Alpaca
26 December 2021 11:45
1
Almost at random I get full system freezes.
When this happens, my screen will freeze but audio keeps playing for ~1-2 seconds.
after that it still displays the last image, but I am unable to move my cursor, or enter tty (ctrl+alt+f2).
Any help with this issue would be much appreciated.
The cause can be anything - to try
Ensure you have configured at least 2G swap.
Ensure your system is fully updated
Ensure you are using the correct display driver.
Alpaca
26 December 2021 12:04
3
Where should I do this?
All my packages are up-to-date
In system settings I clicked Auto Install Proprietary Driver (Nvidia)
This only installs video-hybrid-amd-nvidia-prime, video-linux, video-modesetting and video-vesa.
Should I install the others as well?
*note, I have a gtx 1060 and a ryzen 2400g.
Alpaca
26 December 2021 12:07
6
Frede Hundewadt:
Swap - Manjaro
If you use hibernation: yes, you need swap!
This might be the issue, I’ll try this.
Hi @Alpaca , and welcome!
Please see [HowTo] Provide System Information and, if applicable, see [HowTo] Post screenshots and links .
If/when this happens again, please provide the output for
sudo journalctl --boot=-1
Alpaca
26 December 2021 12:23
8
Frede Hundewadt:
Swap - Manjaro
I’ve created a 20gb (16gb with hibernation) swapfile according to the guide. Let’s hope this helps
I’ll post the logs when it happens again.
Alpaca
26 December 2021 16:22
9
It happened again, this time audio kept playing for a lot longer though.
Here are the logs from journalctl:
-- Journal begins at Sat 2021-12-04 22:40:13 CET, ends at Sun 2021-12-26 17:18:09 CET. --
dec 26 12:31:36 user-ab350ngamingwifi kernel: Linux version 5.15.7-1-MANJARO (builduser@fv-az131-228) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021
dec 26 12:31:36 user-ab350ngamingwifi kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=751ae332-d6cc-49c0-b810-34ddc96fc63c rw quiet udev.log_priority=3
dec 26 12:31:36 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
dec 26 12:31:36 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
dec 26 12:31:36 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
dec 26 12:31:36 user-ab350ngamingwifi kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
dec 26 12:31:36 user-ab350ngamingwifi kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
dec 26 12:31:36 user-ab350ngamingwifi kernel: signal: max sigframe size: 1776
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-provided physical RAM map:
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000004000000-0x000000000400ffff] ACPI NVS
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000004010000-0x0000000009cfffff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000009d00000-0x0000000009ffffff] reserved
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000affffff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000b020000-0x000000007bb36fff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bb37000-0x000000007bc81fff] reserved
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bc82000-0x000000007bd75fff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bd76000-0x000000007c148fff] ACPI NVS
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007c149000-0x000000007cf9dfff] reserved
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007cf9e000-0x000000007effffff] usable
dec 26 12:31:36 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007f000000-0x00000000bfffffff] reserved
Happened again shortly after
-- Journal begins at Sat 2021-12-04 22:40:13 CET, ends at Sun 2021-12-26 17:36:26 CET. --
dec 26 17:17:35 user-ab350ngamingwifi kernel: Linux version 5.15.7-1-MANJARO (builduser@fv-az131-228) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021
dec 26 17:17:35 user-ab350ngamingwifi kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=751ae332-d6cc-49c0-b810-34ddc96fc63c rw quiet udev.log_priority=3
dec 26 17:17:35 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
dec 26 17:17:35 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
dec 26 17:17:35 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
dec 26 17:17:35 user-ab350ngamingwifi kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
dec 26 17:17:35 user-ab350ngamingwifi kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
dec 26 17:17:35 user-ab350ngamingwifi kernel: signal: max sigframe size: 1776
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-provided physical RAM map:
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000004000000-0x000000000400ffff] ACPI NVS
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000004010000-0x0000000009cfffff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000009d00000-0x0000000009ffffff] reserved
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000affffff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000b020000-0x000000007bb36fff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bb37000-0x000000007bc81fff] reserved
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bc82000-0x000000007bd75fff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bd76000-0x000000007c148fff] ACPI NVS
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007c149000-0x000000007cf9dfff] reserved
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007cf9e000-0x000000007effffff] usable
dec 26 17:17:35 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007f000000-0x00000000bfffffff] reserved
Alpaca
27 December 2021 13:36
10
Should I continue posting logs?
Sadly enough I have plenty
I had exactly the same problem.
When I moved the Keyboard and Mouse from USB 3.0 ports to a USB 2.0 hub the problem went away.
I suspect the USB 3.0 driver has issues.
Please do, I have no inspiration at the moment, except modify the command a little biit. Instead of:
rather use,
sudo journalctl --reverse --lines=50 --boot=-1
Edit:
@bpaddock ’s ‘suggestion’ is as good as any. Feel free to try it, if applicable. I’ve got no other suggestions. I’m stumped.
Alpaca
27 December 2021 18:34
13
Didn’t work
-- Journal begins at Tue 2021-12-07 09:37:06 CET, ends at Mon 2021-12-27 19:30:07 CET. --
dec 27 19:28:16 user-ab350ngamingwifi rtkit-daemon[1221]: Supervising 9 threads of 4 processes of 1 users.
dec 27 19:28:08 user-ab350ngamingwifi rtkit-daemon[1221]: Supervising 9 threads of 4 processes of 1 users.
dec 27 19:27:57 user-ab350ngamingwifi rtkit-daemon[1221]: Supervising 9 threads of 4 processes of 1 users.
dec 27 19:27:52 user-ab350ngamingwifi plasmashell[1168]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:15:1: QML Panel: Binding loop detected for property "state"
dec 27 19:26:43 user-ab350ngamingwifi plasmashell[1168]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:15:1: QML Panel: Binding loop detected for property "state"
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58471, resource id: 10485982, major code: 10 (UnmapWindow), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58470, resource id: 10485982, major code: 2 (ChangeWindowAttributes), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58469, resource id: 10485982, major code: 6 (ChangeSaveSet), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58468, resource id: 10485982, major code: 7 (ReparentWindow), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58467, resource id: 10485982, major code: 19 (DeleteProperty), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58466, resource id: 10485982, major code: 19 (DeleteProperty), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58465, resource id: 10485982, major code: 19 (DeleteProperty), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58464, resource id: 10485982, major code: 18 (ChangeProperty), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58463, resource id: 10485982, major code: 19 (DeleteProperty), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi kwin_x11[1100]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58460, resource id: 10485982, major code: 19 (DeleteProperty), minor code: 0
dec 27 19:25:59 user-ab350ngamingwifi rtkit-daemon[1221]: Supervising 9 threads of 4 processes of 1 users.
dec 27 19:25:54 user-ab350ngamingwifi rtkit-daemon[1221]: Supervising 9 threads of 4 processes of 1 users.
dec 27 19:25:54 user-ab350ngamingwifi plasmashell[1168]: org.kde.plasma.notifications: Trying to replace notification with id 1744 which doesn't exist, creating a new one. This is an application bug!
dec 27 19:25:53 user-ab350ngamingwifi plasmashell[1168]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:15:1: QML Panel: Binding loop detected for property "state"
dec 27 19:25:51 user-ab350ngamingwifi rtkit-daemon[1221]: Supervising 9 threads of 4 processes of 1 users.
my guess is that you probably have some troublesome widget installed which is causing issue to kwin
similar issue
Alpaca
27 December 2021 19:15
16
Type: Desktop System: Gigabyte product: AB350N-Gaming WIFI v: N/A
serial: N/A
Mobo: Gigabyte model: AB350N-Gaming WIFI-CF v: x.x serial: N/A
UEFI-[Legacy]: American Megatrends v: F21 date: 02/08/2018
RAM: total: 14.65 GiB used: 6.04 GiB (41.2%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 size: 8 GiB speed: 3000 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: G.Skill part-no: F4-3000C16-8GISB serial: N/A
Device-2: DIMM 1 size: No Module Installed
Device-3: DIMM 0 size: 8 GiB speed: 3000 MT/s type: DDR4
Device-4: DIMM 1 size: No Module Installed
Info: model: AMD Ryzen 5 2400G with Radeon Vega Graphics socket: AM4
bits: 64 type: MT MCP arch: Zen family: 0x17 (23) model-id: 0x11 (17)
stepping: 0 microcode: 0x8101007
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2937 high: 3600 min/max: 1600/3600 boost: enabled
base/boost: 3600/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.5 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
5: 3600 6: 2300 7: 1600 8: 1600 bogomips: 57512
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 0b:00.0 chip-ID: 1002:15dd
class-ID: 0300
Display: server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 965x271mm (38.0x10.7")
s-diag: 1002mm (39.5")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-2: DP-0 res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 0b:00.1 chip-ID: 1002:15de class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 07:00.0
chip-ID: 8086:3165 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI modules: r8169 port: e000
bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
bus-ID: 1-10:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 2.74 TiB used: 2.43 TiB (88.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 36.9 C scheme: MBR
SMART: yes health: PASSED on: 26d 17h cycles: 522
read-units: 2,920,920 [1.49 TB] written-units: 2,456,353 [1.25 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
family: BarraCuda 3.5 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: CC26 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 56d 2h cycles: 4757
read: 194.73 TiB written: 29.94 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800
family: based SSDs size: 476.94 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 8B temp: 20 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 302d 9h cycles: 3911
read: 21.28 TiB written: 57.98 TiB
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 224.03 GiB (49.0%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 751ae332-d6cc-49c0-b810-34ddc96fc63c
ID-2: /mnt/2tbhdd raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.78 TiB (97.8%) fs: ntfs block-size: 4096 B dev: /dev/sda4
maj-min: 8:4 label: N/A uuid: A6D2964FD2962419
ID-3: /mnt/ssd raw-size: 476.37 GiB size: 476.37 GiB (100.00%)
used: 437.77 GiB (91.9%) fs: ntfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18 label: N/A uuid: 20227B49227B2348
ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: Recovery
uuid: 5E9A92709A924505
ID-2: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: vfat label: N/A
uuid: 7894-259F
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sdb1 maj-min: 8:17 size: 579 MiB fs: ntfs
label: System Reserved uuid: 0A4276144276052B
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-4:2 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-2: 1-8:3 info: Cooler Master MasterKeys Pro L type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 2516:003b class-ID: 0300
Device-3: 1-9:4 info: Logitech G203 LIGHTSYNC Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
Device-4: 1-10:5 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 59 C fan: 0% device: amdgpu
temp: 48.0 C
Processes: 300 Uptime: 42m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1619 pacman: 1607 lib: 483
flatpak: 12 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.12
running-in: yakuake inxi: 3.3.11
How should I figure out which widget it might be?
It’s not recommended having both running at the same time. Choose one.
Alpaca
27 December 2021 19:25
18
Should I disable PulseAudio using systemctl?
That’s a way, yes.
systemctl disable pulseaudio.service
Alpaca
27 December 2021 19:57
20
I get:
$sudo systemctl disable pulseaudio.service
Failed to disable unit: Unit file pulseaudio.service does not exist.
