Hello. I’ve been wracking my brain to get this computer to suspend, but it won’t do it. It just goes right back to the login screen. Here are the results.
journalctl --boot 0 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p" ✔
Sep 17 11:43:28 wayne-b550visiond systemd[1]: Starting System Suspend...
Sep 17 11:43:28 wayne-b550visiond systemd-sleep[5570]: Failed to find location to hibernate to: Function not implemented
Sep 17 11:43:28 wayne-b550visiond systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
Sep 17 11:43:28 wayne-b550visiond systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
Sep 17 11:43:28 wayne-b550visiond systemd[1]: Failed to start System Suspend.
Sep 17 11:43:28 wayne-b550visiond systemd[1]: Dependency failed for Suspend.
Sep 17 11:43:28 wayne-b550visiond systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
Sep 17 11:43:28 wayne-b550visiond audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Sep 17 11:43:28 wayne-b550visiond systemd-logind[530]: Operation 'sleep' finished.
Sep 17 11:43:28 wayne-b550visiond systemd[1]: Stopped target Sleep.
Sep 17 11:43:28 wayne-b550visiond kded5[1652]: bluedevil: About to resume
Sep 17 11:43:28 wayne-b550visiond ModemManager[571]: <info> [sleep-monitor] system is resuming
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.3473] manager: sleep: wake requested (sleeping: yes enabled: yes)
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.3474] device (enp80s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Sep 17 11:43:28 wayne-b550visiond kscreenlocker_greet[5534]: libpng warning: iCCP: known incorrect sRGB profile
Sep 17 11:43:28 wayne-b550visiond kernel: audit: type=1130 audit(1631904208.344:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.3765] device (enp81s0): state change: activated -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Sep 17 11:43:28 wayne-b550visiond kscreenlocker_greet[5534]: file:///usr/lib/qt/qml/QtQuick/Controls.2/ToolButton.qml: QML IconImage: Error decoding: file:///usr/share/icons/breeze-dark/actions/24@2x/edit-copy.svg: Unsupported image format
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4085] dhcp4 (enp81s0): canceled DHCP transaction
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4085] dhcp4 (enp81s0): state changed bound -> terminated
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4086] dhcp6 (enp81s0): canceled DHCP transaction
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4086] dhcp6 (enp81s0): state changed bound -> terminated
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Withdrawing address record for 10.0.0.243 on enp81s0.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Leaving mDNS multicast group on interface enp81s0.IPv4 with address 10.0.0.243.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Interface enp81s0.IPv4 no longer relevant for mDNS.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Withdrawing address record for 2601:204:ec80:100::c4e9 on enp81s0.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Withdrawing address record for 2601:204:ec80:100:f724:8b53:ad7a:73ad on enp81s0.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Leaving mDNS multicast group on interface enp81s0.IPv6 with address 2601:204:ec80:100:f724:8b53:ad7a:73ad.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Joining mDNS multicast group on interface enp81s0.IPv6 with address fe80::175f:b8e9:83e4:828e.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Registering new address record for fe80::175f:b8e9:83e4:828e on enp81s0.*.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Withdrawing address record for fe80::175f:b8e9:83e4:828e on enp81s0.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Leaving mDNS multicast group on interface enp81s0.IPv6 with address fe80::175f:b8e9:83e4:828e.
Sep 17 11:43:28 wayne-b550visiond avahi-daemon[523]: Interface enp81s0.IPv6 no longer relevant for mDNS.
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4210] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4491] manager: NetworkManager state is now DISCONNECTED
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4495] device (enp80s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Sep 17 11:43:28 wayne-b550visiond dbus-daemon[525]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=526 comm="/usr/bin/NetworkManager --no-daemon ")
Sep 17 11:43:28 wayne-b550visiond systemd[1]: Starting Network Manager Script Dispatcher Service...
Sep 17 11:43:28 wayne-b550visiond dbus-daemon[525]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Sep 17 11:43:28 wayne-b550visiond systemd[1]: Started Network Manager Script Dispatcher Service.
Sep 17 11:43:28 wayne-b550visiond audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 17 11:43:28 wayne-b550visiond kernel: audit: type=1130 audit(1631904208.454:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 17 11:43:28 wayne-b550visiond NetworkManager[526]: <info> [1631904208.4731] device (enp81s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Sep 17 11:43:28 wayne-b550visiond kscreenlocker_greet[5534]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
Sep 17 11:43:28 wayne-b550visiond kded5[1652]: plasma-nm: Not emitting connection deactivated notification as we've just woken up from suspend
Sep 17 11:43:28 wayne-b550visiond kscreenlocker_greet[5534]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Sep 17 11:43:28 wayne-b550visiond kscreenlocker_greet[5534]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/MediaControls.qml:94:9: QML Image: Binding loop detected for property "sourceSize.height"
Sep 17 11:43:28 wayne-b550visiond kscreenlocker_greet[5534]: Qt Quick Layouts: Polish loop detected. Aborting after two iterations.
Sep 17 11:43:28 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:30 wayne-b550visiond ModemManager[571]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.2/0000:03:08.0/0000:4c:00.0/0000:4d:05.0/0000:50:00.0': not supported by any plugin
Sep 17 11:43:30 wayne-b550visiond ModemManager[571]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.2/0000:03:08.0/0000:4c:00.0/0000:4d:07.0/0000:51:00.0': not supported by any plugin
Sep 17 11:43:31 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:31 wayne-b550visiond kernel: igb 0000:51:00.0 enp81s0: igb: enp81s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0958] device (enp81s0): carrier: link connected
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0960] device (enp81s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0969] policy: auto-activating connection 'Wired connection 2' (9188e0e1-4536-3412-b13c-e4e15757dd0c)
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0971] device (enp81s0): Activation: starting connection 'Wired connection 2' (9188e0e1-4536-3412-b13c-e4e15757dd0c)
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0972] device (enp81s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0973] manager: NetworkManager state is now CONNECTING
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0973] device (enp81s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0978] device (enp81s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.0979] dhcp4 (enp81s0): activation: beginning transaction (timeout in 45 seconds)
Sep 17 11:43:32 wayne-b550visiond kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp81s0: link becomes ready
Sep 17 11:43:32 wayne-b550visiond avahi-daemon[523]: Joining mDNS multicast group on interface enp81s0.IPv6 with address fe80::175f:b8e9:83e4:828e.
Sep 17 11:43:32 wayne-b550visiond avahi-daemon[523]: New relevant interface enp81s0.IPv6 for mDNS.
Sep 17 11:43:32 wayne-b550visiond avahi-daemon[523]: Registering new address record for fe80::175f:b8e9:83e4:828e on enp81s0.*.
Sep 17 11:43:32 wayne-b550visiond kded5[1652]: plasma-nm: Unhandled active connection state change: 1
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1195] dhcp4 (enp81s0): state changed unknown -> bound, address=10.0.0.243
Sep 17 11:43:32 wayne-b550visiond avahi-daemon[523]: Joining mDNS multicast group on interface enp81s0.IPv4 with address 10.0.0.243.
Sep 17 11:43:32 wayne-b550visiond avahi-daemon[523]: New relevant interface enp81s0.IPv4 for mDNS.
Sep 17 11:43:32 wayne-b550visiond avahi-daemon[523]: Registering new address record for 10.0.0.243 on enp81s0.IPv4.
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1202] device (enp81s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1214] device (enp81s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1214] device (enp81s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1216] manager: NetworkManager state is now CONNECTED_LOCAL
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1217] manager: NetworkManager state is now CONNECTED_SITE
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1218] policy: set 'Wired connection 2' (enp81s0) as default for IPv4 routing and DNS
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.1270] device (enp81s0): Activation: successful, device activated.
Sep 17 11:43:32 wayne-b550visiond kded5[1652]: plasma-nm: Not emitting connection activated notification as the connection was active prior to suspend
Sep 17 11:43:32 wayne-b550visiond kded5[1652]: plasma-nm: Network connectivity limited, scheduling notification
Sep 17 11:43:32 wayne-b550visiond NetworkManager[526]: <info> [1631904212.5193] manager: NetworkManager state is now CONNECTED_GLOBAL
Sep 17 11:43:33 wayne-b550visiond NetworkManager[526]: <info> [1631904213.7818] dhcp6 (enp81s0): activation: beginning transaction (timeout in 45 seconds)
Sep 17 11:43:33 wayne-b550visiond avahi-daemon[523]: Leaving mDNS multicast group on interface enp81s0.IPv6 with address fe80::175f:b8e9:83e4:828e.
Sep 17 11:43:33 wayne-b550visiond avahi-daemon[523]: Joining mDNS multicast group on interface enp81s0.IPv6 with address 2601:204:ec80:100:f724:8b53:ad7a:73ad.
Sep 17 11:43:33 wayne-b550visiond avahi-daemon[523]: Registering new address record for 2601:204:ec80:100:f724:8b53:ad7a:73ad on enp81s0.*.
Sep 17 11:43:33 wayne-b550visiond avahi-daemon[523]: Withdrawing address record for fe80::175f:b8e9:83e4:828e on enp81s0.
Sep 17 11:43:33 wayne-b550visiond NetworkManager[526]: <info> [1631904213.7824] policy: set 'Wired connection 2' (enp81s0) as default for IPv6 routing and DNS
Sep 17 11:43:33 wayne-b550visiond NetworkManager[526]: <info> [1631904213.7947] dhcp6 (enp81s0): state changed unknown -> bound, address=2601:204:ec80:100::c4e9
Sep 17 11:43:33 wayne-b550visiond avahi-daemon[523]: Registering new address record for 2601:204:ec80:100::c4e9 on enp81s0.*.
Sep 17 11:43:34 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:35 wayne-b550visiond audit[5661]: USER_AUTH pid=5661 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="wayne" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Sep 17 11:43:35 wayne-b550visiond kernel: audit: type=1100 audit(1631904215.301:97): pid=5661 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="wayne" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Sep 17 11:43:35 wayne-b550visiond kscreenlocker_greet[5534]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
Sep 17 11:43:35 wayne-b550visiond kscreenlocker_greet[5534]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/VirtualKeyboard.qml:45: TypeError: Cannot read property 'height' of null
Sep 17 11:43:35 wayne-b550visiond kwin_x11[1656]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18637, resource id: 111149151, major code: 18 (ChangeProperty), minor code: 0
Sep 17 11:43:37 wayne-b550visiond kwin_x11[1656]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 20276, resource id: 31457564, major code: 14 (GetGeometry), minor code: 0
Sep 17 11:43:37 wayne-b550visiond kwin_x11[1656]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 20277, resource id: 31457566, major code: 14 (GetGeometry), minor code: 0
Sep 17 11:43:37 wayne-b550visiond kwin_x11[1656]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 20278, resource id: 31457568, major code: 14 (GetGeometry), minor code: 0
Sep 17 11:43:37 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:38 wayne-b550visiond systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Sep 17 11:43:38 wayne-b550visiond audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 17 11:43:38 wayne-b550visiond kernel: audit: type=1131 audit(1631904218.531:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 17 11:43:40 wayne-b550visiond kwin_x11[1656]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24252, resource id: 39848954, major code: 15 (QueryTree), minor code: 0
Sep 17 11:43:40 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:43 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:46 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:49 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:52 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
Sep 17 11:43:55 wayne-b550visiond plasmashell[1719]: qml: temp unit: 0
