Graphic troubles after first install
Hello
I just join and a lot a troubles I meet :sweat:
Now i resolved past problem with updating
But since I updated the picture/logo of the taskbar is missing even if I can click them
And it is maybe related that my second (external) screen is detected but stay black (except the cursor of mouse)
When I click identify in the settings I see it on the main screen but not on the full black external one
 Kernel: 5.15.102-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=880c4417-3731-4e84-aae6-ce2ef3420a07 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Acer product: Predator PT314-51s v: V1.02
    serial: <superuser required>
  Mobo: TGL model: Clubman_TLM v: V1.02 serial: <superuser required>
    UEFI: Insyde v: 1.02 date: 02/05/2021
  ID-1: BAT1 charge: 54.0 Wh (100.0%) condition: 54.0/60.2 Wh (89.7%)
    volts: 17.4 min: 15.5 model: SMP AP20A7N type: Li-ion serial: <filter>
    status: full cycles: 13
  RAM: total: 15.42 GiB used: 3.07 GiB (19.9%)
  Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 4053 high: 4271 min/max: 400/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4271 2: 3838 3: 4231
    4: 4130 5: 3918 6: 4088 7: 4260 8: 3691 bogomips: 52856
    arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
    cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.1
    process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
    vendor: Acer Incorporated ALI driver: nouveau v: kernel non-free: 525.xx+
    status: current (as of 2023-02) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 ports: active: HDMI-A-1 empty: none
    bus-ID: 0000:01:00.0 chip-ID: 10de:2520 class-ID: 0300
  Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 3-8:3
    chip-ID: 04f2:b6dd class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915,nouveau
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-A-1 mapped: HDMI-1-1 pos: right model: Philips 244EL
    serial: <filter> built: 2012 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 pos: primary,left model: Sharp LQ140M1JW49 built: 2020
    res: 1920x1080 hz: 144 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Device-2: NVIDIA GA106 High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Sound API: ALSA v: k5.15.102-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.22 running: no
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Wi-Fi 6 AX201 vendor: Rivet Networks driver: iwlwifi
    v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
    chip-ID: 8087:0026 class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 12.15 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-00007
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: EXF7202Q temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 12.15 GiB (1.3%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 880c4417-3731-4e84-aae6-ce2ef3420a07
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: C8B1-66E0
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 04f3:0c4f class-ID: 0000
  Device-2: 3-8:3 info: Chicony HD User Facing type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6dd
  Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 245 Uptime: 35m wakeups: 3226 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1225 libs: 320 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Please enlight me community
What can I do ? :slight_smile:
Hi @Inola, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hello Mirdarthos
Thanks for answering
I had read these articles before to publish
I tried with 3 backstick with 1 back stick with no backstick
In all cases at the moment to publish I receive a forbidding for links
I found somewhere that this is because I don’t have trust level 1
But no where explained how to get it
Apparently it could be to wait 1 week
    udev.log_priority=3
    microcode: 0xA6
    desc: 1x12 MiB
    prctl and seccomp
    direct-render: Yes
    class-ID: 0403
    class-ID: e001
Edit : now it work :slight_smile:
In one of the links I posted, there is an explanation of how to provide links:
Yes as I said I had found it before
If you read it you will notice that it is not said how to get this trust level 1
But now that it worked I guess I had to send one message first
Thank you
You have the free drivers installed, and a new graphics card. It is recommended to rather use the proprietary drivers for it:
And
Seeing as you have dual GPUs, make sure to use the hybrid drivers.
Probably…
Thank you very much !
I will try it this afternoon
Hello !
It worked for my second screen thank you
But not for the missing logos of the task bar
I can use them by letting the cursor on it and read the description
but it is less convenient :roll_eyes:
    udev.log_priority=3
  RAM: total: 15.42 GiB used: 2.21 GiB (14.3%)
    microcode: 0xA6
    desc: 1x12 MiB
  Speed (MHz): avg: 1920 high: 2836 min/max: 400/4800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2836 2: 2101 3: 1596
    4: 2351 5: 1836 6: 1785 7: 1470 8: 1392 bogomips: 52856
    prctl and seccomp
    vendor: Acer Incorporated ALI driver: nvidia v: 525.89.02
    alternate: nouveau,nvidia_drm non-free: 525.xx+
    process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Monitor-1: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 92
    size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
  Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 144 dpi: 158
    size: 309x174mm (12.17x6.85") diag: 355mm (13.96") modes: N/A
    direct-render: Yes
    class-ID: 0403
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 953.87 GiB used: 13.5 GiB (1.4%)
    lanes: 4 type: SSD serial: <filter> rev: EXF7202Q temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 13.5 GiB (1.4%)
    class-ID: e001
  Src: /sys System Temperatures: cpu: 41.0 C mobo: N/A
  Processes: 239 Uptime: 8m wakeups: 373 Init: systemd v: 252
  Packages: pm: pacman pkgs: 1232 libs: 322 tools: pamac pm: flatpak pkgs: 0
Any other idea ?
It seems like the icons cannot be found or something. Try changing them to something else. If you like it, keep it. If you don’t, try changing it back and see what happens.
To change the theme, go to the LauncherSystem SettingsAppearanceIcons.
Once there, click on Get New Icons and search for and install a new icon set in the popup window.
When done, click the Apply button to, well, apply the new theme.
If that doesn’t helps:
:man_shrugging:
Sorry!
:sob:
Unfortunately it didn’t resolved the matter
Thank you for trying !
