Failed to start Thermal Daemon Service
Hi there.
I updated my main PC yesterday & everything was going fine until this morning. I tried & failed to reboot after updating a couple of AUR packages & received the following warning: Failed to start Thermal Daemon Service.
The AUR packages I updated I have been using a long time & they are well supported. I have searched online for a solution but not found it so far. I have tried rebooting with 3 different kernels but this has not helped. Any assistance would be very much appreciated.
Thanks,
Ruziel :wink:
Hi @ruziel,
In addition to your basic information, which you failed to provide, please also provide the output for:
systemctl list-units --state=failed
Hi @Mirdarthos
Thanks for your note. I am using an Intel machine running Manjaro Xfce on the Stable branch, with 6.6 LTS kernel - I have two others for back-up. Please let me know what other basic information will be useful.
I am unsure how to provide the output for the command you suggested, as I cannot boot up my system. Apologies, I have been using Manjaro a long time & hardly ever have an issue - my knowledge/skills are very limited.
If there is a link with steps for me to follow, I am happy to spend time with that. I appreciate your assistance.
Thanks, Ruziel
Hi @ruziel,
The basic info I was referring to was this:
At bare minimum we would need you to please provide a detailed description of the problem faced, as well as the output to:
inxi --filter --verbosity=8
You also only mentioned you receiving the message and failed to mention you are unable to boot. So now I think this should be done in a chroot environment.
So enter a chroot environment, and post the output of:
…please.
How to chroot
  1. Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
  2. Write/copy/dd the ISO to a USB thumb drive.
  3. When done, boot with the above mentioned USB thumb drive into the live environment.
  4. Once booted, open a terminal and enter the following command to enter the chroot environment:
manjaro-chroot -a
  1. If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
For more:
Note that the above text is partially pre-prepared as a general introduction for new users. Please take the time to follow the given links and learn more.
Please also take note that these instructions will not work for/on a BTRFS file-system. For that, see:
Thanks for this - I will have to attempt this later today after work. Much appreciated.
Hi @Mirdarthos - thanks again for your assistance.
The output of “inxi --filter --verbosity=8@” is as follows…
[manjaro /]# inxi --filter --verbosity=8
12System:
  12Kernel 6.9.12-3-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 14.2.1 12clocksource tsc
    12avail hpet,acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCEM_2407 quiet systemd.show_status=1 splash apparmor=1
    security=apparmor driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop Xfce 12v N/A 12wm xfwm4 12with xfce4-panel 12tools xfce4-screensaver
    12avail light-locker,xscreensaver 12dm N/A 12Distro Manjaro 12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Micro-Star 12model Z370-A PRO (MS-7B48) 12v 1.0 12serial <filter>
    12uuid 00000000-0000-0000-0000-309c2382dd10 12UEFI American Megatrends 12v 2.20 12date 10/27/2017
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12System RAM 12total 32 GiB 12available 31.27 GiB 12used 1.61 GiB (5.2%) 12igpu 32 MiB
  12Array-1 12capacity 64 GiB 12slots 4 12modules 4 12EC None 12max-module-size 16 GiB 12note est.
  12Device-1 ChannelA-DIMM0 12type DDR4 12detail synchronous unbuffered (unregistered) 12size 8 GiB
    12speed 2933 MT/s 12volts 12curr 1.35 12width (bits) 12data 64 12total 64 12manufacturer Corsair
    12part-no CMR32GX4M4C3000C15 12serial N/A
  12Device-2 ChannelA-DIMM1 12type DDR4 12detail synchronous unbuffered (unregistered) 12size 8 GiB
  12Device-3 ChannelB-DIMM0 12type DDR4 12detail synchronous unbuffered (unregistered) 12size 8 GiB
  12Device-4 ChannelB-DIMM1 12type DDR4 12detail synchronous unbuffered (unregistered) 12size 8 GiB
12PCI Slots:
  12Slot 0 12type PCIe 12status in use 12info J6B2 12length long 12volts 3.3 12bus-ID 00:01.0
  12Slot 1 12type PCIe 12status in use 12info J6B1 12length short 12volts 3.3 12bus-ID 00:1c.3 12children
    121 02:00.0 12class-ID 0200 12type network
  12Slot 2 12type PCIe 12status in use 12info J6D1 12length short 12volts 3.3 12bus-ID 00:1c.4
  12Slot 3 12type PCIe 12status in use 12info J7B1 12length short 12volts 3.3 12bus-ID 00:1c.5
  12Slot 4 12type PCIe 12status in use 12info J8B4 12length short 12volts 3.3 12bus-ID 00:1c.6
  12Slot 5 12type PCIe 12status in use 12info J8D1 12length short 12volts 3.3 12bus-ID 00:1c.7
  12Slot 6 12type PCI 12status in use 12info J8B3 12length short 12volts 3.3 12bus-ID 00:1e.0
12CPU:
  12Info 12model Intel Core i7-8700 12socket LGA1151 (U3E1) 12note check 12bits 64 12type MT MCP
    12arch Coffee Lake 12gen core 8 12level v3 12note check 12built 2018 12process Intel 14nm 12family 6
    12model-id 0x9E (158) 12stepping 0xA (10) 12microcode 0xF8
  12Topology 12cpus 1x 12dies 1 12clusters 6 12cores 6 12threads 12 12tpc 2 12smt enabled 12cache 12L1 384 KiB
    12desc d-6x32 KiB; i-6x32 KiB 12L2 1.5 MiB 12desc 6x256 KiB 12L3 12 MiB 12desc 1x12 MiB
  12Speed (MHz) 12avg 800 12min/max 800/4600 12base/boost 3200/8300 12scaling 12driver intel_pstate
    12governor powersave 12volts 1.0 V 12ext-clock 100 MHz 12cores 121 800 122 800 123 800 124 800 125 800 126 800 127 800
    128 800 129 800 1210 800 1211 800 1212 800 12bogomips 76831
  12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
    avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
    ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
    tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  12Vulnerabilities
  12Type gather_data_sampling 12mitigation Microcode
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
  12Type meltdown 12mitigation PTI
  12Type mmio_stale_data 12mitigation Clear CPU buffers; SMT vulnerable
  12Type reg_file_data_sampling 12status Not affected
  12Type retbleed 12mitigation IBRS
  12Type spec_rstack_overflow 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation IBRS; IBPB: conditional; STIBP: conditional; RSB filling;
  12Type srbds 12mitigation Microcode
  12Type tsx_async_abort 12mitigation TSX disabled
12Graphics:
  12Device-1 Intel CoffeeLake-S GT2 [UHD Graphics 630] 12vendor Micro-Star MSI 12driver i915 12v kernel
    12arch Gen-9.5 12process Intel 14nm 12built 2016-20 12ports 12active DP-1 12empty DP-2, HDMI-A-1, HDMI-A-2,
    HDMI-A-3 12bus-ID 00:02.0 12chip-ID 8086:3e92 12class-ID 0300
  12Device-2 Logitech C922 Pro Stream Webcam 12driver snd-usb-audio,uvcvideo 12type USB 12rev 2.0
    12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-7:6 12chip-ID 046d:085c 12class-ID 0102 12serial <filter>
  12Display 12server X.org 12v 1.21.1.16 12compositor xfwm4 12driver 12X 12loaded intel 12dri i965 12gpu i915
    12display-ID :0.0
  12Monitor-1 DP-1 12model Dell U2717D 12serial <filter> 12built 2018 12res 2560x1440 12dpi 109 12gamma 1.2
    12chroma 12red 12x 0.639 12y 0.329 12green 12x 0.298 12y 0.600 12blue 12x 0.149 12y 0.059 12white 12x 0.314 12y 0.329
    12size 597x336mm (23.5x13.23") 12diag 685mm (27") 12ratio 16:9 12modes 2560x1440, 2048x1080,
    1920x1080, 1920x1080i, 1600x1200, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  12API OpenGL 12Message Unable to show GL data. glxinfo is missing.
  12Info 12Tools 12de xfce4-display-settings 12gpu nvidia-smi 12x11 xprop,xrandr
12Audio:
  12Device-1 Intel 200 Series PCH HD Audio 12vendor Micro-Star MSI 12driver snd_hda_intel 12v kernel
    12bus-ID 00:1f.3 12chip-ID 8086:a2f0 12class-ID 0403
  12API ALSA 12v k6.9.12-3-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 JACK 12v 1.9.22 12status off 12tools qjackctl
  12Server-2 PipeWire 12v 1.4.2 12status n/a (root, process) 12tools pw-cli
  12Server-3 PulseAudio 12v 17.0-43-g3e2bb 12status off 12with 121 pulseaudio-alsa 12type plugin
    122 pulseaudio-jack 12type module 12tools pacat,pactl,pavucontrol
12Network:
  12Device-1 Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet 12vendor Micro-Star MSI
    12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port e000 12bus-ID 02:00.0
    12chip-ID 10ec:8168 12class-ID 0200
  12IF enp2s0 12state up 12speed 100 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12Info 12services NetworkManager,systemd-timesyncd
  12WAN IP <filter>
12Bluetooth:
  12Message No bluetooth data found.
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 1.37 TiB 12used 135.45 GiB (9.6%)
  12SMART Message Required tool smartctl not installed. Check --recommends
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Samsung 12model SSD 960 EVO 250GB 12size 232.89 GiB
    12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12tech SSD 12serial <filter>
    12fw-rev 3B7QCXE7 12temp 25.9 C
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 850 EVO 250GB 12size 232.89 GiB 12block-size
    12physical 512 B 12logical 512 B 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 3B6Q
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor Seagate 12model ST1000DM010-2EP102 12size 931.51 GiB 12block-size
    12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12tech N/A 12serial <filter> 12fw-rev CC43
  12ID-4 /dev/sdc 12maj-min 8:32 12vendor SanDisk 12model Cruzer Fit 12size 7.45 GiB 12block-size
    12physical 512 B 12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech N/A
    12serial <filter> 12fw-rev 1.27
  12Optical-1 /dev/sr0 12vendor HL-DT-ST 12model DVDRAM GH24NSD0 12rev LH00 12dev-links cdrom
  12Features 12speed 12 12multisession yes 12audio yes 12dvd yes 12rw cd-r,cd-rw,dvd-r,dvd-ram 12state running
12Partition:
  12ID-1 / 12raw-size 198.12 GiB 12size 193.95 GiB (97.90%) 12used 135.44 GiB (69.8%) 12fs ext4
    12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2 12label N/A
    12uuid 7a3a3c0d-07c7-4cab-8c85-ea0b3a1e1be2
  12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 292 KiB (0.1%) 12fs vfat
    12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label N/A 12uuid F812-B691
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/nvme0n1p3 12maj-min 259:3 12size 34.47 GiB 12fs swap 12label N/A
    12uuid bd7e87b9-9dd9-4371-b093-d4069013e7e2
  12ID-2 /dev/sda1 12maj-min 8:1 12size 499 MiB 12fs fat (32 bit) 12label N/A 12uuid 3B2D-F9E6
  12ID-3 /dev/sda2 12maj-min 8:2 12size 99 MiB 12fs fat (32 bit) 12label N/A 12uuid F64A-6720
  12ID-4 /dev/sda3 12maj-min 8:3 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-5 /dev/sda4 12maj-min 8:4 12size 231.77 GiB 12fs ntfs 12label N/A 12uuid 1A2E4C762E4C4D47
  12ID-6 /dev/sda5 12maj-min 8:5 12size 526 MiB 12fs ntfs 12label N/A 12uuid DEE6CDC3E6CD9BE1
  12ID-7 /dev/sdb1 12maj-min 8:17 12size 931.51 GiB 12fs ntfs 12label 1T DRIVE 12uuid B6C45944C45907CF
  12ID-8 /dev/sdc1 12maj-min 8:33 12size 2.64 GiB 12fs N/A 12label MANJARO_XFCEM_2407
    12uuid 2024-08-21-01-32-26-00
  12ID-9 /dev/sdc2 12maj-min 8:34 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 07F2-031F
12USB:
  12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 16 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
    12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-3:2 12info SanDisk Cruzer Fit 12type mass storage 12driver usb-storage 12interfaces 1
    12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 200mA 12chip-ID 0781:5571 12class-ID 0806
    12serial <filter>
  12Device-2 1-7:6 12info Logitech C922 Pro Stream Webcam 12type video,audio
    12driver snd-usb-audio,uvcvideo 12interfaces 4 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0
    12power 500mA 12chip-ID 046d:085c 12class-ID 0102 12serial <filter>
  12Device-3 1-9:4 12info Microsoft Trackball Explorer 12type mouse 12driver hid-generic,usbhid
    12interfaces 1 12rev 1.1 12speed 1.5 Mb/s (183 KiB/s) 12lanes 1 12mode 1.0 12power 100mA 12chip-ID 045e:0024
    12class-ID 0301
  12Device-4 1-10:5 12info Logitech Keyboard K120 12type keyboard,HID 12driver hid-generic,usbhid
    12interfaces 2 12rev 1.1 12speed 1.5 Mb/s (183 KiB/s) 12lanes 1 12mode 1.0 12power 90mA 12chip-ID 046d:c31c
    12class-ID 0300
  12Hub-2 2-0:1 12info super-speed hub 12ports 10 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1
    12mode 3.2 gen-1x1 12chip-ID 1d6b:0003 12class-ID 0900
12Sensors:
  12System Temperatures 12cpu 25.2 C 12mobo N/A
  12Fan Speeds (rpm) N/A
12Repos:
  12Packages No packages detected. Unsupported package manager? 12pm pacman 12pkgs 0 12tools pamac,yay
  12Active pacman repo servers in /etc/pacman.d/mirrorlist
    121 http: //ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    122 http: //ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    123 https: //mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    124 https: //mirror.init7.net/manjaro/stable/$repo/$arch
    125 https: //mirror.alpix.eu/manjaro/stable/$repo/$arch
    126 https: //mirror.netcologne.de/manjaro/stable/$repo/$arch
    127 https: //ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    128 https: //mirror.hostiko.network/manjaro/stable/$repo/$arch
    129 https: //mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    1210 https: //ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
12Processes:
  12CPU top 5 of 298
  121 12cpu 0.8% 12command [kworker/u48:0-events_unbound] 12pid 10 12mem 0.00 MiB (0.0%)
  122 12cpu 0.8% 12command Xorg 12pid 1274 12mem 77.4 MiB (0.2%)
  123 12cpu 0.7% 12command gpg-agent 12pid 918 12mem 4.12 MiB (0.0%)
  124 12cpu 0.6% 12command init 12pid 1 12mem 12.6 MiB (0.0%)
  125 12cpu 0.4% 12command xfdesktop 12pid 1442 12mem 66.6 MiB (0.2%)
  12Memory top 5 of 298
  121 12mem 79.0 MiB (0.2%) 12command xfwm4 12pid 1391 12cpu 0.3%
  122 12mem 77.4 MiB (0.2%) 12command Xorg 12pid 1274 12cpu 0.8%
  123 12mem 71.7 MiB (0.2%) 12command manjaro-hello 12started-by python3 12pid 1485 12cpu 0.3%
  124 12mem 66.6 MiB (0.2%) 12command xfdesktop 12pid 1442 12cpu 0.4%
  125 12mem 59.0 MiB (0.1%) 12command xfce4-session 12pid 1325 12cpu 0.1%
12Info:
  12Processes 298 12Power 12uptime 4m 12states freeze,mem,disk 12suspend deep 12avail s2idle 12wakeups 0
    12hibernate platform 12avail shutdown, reboot, suspend, test_resume 12image 12.46 GiB
    12services upowerd,xfce4-power-manager 12Init systemd 12v 257 12default graphical 12tool systemctl
  12Compilers 12clang 19 12gcc 14.2.1 12Client systemd 12inxi 3.3.38
The other command you suggested gives the following:
Running in chroot, ignoring command 'list-units'
I trust the first one helps - I’m not sure why the second command didn’t provide further information.
Thanks a lot. R…
Probably to make us work a bit harder.
So let’s try the following. From the chroot environment, please post the output of:
ls -l /usr/lib/systemd/system/  && echo && echo && ls -l /etc/systemd/system/
Thanks @Mirdarthos - I really appreciate your assistance in this tight spot :wink:
Output as follows:
[manjaro /]# ls -l /usr/lib/systemd/system/  && echo && echo && ls -l /etc/systemd/system/
total 1940
-rw-r--r-- 1 root root  514 Apr 11 02:38  ModemManager.service
-rw-r--r-- 1 root root  692 Feb 28 18:56  NetworkManager-dispatcher.service
-rw-r--r-- 1 root root 1173 Feb 28 18:56  NetworkManager-wait-online.service
-rw-r--r-- 1 root root 1374 Feb 28 18:56  NetworkManager.service
-rw-r--r-- 1 root root 1960 Apr 19  2024  accounts-daemon.service
-rw-r--r-- 1 root root  161 Jul  4  2024  acpid.service
-rw-r--r-- 1 root root  410 Apr 14 21:22  alsa-restore.service
-rw-r--r-- 1 root root  387 Apr 14 21:22  alsa-state.service
-rw-r--r-- 1 root root  973 Apr 16 11:47  apparmor.service
-rw-r--r-- 1 root root 1032 Apr 30 18:44  archlinux-keyring-wkd-sync.service
-rw-r--r-- 1 root root  144 Apr 30 18:44  archlinux-keyring-wkd-sync.timer
-rw-r--r-- 1 root root  937 Jan 12 10:03  audit-rules.service
-rw-r--r-- 1 root root 1787 Jan 12 10:03  auditd.service
-rw-r--r-- 1 root root  721 Apr  2 16:36  auth-rpcgss-module.service
lrwxrwxrwx 1 root root   14 Apr 20 00:03  autovt@.service -> getty@.service
-rw-r--r-- 1 root root 1042 Nov 21 15:47  avahi-daemon.service
-rw-r--r-- 1 root root  870 Nov 21 15:47  avahi-daemon.socket
-rw-r--r-- 1 root root  950 Nov 21 15:47  avahi-dnsconfd.service
-rw-r--r-- 1 root root  927 Apr 20 00:03  basic.target
-rw-r--r-- 1 root root  383 Feb 27 17:17  blk-availability.service
-rw-r--r-- 1 root root  519 Apr 20 00:03  blockdev@.target
-rw-r--r-- 1 root root  201 Feb  3 16:44  blueman-mechanism.service
-rw-r--r-- 1 root root  756 Apr  2 14:11  bluetooth.service
-rw-r--r-- 1 root root  435 Apr 20 00:03  bluetooth.target
-rw-r--r-- 1 root root  463 Apr 20 00:03  boot-complete.target
-rw-r--r-- 1 root root  190 Mar 27 05:58  btrfs-scrub@.service
-rw-r--r-- 1 root root  160 Mar 27 05:58  btrfs-scrub@.timer
-rw-r--r-- 1 root root  491 Jul 12  2024  canberra-system-bootup.service
-rw-r--r-- 1 root root  509 Jul 12  2024  canberra-system-shutdown-reboot.service
-rw-r--r-- 1 root root  466 Jul 12  2024  canberra-system-shutdown.service
-rw-r--r-- 1 root root  431 Apr 20 00:03  capsule.slice
-rw-r--r-- 1 root root 1129 Apr 20 00:03  capsule@.service
-rw-r--r-- 1 root root 1244 Feb  7  2024  colord.service
-rw-r--r-- 1 root root 1208 Apr 20 00:03  console-getty.service
-rw-r--r-- 1 root root 1364 Apr 20 00:03  container-getty@.service
-rw-r--r-- 1 root root  247 Mar 25 17:27  cpupower.service
-rw-r--r-- 1 root root  372 Apr  8  2024  cronie.service
-rw-r--r-- 1 root root  473 Apr 20 00:03  cryptsetup-pre.target
-rw-r--r-- 1 root root  420 Apr 20 00:03  cryptsetup.target
lrwxrwxrwx 1 root root   13 Apr 20 00:03  ctrl-alt-del.target -> reboot.target
-r--r--r-- 1 root root  139 Apr 11 14:23  cups-lpd.socket
-r--r--r-- 1 root root  172 Apr 11 14:23  cups-lpd@.service
-r--r--r-- 1 root root  142 Apr 11 14:23  cups.path
-r--r--r-- 1 root root  331 Apr 11 14:23  cups.service
-r--r--r-- 1 root root  148 Apr 11 14:23  cups.socket
-rw-r--r-- 1 root root  547 Jul 22  2024  dbus-broker.service
lrwxrwxrwx 1 root root   25 Apr 20 00:03  dbus-org.freedesktop.hostname1.service -> systemd-hostnamed.service
lrwxrwxrwx 1 root root   23 Apr 20 00:03  dbus-org.freedesktop.import1.service -> systemd-importd.service
lrwxrwxrwx 1 root root   23 Apr 20 00:03  dbus-org.freedesktop.locale1.service -> systemd-localed.service
lrwxrwxrwx 1 root root   22 Apr 20 00:03  dbus-org.freedesktop.login1.service -> systemd-logind.service
lrwxrwxrwx 1 root root   24 Apr 20 00:03  dbus-org.freedesktop.machine1.service -> systemd-machined.service
lrwxrwxrwx 1 root root   25 Apr 20 00:03  dbus-org.freedesktop.portable1.service -> systemd-portabled.service
lrwxrwxrwx 1 root root   25 Apr 20 00:03  dbus-org.freedesktop.timedate1.service -> systemd-timedated.service
lrwxrwxrwx 1 root root   19 Jul 22  2024  dbus.service -> dbus-broker.service
-rw-r--r-- 1 root root  102 Mar  2 01:56  dbus.socket
-rw-r--r-- 1 root root 1100 Apr 20 00:03  debug-shell.service
lrwxrwxrwx 1 root root   16 Apr 20 00:03  default.target -> graphical.target
-rw-r--r-- 1 root root  746 Apr 20 00:03  dev-hugepages.mount
-rw-r--r-- 1 root root  672 Apr 20 00:03  dev-mqueue.mount
-rw-r--r-- 1 root root  255 Dec 31 22:33  dhclient@.service
-rw-r--r-- 1 root root  197 Mar  4 08:50  dhcpcd.service
-rw-r--r-- 1 root root  345 Mar  4 08:50  dhcpcd@.service
-rw-r--r-- 1 root root  248 Nov 28 10:19  dirmngr@.service
-rw-r--r-- 1 root root  202 Nov 28 10:19  dirmngr@.socket
-rw-r--r-- 1 root root  344 Feb 27 17:17  dm-event.service
-rw-r--r-- 1 root root  214 Feb 27 17:17  dm-event.socket
-rw-r--r-- 1 root root  336 Jul  1  2024  dmraid.service
-rw-r--r-- 1 root root  485 Mar 20 18:31  dnsmasq.service
-rw-r--r-- 1 root root  441 Mar 25 08:48  e2scrub@.service
-rw-r--r-- 1 root root  300 Mar 25 08:48  e2scrub_all.service
-rw-r--r-- 1 root root  251 Mar 25 08:48  e2scrub_all.timer
-rw-r--r-- 1 root root  228 Mar 25 08:48  e2scrub_fail@.service
-rw-r--r-- 1 root root  556 Mar 25 08:48  e2scrub_reap.service
-rw-r--r-- 1 root root  804 Apr 20 00:03  emergency.service
-rw-r--r-- 1 root root  479 Apr 20 00:03  emergency.target
-rw-r--r-- 1 root root  597 Apr 20 00:03  exit.target
-rw-r--r-- 1 root root  410 Apr 20 00:03  factory-reset.target
-rw-r--r-- 1 root root  781 Nov 16 21:55  fail2ban.service
-rw-r--r-- 1 root root  235 Jul 12  2024  fancontrol.service
-rw-r--r-- 1 root root  500 Apr 20 00:03  final.target
-rw-r--r-- 1 root root  461 Apr 20 00:03  first-boot-complete.target
-rw-r--r-- 1 root root  199 Apr  2 16:36  fsidd.service
-rw-r--r-- 1 root root  480 Mar 29 14:22  fstrim.service
-rw-r--r-- 1 root root  283 Mar 29 14:22  fstrim.timer
-rw-r--r-- 1 root root  205 Apr 15 17:57  ftpd.service
-rw-r--r-- 1 root root  588 Apr  9 16:30  fwupd-refresh.service
-rw-r--r-- 1 root root  193 Apr  9 16:30  fwupd-refresh.timer
-rw-r--r-- 1 root root 1635 Apr  9 16:30  fwupd.service
-rw-r--r-- 1 root root  503 Sep  4  2024  geoclue.service
-rw-r--r-- 1 root root  518 Apr 20 00:03  getty-pre.target
-rw-r--r-- 1 root root  509 Apr 20 00:03  getty.target
-rw-r--r-- 1 root root 2067 Apr 20 00:03  getty@.service
-rw-r--r-- 1 root root  112 Mar 14 17:20  git-daemon.socket
-rw-r--r-- 1 root root  324 Mar 14 17:20  git-daemon@.service
-rw-r--r-- 1 root root  299 Nov 28 10:19  gpg-agent-browser@.socket
-rw-r--r-- 1 root root  282 Nov 28 10:19  gpg-agent-extra@.socket
-rw-r--r-- 1 root root  309 Nov 28 10:19  gpg-agent-ssh@.socket
-rw-r--r-- 1 root root  259 Nov 28 10:19  gpg-agent@.service
-rw-r--r-- 1 root root  232 Nov 28 10:19  gpg-agent@.socket
-rw-r--r-- 1 root root   83 Jul 23  2024  gpm.path
-rw-r--r-- 1 root root  271 Jul 23  2024  gpm.service
-rw-r--r-- 1 root root  606 Apr 20 00:03  graphical.target
-rw-r--r-- 1 root root 1194 Oct 19  2023  gssproxy.service
-rw-r--r-- 1 root root  590 Apr 20 00:03  halt.target
drwxr-xr-x 2 root root 4096 Feb  4 04:45  halt.target.wants
-rw-r--r-- 1 root root  881 Oct  3  2024  haveged-once.service
-rw-r--r-- 1 root root 1049 Oct  3  2024  haveged.service
-rw-r--r-- 1 root root  199 Jul 12  2024  healthd.service
-rw-r--r-- 1 root root  526 Apr 20 00:03  hibernate.target
-rw-r--r-- 1 root root  538 Apr 20 00:03  hybrid-sleep.target
-rw-r--r-- 1 root root  670 Apr 20 00:03  initrd-cleanup.service
-rw-r--r-- 1 root root  598 Apr 20 00:03  initrd-fs.target
-rw-r--r-- 1 root root 1116 Apr 20 00:03  initrd-parse-etc.service
-rw-r--r-- 1 root root  566 Apr 20 00:03  initrd-root-device.target
drwxr-xr-x 2 root root 4096 May  5 09:41  initrd-root-device.target.wants
-rw-r--r-- 1 root root  571 Apr 20 00:03  initrd-root-fs.target
drwxr-xr-x 2 root root 4096 May  5 09:41  initrd-root-fs.target.wants
-rw-r--r-- 1 root root  614 Apr 20 00:03  initrd-switch-root.service
-rw-r--r-- 1 root root  779 Apr 20 00:03  initrd-switch-root.target
-rw-r--r-- 1 root root  823 Apr 20 00:03  initrd-udevadm-cleanup-db.service
-rw-r--r-- 1 root root  571 Apr 20 00:03  initrd-usr-fs.target
-rw-r--r-- 1 root root  810 Apr 20 00:03  initrd.target
drwxr-xr-x 2 root root 4096 May  5 09:41  initrd.target.wants
-rw-r--r-- 1 root root  487 Apr 20 00:03  integritysetup-pre.target
-rw-r--r-- 1 root root  430 Apr 20 00:03  integritysetup.target
-rw-r--r-- 1 root root  305 Feb 21 18:08  invidious.service
-rw-r--r-- 1 root root  393 Mar 22 17:58  ip6tables.service
-rw-r--r-- 1 root root  364 Mar 22 17:58  iptables.service
-rw-r--r-- 1 root root  631 Nov 20 09:43  irexec.service
-rw-r--r-- 1 root root  598 Apr 20 00:03  kexec.target
drwxr-xr-x 2 root root 4096 Feb  4 04:45  kexec.target.wants
-rw-r--r-- 1 root root  217 Nov 28 10:19  keyboxd@.service
-rw-r--r-- 1 root root  188 Nov 28 10:19  keyboxd@.socket
-rw-r--r-- 1 root root  711 Apr 20 00:03  kmod-static-nodes.service
-rw-r--r-- 1 root root  136 Jul  6  2024  krb5-kadmind.service
-rw-r--r-- 1 root root  128 Jul  6  2024  krb5-kdc.service
-rw-r--r-- 1 root root  127 Jul  6  2024  krb5-kpropd.service
-rw-r--r-- 1 root root  122 Jul  6  2024  krb5-kpropd.socket
-rw-r--r-- 1 root root  158 Jul  6  2024  krb5-kpropd@.service
-rw-r--r-- 1 root root  404 Mar 29 14:22  lastlog2-import.service
-rw-r--r-- 1 root root  952 Apr 20 00:03  ldconfig.service
-rw-r--r-- 1 root root  340 Feb 11  2024  lightdm.service
-rw-r--r-- 1 root root  182 Nov 20 09:43  lircd-setup.service
-rw-r--r-- 1 root root  489 Nov 20 09:43  lircd-uinput.service
-rw-r--r-- 1 root root  654 Nov 20 09:43  lircd.service
-rw-r--r-- 1 root root   93 Nov 20 09:43  lircd.socket
-rw-r--r-- 1 root root  507 Nov 20 09:43  lircmd.service
-rw-r--r-- 1 root root  328 Jul 12  2024  lm_sensors.service
-rw-r--r-- 1 root root  453 Apr 20 00:03  local-fs-pre.target
-rw-r--r-- 1 root root  556 Apr 20 00:03  local-fs.target
drwxr-xr-x 2 root root 4096 May  5 09:41  local-fs.target.wants
-rw-r--r-- 1 root root  870 Jul  7  2024  logrotate.service
-rw-r--r-- 1 root root  198 Jul  7  2024  logrotate.timer
-rw-r--r-- 1 root root  298 Feb 27 17:17  lvm-devices-import.path
-rw-r--r-- 1 root root  232 Feb 27 17:17  lvm-devices-import.service
-rw-r--r-- 1 root root  326 Feb 27 17:17  lvm2-lvmpolld.service
-rw-r--r-- 1 root root  205 Feb 27 17:17  lvm2-lvmpolld.socket
-rw-r--r-- 1 root root  515 Feb 27 17:17  lvm2-monitor.service
-rw-r--r-- 1 root root  453 Apr 20 00:03  machine.slice
-rw-r--r-- 1 root root  470 Apr 20 00:03  machines.target
drwxr-xr-x 2 root root 4096 May  5 09:41  machines.target.wants
-rw-r--r-- 1 root root  603 Aug 29  2024  man-db.service
-rw-r--r-- 1 root root  171 Aug 29  2024  man-db.timer
-rw-r--r-- 1 root root  494 Jan  1 15:25  mdadm-grow-continue@.service
-rw-r--r-- 1 root root  237 Jan  1 15:25  mdadm-last-resort@.service
-rw-r--r-- 1 root root  179 Jan  1 15:25  mdadm-last-resort@.timer
-rw-r--r-- 1 root root  558 Jan  1 15:25  mdcheck_continue.service
-rw-r--r-- 1 root root  400 Jan  1 15:25  mdcheck_continue.timer
-rw-r--r-- 1 root root  510 Jan  1 15:25  mdcheck_start.service
-rw-r--r-- 1 root root  426 Jan  1 15:25  mdcheck_start.timer
-rw-r--r-- 1 root root 1170 Jan  1 15:25  mdmon@.service
-rw-r--r-- 1 root root  548 Jan  1 15:25  mdmonitor-oneshot.service
-rw-r--r-- 1 root root  398 Jan  1 15:25  mdmonitor-oneshot.timer
-rw-r--r-- 1 root root 1239 Jan  1 15:25  mdmonitor.service
-rw-r--r-- 1 root root  701 Dec 18 22:07  mkinitcpio-generate-shutdown-ramfs.service
-rw-r--r-- 1 root root  573 Apr 20 00:03  modprobe@.service
-rw-r--r-- 1 root root  540 Apr 20 00:03  multi-user.target
drwxr-xr-x 2 root root 4096 May  5 09:41  multi-user.target.wants
-rw-r--r-- 1 root root  483 Apr 20 00:03  network-online.target
-rw-r--r-- 1 root root  490 Apr 20 00:03  network-pre.target
-rw-r--r-- 1 root root  499 Apr 20 00:03  network.target
-rw-r--r-- 1 root root  320 Apr  2 16:36  nfs-blkmap.service
-rw-r--r-- 1 root root  433 Apr  2 16:36  nfs-client.target
-rw-r--r-- 1 root root  300 Apr  2 16:36  nfs-idmapd.service
-rw-r--r-- 1 root root  319 Apr  2 16:36  nfs-mountd.service
-rw-r--r-- 1 root root 1049 Apr  2 16:36  nfs-server.service
-rw-r--r-- 1 root root  567 Apr  2 16:36  nfs-utils.service
-rw-r--r-- 1 root root  292 Apr  2 16:36  nfsdcld.service
-rw-r--r-- 1 root root  273 Apr  2 16:36  nfsv4-exportd.service
-rw-r--r-- 1 root root  779 Apr  2 16:36  nfsv4-server.service
-rw-r--r-- 1 root root  219 Apr 22 22:20  nftables.service
-rw-r--r-- 1 root root 2115 Feb 28 18:56  nm-priv-helper.service
-rw-r--r-- 1 root root  404 Apr 17 20:52  nmb.service
lrwxrwxrwx 1 root root    9 May  3 14:31  nordvpn.service -> /dev/null
-rw-r--r-- 1 root root  337 May  3 14:31  nordvpnd.service
-rw-r--r-- 1 root root  248 May  3 14:31  nordvpnd.socket
-rw-r--r-- 1 root root  562 Apr 20 00:03  nss-lookup.target
-rw-r--r-- 1 root root  521 Apr 20 00:03  nss-user-lookup.target
-rw-r--r-- 1 root root  246 Oct 27  2024  ntpd.service
-rw-r--r-- 1 root root  230 Oct 27  2024  ntpdate.service
-rw-r--r-- 1 root root  270 Apr 21 16:57  nvidia-hibernate.service
-rw-r--r-- 1 root root 1501 Apr 21 16:57  nvidia-persistenced.service
-rw-r--r-- 1 root root  135 Apr 21 16:57  nvidia-powerd.service
-rw-r--r-- 1 root root  414 Apr 21 16:57  nvidia-resume.service
-rw-r--r-- 1 root root  388 Apr 21 16:57  nvidia-suspend-then-hibernate.service
-rw-r--r-- 1 root root  258 Apr 21 16:57  nvidia-suspend.service
-rw-r--r-- 1 root root  865 Apr  2 16:08  openvpn-client@.service
-rw-r--r-- 1 root root 1024 Apr  2 16:08  openvpn-server@.service
-rw-r--r-- 1 root root  864 Feb  1 18:22  paccache.service
-rw-r--r-- 1 root root  142 Feb  1 18:22  paccache.timer
-rw-r--r-- 1 root root  269 Feb  1 18:22  pacman-filesdb-refresh.service
-rw-r--r-- 1 root root  149 Feb  1 18:22  pacman-filesdb-refresh.timer
-rw-r--r-- 1 root root  330 Feb  7 11:08  pam_namespace.service
-rw-r--r-- 1 root root  108 Mar  3 17:56  pamac-cleancache.service
-rw-r--r-- 1 root root  140 Mar  3 17:56  pamac-cleancache.timer
-rw-r--r-- 1 root root  118 Mar  3 17:56  pamac-daemon.service
-rw-r--r-- 1 root root  205 Mar  3 17:56  pamac-mirrorlist.service
-rw-r--r-- 1 root root  157 Mar  3 17:56  pamac-mirrorlist.timer
-rw-r--r-- 1 root root  813 Jan 26 16:49  pamac-offline-upgrade.service
-rw-r--r-- 1 root root  889 Feb  3 14:00  passim.service
-rw-r--r-- 1 root root  407 Apr 20 00:03  paths.target
-rw-r--r-- 1 root root  890 Apr  2 17:15  pcscd.service
-rw-r--r-- 1 root root  157 Apr  2 17:15  pcscd.socket
-rw-r--r-- 1 root root  604 Nov 27 18:24  plocate-updatedb.service
-rw-r--r-- 1 root root  132 Nov 27 18:24  plocate-updatedb.timer
-rw-r--r-- 1 root root  795 Jan 15 08:36  polkit.service
-rw-r--r-- 1 root root  607 Apr 20 00:03  poweroff.target
drwxr-xr-x 2 root root 4096 Feb  4 04:45  poweroff.target.wants
-rw-r--r-- 1 root root  177 Jan  2 19:07  ppp@.service
-rw-r--r-- 1 root root  433 Apr 20 00:03  printer.target
-rw-r--r-- 1 root root  133 Apr  2 16:36  proc-fs-nfsd.mount
-rw-r--r-- 1 root root  760 Apr 20 00:03  proc-sys-fs-binfmt_misc.automount
-rw-r--r-- 1 root root  682 Apr 20 00:03  proc-sys-fs-binfmt_misc.mount
-rw-r--r-- 1 root root  665 Apr 20 00:03  quotaon-root.service
-rw-r--r-- 1 root root  706 Apr 20 00:03  quotaon@.service
-rw-r--r-- 1 root root  598 Apr 20 00:03  reboot.target
drwxr-xr-x 2 root root 4096 Feb  4 04:45  reboot.target.wants
-rw-r--r-- 1 root root  557 Apr 20 00:03  remote-cryptsetup.target
-rw-r--r-- 1 root root  454 Apr 20 00:03  remote-fs-pre.target
-rw-r--r-- 1 root root  530 Apr 20 00:03  remote-fs.target
drwxr-xr-x 2 root root 4096 May  5 09:41  remote-fs.target.wants
-rw-r--r-- 1 root root  565 Apr 20 00:03  remote-veritysetup.target
-rw-r--r-- 1 root root  795 Apr 20 00:03  rescue.service
-rw-r--r-- 1 root root  500 Apr 20 00:03  rescue.target
-rw-r--r-- 1 root root  165 Mar 29 14:22  rfkill-block@.service
-rw-r--r-- 1 root root  167 Mar 29 14:22  rfkill-unblock@.service
-rw-r--r-- 1 root root  135 Apr 15 17:57  rlogin.socket
-rw-r--r-- 1 root root  132 Apr 15 17:57  rlogin@.service
-rw-r--r-- 1 root root  311 Apr  2 16:36  rpc-gssd.service
-rw-r--r-- 1 root root  435 Apr  2 16:36  rpc-statd-notify.service
-rw-r--r-- 1 root root  461 Apr  2 16:36  rpc-statd.service
-rw-r--r-- 1 root root   80 Apr  2 16:36  rpc_pipefs.target
-rw-r--r-- 1 root root  480 Jan  6 19:54  rpcbind.service
-rw-r--r-- 1 root root  400 Jan  6 19:54  rpcbind.socket
-rw-r--r-- 1 root root  548 Apr 20 00:03  rpcbind.target
-rw-r--r-- 1 root root  135 Apr 15 17:57  rsh.socket
-rw-r--r-- 1 root root  129 Apr 15 17:57  rsh@.service
-rw-r--r-- 1 root root 1030 Feb  2 10:41  rsyncd.service
-rw-r--r-- 1 root root  165 Feb  2 10:41  rsyncd.socket
-rw-r--r-- 1 root root  933 Feb  2 10:41  rsyncd@.service
-rw-r--r-- 1 root root 1020 Jul 13  2024  rtkit-daemon.service
-rw-r--r-- 1 root root  459 Apr 17 20:52  samba-bgqd.service
-rw-r--r-- 1 root root  406 Apr 17 20:52  samba.service
-rw-r--r-- 1 root root  264 Jul 12  2024  sensord.service
-rw-r--r-- 1 root root 1632 Apr 20 00:03  serial-getty@.service
-rw-r--r-- 1 root root  951 Mar 20 14:22  shadow.service
-rw-r--r-- 1 root root  124 Mar 20 14:22  shadow.timer
-rw-r--r-- 1 root root  457 Apr 20 00:03  shutdown.target
-rw-r--r-- 1 root root  410 Apr 20 00:03  sigpwr.target
-rw-r--r-- 1 root root  468 Apr 20 00:03  sleep.target
-rw-r--r-- 1 root root  462 Apr 20 00:03  slices.target
-rw-r--r-- 1 root root  428 Apr 20 00:03  smartcard.target
-rw-r--r-- 1 root root  450 Apr 17 20:52  smb.service
-rw-r--r-- 1 root root 1299 Apr  2 17:16  snapd.apparmor.service
-rw-r--r-- 1 root root  144 Apr  2 17:16  snapd.mounts-pre.target
-rw-r--r-- 1 root root  144 Apr  2 17:16  snapd.mounts.target
-rw-r--r-- 1 root root  304 Apr  2 17:16  snapd.seeded.service
-rw-r--r-- 1 root root  771 Apr  2 17:16  snapd.service
-rw-r--r-- 1 root root  281 Apr  2 17:16  snapd.socket
-rw-r--r-- 1 root root  409 Apr 20 00:03  sockets.target
drwxr-xr-x 2 root root 4096 May  5 09:41  sockets.target.wants
-rw-r--r-- 1 root root  586 Apr 20 00:03  soft-reboot.target
-rw-r--r-- 1 root root  428 Apr 20 00:03  sound.target
drwxr-xr-x 2 root root 4096 May  5 09:41  sound.target.wants
-rw-r--r-- 1 root root  417 Apr 20 00:03  ssh-access.target
-rw-r--r-- 1 root root  234 Apr  9 17:09  sshd.service
-rw-r--r-- 1 root root  445 Apr  9 17:09  sshdgenkeys.service
-rw-r--r-- 1 root root  943 Apr 20 00:03  storage-target-mode.target
-rw-r--r-- 1 root root  292 Nov 30 14:54  sudo_logsrvd.service
-rw-r--r-- 1 root root  585 Apr 20 00:03  suspend-then-hibernate.target
-rw-r--r-- 1 root root  511 Apr 20 00:03  suspend.target
-rw-r--r-- 1 root root  218 Dec 11 08:55  svnserve.service
-rw-r--r-- 1 root root  402 Apr 20 00:03  swap.target
-rw-r--r-- 1 root root 1117 Apr 20 00:03  sys-fs-fuse-connections.mount
-rw-r--r-- 1 root root 1082 Apr 20 00:03  sys-kernel-config.mount
-rw-r--r-- 1 root root  701 Apr 20 00:03  sys-kernel-debug.mount
-rw-r--r-- 1 root root  727 Apr 20 00:03  sys-kernel-tracing.mount
-rw-r--r-- 1 root root  574 Apr 20 00:03  sysinit.target
drwxr-xr-x 2 root root 4096 May  5 09:41  sysinit.target.wants
-rw-r--r-- 1 root root 1353 Apr 20 00:03  syslog.socket
-r--r--r-- 1 root root   56 Apr 11 14:23  system-cups.slice
-rw-r--r-- 1 root root  468 Apr 20 00:03 'system-systemd\x2dcryptsetup.slice'
-rw-r--r-- 1 root root  463 Apr 20 00:03 'system-systemd\x2dveritysetup.slice'
-rw-r--r-- 1 root root 1525 Apr 20 00:03  system-update-cleanup.service
-rw-r--r-- 1 root root  551 Apr 20 00:03  system-update-pre.target
-rw-r--r-- 1 root root  625 Apr 20 00:03  system-update.target
-rw-r--r-- 1 root root 1205 Apr 14 20:59  system-xfs_scrub.slice
-rw-r--r-- 1 root root  771 Apr 20 00:03  systemd-ask-password-console.path
-rw-r--r-- 1 root root  834 Apr 20 00:03  systemd-ask-password-console.service
-rw-r--r-- 1 root root  695 Apr 20 00:03  systemd-ask-password-wall.path
-rw-r--r-- 1 root root  747 Apr 20 00:03  systemd-ask-password-wall.service
-rw-r--r-- 1 root root  777 Apr 20 00:03  systemd-backlight@.service
-rw-r--r-- 1 root root  908 Apr 20 00:03  systemd-battery-check.service
-rw-r--r-- 1 root root 1184 Apr 20 00:03  systemd-binfmt.service
-rw-r--r-- 1 root root  690 Apr 20 00:03  systemd-bless-boot.service
-rw-r--r-- 1 root root  681 Apr 20 00:03  systemd-boot-check-no-failures.service
-rw-r--r-- 1 root root 1029 Apr 20 00:03  systemd-boot-random-seed.service
-rw-r--r-- 1 root root  733 Apr 20 00:03  systemd-boot-update.service
-rw-r--r-- 1 root root  596 Apr 20 00:03  systemd-bootctl.socket
-rw-r--r-- 1 root root  532 Apr 20 00:03  systemd-bootctl@.service
-rw-r--r-- 1 root root  672 Apr 20 00:03  systemd-bsod.service
-rw-r--r-- 1 root root 1089 Apr 20 00:03  systemd-confext.service
-rw-r--r-- 1 root root  643 Apr 20 00:03  systemd-coredump.socket
-rw-r--r-- 1 root root 1164 Apr 20 00:03  systemd-coredump@.service
-rw-r--r-- 1 root root  612 Apr 20 00:03  systemd-creds.socket
-rw-r--r-- 1 root root  587 Apr 20 00:03  systemd-creds@.service
-rw-r--r-- 1 root root  564 Apr 20 00:03  systemd-exit.service
-rw-r--r-- 1 root root 1552 Apr 20 00:03  systemd-firstboot.service
-rw-r--r-- 1 root root  724 Apr 20 00:03  systemd-fsck-root.service
-rw-r--r-- 1 root root  771 Apr 20 00:03  systemd-fsck@.service
-rw-r--r-- 1 root root  667 Apr 20 00:03  systemd-growfs-root.service
-rw-r--r-- 1 root root  664 Apr 20 00:03  systemd-growfs@.service
-rw-r--r-- 1 root root  562 Apr 20 00:03  systemd-halt.service
-rw-r--r-- 1 root root  782 Apr 20 00:03  systemd-hibernate-clear.service
-rw-r--r-- 1 root root  666 Apr 20 00:03  systemd-hibernate-resume.service
-rw-r--r-- 1 root root  562 Apr 20 00:03  systemd-hibernate.service
drwxr-xr-x 2 root root 4096 May  5 09:41  systemd-hibernate.service.d
-rw-r--r-- 1 root root  645 Apr 20 00:03  systemd-homed-activate.service
-rw-r--r-- 1 root root  780 Apr 20 00:03  systemd-homed-firstboot.service
-rw-r--r-- 1 root root 1394 Apr 20 00:03  systemd-homed.service
drwxr-xr-x 2 root root 4096 May  5 09:41  systemd-homed.service.d
-rw-r--r-- 1 root root 1224 Apr 20 00:03  systemd-hostnamed.service
-rw-r--r-- 1 root root  593 Apr 20 00:03  systemd-hostnamed.socket
-rw-r--r-- 1 root root  834 Apr 20 00:03  systemd-hwdb-update.service
-rw-r--r-- 1 root root  583 Apr 20 00:03  systemd-hybrid-sleep.service
drwxr-xr-x 2 root root 4096 May  5 09:41  systemd-hybrid-sleep.service.d
-rw-r--r-- 1 root root 1249 Apr 20 00:03  systemd-importd.service
-rw-r--r-- 1 root root  798 Apr 20 00:03  systemd-importd.socket
-rw-r--r-- 1 root root  750 Apr 20 00:03  systemd-journal-catalog-update.service
-rw-r--r-- 1 root root  943 Apr 20 00:03  systemd-journal-flush.service
-rw-r--r-- 1 root root 1145 Apr 20 00:03  systemd-journal-gatewayd.service
-rw-r--r-- 1 root root  500 Apr 20 00:03  systemd-journal-gatewayd.socket
-rw-r--r-- 1 root root 1307 Apr 20 00:03  systemd-journal-remote.service
-rw-r--r-- 1 root root  450 Apr 20 00:03  systemd-journal-remote.socket
-rw-r--r-- 1 root root 1257 Apr 20 00:03  systemd-journal-upload.service
-rw-r--r-- 1 root root  724 Apr 20 00:03  systemd-journald-audit.socket
-rw-r--r-- 1 root root 1182 Apr 20 00:03  systemd-journald-dev-log.socket
-rw-r--r-- 1 root root  880 Apr 20 00:03  systemd-journald-sync@.service
-rw-r--r-- 1 root root  605 Apr 20 00:03  systemd-journald-varlink@.socket
-rw-r--r-- 1 root root 2833 Apr 20 00:03  systemd-journald.service
-rw-r--r-- 1 root root  935 Apr 20 00:03  systemd-journald.socket
-rw-r--r-- 1 root root 1458 Apr 20 00:03  systemd-journald@.service
-rw-r--r-- 1 root root  782 Apr 20 00:03  systemd-journald@.socket
-rw-r--r-- 1 root root  569 Apr 20 00:03  systemd-kexec.service
-rw-r--r-- 1 root root 1225 Apr 20 00:03  systemd-localed.service
-rw-r--r-- 1 root root 2088 Apr 20 00:03  systemd-logind.service
-rw-r--r-- 1 root root  744 Apr 20 00:03  systemd-machine-id-commit.service
-rw-r--r-- 1 root root 1326 Apr 20 00:03  systemd-machined.service
-rw-r--r-- 1 root root 1104 Apr 20 00:03  systemd-modules-load.service
-rw-r--r-- 1 root root 1306 Apr 20 00:03  systemd-mountfsd.service
-rw-r--r-- 1 root root  637 Apr 20 00:03  systemd-mountfsd.socket
-rw-r--r-- 1 root root  893 Apr 20 00:03  systemd-network-generator.service
-rw-r--r-- 1 root root  857 Apr 20 00:03  systemd-networkd-persistent-storage.service
-rw-r--r-- 1 root root  785 Apr 20 00:03  systemd-networkd-wait-online.service
-rw-r--r-- 1 root root  804 Apr 20 00:03  systemd-networkd-wait-online@.service
-rw-r--r-- 1 root root 2557 Apr 20 00:03  systemd-networkd.service
-rw-r--r-- 1 root root  682 Apr 20 00:03  systemd-networkd.socket
-rw-r--r-- 1 root root 1645 Apr 20 00:03  systemd-nspawn@.service
-rw-r--r-- 1 root root 1391 Apr 20 00:03  systemd-nsresourced.service
-rw-r--r-- 1 root root  703 Apr 20 00:03  systemd-nsresourced.socket
-rw-r--r-- 1 root root 1761 Apr 20 00:03  systemd-oomd.service
-rw-r--r-- 1 root root  838 Apr 20 00:03  systemd-oomd.socket
-rw-r--r-- 1 root root  686 Apr 20 00:03  systemd-pcrextend.socket
-rw-r--r-- 1 root root  625 Apr 20 00:03  systemd-pcrextend@.service
-rw-r--r-- 1 root root  749 Apr 20 00:03  systemd-pcrfs-root.service
-rw-r--r-- 1 root root  773 Apr 20 00:03  systemd-pcrfs@.service
-rw-r--r-- 1 root root  809 Apr 20 00:03  systemd-pcrlock-file-system.service
-rw-r--r-- 1 root root  839 Apr 20 00:03  systemd-pcrlock-firmware-code.service
-rw-r--r-- 1 root root  850 Apr 20 00:03  systemd-pcrlock-firmware-config.service
-rw-r--r-- 1 root root  806 Apr 20 00:03  systemd-pcrlock-machine-id.service
-rw-r--r-- 1 root root  800 Apr 20 00:03  systemd-pcrlock-make-policy.service
-rw-r--r-- 1 root root  864 Apr 20 00:03  systemd-pcrlock-secureboot-authority.service
-rw-r--r-- 1 root root  858 Apr 20 00:03  systemd-pcrlock-secureboot-policy.service
-rw-r--r-- 1 root root  654 Apr 20 00:03  systemd-pcrlock.socket
-rw-r--r-- 1 root root  648 Apr 20 00:03  systemd-pcrlock@.service
-rw-r--r-- 1 root root  728 Apr 20 00:03  systemd-pcrmachine.service
-rw-r--r-- 1 root root  909 Apr 20 00:03  systemd-pcrphase-initrd.service
-rw-r--r-- 1 root root  805 Apr 20 00:03  systemd-pcrphase-sysinit.service
-rw-r--r-- 1 root root  767 Apr 20 00:03  systemd-pcrphase.service
-rw-r--r-- 1 root root 1074 Apr 20 00:03  systemd-portabled.service
-rw-r--r-- 1 root root  575 Apr 20 00:03  systemd-poweroff.service
-rw-r--r-- 1 root root  815 Apr 20 00:03  systemd-pstore.service
-rw-r--r-- 1 root root  712 Apr 20 00:03  systemd-quotacheck-root.service
-rw-r--r-- 1 root root  731 Apr 20 00:03  systemd-quotacheck@.service
-rw-r--r-- 1 root root 1187 Apr 20 00:03  systemd-random-seed.service
-rw-r--r-- 1 root root  568 Apr 20 00:03  systemd-reboot.service
-rw-r--r-- 1 root root  758 Apr 20 00:03  systemd-remount-fs.service
-rw-r--r-- 1 root root 1318 Apr 20 00:03  systemd-repart.service
-rw-r--r-- 1 root root 1852 Apr 20 00:03  systemd-resolved.service
-rw-r--r-- 1 root root  771 Apr 20 00:03  systemd-rfkill.service
-rw-r--r-- 1 root root  776 Apr 20 00:03  systemd-rfkill.socket
-rw-r--r-- 1 root root  588 Apr 20 00:03  systemd-soft-reboot.service
-rw-r--r-- 1 root root  920 Apr 20 00:03  systemd-storagetm.service
-rw-r--r-- 1 root root  601 Apr 20 00:03  systemd-suspend-then-hibernate.service
drwxr-xr-x 2 root root 4096 May  5 09:41  systemd-suspend-then-hibernate.service.d
-rw-r--r-- 1 root root  556 Apr 20 00:03  systemd-suspend.service
drwxr-xr-x 2 root root 4096 May  5 09:41  systemd-suspend.service.d
-rw-r--r-- 1 root root  731 Apr 20 00:03  systemd-sysctl.service
-rw-r--r-- 1 root root 1046 Apr 20 00:03  systemd-sysext.service
-rw-r--r-- 1 root root  700 Apr 20 00:03  systemd-sysext.socket
-rw-r--r-- 1 root root  612 Apr 20 00:03  systemd-sysext@.service
-rw-r--r-- 1 root root  612 Apr 20 00:03  systemd-sysupdate-reboot.service
-rw-r--r-- 1 root root  573 Apr 20 00:03  systemd-sysupdate-reboot.timer
-rw-r--r-- 1 root root 1072 Apr 20 00:03  systemd-sysupdate.service
-rw-r--r-- 1 root root 1022 Apr 20 00:03  systemd-sysupdate.timer
-rw-r--r-- 1 root root 1310 Apr 20 00:03  systemd-sysusers.service
-rw-r--r-- 1 root root 1209 Apr 20 00:03  systemd-time-wait-sync.service
-rw-r--r-- 1 root root 1174 Apr 20 00:03  systemd-timedated.service
-rw-r--r-- 1 root root 1777 Apr 20 00:03  systemd-timesyncd.service
-rw-r--r-- 1 root root  747 Apr 20 00:03  systemd-tmpfiles-clean.service
-rw-r--r-- 1 root root  539 Apr 20 00:03  systemd-tmpfiles-clean.timer
-rw-r--r-- 1 root root  852 Apr 20 00:03  systemd-tmpfiles-setup-dev-early.service
-rw-r--r-- 1 root root  877 Apr 20 00:03  systemd-tmpfiles-setup-dev.service
-rw-r--r-- 1 root root 1003 Apr 20 00:03  systemd-tmpfiles-setup.service
-rw-r--r-- 1 root root  902 Apr 20 00:03  systemd-tpm2-setup-early.service
-rw-r--r-- 1 root root  954 Apr 20 00:03  systemd-tpm2-setup.service
-rw-r--r-- 1 root root  832 Apr 20 00:03  systemd-udev-load-credentials.service
-rw-r--r-- 1 root root  863 Apr 20 00:03  systemd-udev-settle.service
-rw-r--r-- 1 root root  758 Apr 20 00:03  systemd-udev-trigger.service
-rw-r--r-- 1 root root  650 Apr 20 00:03  systemd-udevd-control.socket
-rw-r--r-- 1 root root  624 Apr 20 00:03  systemd-udevd-kernel.socket
-rw-r--r-- 1 root root 1368 Apr 20 00:03  systemd-udevd.service
drwxr-xr-x 2 root root 4096 Feb  4 04:45  systemd-udevd.service.d
-rw-r--r-- 1 root root  682 Apr 20 00:03  systemd-update-done.service
-rw-r--r-- 1 root root  856 Apr 20 00:03  systemd-update-utmp.service
-rw-r--r-- 1 root root  655 Apr 20 00:03  systemd-user-sessions.service
-rw-r--r-- 1 root root 1204 Apr 20 00:03  systemd-userdbd.service
-rw-r--r-- 1 root root  691 Apr 20 00:03  systemd-userdbd.socket
-rw-r--r-- 1 root root 1196 Apr 20 00:03  systemd-vconsole-setup.service
-rw-r--r-- 1 root root  918 Apr 20 00:03  systemd-vmspawn@.service
-rw-r--r-- 1 root root  743 Apr 20 00:03  systemd-volatile-root.service
-rw-r--r-- 1 root root  177 Apr 15 17:57  talk.service
-rw-r--r-- 1 root root  160 Apr 15 17:57  talk.socket
-rw-r--r-- 1 root root  244 Jul 12  2024  teamd@.service
-rw-r--r-- 1 root root  153 Apr 15 17:57  telnet.socket
-rw-r--r-- 1 root root  115 Apr 15 17:57  telnet@.service
-rw-r--r-- 1 root root  308 Feb 11 11:15  thermald.service
-rw-r--r-- 1 root root  434 Apr 20 00:03  time-set.target
-rw-r--r-- 1 root root  487 Apr 20 00:03  time-sync.target
-rw-r--r-- 1 root root  458 Apr 20 00:03  timers.target
drwxr-xr-x 2 root root 4096 May  5 09:41  timers.target.wants
-rw-r--r-- 1 root root  490 Feb 18 18:27  tlp.service
-rw-r--r-- 1 root root  769 Apr 20 00:03  tmp.mount
-rw-r--r-- 1 root root  535 Apr 20 00:03  tpm2.target
-rw-r--r-- 1 root root  366 Jan 30 09:30  transmission.service
-rw-r--r-- 1 root root  203 Sep  3  2024  udisks2.service
-rw-r--r-- 1 root root  351 Nov 17 15:08  ufw.service
-rw-r--r-- 1 root root  465 Apr 20 00:03  umount.target
-rw-r--r-- 1 root root  990 Apr 10 20:40  upower.service
-rw-r--r-- 1 root root  426 Apr 20 00:03  usb-gadget.target
-rw-r--r-- 1 root root  200 Feb 24 18:46  usb_modeswitch@.service
-rw-r--r-- 1 root root  199 Jul  4  2024  usbmuxd.service
drwxr-xr-x 2 root root 4096 May  5 09:41  user-.slice.d
-rw-r--r-- 1 root root  676 Apr 20 00:03  user-runtime-dir@.service
-rw-r--r-- 1 root root  440 Apr 20 00:03  user.slice
-rw-r--r-- 1 root root 1039 Apr 20 00:03  user@.service
drwxr-xr-x 2 root root 4096 May  5 09:41  user@.service.d
drwxr-xr-x 2 root root 4096 May  5 09:41  user@0.service.d
-rw-r--r-- 1 root root  532 Mar 29 14:22  uuidd.service
-rw-r--r-- 1 root root  149 Mar 29 14:22  uuidd.socket
-rw-r--r-- 1 root root  807 Apr 20 00:03  var-lib-machines.mount
-rw-r--r-- 1 root root  191 Apr  2 16:36  var-lib-nfs-rpc_pipefs.mount
-rw-r--r-- 1 root root  481 Apr 20 00:03  veritysetup-pre.target
-rw-r--r-- 1 root root  427 Apr 20 00:03  veritysetup.target
-rw-r--r-- 1 root root  234 May 27  2024  vpnc@.service
-rw-r--r-- 1 root root  385 Apr 17 20:52  winbind.service
-rw-r--r-- 1 root root  471 Jan 23 17:12  wpa_supplicant-nl80211@.service
-rw-r--r-- 1 root root  481 Jan 23 17:12  wpa_supplicant-wired@.service
-rw-r--r-- 1 root root  345 Jan 23 17:12  wpa_supplicant.service
-rw-r--r-- 1 root root  439 Jan 23 17:12  wpa_supplicant@.service
-rw-r--r-- 1 root root 2847 Apr 14 20:59  xfs_scrub@.service
-rw-r--r-- 1 root root 2445 Apr 14 20:59  xfs_scrub_all.service
-rw-r--r-- 1 root root  814 Apr 14 20:59  xfs_scrub_all.timer
-rw-r--r-- 1 root root 1784 Apr 14 20:59  xfs_scrub_all_fail.service
-rw-r--r-- 1 root root 1913 Apr 14 20:59  xfs_scrub_fail@.service
-rw-r--r-- 1 root root 2857 Apr 14 20:59  xfs_scrub_media@.service
-rw-r--r-- 1 root root 2010 Apr 14 20:59  xfs_scrub_media_fail@.service
total 40
lrwxrwxrwx 1 root root   46 Mar 15  2018 dbus-org.freedesktop.NetworkManager.service -> /usr/lib/systemd/system/NetworkManager.service
lrwxrwxrwx 1 root root   57 Mar 15  2018 dbus-org.freedesktop.nm-dispatcher.service -> /usr/lib/systemd/system/NetworkManager-dispatcher.service
lrwxrwxrwx 1 root root   40 Mar 24  2023 dbus-org.freedesktop.thermald.service -> /usr/lib/systemd/system/thermald.service
lrwxrwxrwx 1 root root   49 Jun 28  2019 dbus-org.freedesktop.timesync1.service -> /usr/lib/systemd/system/systemd-timesyncd.service
drwxr-xr-x 2 root root 4096 Jun 20  2022 default.target.wants
lrwxrwxrwx 1 root root   39 Mar 15  2018 display-manager.service -> /usr/lib/systemd/system/lightdm.service
drwxr-xr-x 2 root root 4096 Feb 25  2018 getty.target.wants
drwxr-xr-x 2 root root 4096 Mar 23  2018 graphical.target.wants
drwxr-xr-x 2 root root 4096 Mar 24  2023 multi-user.target.wants
drwxr-xr-x 2 root root 4096 Mar 15  2018 printer.target.wants
drwxr-xr-x 2 root root 4096 Mar 15  2018 sleep.target.wants
drwxr-xr-x 2 root root 4096 Apr  4  2020 sockets.target.wants
drwxr-xr-x 2 root root 4096 Jun 28  2019 sysinit.target.wants
drwxr-xr-x 2 root root 4096 Dec  6 08:11 systemd-hibernate.service.wants
drwxr-xr-x 2 root root 4096 Dec  6 08:11 systemd-suspend.service.wants
lrwxrwxrwx 1 root root   46 Jul 22  2019 timers.target.wants -> /usr/lib/systemd/system/pamac-mirrorlist.timer
Thanks, R
OK, now while still in chroot please provide the output of:
journalctl --no-pager --unit=thermald.service
Thanks, output as follows:
Mar 13 14:57:30 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 13 14:57:30 RZL thermald[734]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 13 14:57:30 RZL thermald[734]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 13 14:57:30 RZL thermald[734]: Polling mode is enabled: 4
Mar 13 14:57:30 RZL systemd[1]: Started Thermal Daemon Service.
Mar 13 17:07:10 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 13 17:07:10 RZL thermald[734]: Terminating ...
Mar 13 17:07:11 RZL thermald[734]: terminating on user request ..
Mar 13 17:07:12 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 13 17:07:12 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot cf4329b4381f49c0b9d1198bbc8d0c28 --
Mar 14 07:37:27 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 14 07:37:27 RZL thermald[728]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 14 07:37:27 RZL thermald[728]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 14 07:37:27 RZL thermald[728]: Polling mode is enabled: 4
Mar 14 07:37:27 RZL systemd[1]: Started Thermal Daemon Service.
Mar 14 07:38:03 RZL thermald[728]: Terminating ...
Mar 14 07:38:03 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 14 07:38:04 RZL thermald[728]: terminating on user request ..
Mar 14 07:38:05 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 14 07:38:05 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 2be2ff24bae845dcab862b0a3ed6c072 --
Mar 14 07:38:37 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 14 07:38:37 RZL thermald[727]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 14 07:38:37 RZL thermald[727]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 14 07:38:37 RZL thermald[727]: Polling mode is enabled: 4
Mar 14 07:38:37 RZL systemd[1]: Started Thermal Daemon Service.
Mar 14 21:03:45 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 14 21:03:45 RZL thermald[727]: Terminating ...
Mar 14 21:03:46 RZL thermald[727]: terminating on user request ..
Mar 14 21:03:47 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 14 21:03:47 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 14 21:03:47 RZL systemd[1]: thermald.service: Consumed 3.661s CPU time.
-- Boot 91f63197da8a4e72a13a39a8b426d29f --
Mar 15 13:32:47 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 15 13:32:47 RZL thermald[710]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 15 13:32:47 RZL thermald[710]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 15 13:32:47 RZL thermald[710]: Polling mode is enabled: 4
Mar 15 13:32:47 RZL systemd[1]: Started Thermal Daemon Service.
Mar 15 17:41:13 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 15 17:41:13 RZL thermald[710]: Terminating ...
Mar 15 17:41:14 RZL thermald[710]: terminating on user request ..
Mar 15 17:41:15 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 15 17:41:15 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 15 17:41:15 RZL systemd[1]: thermald.service: Consumed 1.334s CPU time.
-- Boot 0314c507041a42a4905f65590733d791 --
Mar 16 07:00:21 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 16 07:00:21 RZL thermald[711]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 16 07:00:21 RZL thermald[711]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 16 07:00:21 RZL thermald[711]: Polling mode is enabled: 4
Mar 16 07:00:21 RZL systemd[1]: Started Thermal Daemon Service.
Mar 17 17:53:16 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 17 17:53:16 RZL thermald[711]: Terminating ...
Mar 17 17:53:17 RZL thermald[711]: terminating on user request ..
Mar 17 17:53:18 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 17 17:53:18 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 17 17:53:18 RZL systemd[1]: thermald.service: Consumed 3.851s CPU time.
-- Boot 18ba0b862c97495ca327a5dedaa919f3 --
Mar 18 03:46:05 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 18 03:46:05 RZL thermald[713]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 18 03:46:05 RZL thermald[713]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 18 03:46:05 RZL thermald[713]: Polling mode is enabled: 4
Mar 18 03:46:05 RZL systemd[1]: Started Thermal Daemon Service.
Mar 18 17:28:34 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 18 17:28:34 RZL thermald[713]: Terminating ...
Mar 18 17:28:35 RZL thermald[713]: terminating on user request ..
Mar 18 17:28:36 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 18 17:28:36 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 18 17:28:36 RZL systemd[1]: thermald.service: Consumed 4.616s CPU time.
-- Boot 0837605249ce47b3a65837987f66ecb2 --
Mar 19 04:40:07 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 19 04:40:07 RZL thermald[712]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 19 04:40:07 RZL thermald[712]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 19 04:40:07 RZL thermald[712]: Polling mode is enabled: 4
Mar 19 04:40:07 RZL systemd[1]: Started Thermal Daemon Service.
Mar 19 15:53:36 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 19 15:53:36 RZL thermald[712]: Terminating ...
Mar 19 15:53:37 RZL thermald[712]: terminating on user request ..
Mar 19 15:53:38 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 19 15:53:38 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 19 15:53:38 RZL systemd[1]: thermald.service: Consumed 4.435s CPU time.
-- Boot 3ccf18e9968341b5a0ee3bc4baf17374 --
Mar 20 04:37:14 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 20 04:37:14 RZL thermald[697]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 20 04:37:14 RZL thermald[697]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 20 04:37:14 RZL thermald[697]: Polling mode is enabled: 4
Mar 20 04:37:14 RZL systemd[1]: Started Thermal Daemon Service.
Mar 20 19:17:32 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 20 19:17:32 RZL thermald[697]: Terminating ...
Mar 20 19:17:33 RZL thermald[697]: terminating on user request ..
Mar 20 19:17:34 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 20 19:17:34 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 20 19:17:34 RZL systemd[1]: thermald.service: Consumed 4.371s CPU time.
-- Boot 88052070d4d34c44b9adc486737b9034 --
Mar 21 06:30:41 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 21 06:30:41 RZL thermald[729]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 21 06:30:41 RZL thermald[729]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 21 06:30:41 RZL thermald[729]: Polling mode is enabled: 4
Mar 21 06:30:41 RZL systemd[1]: Started Thermal Daemon Service.
Mar 21 12:19:37 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 21 12:19:37 RZL thermald[729]: Terminating ...
Mar 21 12:19:38 RZL thermald[729]: terminating on user request ..
Mar 21 12:19:39 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 21 12:19:39 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 21 12:19:39 RZL systemd[1]: thermald.service: Consumed 2.597s CPU time.
-- Boot 064c086c3a5748e2b78542c29d6af7a1 --
Mar 21 12:20:04 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 21 12:20:04 RZL thermald[691]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 21 12:20:04 RZL thermald[691]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 21 12:20:04 RZL thermald[691]: Polling mode is enabled: 4
Mar 21 12:20:04 RZL systemd[1]: Started Thermal Daemon Service.
Mar 21 19:31:09 RZL thermald[691]: Terminating ...
Mar 21 19:31:09 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 21 19:31:10 RZL thermald[691]: terminating on user request ..
Mar 21 19:31:11 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 21 19:31:11 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot d34fd0d6278d429a8949fcc96be6accf --
Mar 22 09:22:18 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 22 09:22:18 RZL thermald[682]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 22 09:22:18 RZL thermald[682]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 22 09:22:18 RZL thermald[682]: Polling mode is enabled: 4
Mar 22 09:22:18 RZL systemd[1]: Started Thermal Daemon Service.
Mar 22 16:38:03 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 22 16:38:03 RZL thermald[682]: Terminating ...
Mar 22 16:38:04 RZL thermald[682]: terminating on user request ..
Mar 22 16:38:05 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 22 16:38:06 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 68dfd9c555f54b72a44a480a37f22960 --
Mar 24 05:09:53 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 24 05:09:53 RZL thermald[669]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 24 05:09:53 RZL thermald[669]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 24 05:09:53 RZL thermald[669]: Polling mode is enabled: 4
Mar 24 05:09:54 RZL systemd[1]: Started Thermal Daemon Service.
-- Boot 2c3a08ba33554816936f3cba92630147 --
Mar 24 05:11:17 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 24 05:11:18 RZL thermald[672]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 24 05:11:18 RZL thermald[672]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 24 05:11:18 RZL thermald[672]: Polling mode is enabled: 4
Mar 24 05:11:18 RZL systemd[1]: Started Thermal Daemon Service.
Mar 24 20:53:57 RZL thermald[672]: Terminating ...
Mar 24 20:53:57 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 24 20:53:58 RZL thermald[672]: terminating on user request ..
Mar 24 20:53:59 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 24 20:53:59 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 24 20:53:59 RZL systemd[1]: thermald.service: Consumed 1.992s CPU time, 11.1M memory peak.
-- Boot 6c313b7d208b43d097b29db8e5e0c71a --
Mar 25 06:17:50 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 25 06:17:50 RZL thermald[686]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 25 06:17:50 RZL thermald[686]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 25 06:17:50 RZL thermald[686]: Polling mode is enabled: 4
Mar 25 06:17:50 RZL systemd[1]: Started Thermal Daemon Service.
Mar 25 13:45:07 RZL thermald[686]: Terminating ...
Mar 25 13:45:07 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 25 13:45:08 RZL thermald[686]: terminating on user request ..
Mar 25 13:45:09 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 25 13:45:09 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 25 13:45:09 RZL systemd[1]: thermald.service: Consumed 2.491s CPU time, 9.4M memory peak.
-- Boot 91abf2fd27374dc9998ab275acc7da32 --
Mar 25 13:45:32 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 25 13:45:32 RZL thermald[685]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 25 13:45:32 RZL thermald[685]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 25 13:45:32 RZL thermald[685]: Polling mode is enabled: 4
Mar 25 13:45:32 RZL systemd[1]: Started Thermal Daemon Service.
Mar 25 18:15:03 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 25 18:15:03 RZL thermald[685]: Terminating ...
Mar 25 18:15:04 RZL thermald[685]: terminating on user request ..
Mar 25 18:15:05 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 25 18:15:05 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot d1238f11da164118a1eb62592092baf8 --
Mar 26 04:01:17 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 26 04:01:17 RZL thermald[683]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 26 04:01:17 RZL thermald[683]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 26 04:01:17 RZL thermald[683]: Polling mode is enabled: 4
Mar 26 04:01:17 RZL systemd[1]: Started Thermal Daemon Service.
Mar 26 19:59:43 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 26 19:59:43 RZL thermald[683]: Terminating ...
Mar 26 19:59:44 RZL thermald[683]: terminating on user request ..
Mar 26 19:59:45 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 26 19:59:45 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 26 19:59:45 RZL systemd[1]: thermald.service: Consumed 2.308s CPU time, 12.9M memory peak, 4K memory swap peak.
-- Boot c21a8ca1bbeb46c6a513ee29b9b6ecf2 --
Mar 27 06:08:42 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 27 06:08:42 RZL thermald[707]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 27 06:08:42 RZL thermald[707]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 27 06:08:42 RZL thermald[707]: Polling mode is enabled: 4
Mar 27 06:08:42 RZL systemd[1]: Started Thermal Daemon Service.
Mar 27 18:33:27 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 27 18:33:27 RZL thermald[707]: Terminating ...
Mar 27 18:33:28 RZL thermald[707]: terminating on user request ..
Mar 27 18:33:29 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 27 18:33:29 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot aeece25b32a5485283aa744e07afddce --
Mar 28 07:11:01 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 28 07:11:01 RZL thermald[694]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 28 07:11:01 RZL thermald[694]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 28 07:11:01 RZL thermald[694]: Polling mode is enabled: 4
Mar 28 07:11:01 RZL systemd[1]: Started Thermal Daemon Service.
Mar 28 16:38:38 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 28 16:38:38 RZL thermald[694]: Terminating ...
Mar 28 16:38:39 RZL thermald[694]: terminating on user request ..
Mar 28 16:38:40 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 28 16:38:40 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 28 16:38:40 RZL systemd[1]: thermald.service: Consumed 2.404s CPU time, 11.5M memory peak.
-- Boot f965edf965b540b7aae5f4fbbf852d70 --
Mar 29 08:19:31 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 29 08:19:31 RZL thermald[698]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 29 08:19:31 RZL thermald[698]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 29 08:19:31 RZL thermald[698]: Polling mode is enabled: 4
Mar 29 08:19:31 RZL systemd[1]: Started Thermal Daemon Service.
Mar 29 17:17:24 RZL thermald[698]: Terminating ...
Mar 29 17:17:24 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 29 17:17:25 RZL thermald[698]: terminating on user request ..
Mar 29 17:17:26 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 29 17:17:26 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 29 17:17:26 RZL systemd[1]: thermald.service: Consumed 1.034s CPU time, 9.4M memory peak.
-- Boot 534c85871530429fa1123d74ee88d592 --
Mar 30 09:52:17 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 30 09:52:17 RZL thermald[693]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 30 09:52:17 RZL thermald[693]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 30 09:52:17 RZL thermald[693]: Polling mode is enabled: 4
Mar 30 09:52:17 RZL systemd[1]: Started Thermal Daemon Service.
Mar 30 10:06:48 RZL thermald[693]: Terminating ...
Mar 30 10:06:48 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 30 10:06:49 RZL thermald[693]: terminating on user request ..
Mar 30 10:06:50 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 30 10:06:50 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 9ca3e90c95d14ff6bbedf3c98659ed94 --
Mar 30 10:07:13 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 30 10:07:13 RZL thermald[697]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 30 10:07:13 RZL thermald[697]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 30 10:07:13 RZL thermald[697]: Polling mode is enabled: 4
Mar 30 10:07:13 RZL systemd[1]: Started Thermal Daemon Service.
Mar 30 12:58:48 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 30 12:58:48 RZL thermald[697]: Terminating ...
Mar 30 12:58:49 RZL thermald[697]: terminating on user request ..
Mar 30 12:58:50 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 30 12:58:50 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 02a99f709b9248d1ba6bd6d17bfcd274 --
Mar 31 07:01:09 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 31 07:01:09 RZL thermald[703]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 31 07:01:09 RZL thermald[703]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 31 07:01:09 RZL thermald[703]: Polling mode is enabled: 4
Mar 31 07:01:09 RZL systemd[1]: Started Thermal Daemon Service.
-- Boot 6b00faaa07f7465aab8817d7fd7ae8f7 --
Mar 31 07:59:52 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 31 07:59:52 RZL thermald[704]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 31 07:59:52 RZL thermald[704]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 31 07:59:52 RZL thermald[704]: Polling mode is enabled: 4
Mar 31 07:59:52 RZL systemd[1]: Started Thermal Daemon Service.
-- Boot d9ecb4c6140949afb2b6c761d4ca780c --
Mar 31 08:00:58 RZL systemd[1]: Starting Thermal Daemon Service...
Mar 31 08:00:58 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Mar 31 08:00:58 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
Mar 31 08:00:58 RZL thermald[695]: Polling mode is enabled: 4
Mar 31 08:00:58 RZL systemd[1]: Started Thermal Daemon Service.
Mar 31 17:29:29 RZL thermald[695]: Terminating ...
Mar 31 17:29:29 RZL systemd[1]: Stopping Thermal Daemon Service...
Mar 31 17:29:30 RZL thermald[695]: terminating on user request ..
Mar 31 17:29:31 RZL systemd[1]: thermald.service: Deactivated successfully.
Mar 31 17:29:31 RZL systemd[1]: Stopped Thermal Daemon Service.
Mar 31 17:29:31 RZL systemd[1]: thermald.service: Consumed 2.805s CPU time, 8.8M memory peak.
-- Boot d9862a385f7a401c849ef36994aa6bf0 --
Apr 01 08:00:14 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 01 08:00:14 RZL thermald[686]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 01 08:00:14 RZL thermald[686]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 01 08:00:14 RZL thermald[686]: Polling mode is enabled: 4
Apr 01 08:00:14 RZL systemd[1]: Started Thermal Daemon Service.
Apr 01 16:02:13 RZL thermald[686]: Terminating ...
Apr 01 16:02:13 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 01 16:02:14 RZL thermald[686]: terminating on user request ..
Apr 01 16:02:15 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 01 16:02:15 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 01 16:02:15 RZL systemd[1]: thermald.service: Consumed 2.018s CPU time, 11.5M memory peak.
-- Boot e7729207726e4d60b86fd7f64889ca97 --
Apr 02 07:32:03 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 02 07:32:03 RZL thermald[624]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 02 07:32:03 RZL thermald[624]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 02 07:32:03 RZL thermald[624]: Polling mode is enabled: 4
Apr 02 07:32:03 RZL systemd[1]: Started Thermal Daemon Service.
Apr 02 19:37:03 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 02 19:37:03 RZL thermald[624]: Terminating ...
Apr 02 19:37:04 RZL thermald[624]: terminating on user request ..
Apr 02 19:37:05 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 02 19:37:05 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 02 19:37:05 RZL systemd[1]: thermald.service: Consumed 2.707s CPU time, 11.3M memory peak.
-- Boot 321dc74515df4f63b2ce97ba9ecde6a5 --
Apr 03 05:20:09 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 03 05:20:09 RZL thermald[700]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 03 05:20:09 RZL thermald[700]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 03 05:20:09 RZL thermald[700]: Polling mode is enabled: 4
Apr 03 05:20:09 RZL systemd[1]: Started Thermal Daemon Service.
-- Boot 55a171e6702346eda38bb127d4947da8 --
Apr 04 09:48:58 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 04 09:48:58 RZL thermald[720]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 04 09:48:58 RZL thermald[720]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 04 09:48:58 RZL thermald[720]: Polling mode is enabled: 4
Apr 04 09:48:58 RZL systemd[1]: Started Thermal Daemon Service.
-- Boot 6cc10f36a940475aa1c9e1df4d90eb2f --
Apr 04 16:13:13 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 04 16:13:13 RZL thermald[704]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 04 16:13:13 RZL thermald[704]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 04 16:13:13 RZL thermald[704]: Polling mode is enabled: 4
Apr 04 16:13:13 RZL systemd[1]: Started Thermal Daemon Service.
Apr 05 08:01:35 RZL thermald[704]: Terminating ...
Apr 05 08:01:35 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 05 08:01:36 RZL thermald[704]: terminating on user request ..
Apr 05 08:01:37 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 05 08:01:37 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 832089cae0bb4167bbabd4bc8be46c91 --
Apr 05 08:02:00 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 05 08:02:00 RZL thermald[617]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 05 08:02:00 RZL thermald[617]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 05 08:02:00 RZL thermald[617]: Polling mode is enabled: 4
Apr 05 08:02:00 RZL systemd[1]: Started Thermal Daemon Service.
Apr 06 17:16:04 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 06 17:16:04 RZL thermald[617]: Terminating ...
Apr 06 17:16:05 RZL thermald[617]: terminating on user request ..
Apr 06 17:16:06 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 06 17:16:06 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 06 17:16:06 RZL systemd[1]: thermald.service: Consumed 4.881s CPU time, 9.3M memory peak.
-- Boot 175aa195d1a146fe9999938b620f0511 --
Apr 06 17:35:44 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 06 17:35:44 RZL thermald[684]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 06 17:35:44 RZL thermald[684]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 06 17:35:44 RZL thermald[684]: Polling mode is enabled: 4
Apr 06 17:35:44 RZL systemd[1]: Started Thermal Daemon Service.
Apr 07 15:19:23 RZL thermald[684]: Terminating ...
Apr 07 15:19:23 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 07 15:19:24 RZL thermald[684]: terminating on user request ..
Apr 07 15:19:25 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 07 15:19:25 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 07 15:19:25 RZL systemd[1]: thermald.service: Consumed 3.714s CPU time, 11.4M memory peak.
-- Boot 9e947af2a56f4db2bdec3f26e93d5094 --
Apr 07 16:01:42 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 07 16:01:42 RZL thermald[623]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 07 16:01:42 RZL thermald[623]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 07 16:01:42 RZL thermald[623]: Polling mode is enabled: 4
Apr 07 16:01:42 RZL systemd[1]: Started Thermal Daemon Service.
Apr 07 19:30:43 RZL thermald[623]: Terminating ...
Apr 07 19:30:43 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 07 19:30:44 RZL thermald[623]: terminating on user request ..
Apr 07 19:30:45 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 07 19:30:45 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 775f5193bea2421bb3a1008e3f513322 --
Apr 08 04:28:23 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 08 04:28:23 RZL thermald[681]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 08 04:28:23 RZL thermald[681]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 08 04:28:23 RZL thermald[681]: Polling mode is enabled: 4
Apr 08 04:28:23 RZL systemd[1]: Started Thermal Daemon Service.
Apr 08 20:24:15 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 08 20:24:15 RZL thermald[681]: Terminating ...
Apr 08 20:24:16 RZL thermald[681]: terminating on user request ..
Apr 08 20:24:17 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 08 20:24:18 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 08 20:24:18 RZL systemd[1]: thermald.service: Consumed 3.594s CPU time, 11.5M memory peak.
-- Boot 5cf13010446944e494518e1dfb9eba55 --
Apr 08 20:35:41 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 08 20:35:41 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 08 20:35:41 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 08 20:35:41 RZL thermald[695]: Polling mode is enabled: 4
Apr 08 20:35:41 RZL systemd[1]: Started Thermal Daemon Service.
Apr 08 20:40:28 RZL thermald[695]: Terminating ...
Apr 08 20:40:28 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 08 20:40:29 RZL thermald[695]: terminating on user request ..
Apr 08 20:40:30 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 08 20:40:30 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 4eb1e5f13308451a9840b8726448368a --
Apr 09 04:18:42 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 09 04:18:42 RZL thermald[689]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 09 04:18:42 RZL thermald[689]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 09 04:18:42 RZL thermald[689]: Polling mode is enabled: 4
Apr 09 04:18:42 RZL systemd[1]: Started Thermal Daemon Service.
Apr 09 19:04:49 RZL thermald[689]: Terminating ...
Apr 09 19:04:49 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 09 19:04:50 RZL thermald[689]: terminating on user request ..
Apr 09 19:04:51 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 09 19:04:51 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 09 19:04:51 RZL systemd[1]: thermald.service: Consumed 4.050s CPU time, 12.9M memory peak.
-- Boot 955ebe96757641259cd2bfb54dd1cbb3 --
Apr 10 08:16:29 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 10 08:16:29 RZL thermald[690]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 10 08:16:29 RZL thermald[690]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 10 08:16:29 RZL thermald[690]: Polling mode is enabled: 4
Apr 10 08:16:29 RZL systemd[1]: Started Thermal Daemon Service.
Apr 10 19:29:00 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 10 19:29:00 RZL thermald[690]: Terminating ...
Apr 10 19:29:01 RZL thermald[690]: terminating on user request ..
Apr 10 19:29:02 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 10 19:29:02 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 10 19:29:02 RZL systemd[1]: thermald.service: Consumed 3.007s CPU time, 9.1M memory peak.
-- Boot bb5e034743bc4f238f8e7da43d6a9d09 --
Apr 11 06:08:07 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 11 06:08:07 RZL thermald[692]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 11 06:08:07 RZL thermald[692]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 11 06:08:07 RZL thermald[692]: Polling mode is enabled: 4
Apr 11 06:08:07 RZL systemd[1]: Started Thermal Daemon Service.
Apr 11 14:13:43 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 11 14:13:43 RZL thermald[692]: Terminating ...
Apr 11 14:13:44 RZL thermald[692]: terminating on user request ..
Apr 11 14:13:45 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 11 14:13:45 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 11 14:13:45 RZL systemd[1]: thermald.service: Consumed 2.264s CPU time, 9.4M memory peak.
-- Boot cf6c854e8e9941eea198caa1cdaca8f9 --
Apr 11 17:17:30 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 11 17:17:30 RZL thermald[693]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 11 17:17:30 RZL thermald[693]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 11 17:17:30 RZL thermald[693]: Polling mode is enabled: 4
Apr 11 17:17:30 RZL systemd[1]: Started Thermal Daemon Service.
Apr 11 18:14:35 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 11 18:14:35 RZL thermald[693]: Terminating ...
Apr 11 18:14:36 RZL thermald[693]: terminating on user request ..
Apr 11 18:14:37 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 11 18:14:37 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 3b8965e716014143a426660e31030d44 --
Apr 12 08:33:54 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 12 08:33:54 RZL thermald[624]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 12 08:33:54 RZL thermald[624]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 12 08:33:54 RZL thermald[624]: Polling mode is enabled: 4
Apr 12 08:33:54 RZL systemd[1]: Started Thermal Daemon Service.
Apr 12 12:33:28 RZL thermald[624]: Terminating ...
Apr 12 12:33:28 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 12 12:33:29 RZL thermald[624]: terminating on user request ..
Apr 12 12:33:30 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 12 12:33:30 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot bdca82dd19b24a05bafd4cdfe59c76e0 --
Apr 12 13:14:18 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 12 13:14:18 RZL thermald[696]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 12 13:14:18 RZL thermald[696]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 12 13:14:18 RZL thermald[696]: Polling mode is enabled: 4
Apr 12 13:14:18 RZL systemd[1]: Started Thermal Daemon Service.
Apr 12 13:35:24 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 12 13:35:24 RZL thermald[696]: Terminating ...
Apr 12 13:35:25 RZL thermald[696]: terminating on user request ..
Apr 12 13:35:26 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 12 13:35:26 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 47f1dccbe7a44e859ac5b14943108b6d --
Apr 12 19:12:31 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 12 19:12:31 RZL thermald[675]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 12 19:12:31 RZL thermald[675]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 12 19:12:31 RZL thermald[675]: Polling mode is enabled: 4
Apr 12 19:12:31 RZL systemd[1]: Started Thermal Daemon Service.
Apr 12 19:45:47 RZL thermald[675]: Terminating ...
Apr 12 19:45:47 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 12 19:45:48 RZL thermald[675]: terminating on user request ..
Apr 12 19:45:49 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 12 19:45:49 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 92e34da2f2194b81a6f0549b82680932 --
Apr 13 09:43:05 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 13 09:43:05 RZL thermald[676]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 13 09:43:05 RZL thermald[676]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 13 09:43:05 RZL thermald[676]: Polling mode is enabled: 4
Apr 13 09:43:05 RZL systemd[1]: Started Thermal Daemon Service.
Apr 13 09:54:11 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 13 09:54:11 RZL thermald[676]: Terminating ...
Apr 13 09:54:12 RZL thermald[676]: terminating on user request ..
Apr 13 09:54:13 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 13 09:54:13 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 89f1e5269aa84e8fa81c127cc8681352 --
Apr 14 07:17:55 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 14 07:17:55 RZL thermald[617]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 14 07:17:55 RZL thermald[617]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 14 07:17:55 RZL thermald[617]: Polling mode is enabled: 4
Apr 14 07:17:55 RZL systemd[1]: Started Thermal Daemon Service.
Apr 14 07:31:59 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 14 07:31:59 RZL thermald[617]: Terminating ...
Apr 14 07:32:00 RZL thermald[617]: terminating on user request ..
Apr 14 07:32:01 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 14 07:32:01 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot a599d7d6fc1b4572a9c907b24cb233f7 --
Apr 14 07:32:25 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 14 07:32:25 RZL thermald[698]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 14 07:32:25 RZL thermald[698]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 14 07:32:25 RZL thermald[698]: Polling mode is enabled: 4
Apr 14 07:32:25 RZL systemd[1]: Started Thermal Daemon Service.
Apr 15 18:50:31 RZL thermald[698]: Terminating ...
Apr 15 18:50:31 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 15 18:50:32 RZL thermald[698]: terminating on user request ..
Apr 15 18:50:33 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 15 18:50:33 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 15 18:50:33 RZL systemd[1]: thermald.service: Consumed 2.557s CPU time, 11.1M memory peak.
-- Boot e76a9692bdc144a9bfe7f9fb567b8a37 --
Apr 15 18:52:28 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 15 18:52:28 RZL thermald[611]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 15 18:52:28 RZL thermald[611]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 15 18:52:28 RZL thermald[611]: Polling mode is enabled: 4
Apr 15 18:52:28 RZL systemd[1]: Started Thermal Daemon Service.
Apr 15 18:55:06 RZL thermald[611]: Terminating ...
Apr 15 18:55:06 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 15 18:55:07 RZL thermald[611]: terminating on user request ..
Apr 15 18:55:08 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 15 18:55:08 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 043560acafa14be1952c215e92d217a4 --
Apr 16 08:09:38 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 16 08:09:38 RZL thermald[697]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 16 08:09:38 RZL thermald[697]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 16 08:09:38 RZL thermald[697]: Polling mode is enabled: 4
Apr 16 08:09:38 RZL systemd[1]: Started Thermal Daemon Service.
Apr 16 19:44:13 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 16 19:44:13 RZL thermald[697]: Terminating ...
Apr 16 19:44:14 RZL thermald[697]: terminating on user request ..
Apr 16 19:44:15 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 16 19:44:16 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 16 19:44:16 RZL systemd[1]: thermald.service: Consumed 1.950s CPU time, 9.4M memory peak.
-- Boot 9197e3832c5b453ca3f54c390f6e5d0a --
Apr 17 06:58:00 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 17 06:58:00 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 17 06:58:00 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 17 06:58:00 RZL thermald[695]: Polling mode is enabled: 4
Apr 17 06:58:00 RZL systemd[1]: Started Thermal Daemon Service.
Apr 17 15:36:30 RZL thermald[695]: Terminating ...
Apr 17 15:36:30 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 17 15:36:31 RZL thermald[695]: terminating on user request ..
Apr 17 15:36:32 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 17 15:36:32 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 17 15:36:32 RZL systemd[1]: thermald.service: Consumed 1.749s CPU time, 9.1M memory peak.
-- Boot 64dbe9e6d416470ca751b67fa9ab5dc5 --
Apr 18 06:58:53 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 18 06:58:53 RZL thermald[693]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 18 06:58:53 RZL thermald[693]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 18 06:58:53 RZL thermald[693]: Polling mode is enabled: 4
Apr 18 06:58:53 RZL systemd[1]: Started Thermal Daemon Service.
Apr 18 07:35:55 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 18 07:35:55 RZL thermald[693]: Terminating ...
Apr 18 07:35:56 RZL thermald[693]: terminating on user request ..
Apr 18 07:35:57 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 18 07:35:57 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 5b51a4ac2f0a4bfcb4aae5865a741f2b --
Apr 18 08:51:05 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 18 08:51:05 RZL thermald[615]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 18 08:51:05 RZL thermald[615]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 18 08:51:05 RZL thermald[615]: Polling mode is enabled: 4
Apr 18 08:51:05 RZL systemd[1]: Started Thermal Daemon Service.
Apr 18 09:48:33 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 18 09:48:33 RZL thermald[615]: Terminating ...
Apr 18 09:48:34 RZL thermald[615]: terminating on user request ..
Apr 18 09:48:35 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 18 09:48:35 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 41b403a3f1a04f1aa79bff29827c92b8 --
Apr 18 09:48:57 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 18 09:48:57 RZL thermald[629]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 18 09:48:57 RZL thermald[629]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 18 09:48:57 RZL thermald[629]: Polling mode is enabled: 4
Apr 18 09:48:57 RZL systemd[1]: Started Thermal Daemon Service.
Apr 18 19:37:14 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 18 19:37:14 RZL thermald[629]: Terminating ...
Apr 18 19:37:15 RZL thermald[629]: terminating on user request ..
Apr 18 19:37:16 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 18 19:37:16 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 18 19:37:16 RZL systemd[1]: thermald.service: Consumed 1.688s CPU time, 9.8M memory peak.
-- Boot 33ac0f31c7114eca9088ff94f58fac0f --
Apr 20 07:03:13 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 20 07:03:13 RZL thermald[681]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 20 07:03:13 RZL thermald[681]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 20 07:03:13 RZL thermald[681]: Polling mode is enabled: 4
Apr 20 07:03:13 RZL systemd[1]: Started Thermal Daemon Service.
Apr 20 18:00:07 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 20 18:00:07 RZL thermald[681]: Terminating ...
Apr 20 18:00:08 RZL thermald[681]: terminating on user request ..
Apr 20 18:00:09 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 20 18:00:09 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot f54722da153e40bd9a4843b729bc4756 --
Apr 21 08:37:35 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 21 08:37:35 RZL thermald[688]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 21 08:37:35 RZL thermald[688]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 21 08:37:35 RZL thermald[688]: Polling mode is enabled: 4
Apr 21 08:37:35 RZL systemd[1]: Started Thermal Daemon Service.
Apr 21 11:05:44 RZL thermald[688]: Terminating ...
Apr 21 11:05:44 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 21 11:05:45 RZL thermald[688]: terminating on user request ..
Apr 21 11:05:46 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 21 11:05:46 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot ae446cbbbc88485292204b64cd618d6e --
Apr 21 13:46:37 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 21 13:46:37 RZL thermald[620]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 21 13:46:37 RZL thermald[620]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 21 13:46:37 RZL thermald[620]: Polling mode is enabled: 4
Apr 21 13:46:37 RZL systemd[1]: Started Thermal Daemon Service.
Apr 21 16:27:08 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 21 16:27:08 RZL thermald[620]: Terminating ...
Apr 21 16:27:09 RZL thermald[620]: terminating on user request ..
Apr 21 16:27:10 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 21 16:27:10 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 3e472373ed024f3db6126ded4942a1d9 --
Apr 22 07:29:15 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 22 07:29:15 RZL thermald[687]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 22 07:29:15 RZL thermald[687]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 22 07:29:15 RZL thermald[687]: Polling mode is enabled: 4
Apr 22 07:29:15 RZL systemd[1]: Started Thermal Daemon Service.
Apr 22 19:23:15 RZL thermald[687]: Terminating ...
Apr 22 19:23:15 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 22 19:23:16 RZL thermald[687]: terminating on user request ..
Apr 22 19:23:17 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 22 19:23:17 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 22 19:23:17 RZL systemd[1]: thermald.service: Consumed 1.911s CPU time, 12.6M memory peak.
-- Boot 658d1ab4536a4eab80f2376ce7f00848 --
Apr 23 06:48:15 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 23 06:48:15 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 23 06:48:15 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 23 06:48:15 RZL thermald[695]: Polling mode is enabled: 4
Apr 23 06:48:15 RZL systemd[1]: Started Thermal Daemon Service.
Apr 23 07:05:45 RZL thermald[695]: Terminating ...
Apr 23 07:05:45 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 23 07:05:46 RZL thermald[695]: terminating on user request ..
Apr 23 07:05:47 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 23 07:05:47 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot d4d841ef36c04c52b8711b5423d3f234 --
Apr 23 09:49:04 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 23 09:49:04 RZL thermald[696]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 23 09:49:04 RZL thermald[696]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 23 09:49:04 RZL thermald[696]: Polling mode is enabled: 4
Apr 23 09:49:04 RZL systemd[1]: Started Thermal Daemon Service.
Apr 23 16:15:01 RZL thermald[696]: Terminating ...
Apr 23 16:15:01 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 23 16:15:02 RZL thermald[696]: terminating on user request ..
Apr 23 16:15:03 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 23 16:15:03 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 23 16:15:03 RZL systemd[1]: thermald.service: Consumed 1.510s CPU time, 9.1M memory peak.
-- Boot 2e5db0085ffa4f5fa4d762013b48c7e6 --
Apr 23 16:22:15 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 23 16:22:15 RZL thermald[700]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 23 16:22:15 RZL thermald[700]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 23 16:22:15 RZL thermald[700]: Polling mode is enabled: 4
Apr 23 16:22:15 RZL systemd[1]: Started Thermal Daemon Service.
Apr 23 16:34:30 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 23 16:34:30 RZL thermald[700]: Terminating ...
Apr 23 16:34:31 RZL thermald[700]: terminating on user request ..
Apr 23 16:34:32 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 23 16:34:32 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 30cf0849922741b39a98df25474adebf --
Apr 24 06:58:22 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 24 06:58:22 RZL thermald[685]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 24 06:58:22 RZL thermald[685]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 24 06:58:22 RZL thermald[685]: Polling mode is enabled: 4
Apr 24 06:58:22 RZL systemd[1]: Started Thermal Daemon Service.
Apr 24 20:13:36 RZL thermald[685]: Terminating ...
Apr 24 20:13:36 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 24 20:13:37 RZL thermald[685]: terminating on user request ..
Apr 24 20:13:38 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 24 20:13:38 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 24 20:13:38 RZL systemd[1]: thermald.service: Consumed 2.699s CPU time, 11.8M memory peak.
-- Boot 11c1b0b6602d4295b29a3184e0836f65 --
Apr 25 06:14:26 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 25 06:14:26 RZL thermald[697]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 25 06:14:26 RZL thermald[697]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 25 06:14:26 RZL thermald[697]: Polling mode is enabled: 4
Apr 25 06:14:26 RZL systemd[1]: Started Thermal Daemon Service.
-- Boot f09e30b8acbe41d9ba1d9be2caa8ebf4 --
Apr 28 09:09:01 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 28 09:09:01 RZL thermald[702]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 28 09:09:01 RZL thermald[702]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 28 09:09:01 RZL thermald[702]: Polling mode is enabled: 4
Apr 28 09:09:01 RZL systemd[1]: Started Thermal Daemon Service.
Apr 29 17:17:15 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 29 17:17:15 RZL thermald[702]: Terminating ...
Apr 29 17:17:16 RZL thermald[702]: terminating on user request ..
Apr 29 17:17:17 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 29 17:17:18 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 29 17:17:18 RZL systemd[1]: thermald.service: Consumed 3.520s CPU time, 12.6M memory peak.
-- Boot d55de037836f4cea8517fe5810cb4769 --
Apr 30 07:57:15 RZL systemd[1]: Starting Thermal Daemon Service...
Apr 30 07:57:15 RZL thermald[696]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
Apr 30 07:57:15 RZL thermald[696]: Config file /etc/thermald/thermal-conf.xml does not exist
Apr 30 07:57:15 RZL thermald[696]: Polling mode is enabled: 4
Apr 30 07:57:15 RZL systemd[1]: Started Thermal Daemon Service.
Apr 30 19:14:35 RZL systemd[1]: Stopping Thermal Daemon Service...
Apr 30 19:14:35 RZL thermald[696]: Terminating ...
Apr 30 19:14:36 RZL thermald[696]: terminating on user request ..
Apr 30 19:14:37 RZL systemd[1]: thermald.service: Deactivated successfully.
Apr 30 19:14:37 RZL systemd[1]: Stopped Thermal Daemon Service.
Apr 30 19:14:37 RZL systemd[1]: thermald.service: Consumed 2.503s CPU time, 9.4M memory peak.
-- Boot fe68d88a0aff4da19388e3f92bfd0bb7 --
May 01 08:03:03 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 08:03:03 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 08:03:03 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 08:03:03 RZL thermald[695]: Polling mode is enabled: 4
May 01 08:03:03 RZL systemd[1]: Started Thermal Daemon Service.
May 01 08:04:47 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 08:04:47 RZL thermald[695]: Terminating ...
May 01 08:04:48 RZL thermald[695]: terminating on user request ..
May 01 08:04:49 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 08:04:49 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 207afa4f442642e3b327540e4117ec39 --
May 01 08:05:12 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 08:05:12 RZL thermald[688]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 08:05:12 RZL thermald[688]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 08:05:12 RZL thermald[688]: Polling mode is enabled: 4
May 01 08:05:12 RZL systemd[1]: Started Thermal Daemon Service.
May 01 08:12:04 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 08:12:04 RZL thermald[688]: Terminating ...
May 01 08:12:05 RZL thermald[688]: terminating on user request ..
May 01 08:12:06 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 08:12:06 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot e61e5cb28787460899cd081f60d932da --
May 01 08:24:24 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 08:24:24 RZL thermald[682]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 08:24:24 RZL thermald[682]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 08:24:24 RZL thermald[682]: Polling mode is enabled: 4
May 01 08:24:24 RZL systemd[1]: Started Thermal Daemon Service.
May 01 08:30:22 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 08:30:22 RZL thermald[682]: Terminating ...
May 01 08:30:23 RZL thermald[682]: terminating on user request ..
May 01 08:30:24 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 08:30:24 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 7d0e16c788b74522a9aff8283d11608b --
May 01 08:30:46 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 08:30:46 RZL thermald[641]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 08:30:46 RZL thermald[641]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 08:30:46 RZL thermald[641]: Polling mode is enabled: 4
May 01 08:30:46 RZL systemd[1]: Started Thermal Daemon Service.
May 01 09:14:36 RZL thermald[641]: Terminating ...
May 01 09:14:36 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 09:14:37 RZL thermald[641]: terminating on user request ..
May 01 09:14:38 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 09:14:38 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot d62d491c1caa4da7b6aefeaa118011cf --
May 01 09:15:01 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 09:15:01 RZL thermald[698]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 09:15:01 RZL thermald[698]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 09:15:01 RZL thermald[698]: Polling mode is enabled: 4
May 01 09:15:01 RZL systemd[1]: Started Thermal Daemon Service.
May 01 09:53:42 RZL thermald[698]: Terminating ...
May 01 09:53:42 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 09:53:43 RZL thermald[698]: terminating on user request ..
May 01 09:53:44 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 09:53:44 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot bbaa27a7af3f4de4a0b06ec7ea9d5166 --
May 01 10:17:55 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 10:17:55 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 10:17:55 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 10:17:55 RZL thermald[695]: Polling mode is enabled: 4
May 01 10:17:55 RZL systemd[1]: Started Thermal Daemon Service.
May 01 10:30:20 RZL thermald[695]: Terminating ...
May 01 10:30:20 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 10:30:21 RZL thermald[695]: terminating on user request ..
May 01 10:30:22 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 10:30:22 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot f3e44091e0ca42e8ae25debe2ad3f6af --
May 01 11:26:14 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 11:26:14 RZL thermald[609]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 11:26:14 RZL thermald[609]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 11:26:14 RZL thermald[609]: Polling mode is enabled: 4
May 01 11:26:14 RZL systemd[1]: Started Thermal Daemon Service.
May 01 14:52:48 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 14:52:48 RZL thermald[609]: Terminating ...
May 01 14:52:49 RZL thermald[609]: terminating on user request ..
May 01 14:52:50 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 14:52:50 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 16c07c2f6a2f42fdb2558ff483507a6a --
May 01 15:11:01 RZL systemd[1]: Starting Thermal Daemon Service...
May 01 15:11:01 RZL thermald[702]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 01 15:11:01 RZL thermald[702]: Config file /etc/thermald/thermal-conf.xml does not exist
May 01 15:11:01 RZL thermald[702]: Polling mode is enabled: 4
May 01 15:11:01 RZL systemd[1]: Started Thermal Daemon Service.
May 01 15:27:29 RZL systemd[1]: Stopping Thermal Daemon Service...
May 01 15:27:29 RZL thermald[702]: Terminating ...
May 01 15:27:30 RZL thermald[702]: terminating on user request ..
May 01 15:27:31 RZL systemd[1]: thermald.service: Deactivated successfully.
May 01 15:27:31 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot b59188bfe3e54e14b497de600a182931 --
May 02 10:52:58 RZL systemd[1]: Starting Thermal Daemon Service...
May 02 10:52:58 RZL thermald[688]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 02 10:52:58 RZL thermald[688]: Config file /etc/thermald/thermal-conf.xml does not exist
May 02 10:52:58 RZL thermald[688]: Polling mode is enabled: 4
May 02 10:52:58 RZL systemd[1]: Started Thermal Daemon Service.
May 02 10:58:24 RZL thermald[688]: Terminating ...
May 02 10:58:24 RZL systemd[1]: Stopping Thermal Daemon Service...
May 02 10:58:25 RZL thermald[688]: terminating on user request ..
May 02 10:58:26 RZL systemd[1]: thermald.service: Deactivated successfully.
May 02 10:58:26 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot a6778334cda841deb68d7aa3d4831650 --
May 03 14:26:14 RZL systemd[1]: Starting Thermal Daemon Service...
May 03 14:26:14 RZL thermald[690]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 03 14:26:14 RZL thermald[690]: Config file /etc/thermald/thermal-conf.xml does not exist
May 03 14:26:14 RZL thermald[690]: Polling mode is enabled: 4
May 03 14:26:14 RZL systemd[1]: Started Thermal Daemon Service.
May 03 14:26:31 RZL systemd[1]: Stopping Thermal Daemon Service...
May 03 14:26:31 RZL thermald[690]: Terminating ...
May 03 14:26:32 RZL thermald[690]: terminating on user request ..
May 03 14:26:33 RZL systemd[1]: thermald.service: Deactivated successfully.
May 03 14:26:33 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 2822a56238554ec2b77430c29cf85645 --
May 03 14:27:00 RZL systemd[1]: Starting Thermal Daemon Service...
May 03 14:27:00 RZL thermald[687]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 03 14:27:00 RZL thermald[687]: Config file /etc/thermald/thermal-conf.xml does not exist
May 03 14:27:00 RZL thermald[687]: Polling mode is enabled: 4
May 03 14:27:00 RZL systemd[1]: Started Thermal Daemon Service.
May 03 16:00:39 RZL systemd[1]: Stopping Thermal Daemon Service...
May 03 16:00:39 RZL thermald[687]: Terminating ...
May 03 16:00:40 RZL thermald[687]: terminating on user request ..
May 03 16:00:41 RZL systemd[1]: thermald.service: Deactivated successfully.
May 03 16:00:41 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot cd782fa7d4b74a2ca3ef2075c59bf8b5 --
May 04 09:38:40 RZL systemd[1]: Starting Thermal Daemon Service...
May 04 09:38:40 RZL thermald[690]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 04 09:38:40 RZL thermald[690]: Config file /etc/thermald/thermal-conf.xml does not exist
May 04 09:38:40 RZL thermald[690]: Polling mode is enabled: 4
May 04 09:38:40 RZL systemd[1]: Started Thermal Daemon Service.
May 04 11:39:42 RZL systemd[1]: Stopping Thermal Daemon Service...
May 04 11:39:42 RZL thermald[690]: Terminating ...
May 04 11:39:43 RZL thermald[690]: terminating on user request ..
May 04 11:39:44 RZL systemd[1]: thermald.service: Deactivated successfully.
May 04 11:39:44 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot e268256e91fa49f99c85bd8ef852f5c8 --
May 05 09:14:36 RZL systemd[1]: Starting Thermal Daemon Service...
May 05 09:14:36 RZL thermald[686]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 05 09:14:36 RZL thermald[686]: Config file /etc/thermald/thermal-conf.xml does not exist
May 05 09:14:36 RZL thermald[686]: Polling mode is enabled: 4
May 05 09:14:36 RZL systemd[1]: Started Thermal Daemon Service.
May 05 09:54:09 RZL systemd[1]: Stopping Thermal Daemon Service...
May 05 09:54:09 RZL thermald[686]: Terminating ...
May 05 09:54:10 RZL thermald[686]: terminating on user request ..
May 05 09:54:11 RZL systemd[1]: thermald.service: Deactivated successfully.
May 05 09:54:11 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot a8c2f075b19f4ae28d96bb8484a51ded --
May 05 11:45:02 RZL systemd[1]: Starting Thermal Daemon Service...
May 05 11:45:02 RZL thermald[701]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 05 11:45:02 RZL thermald[701]: Config file /etc/thermald/thermal-conf.xml does not exist
May 05 11:45:02 RZL thermald[701]: Polling mode is enabled: 4
May 05 11:45:02 RZL systemd[1]: Started Thermal Daemon Service.
May 05 12:28:28 RZL thermald[701]: Terminating ...
May 05 12:28:28 RZL systemd[1]: Stopping Thermal Daemon Service...
May 05 12:28:29 RZL thermald[701]: terminating on user request ..
May 05 12:28:30 RZL systemd[1]: thermald.service: Deactivated successfully.
May 05 12:28:30 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 5e810ff728b940d2b007cd3c9a67cf95 --
May 05 12:28:53 RZL systemd[1]: Starting Thermal Daemon Service...
May 05 12:28:53 RZL thermald[693]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 05 12:28:53 RZL thermald[693]: Config file /etc/thermald/thermal-conf.xml does not exist
May 05 12:28:53 RZL thermald[693]: Polling mode is enabled: 4
May 05 12:28:53 RZL systemd[1]: Started Thermal Daemon Service.
May 05 12:31:59 RZL thermald[693]: Terminating ...
May 05 12:31:59 RZL systemd[1]: Stopping Thermal Daemon Service...
May 05 12:32:00 RZL thermald[693]: terminating on user request ..
May 05 12:32:01 RZL systemd[1]: thermald.service: Deactivated successfully.
May 05 12:32:01 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot cf2638fb28b04f9a8982e76176fe890f --
May 05 14:53:24 RZL systemd[1]: Starting Thermal Daemon Service...
May 05 14:53:24 RZL thermald[696]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 05 14:53:24 RZL thermald[696]: Config file /etc/thermald/thermal-conf.xml does not exist
May 05 14:53:24 RZL thermald[696]: Polling mode is enabled: 4
May 05 14:53:24 RZL systemd[1]: Started Thermal Daemon Service.
May 05 20:27:35 RZL thermald[696]: Terminating ...
May 05 20:27:35 RZL systemd[1]: Stopping Thermal Daemon Service...
May 05 20:27:36 RZL thermald[696]: terminating on user request ..
May 05 20:27:37 RZL systemd[1]: thermald.service: Deactivated successfully.
May 05 20:27:37 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot 147d025f5fea4b3f967d289cf7ee62f5 --
May 06 08:25:14 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 08:25:14 RZL thermald[695]: 22 CPUID levels; family:model:stepping 0x6:9e:a (6:158:10)
May 06 08:25:14 RZL thermald[695]: Config file /etc/thermald/thermal-conf.xml does not exist
May 06 08:25:14 RZL thermald[695]: Polling mode is enabled: 4
May 06 08:25:14 RZL systemd[1]: Started Thermal Daemon Service.
May 06 09:28:43 RZL thermald[695]: Terminating ...
May 06 09:28:43 RZL systemd[1]: Stopping Thermal Daemon Service...
May 06 09:28:44 RZL thermald[695]: terminating on user request ..
May 06 09:28:45 RZL systemd[1]: thermald.service: Deactivated successfully.
May 06 09:28:45 RZL systemd[1]: Stopped Thermal Daemon Service.
-- Boot b6ff1f93eefd4686be976044aa6389d9 --
May 06 09:29:08 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:29:08 RZL thermald[693]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:29:08 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:29:08 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:29:08 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:29:08 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:29:08 RZL thermald[778]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:29:09 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:29:09 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:29:09 RZL thermald[797]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:29:09 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:29:09 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:29:09 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:29:09 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:29:09 RZL thermald[821]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:29:09 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:29:09 RZL thermald[831]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:29:09 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:29:09 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot 97593c8d3ea04cdb8ef623121e44756b --
May 06 09:30:05 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:30:05 RZL thermald[652]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:30:05 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:30:05 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:30:05 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:30:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:30:05 RZL thermald[743]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:30:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:30:05 RZL thermald[759]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:30:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:30:05 RZL thermald[805]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:30:06 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:30:06 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:30:06 RZL thermald[867]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:30:06 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:30:06 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:30:06 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:30:06 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:30:06 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot a29aa14a645946d0a935a803f2a7a2e0 --
May 06 09:32:25 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:32:25 RZL thermald[618]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:32:25 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:32:25 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:32:25 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:32:25 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:32:25 RZL thermald[736]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:32:25 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:32:25 RZL thermald[753]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:32:25 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:32:25 RZL thermald[761]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:32:25 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:32:25 RZL thermald[807]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:32:26 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:32:26 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:32:26 RZL systemd[1]: thermald.service: Start request repeated too quickly.
May 06 09:32:26 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
-- Boot 93d8e4fc4d834d71b9f3997d18bb64fd --
May 06 09:33:27 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:33:27 RZL thermald[625]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:33:27 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:33:27 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:33:27 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:33:27 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:33:27 RZL thermald[736]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:33:27 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:33:27 RZL thermald[753]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:33:27 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:33:27 RZL thermald[796]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:33:27 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:33:28 RZL thermald[853]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:33:28 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:33:28 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:33:28 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:33:28 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:33:28 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot e427d47fa0d94112bcb0ea7d58334c34 --
May 06 09:34:05 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:34:05 RZL thermald[694]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:34:05 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:34:05 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:34:05 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:34:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:34:05 RZL thermald[814]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:34:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:34:05 RZL thermald[831]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:34:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:34:05 RZL thermald[839]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:34:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:34:05 RZL thermald[859]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:34:06 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:34:06 RZL systemd[1]: thermald.service: Start request repeated too quickly.
May 06 09:34:06 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:34:06 RZL systemd[1]: Failed to start Thermal Daemon Service.
-- Boot 13c83e827f0d4f20ae875e28f40cafd5 --
May 06 09:35:59 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:35:59 RZL thermald[699]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:35:59 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:35:59 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:35:59 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:35:59 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:35:59 RZL thermald[817]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:35:59 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:35:59 RZL thermald[837]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:35:59 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:35:59 RZL thermald[841]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:35:59 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:35:59 RZL thermald[849]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:35:59 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:35:59 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot 07f24da237664a83aecb2f3a52c8b4fe --
May 06 09:36:41 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:36:41 RZL thermald[729]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:36:41 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:36:41 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:36:41 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:36:41 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:36:41 RZL thermald[793]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:36:41 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:36:41 RZL thermald[801]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:36:41 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:36:41 RZL thermald[876]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:36:41 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:36:41 RZL thermald[956]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:36:41 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:36:41 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot cce7c2f310fe426c8c81fb43258ffd98 --
May 06 09:39:55 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:39:55 RZL thermald[622]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:39:55 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:39:55 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:39:55 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:39:55 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:39:55 RZL thermald[740]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:39:55 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:39:55 RZL thermald[757]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:39:55 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:39:55 RZL thermald[773]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:39:55 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:39:55 RZL thermald[812]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:39:56 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:39:56 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:39:56 RZL systemd[1]: thermald.service: Start request repeated too quickly.
May 06 09:39:56 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
-- Boot e4f193291417436e87a2d370a2e6eb8e --
May 06 09:54:57 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:54:57 RZL thermald[621]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:54:57 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:54:57 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:54:57 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:54:57 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:54:57 RZL thermald[729]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:54:57 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:54:57 RZL thermald[745]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:54:57 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:54:57 RZL thermald[776]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:54:57 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:54:57 RZL thermald[843]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:54:58 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:54:58 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:54:58 RZL systemd[1]: thermald.service: Start request repeated too quickly.
May 06 09:54:58 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
-- Boot d3a2368a46d243638744cef883a30ecf --
May 06 09:56:43 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:56:43 RZL thermald[620]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:56:43 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:56:43 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:56:43 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:56:43 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 09:56:43 RZL thermald[754]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:56:43 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 09:56:43 RZL thermald[770]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:56:44 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 09:56:44 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 09:56:44 RZL thermald[803]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:56:44 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 09:56:44 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 09:56:44 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 09:56:44 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 09:56:44 RZL thermald[925]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 09:56:44 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 09:56:44 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot 58d125acfd9841afb73f155b1af5ee24 --
May 06 10:01:07 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 10:01:07 RZL thermald[618]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 10:01:07 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 10:01:07 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 10:01:07 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 10:01:07 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 10:01:07 RZL thermald[753]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 10:01:07 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 10:01:07 RZL thermald[775]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 10:01:08 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 10:01:08 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 10:01:08 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 10:01:08 RZL thermald[854]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 10:01:08 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 10:01:08 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 10:01:08 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 10:01:08 RZL thermald[1097]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 10:01:08 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 10:01:08 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot b4ec977c48a94a9898ac6064f43ce77d --
May 06 11:26:24 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 11:26:24 RZL thermald[690]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:26:24 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 11:26:24 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 11:26:24 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 11:26:24 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 11:26:24 RZL thermald[737]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:26:24 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 11:26:24 RZL thermald[753]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:26:24 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 11:26:25 RZL thermald[796]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:26:25 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 11:26:25 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 11:26:25 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 11:26:25 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 11:26:25 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 11:26:25 RZL thermald[950]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:26:25 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 11:26:25 RZL systemd[1]: thermald.service: Start request repeated too quickly.
-- Boot 99ec055d80734e2badc6edecb0b2b308 --
May 06 11:27:04 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 11:27:04 RZL thermald[695]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:04 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 11:27:04 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 11:27:04 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 11:27:04 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 11:27:04 RZL thermald[742]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:04 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 11:27:04 RZL thermald[758]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:04 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 11:27:04 RZL thermald[802]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:04 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 11:27:04 RZL thermald[982]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:05 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 11:27:05 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 11:27:05 RZL systemd[1]: thermald.service: Start request repeated too quickly.
May 06 11:27:05 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
-- Boot 73adb623de6a4159b6e6c2d3ff4a3f13 --
May 06 11:27:48 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 11:27:48 RZL thermald[739]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:48 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 11:27:48 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 11:27:48 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 11:27:49 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 1.
May 06 11:27:49 RZL systemd[1]: Starting Thermal Daemon Service...
May 06 11:27:49 RZL thermald[805]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:49 RZL systemd[1]: thermald.service: Main process exited, code=exited, status=127/n/a
May 06 11:27:49 RZL systemd[1]: thermald.service: Failed with result 'exit-code'.
May 06 11:27:49 RZL systemd[1]: Failed to start Thermal Daemon Service.
May 06 11:27:49 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 2.
May 06 11:27:49 RZL thermald[834]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:49 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 3.
May 06 11:27:49 RZL thermald[1069]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:49 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 4.
May 06 11:27:49 RZL thermald[1109]: /usr/bin/thermald: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
May 06 11:27:49 RZL systemd[1]: thermald.service: Scheduled restart job, restart counter is at 5.
May 06 11:27:49 RZL systemd[1]: thermald.service: Start request repeated too quickly.
Thanks…
This seems to be the problem. Did you, perhaps even accidentally, delete the file? Because that’s the only reason I can think of this happening. Either way, please provide the output for:
pamac search -f /etc/thermald/thermal-conf.xml
Holy crap @Mirdarthos - I recognise the file name “libxml2.so.2” that is mentioned in the following output. I was trying to sort out a problem with another app (Viber) & I think I might have deleted it. Is there any way back?
Output as follows:
pamac: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
Well, that would explain it. Don’t just delete any files, especially system files. That file, libxml2.so.2, is owned by the package libxml2:
$ pamac search -f libxml2.so.2
/usr/lib/libxml2.so.2 is owned by libxml2
So try reinstalling that:
pamac reinstall libxml2 --overwrite='/usr/*'
I did check if the value for the --overwrite flag is safe, and it seems so.
Thanks, it was a total rookie mistake. Output of that command as follows:
[manjaro /]# pamac reinstall libxml2 --overwrite='/usr/*'
hmmm, OK. Let us try something else, because as you can see, that package, and thus the file are quite important. So let’s try this before going very extreme:
In the chroot environment, try:
pacman -S libxml2 --overwrite='/usr/*'
If this still doesn’t work, we’ll have to go more…erm, much more extreme.
Unfortunately that didn’t work either. Output…
[manjaro /]# pacman -S libxml2 --overwrite='/usr/*'
pacman: error while loading shared libraries: libxml2.so.2: cannot open shared object file: No such file or directory
Can you let me know what the implications of the more extreme step is, before we go for it? I just need to know if I can still get files off etc. Thanks…
I was afraid of that, but kind of expected it. It seems you’ll have to use pacman-static. These commands are for the chroot environment, unless otherwise specified. So let’s try this:
  1. Go the the root user’s $HOME directory:
    cd /root
  2. Download the pacman-static precompiled binary:
    curl --header 'Host: pkgbuild.com' --user-agent 'Mozilla/5.0 (X11; Linux x86_64; rv:138.0) Gecko/20100101 Firefox/138.0' --header 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8' --header 'Accept-Language: en-US,en;q=0.5' --referer 'https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/' --header 'Upgrade-Insecure-Requests: 1' --header 'Sec-Fetch-Dest: document' --header 'Sec-Fetch-Mode: navigate' --header 'Sec-Fetch-Site: same-origin' --header 'Sec-Fetch-User: ?1' --header 'DNT: 1' --header 'Sec-GPC: 1' 'https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static' --output 'pacman-static'
I use a generator for it, didn’t come all out of my mind.
  1. Make it executable:
    chmod +x pacman-static
  2. Use that to reinstall libxml2:
    ./pacman-static -Sy libxml2
  3. If successful you can reboot and see what happens.
    reboot
Note:
I have never done this, so it’s all just theory. But I think my theory is sound.
If you could let me know the steps in the meantime, I just want to back up a few things after my upcoming conference call. I can then give it a go. I appreciate there are no guarantees.
What is the worst case scenario of trying this? I mean, what is the worst that could happen?
Thanks so much for your time - I really do appreciate it.
Ruziel
You have to reinstall Manjaro. Don’t know how your data and things are stored and/or your partition layout, so can’t comment on that, but I think the worst case scenario would require a Manjaro reinstall.
