Hi, I recently installed manjaro, and there is no sound at all. In sound outputs, it shows only dummy sound and I cannot connect to my bluetooth earphones(it doesn’t show up in bluetooth devices) how can i fix this
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4bf49c39-63d3-4256-91fe-3bf17f3d4f9a rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Apple product: iMac18,3 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-BE088AF8C5EB4FA2
Mobo: Apple model: Mac-BE088AF8C5EB4FA2 v: iMac18,3
serial: <superuser required> UEFI: Apple v: 499.40.2.0.0 date: 08/22/2022
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 7.66 GiB used: 3.05 GiB (39.8%)
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 3500 high: 3800 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 3400 2: 3400 3: 3800
4: 3400 bogomips: 27208
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Apple driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300 temp: 57.0 C
Device-2: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 05ac:8511 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Apple iMac serial: <filter> built: 2016
res: 3840x2160 dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 3840x2160 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon RX 470 Graphics
(polaris10 LLVM 14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-2: Broadcom NetXtreme BCM57766 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
chip-ID: 14e4:1686 class-ID: 0200
IF: enp4s0f0 state: down mac: <filter>
Device-1: Apple Bluetooth USB Host Controller type: USB
driver: btusb,hid-generic,usbhid bus-ID: 1-6:5 chip-ID: 05ac:8296
class-ID: fe01
Local Storage: total: 965.05 GiB used: 9.5 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD SM0032L
size: 26.08 GiB block-size: physical: 4096 B logical: 4096 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: DXZ77A0Q temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Apple model: HDD ST1000DM003
type: HDD rpm: 7200 serial: <filter> rev: AQ04 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Blade
size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 837.89 GiB size: 823.66 GiB (98.30%) used: 9.48 GiB (1.2%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 4bf49c39-63d3-4256-91fe-3bf17f3d4f9a
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.44%)
used: 25.1 MiB (12.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: 2860-11F4
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: EFI
uuid: 5F66-17ED
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 25.78 GiB fs: apfs label: N/A
uuid: 442e9b67-fe4a-4fdb-b09b-4af1b834bc56
ID-3: /dev/sda2 maj-min: 8:2 size: 93.43 GiB fs: apfs label: N/A
ID-4: /dev/sdb1 maj-min: 8:17 size: 3.54 GiB fs: iso9660
ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 4E6A-3480
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-4:3 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-3: 1-5:4 info: Apple FaceTime HD Camera (Built-in) type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-4: 1-6:5 info: Apple Bluetooth USB Host Controller
type: Keyboard,Mouse,Bluetooth driver: btusb,hid-generic,usbhid interfaces: 6
rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8296 class-ID: fe01
Device-5: 1-10:6 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 61.0 C mobo: N/A gpu: amdgpu temp: 57.0 C
Processes: 261 Uptime: 26m wakeups: 5 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1211 libs: 311 tools: gnome-software,pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
picture:
https://paste.pics/L53VQ
