'Failed to start Load Kernel Modules' after reboot
I updated the system, after the reboot I get the following error:
[FAILED] Failed to start Load Kernel Modules.
systemctl says:
Failed insert module 'nvidia': Exec format error
Failed insert module 'nvidia_drm': Exec format error
Failed insert module 'nvidia_uvm': Exec format error
Could you help me please?
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Thanks for the answer, but how can I provide logs when my system is not booting?
Can you login in tty2 with ctrl+alt+f2?
You can also boot the Manjaro USB stick, chroot into the system and read the log files.
Yeah, but how does this help me? Sorry for the noob-question… :see_no_evil:
Ok, I’m trying this now. Get back to you as soon, as I get results!
So here it is:
12System:
  12Kernel 5.15.32-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 11.2.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
    tz=Europe/Berlin misobasedir=manjaro misolabel=MANJARO_KDE_2126 quiet
    systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
    nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  12Console N/A 12wm kwin_x11 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12Mobo MSI 12model Z87-G43 (MS-7816) 12v 1.0 12serial N/A
    12UEFI American Megatrends 12v 1.11 12date 05/09/2015
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12RAM 12total 19.48 GiB 12used 3.48 GiB (17.9%)
  12Array-1 12capacity 32 GiB 12slots 4 12EC None 12max-module-size 8 GiB 12note est.
  12Device-1 ChannelA-DIMM0 12type DDR3 12detail synchronous 12size 2 GiB
    12speed 1333 MT/s 12volts 12curr 1.5 12min 1.5 12max 1.5 12width (bits) 12data 64 12total 64
    12manufacturer Kingston 12part-no 99U5471-002.A00LF 12serial <filter>
  12Device-2 ChannelA-DIMM1 12type DDR3 12detail synchronous 12size 8 GiB 12speed
    12spec 1600 MT/s 12actual 1333 MT/s 12volts 12curr 1.5 12min 1.5 12max 1.5 12width (bits)
    12data 64 12total 64 12manufacturer Crucial 12part-no BLT8G3D1608ET3LX0.
    12serial <filter>
  12Device-3 ChannelB-DIMM0 12type DDR3 12detail synchronous 12size 2 GiB
  12Device-4 ChannelB-DIMM1 12type DDR3 12detail synchronous 12size 8 GiB 12speed
    12serial <filter>
12CPU:
  12Info 12model Intel Core i5-4670K 12socket BGA1155 12bits 64 12type MCP 12arch Haswell
    12gen core 4 12built 2013-15 12process Intel 22nm 12family 6 12model-id 0x3C (60)
    12stepping 3 12microcode 0x28
  12Topology 12cpus 1x 12cores 4 12smt <unsupported> 12cache 12L1 256 KiB
    12desc d-4x32 KiB; i-4x32 KiB 12L2 1024 KiB 12desc 4x256 KiB 12L3 6 MiB 12desc 1x6 MiB
  12Speed (MHz) 12avg 2851 12high 3780 12min/max 800/3800 12base/boost 3400/3800
    12scaling 12driver intel_cpufreq 12governor schedutil 12volts 1.2 V
    12ext-clock 100 MHz 12cores 121 3228 122 2258 123 2141 124 3780 12bogomips 27215
  12Flags abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid xsave xsaveopt xtopology xtpr
  12Vulnerabilities
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf
    12mitigation PTE Inversion; VMX: conditional cache flushes, SMT disabled
  12Type mds 12mitigation Clear CPU buffers; SMT disabled
  12Type meltdown 12mitigation PTI
  12Type spec_store_bypass
    12mitigation Speculative Store Bypass disabled via prctl and seccomp
  12Type spectre_v1
    12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
    disabled, RSB filling
  12Type srbds 12mitigation Microcode
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 NVIDIA GP104 [GeForce GTX 1070] 12driver nvidia 12v 510.60.02
    12non-free 515.xx+ 12status current (as of 2022-06) 12arch Pascal
    12process TSMC 16nm 12built 2016-21 12pcie 12gen 3 12speed 8 GT/s 12lanes 16
    12bus-ID 01:00.0 12chip-ID 10de:1b81 12class-ID 0300
  12Display 12server X.Org 12v 21.1.3 12compositor kwin_x11 12driver 12X 12loaded nvidia
    12gpu nvidia 12display-ID :0 12screens 1
  12Screen-1 0 12s-res 3840x2160 12s-dpi 157 12s-size 621x341mm (24.45x13.43")
    12s-diag 708mm (27.89")
  12Monitor-1 DP-4 12res 3840x2160 12hz 60 12dpi 157 12size 621x341mm (24.45x13.43")
    12diag 708mm (27.89") 12modes N/A
  12OpenGL 12renderer N/A 12v N/A 12direct render N/A
12Audio:
  12Device-1 Intel 8 Series/C220 Series High Definition Audio
    12vendor Micro-Star MSI 12driver snd_hda_intel 12bus-ID 3-7:4 12v kernel
    12bus-ID 00:1b.0 12chip-ID 0951:16a4 12class-ID 0300 12chip-ID 8086:8c20
    12class-ID 0403 12serial <filter>
  12Device-2 NVIDIA GP104 High Definition Audio 12driver snd_hda_intel 12v kernel
    12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12bus-ID 01:00.1 12chip-ID 10de:10f0
    12class-ID 0403
  12Device-3 Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series]
    12driver snd_ctxfi 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12bus-ID 04:00.0
    12chip-ID 1102:000b 12class-ID 0403
  12Device-4 Kingston HyperX 7.1 Audio 12type USB
    12driver hid-generic,snd-usb-audio,usbhid
  12Sound Server-1 ALSA 12v k5.15.32-1-MANJARO 12running yes
  12Sound Server-2 JACK 12v 1.9.21 12running no
  12Sound Server-3 PulseAudio 12v 15.0 12running yes
  12Sound Server-4 PipeWire 12v 0.3.51 12running yes
12Network:
  12Device-1 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
    12vendor Micro-Star MSI 12driver r8169 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s
    12lanes 1 12port d000 12bus-ID 03:00.0 12chip-ID 10ec:8168 12class-ID 0200
  12IF enp3s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12WAN IP <filter>
12Bluetooth:
  12Device-1 Broadcom BCM20702A0 Bluetooth 4.0 12type USB 12driver btusb 12v 0.8
    12bus-ID 3-8.2:11 12chip-ID 0a5c:21e8 12class-ID fe01 12serial <filter>
  12Report rfkill 12ID hci0 12rfk-id 1 12state up 12address see --recommends
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 2.28 TiB 12used 347.75 GiB (14.9%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Western Digital
    12model WDS100T3X0C-00SJG0 12size 931.51 GiB 12block-size 12physical 512 B
    12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12type SSD 12serial <filter>
    12rev 111130WD 12temp 44.9 C
  12SMART yes 12health PASSED 12on 37d 20h 12cycles 431
    12read-units 14,989,566 [7.67 TB] 12written-units 8,875,443 [4.54 TB]
  12ID-2 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 850 EVO 500GB
    12family based SSDs 12size 465.76 GiB 12block-size 12physical 512 B 12logical 512 B
    12sata 3.1 12speed 6.0 Gb/s 12type SSD 12serial <filter> 12rev 1B6Q 12temp 30 C
  12SMART yes 12state enabled 12health PASSED 12on 305d 17h 12cycles 4236
    12written 19.89 TiB
  12ID-3 /dev/sdb 12maj-min 8:16 12vendor Western Digital 12model WD10EACS-00ZJB0
    12family Caviar Green 12size 931.51 GiB 12block-size 12physical 512 B 12logical 512 B
    12sata 2.5 12speed 3.0 Gb/s 12type N/A 12serial <filter> 12rev 1B01 12temp 38 C
  12SMART yes 12state enabled 12health PASSED 12on 3y 85d 2h 12cycles 9491
  12ID-4 /dev/sdc 12maj-min 8:32 12type USB 12vendor Generic 12model Flash Disk
    12size 7.62 GiB 12block-size 12physical 512 B 12logical 512 B 12type SSD
    12serial <filter> 12rev 8.07
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Optical-1 /dev/sr0 12vendor TSSTcorp 12model CDDVDW SH-S223L 12rev SB04
    12dev-links cdrom
  12Features 12speed 48 12multisession yes 12audio yes 12dvd yes
    12rw cd-r,cd-rw,dvd-r,dvd-ram 12state running
12Partition:
  12ID-1 / 12raw-size 863.15 GiB 12size 848.53 GiB (98.31%) 12used 347.75 GiB (41.0%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p5 12maj-min 259:5 12label N/A
    12uuid f4ff806d-a91a-4eac-8fec-7fa6c738d5d8
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/nvme0n1p1 12maj-min 259:1 12size 100 MiB 12fs fat (32 bit) 12label N/A
    12uuid C89F-3F79
  12ID-2 /dev/nvme0n1p2 12maj-min 259:2 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-3 /dev/nvme0n1p3 12maj-min 259:3 12size 67.74 GiB 12fs ntfs 12label N/A
    12uuid 5E06A3BE06A39595
  12ID-4 /dev/nvme0n1p4 12maj-min 259:4 12size 515 MiB 12fs ntfs 12label N/A
    12uuid 7AC2DBAAC2DB6941
  12ID-5 /dev/sda1 12maj-min 8:1 12size 146.48 GiB 12fs ntfs 12label N/A
    12uuid 7EE1113036A2046D
  12ID-6 /dev/sda2 12maj-min 8:2 12size 319.28 GiB 12fs ext4 12label N/A
    12uuid 8c2ea77d-8b4d-4dfe-a7ba-ebe248f2b140
  12ID-7 /dev/sdb1 12maj-min 8:17 12size 931.51 GiB 12fs ntfs 12label Daten
    12uuid 2D3EFB572F52FFC5
  12ID-8 /dev/sdc1 12maj-min 8:33 12size 3.53 GiB 12fs N/A 12label MANJARO_KDE_2126
    12uuid 2022-04-16-05-50-10-00
  12ID-9 /dev/sdc2 12maj-min 8:34 12size 4 MiB 12fs N/A 12label MISO_EFI
    12uuid 2725-614A
12USB:
  12Hub-1 1-0:1 12info Full speed or root hub 12ports 2 12rev 2.0 12speed 480 Mb/s
    12chip-ID 1d6b:0002 12class-ID 0900
  12Hub-2 1-1:2 12info Intel Integrated Rate Matching Hub 12ports 6 12rev 2.0
    12speed 480 Mb/s 12chip-ID 8087:8008 12class-ID 0900
  12Hub-3 2-0:1 12info Full speed or root hub 12ports 2 12rev 2.0 12speed 480 Mb/s
  12Hub-4 2-1:2 12info Intel Integrated Rate Matching Hub 12ports 8 12rev 2.0
    12speed 480 Mb/s 12chip-ID 8087:8000 12class-ID 0900
  12Hub-5 3-0:1 12info Hi-speed hub with single TT 12ports 14 12rev 2.0
    12speed 480 Mb/s 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 3-1:2 12info Razer USA DeathAdder V2 Pro 12type Mouse,Keyboard
    12driver hid-generic,usbhid 12interfaces 5 12rev 2.0 12speed 12 Mb/s 12power 100mA
    12chip-ID 1532:007d 12class-ID 0300 12serial <filter>
  12Device-2 3-3:3 12info Cherry GmbH MX-Board 3.0 Keyboard 12type Keyboard,HID
    12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 1.5 Mb/s 12power 100mA
    12chip-ID 046a:010d 12class-ID 0300
  12Device-3 3-7:4 12info Kingston HyperX 7.1 Audio 12type Audio,HID
    12driver hid-generic,snd-usb-audio,usbhid 12interfaces 4 12rev 2.0 12speed 12 Mb/s
    12power 100mA 12chip-ID 0951:16a4 12class-ID 0300 12serial <filter>
  12Hub-6 3-8:9 12info VIA Labs Hub 12ports 4 12rev 2.1 12speed 480 Mb/s
    12chip-ID 2109:2811 12class-ID 0900
  12Device-1 3-8.1:10 12info Valve Wireless Steam Controller 12type Keyboard,HID
    12driver hid-steam,usbhid 12interfaces 5 12rev 2.0 12speed 12 Mb/s 12power 100mA
    12chip-ID 28de:1142 12class-ID 0300
  12Device-2 3-8.2:11 12info Broadcom BCM20702A0 Bluetooth 4.0 12type Bluetooth
    12driver btusb 12interfaces 4 12rev 2.0 12speed 12 Mb/s 12chip-ID 0a5c:21e8
  12Device-3 3-9:6 12info Alcor Micro Flash Drive 12type Mass Storage
    12driver usb-storage 12interfaces 1 12rev 2.0 12speed 480 Mb/s 12power 200mA
    12chip-ID 058f:6387 12class-ID 0806 12serial <filter>
  12Hub-7 4-0:1 12info Super-speed hub 12ports 6 12rev 3.0 12speed 5 Gb/s
    12chip-ID 1d6b:0003 12class-ID 0900
12Sensors:
  12System Temperatures 12cpu 29.8 C 12mobo 27.8 C 12gpu nvidia 12temp 52 C
  12Fan Speeds (RPM) N/A 12gpu nvidia 12fan 0%
12Info:
  12Processes 203 12Uptime 12m 12wakeups 0 12Init systemd 12v 251 12default graphical
  12tool systemctl 12Compilers 12gcc 12.1.0 12clang 13.0.1 12Packages 1527 12pacman 1511
  12lib 447 12flatpak 16 12Client shell wrapper 12v 5.1.16-release 12inxi 3.3.17
I hope this helps…
are you chrooted? if not, chroot and provide output from this:
mhwd -l && mhwd -li
To have a booting system is excellent news:
check logs what modules failed.
You don’t need extra steps with live iso then.
So… 1. update your system, 2. (re)install kernel headers, 3. reinstall nvidia drivers.
These should do it… definitely probably maybe.
@brahma yes, I’m on LiveOS now and this is was the output from:
@freggel.doe aren’t these the modules I already wrote in the first post? :thinking:
@anon51566685 sounds good! Could you tell me how to do this from terminal? Always done it from GUI before… :see_no_evil:
so chroot into your system, run this command:
sudo manjaro-chroot -a
then rerun update again:
pamac update
any errors post here
Was done in a few seconds. Only one warning:
Warning: python-pyqt5: local (5.15.6-7.1) is newer than extra (5.15.6-7)
ok, now post output from this command:
mhwd-kernel -li && mhwd -l && mhwd -li
sorry, but I got an error from manjaro-chroot, even if it worked:
grub-probe: error: cannot find a GRUB drive for /dev/sdc1.  Check your device.map.
Don’t know if this is important…
Output from mhwd-kernel -li && mhwd -l && mhwd -li:
Currently running: 5.15.32-1-MANJARO (linux515)
   * linux515
   * linux517
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1b81) Display controller nVidia Corporation:
          video-nvidia            2021.12.18               false            PCI
    video-nvidia-470xx            2021.12.18               false            PCI
    video-nvidia-390xx            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
> Installed PCI configs:
ok so now reinstall nvidia drivers:
sudo mhwd -i pci video-nvidia
post any errors here…
the grub error is for the usb, so ignore it
Warning: a version of config 'video-nvidia' is already installed!
Use -f/--force to force installation...
I guess, I should use -f/--force, right?
no it would be better to uninstall it and install it again:
uninstall:
sudo mhwd -r pci video-nvidia
install again:
Ok, that worked (with only a few warnings). Should I reboot now or do I have to do something else?
now run these:
update-grub
mkinitcpio -P
exit
systemctl reboot
and hopefully you boot normally
