like I can’t really use it since I have an UEFI and can’t go into a bios mode :confused:
Sorry, the messages are shown at boot so I figured posting an image is my best option since I can’t copy-paste the messages. I would edit my question, but I can’t find a way to do so :thinking:
Before you try anything else, upgrade to Kernel 5.10 LTS and see if the hardware error goes away (that’s an easy check)
If it remains:
  • Remove DIMM from bank 6 and reboot.
  • Does the hardware error go away?
    • If yes: Replace that DIMM
    • If no: what’s the new hardware error?
All the other stuff looks OK, except this:
So read this: Swap - Manjaro
sudo journalctl --system --priority=1 | grep --ignore-case hardware
:grin:
I see there are BIOS updates too for this motherboard, It could be worth a try to update it (at your own risk of course). Switching kernel to 5.10 LTS could be a proper easier solution too.
I am getting the same error , I just got a new board , a intel z590 ( asrock entreme 590) that is when The error started . At 1st I thought to try different memory kits , reseat the GPU card , reseat the CPU .
Tried every bios setting under the sun . I also get with memtest " Internal error line 169 test C
nope not a memory issue the fact that we both have Asrock Z590 boards and both have the exact same problem , indicates to me some kind of bios, firmware issue
also not a bios update issue as I am running the latest 1.4
say what cpu are you using a rocket lake or comet lake ? Me I am using a 10600kf just wondering if it is because of not running a rocket lake and the kernal is seeing things being disabled
ok the problem is with the Asrock Z590 , I just swapped back to my MSI b460 Tomahawk and all those error messages went bye bye . I am sending My Asrock Z590 Extreme back to new egg , swapping it out for a MSI Z590 Torpedo
https://www.newegg.com/p/N82E16813144390
I will update when I get the board to see if messages return
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
I am not sure if I found THE solution , why do I say this ? Because I am moving to a different chipset , a b460 chipset and the problem went away . was it the chipset or the motherboard that caused the issue ?
Did Asrock produce a buggy board or is it something in the Intel Z590 chipset ?
is it that manjaro Just cant deal with a Z590 chipset ?
I will have a definite answer to that question soon as I have a new MSI Z590 en route to try out
:man_shrugging:
I got the MSI Z590 installed with a fresh install of Manjaro , switched to the latest Kernel . 5.11 and the problem returns , not asrocks problem . I suspect it is a problem either with the Intel ME firmware or Manjaros’ kernel not seeing something … Not that I am complaining , it just too new cutting edge hardware . I am suprised that the B460 chipset worked so well
Maybe it is a kernel or BIOS issue.
I had also a similar problem with different messages after updating my BIOS once and I had to disable IOMMU in BIOS to get rid of the message on boot. It took three consecutive BIOS updates for that to eventually being fixed. Maybe it is a not so serious issue that will get fixed in later BIOS check you manufacturer for new BIOS in the future.
ok problem is solved for me , MSI just released a cpu microcode update in a beta bios , I suspect Asrock needs to do the same .
Flashed to the latest bios and poof all gone :slight_smile:
:+1: nice
