Fslint-gui searches do not work
Hi there,
after installing fslint and trying my first search the program would complain, that ist cant find:
“/usr/share/fslint/fslint/”
the last directory was missing, so i created it manually.
Now when I want to search for dupliactes i get:
“/bin/sh: Zeile 1: ./findnl: Datei oder Verzeichnis nicht gefunden”
and similar lines searching for Bad Names etc.
any idea how to fix this?
Thanks for reading
AUR package - consult the maintainer
Hi @FluffyMcDuckface, and welcome!
According to this page, the full error was probably something like:
Traceback (most recent call last): File “/usr/bin/fslint-gui”, line 27, in import gtk ImportError: No module named gtk
But there’s no way to be sure, and without more information, we’re shooting in the dark here. Please see [HowTo] Provide System Information, [HowTo] Post screenshots and links and [HowTo] Request support for more information and help to provide the required information.
What did you actually install?
fslint
or
fslint-gui
How did you install it?
(because just did - and it works for me no problem …)
What command did you use here - to get this output/this message?
Please start the program from a terminal - and like this:
LANG=C fslint
or
LANG=C fslint-gui
so that the output will be in english.
I installed
fslint-gui
I used Pamac, with the graphical UI
the GUI of fslint starts fine. I get the output after pressing “Find”
Trying to search Duplicates gets me:
/bin/sh: line 1: ./findup: No such file or directory
Bad names:
/bin/sh: line 1: ./findnl: No such file or directory
Name clashes:
/bin/sh: line 1: ./findsn: No such file or directory
I don’t know if its important:
starting fslint-gui from terminal with
LANG=C fslint-gui
works also, but shows also this:
(fslint-gui:12648): Gtk-WARNING **: 18:22:38.388: Unable to locate theme engine in module_path: “murrine”,
What I find strange is that all the error messages
(which I do not get)
are starting with:
/bin/sh: line 1: ...
even though all the scripts that the program uses are bash scripts
and all but one start with:
#!/bin/bash
so I don’t know why /bin/sh is what the error starts with
(have you done something to your shell environment variable - aliased it to something …?
idk …)
Just something I noticed.
I have used this program before - it always worked nicely.
And I just installed it in this my installation, which did not have it yet.
and it works - as I’m used to.
Can’t really help - sorry.
I had the same problem and the issue was that I did only install fslint-gui. After installing fslint too, everything worked fine.
:warning:
Don’t use fslint or fslint-gui anymore. :-1:
Use czkawka-gui-bin. :+1:
It’s available on the AUR.
https://forum.manjaro.org/t/favorite-lesser-known-apps/5481/91?u=winnie
the name is a bit … unintuitive
(it doesn’t readily give away what the program does/is for)
but, yes: right on!
Thanks, this worked. Strange that in fslint-gui it does not say anywhere that fslint needs to be nstalled…
Should be added as a dependency, but that is a job for the developer obviously.
You need to install both fslint and fslint-gui and then it works.
