no need to disable pulseaudio. if you want to switch to pipewire just install manjaro-pipewire
and enter yes for every conflict.
That worked, now itâs only running pipewire.
shouldnât it be running pipewire instead
fixed
-- Journal begins at Tue 2021-12-07 09:38:02 CET, ends at Mon 2021-12-27 21:56:00 CET. --
dec 27 21:53:24 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:23 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:22 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:21 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:20 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:19 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:10 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:08 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
dec 27 21:53:05 user-ab350ngamingwifi rtkit-daemon[1435]: Supervising 14 threads of 10 processes of 1 users.
dec 27 21:53:05 user-ab350ngamingwifi rtkit-daemon[1435]: Successfully made thread 11197 of process 11013 owned by '1000' RT at priority 10.
dec 27 21:53:05 user-ab350ngamingwifi rtkit-daemon[1435]: Supervising 13 threads of 9 processes of 1 users.
dec 27 21:53:00 user-ab350ngamingwifi rtkit-daemon[1435]: Supervising 13 threads of 9 processes of 1 users.
dec 27 21:52:59 user-ab350ngamingwifi systemsettings5[3960]: file:///usr/share/kpackage/kcms/kcm_pulseaudio/contents/ui/StreamListItem.qml:22: TypeError: Cannot read property 'width' of null
-- Journal begins at Tue 2021-12-07 09:38:02 CET, ends at Mon 2021-12-27 21:59:50 CET. --
dec 27 21:02:25 user-ab350ngamingwifi kernel: Linux version 5.15.7-1-MANJARO (builduser@fv-az131-228) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 8 10:09:19 UTC 2021
dec 27 21:02:25 user-ab350ngamingwifi kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=751ae332-d6cc-49c0-b810-34ddc96fc63c rw quiet udev.log_priority=3
dec 27 21:02:25 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
dec 27 21:02:25 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
dec 27 21:02:25 user-ab350ngamingwifi kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
dec 27 21:02:25 user-ab350ngamingwifi kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
dec 27 21:02:25 user-ab350ngamingwifi kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
dec 27 21:02:25 user-ab350ngamingwifi kernel: signal: max sigframe size: 1776
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-provided physical RAM map:
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d3ff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000009d400-0x000000000009ffff] reserved
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000004000000-0x000000000400ffff] ACPI NVS
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000004010000-0x0000000009cfffff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x0000000009d00000-0x0000000009ffffff] reserved
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000affffff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000000b020000-0x000000007bb36fff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bb37000-0x000000007bc81fff] reserved
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bc82000-0x000000007bd75fff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007bd76000-0x000000007c148fff] ACPI NVS
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007c149000-0x000000007cf9dfff] reserved
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007cf9e000-0x000000007effffff] usable
dec 27 21:02:25 user-ab350ngamingwifi kernel: BIOS-e820: [mem 0x000000007f000000-0x00000000bfffffff] reserved
Should I consider abandoning this install?
I donât know. I donât think anyone can answer that. I will say, however, that sometimes itâs easier and quicker.
I have done it myself. With excellent results. My current Manjaro installation is because I abandoned my previous one. Just got fed up one day with a problem I was having and decided to reinstall.
Last thing I can recommend you check, is see if you have any unmerged .pacnew
files:
sudo DIFFPROG=meld pacdiff
Also, make sure you are using an LTS kernel. IIRC your current kernel is 5.15
, which is the latest LTS, but just for thoroughnessâ sake, try 5.10
and/or 5.4
as well. Who knows? It might make a difference.
