Hi everyone,
after updating to the latest Manjaro with Gnome 46, my Laptop stops switching to newly connected audio devices like my Bluetooth headphones or wired speakers. Additionally, if the device is disconnected, it always switches back to the internal speaker.
Before it switches to newly connected devices and after disconnection, it switches back to the device that was selected before. How can I get this behaviour back? I have no clue where I can start to search for a solution.
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements, which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
Weird. Been using Gnome since ver 41 and that’s been the normal behavior with my Gnome. I used the dafault PulseAudio and tried PipeWire which was buggy when switching input sources…
[EDIT] I found my issue. I have the HDMI audio out and that audio switch is NOT automatic. When plugging headphones/audio out in a combo jack it should show the pop up
Asking which connector is plugged and audio should change to it. Disconnecting it returns the audio to the build in speakers.
[UPDATE] I think this issue is a brand new bug (perhaps Gnome 46). I just unplugged my laptop so it no longer had HDMI sound out. It should just change back to speakers however I just played a youtube video and had no sound. Changed volume and the OSD said it was HDMI out. The quick settings showed NO audio source available, only the volume slider. Checked Gnome settings and said no audio out available. I plugged headphones and now it shows correctly.
I will try to reproduce and take screenshots and logs.
