Graphics Issue After Updating Manjaro
hello everyone,
I’m new on this forum and also newbie on Manjaro Distro.
I installed and update manjaro to the latest (stable) version but after restarting, I found issue with graphics, cursor become grey square and on login screen after booting, everything is looking so weird.
Machine Information :
  Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
  root=UUID=b7303866-2ab4-4828-ac41-312b12df25cb rw rootflags=subvol=@ quiet
  udev.log_priority=3
  Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: Dell product: Latitude E6410 v: 0001 serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0HNGW4 serial: <filter> BIOS: Dell v: A17 date: 05/12/2017
  ID-1: BAT0 charge: 48.8 Wh condition: N/A/48.8 Wh volts: 12.5 min: 11.1
  model: Samsung SDI DELL PT43699 type: Li-ion serial: <filter> status: Full
  RAM: total: 3.64 GiB used: 1003.8 MiB (26.9%)
  Info: Dual Core model: Intel Core i5 M 520 bits: 64 type: MT MCP
  arch: Nehalem family: 6 model-id: 25 (37) stepping: 2 microcode: 11 cache:
  L2: 3 MiB bogomips: 19157
  Speed: 2666 MHz min/max: 1199/2400 MHz boost: enabled Core speeds (MHz):
  1: 2666 2: 2917 3: 2660 4: 2679
  Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority
  flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
  nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni popcnt pse pse36
  pti rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
  tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
  Type: l1tf
  Type: mds
  status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
  Device-1: Intel Core Processor Integrated Graphics
  vendor: Dell Latitude E6410 driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:0046 class-ID: 0300
  Device-2: Ricoh HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.4:3
  chip-ID: 05ca:1814 class-ID: 0e02
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: 0
  OpenGL: renderer: Mesa DRI Intel HD Graphics (ILK) v: 2.1 Mesa 21.1.6
  direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio
  vendor: Dell Latitude E6410 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:3b56 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6410
  driver: e1000e v: kernel port: 7040 bus-ID: 00:19.0 chip-ID: 8086:10ea
  class-ID: 0200
  Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel
  port: 7000 bus-ID: 02:00.0 chip-ID: 8086:422c class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 7020 bus-ID: 00:1f.2 chip-ID: 8086.282a rev: 05 class-ID: 0104
  Local Storage: total: 409.88 GiB used: 37.41 GiB (9.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WD3200BEKX-75B7WT0 size: 298.09 GiB block-size: physical: 512 B
  logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
  rev: 1A01 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SUV400S37120G
  size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  type: SSD serial: <filter> rev: 96R9 scheme: MBR
  ID-1: / raw-size: 50.62 GiB size: 50.62 GiB (100.00%)
  used: 12.28 GiB (24.3%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19 label: N/A
  uuid: b7303866-2ab4-4828-ac41-312b12df25cb
  ID-2: /home raw-size: 50.62 GiB size: 50.62 GiB (100.00%)
  ID-3: /run/media/mohdkhan/5094525894524120 raw-size: 61.07 GiB
  size: 61.07 GiB (100.00%) used: 25.13 GiB (41.2%) fs: ntfs dev: /dev/sdb2
  maj-min: 8:18 label: N/A uuid: 5094525894524120
  ID-4: /var/cache raw-size: 50.62 GiB size: 50.62 GiB (100.00%)
  ID-5: /var/log raw-size: 50.62 GiB size: 50.62 GiB (100.00%)
  ID-1: swap-1 type: zram size: 233 MiB used: 0 KiB (0.0%) priority: 32767
  dev: /dev/zram0
  ID-2: swap-2 type: zram size: 233 MiB used: 0 KiB (0.0%) priority: 32767
  dev: /dev/zram1
  ID-3: swap-3 type: zram size: 233 MiB used: 0 KiB (0.0%) priority: 32767
  dev: /dev/zram2
  ID-4: swap-4 type: zram size: 233 MiB used: 0 KiB (0.0%) priority: 32767
  dev: /dev/zram3
  ID-1: /dev/sda1 maj-min: 8:1 size: 118.09 GiB fs: f2fs label: Linux Data
  uuid: 0e8fe898-271e-4dde-a4e7-85c85ba036ca
  ID-2: /dev/sda4 maj-min: 8:4 size: 180 GiB fs: ntfs label: Data
  uuid: 1C77D31E565853AF
  ID-3: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs label: System Reserved
  uuid: 701A4D691A4D2D82
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
  Device-1: 1-1.4:3 info: Ricoh HD Webcam type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 05ca:1814
  class-ID: 0e02
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.1:3 info: YICHIP Wireless Device type: Keyboard,Mouse
  power: 100mA chip-ID: 3151:1002 class-ID: 0301
  Device-2: 2-1.8:4 info: Broadcom BCM5880 Secure Applications Processor
  type: Smart Card driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
  System Temperatures: cpu: 73.0 C mobo: N/A sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 4990
  Processes: 222 Uptime: 3m wakeups: 2 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 989 lib: 280 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.06
Please help me in fixing this.
https://paste.pics/954bf9948e64fd6c78d5b08100ace4ed
Welcome to the forum! :wave:
Since you’re new on this forum, I’d recommend you take a look at the link below:
Please update your post accordingly.
Please be more specific and define “weird”. There were important changes to Gnome’s appearance since the release of Gnome 40 a few update cycles ago. See the announcement thread below:
Thanks!
I’m not able to attach a pic or share a link… unable to share why I use term Weird here.
So no need to tell us again:
:wink:
The rest of your inxi looks fine…
Please read this:
:crossed_fingers:
updates with screenshot of actual issue.
Did you try changing your user icon after the issue?
Was it a default system icon, or maybe a custom image of your own coming from another disk/partition? Another disk/partition not necessarily mounted at boot, thus the grey square?
And as already said
is not really precise/helping.
its not icon. it’s cursor image change automatically after upgrading Manjaro.
Then have you tried changing the cursor in Gnome-tweaks? What is your default cursor name?
i do the same and it works for desktop but unfortunately nothing changed on Lock Screen. Also when I disable Wayland Sessions, cursor looks good but other things become miss arranged.
