@megavolt Yeah it’s a long one…
https://0x0.st/-3_r.txt
So ok… now I see that the problem is the amdgpu module. Here is problematic part:
Sep 18 22:57:59 kernel: amdgpu 0000:55:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state!
Sep 18 22:57:59 kernel: amdgpu 0000:55:00.0: amdgpu: Failed to enable gfxoff!
Sep 18 22:58:09 kernel: [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 18 22:58:09 kernel: [drm:set_pixel_clock_v7 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Sep 18 22:58:09 kernel: [drm] free PSP TMR buffer
Sep 18 22:58:09 kernel: amdgpu 0000:55:00.0: amdgpu: MODE1 reset
Sep 18 22:58:09 kernel: amdgpu 0000:55:00.0: amdgpu: GPU smu mode1 reset
Sep 18 22:58:09 kernel: amdgpu 0000:55:00.0: amdgpu: Msg issuing pre-check failed and SMU may be not in the right state!
Sep 18 22:58:09 kernel: amdgpu 0000:55:00.0: amdgpu: GPU mode1 reset failed
Sep 18 22:58:09 kernel: PM: pci_pm_freeze(): amdgpu_pmops_freeze+0x0/0x40 [amdgpu] returns -5
Sep 18 22:58:09 kernel: PM: dpm_run_callback(): pci_pm_freeze+0x0/0xb0 returns -5
Sep 18 22:58:09 kernel: PM: Device 0000:55:00.0 failed to freeze async: error -5
Sep 18 22:58:09 kernel: amdgpu: Move buffer fallback to memcpy unavailable
Sep 18 22:58:09 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to process the buffer list -19!
I am not sure, but it seems to be a bug here.
Try to disable dpm (dynamic power management) by adding amdgpu.dpm=0
to the kernel parameter.
Open the grub config:
sudo nano /etc/default/grub
and add amdgpu.dpm=0
to the variable GRUB_CMDLINE_LINUX_DEFAULT=
Then run sudo update-grub
and reboot
You can set the performance like that manually for now:
echo "high" | sudo tee -a /sys/class/drm/card0/device/power_dpm_force_performance_level
echo "low" | sudo tee -a /sys/class/drm/card0/device/power_dpm_force_performance_level
It looks like that the problem is related to this open bug: [navi2][5.10.20] amdgpu module crash on RX 6900 XT card (#1519) · Issues · drm / amd
However… maybe try kernel 5.4, since there are 4k pages used and not 64k, which seems to be a problem with this specific chipset.
sudo mhwd-kernel --install linux54
and choose on boot at the grub menu this kernel.
You missed a step and your kernel parameters should have resume=UUID=44259802-2967-44c7-b17f-49f8843585b4
(that’s yours)
Search for that here on the forum.
Thanks @Fabby but the OP is asking for suspend and not hibernate. So that is in this case useless If suspend (only RAM) does not work, then hibernate (only swap) will not work either.
@megavolt I just tried everything you suggested, and the computer was stuck booting at that screen where it’s calculating the amount of files and the data.
REISUB and provide the following output:
journalctl --system --boot=0 --priority=err | tail --lines=35
Welp. I had to reinstall Manjaro and I’ve redone everything up to including the swap partition int he fstab file. I should also note that in the Ubuntu live USB, I had the same issues.
@Fabby Okay I’m more or less up to speed on the steps again. It looks like it was the kernel that caused the issue. Here’s what I got.
-- Journal begins at Sun 2021-09-19 14:36:13 PDT, ends at Sun 2021-09-19 15:41:02 PDT. --
Sep 19 15:40:40 wayne-b550visiond kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Sep 19 15:40:41 wayne-b550visiond kernel: sd 6:0:0:0: [sdb] No Caching mode page found
Sep 19 15:40:41 wayne-b550visiond kernel: sd 6:0:0:0: [sdb] Assuming drive cache: write through
Sep 19 15:40:42 wayne-b550visiond kernel: scsi 6:0:0:1: Wrong diagnostic page; asked for 1 got 8
Sep 19 15:40:42 wayne-b550visiond kernel: scsi 6:0:0:1: Failed to get diagnostic page 0x1
Sep 19 15:40:42 wayne-b550visiond kernel: scsi 6:0:0:1: Failed to bind enclosure -19
Sep 19 15:40:42 wayne-b550visiond systemd-udevd[405]: event2: Failed to call EVIOCSKEYCODE with scan code 0xc022d, and key code 103: Invalid argument
Sep 19 15:40:42 wayne-b550visiond systemd-udevd[405]: event2: Failed to call EVIOCSKEYCODE with scan code 0xc022e, and key code 108: Invalid argument
Can I have:
- a new full inxi?
- The exact command you used to produce that output.
@Fabby You got it. Here’s what it produces.
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=664ecb8b-0eeb-4852-807e-bba3daad7365 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B550 VISION D v: -CF
serial: <filter>
Mobo: Gigabyte model: B550 VISION D serial: <filter>
UEFI: American Megatrends LLC. v: F13g date: 03/25/2021
RAM: total: 62.74 GiB used: 2.7 GiB (4.3%)
Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 4 MiB bogomips: 121412
Speed: 2869 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2869 2: 2867 3: 2875 4: 3591 5: 2872 6: 2874 7: 2868 8: 2873 9: 2874
10: 3587 11: 3583 12: 2874 13: 2874 14: 2874 15: 3084 16: 2873
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 55:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: EVGA EVGA XR1 Capture Box type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-2:2 chip-ID: 3842:3103 class-ID: 0102 serial: <filter>
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x2160 s-dpi: 96 s-size: 1185x571mm (46.7x22.5")
s-diag: 1315mm (51.8")
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 240 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-3: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 166
size: 294x165mm (11.6x6.5") diag: 337mm (13.3")
OpenGL: renderer: AMD Radeon RX 6900 XT (SIENNA_CICHLID DRM 3.41.0
5.13.15-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 55:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 57:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Conexant Systems (Rockwell) Hi-Res Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-8:8 chip-ID: 0572:1b09
class-ID: 0300 serial: <filter>
Device-4: EVGA EVGA XR1 Capture Box type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: e000 bus-ID: 50:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp80s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: d000 bus-ID: 51:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp81s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000
bus-ID: 52:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp82s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6.1:7 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 20.01 TiB used: 4.71 TiB (23.6%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 62.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST10000NM001G-2MW103
size: 9.1 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN03 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD My Book 25EE size: 9.1 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 4009 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: BW-16D1HT rev: 3.10 dev-links: cdrom
ID-1: / raw-size: 732.42 GiB size: 719.86 GiB (98.28%)
used: 14.38 GiB (2.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 664ecb8b-0eeb-4852-807e-bba3daad7365
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 24.9 MiB (12.7%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
label: WINEFI uuid: 64D7-0DE0
ID-3: /run/media/wayne/Gaming raw-size: 5.72 TiB size: 5.72 TiB (100.00%)
used: 1.78 TiB (31.1%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Gaming
uuid: 6466086B66083FF2
ID-4: /run/media/wayne/Linux Data raw-size: 3.31 TiB size: 3.26 TiB (98.40%)
used: 291.01 GiB (8.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
label: Linux Data uuid: c90b7810-45c2-4f04-8689-cd0254bf3e39
ID-5: /run/media/wayne/My Book raw-size: 9.1 TiB size: 9.1 TiB (100.00%)
used: 2.63 TiB (29.0%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: My Book
uuid: A4D445EBD445BFF2
ID-1: swap-1 type: partition size: 67.05 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 84202edf-dc62-4db5-97f7-8aca784bbd62
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: C11E-6C02
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 1.1 TiB fs: ntfs label: Windows
uuid: 5D85DC3C2CE42FC7
ID-4: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
Hub-2: 1-4:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-4.4:4 info: Alcor Micro Multi Flash Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
Device-2: 1-5:3 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-3: 1-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.1:7 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-7:6 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-3: 1-8:8 info: Conexant Systems (Rockwell) Hi-Res Audio
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 28mA chip-ID: 0572:1b09 class-ID: 0300
serial: <filter>
Hub-4: 1-10:9 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-10.3:10 info: Cooler Master ARGB Box type: HID,Keyboard
power: 100mA chip-ID: 2516:1011 class-ID: 0300 serial: <filter>
Device-2: 1-10.4:11 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: EVGA EVGA XR1 Capture Box type: Video,Audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 3.0 speed: 5 Gb/s
power: 600mA chip-ID: 3842:3103 class-ID: 0102 serial: <filter>
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-2:2 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0
type: Keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s power: 100mA chip-ID: 045e:00db class-ID: 0300
Hub-9: 5-3:3 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
Device-1: 5-4:4 info: Tablet Monitor type: Mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006d
class-ID: 0300
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Device-1: 6-1:2 info: Western Digital My Book 25EE type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
chip-ID: 1058:25ee class-ID: 0806 serial: <filter>
Hub-11: 6-3:3 info: Genesys Logic USB3.1 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 50.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 396 Uptime: 4m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1361 lib: 370
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
Also, the command that gave me those lines you saw earlier was
Please read this:
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”.
5.13 was the previous Stable Development kernel, so that’s about the worst kernel you can choose to do a Root Cause Analysis (RCA)
Problem solved! I figured out that my BIOS was causing the issue. I downgraded it to F12 and all is now well.
I’ve edited your title so that the next person that has a Gigabyte product: B550
can find your solution too
