I’m having very slow boot times, like Windows-slow or worse. It’s taking 1m32s to boot. I have a “decent” laptop Dell XPS 13 with 16Gb of ram.
This is the result of systemd-analyze critical-chain:
The time when unit became active or started is printed after the “@” character.
The time the unit took to start is printed after the “+” character.
graphical.target @1min 31.631s
└─sddm.service @1min 31.630s
└─plymouth-quit.service @1min 31.496s +93ms
└─systemd-user-sessions.service @1min 31.456s +36ms
└─network.target @1min 31.453s
└─NetworkManager.service @1min 31.423s +29ms
└─dbus.service @1min 31.345s +44ms
└─basic.target @1min 31.340s
└─sockets.target @1min 31.340s
└─dbus.socket @1min 31.340s
└─sysinit.target @1min 31.337s
└─systemd-timesyncd.service @1min 31.293s +42ms
└─systemd-tmpfiles-setup.service @1min 31.113s +163ms
└─local-fs.target @1min 31.109s
└─run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount @1min 31.117s
└─local-fs-pre.target @1.351s
└─systemd-tmpfiles-setup-dev.service @1.148s +201ms
└─kmod-static-nodes.service @857ms +39ms
└─systemd-journald.socket @851ms
└─-.mount @816ms
└─-.slice @816ms
There is a gap between local-fs-pre.target and the next task of about 1m30s. What the heck is going on there?
fasto
March 28, 2023, 1:01am
2
Can you run the below command and and paste the output?
sudo systemctl status run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount
That doesn’t tell us much about your computer, see below
Difficulty: ★☆☆☆☆
Rather than providing the commercial reference of a computer or piece of hardware, it is usually better to directly ask the system to describe itself. On top of saving time to everyone, this also often provides more details, including something specific to the running system.
Below is a (not exhaustive) list of commands for retrieving system information.
If you don’t know how to use those commands, or how to provide them to support, see: [HowTo] Use the terminal / TTY …
● run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount - /run/credentials/systemd-tmpfiles-setup.service
Loaded: loaded (/proc/self/mountinfo)
Active: active (mounted) since Mon 2023-03-27 19:36:16 CDT; 31min ago
Until: Mon 2023-03-27 19:36:16 CDT; 31min ago
Where: /run/credentials/systemd-tmpfiles-setup.service
What: ramfs
Regarding the spec of my computer, this is the output:
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=f3ece844-9e18-4d9e-b340-209417be041f rw rootflags=subvol=@ quiet
splash resume=UUID=759061c4-1440-4043-9212-44dc140b978a
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: XPS 13 9370 v: N/A
Mobo: Dell model: 0F6P3V v: A00 serial: <superuser required> UEFI: Dell
v: 1.21.0 date: 07/06/2022
ID-1: BAT0 charge: 26.8 Wh (57.5%) condition: 46.6/52.0 Wh (89.7%) volts: 8.3
min: 7.6 model: LGC-LGC6.73 DELL H754V79 type: Li-poly serial: <filter>
status: charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: discharging
RAM: total: 15.35 GiB used: 4.67 GiB (30.5%)
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1838 high: 2000 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 2000 3: 2000
4: 2000 5: 711 6: 2000 7: 2000 8: 2000 bogomips: 32012
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-2,DP-5
off: eDP-1 empty: DP-1,DP-3,DP-4 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0bda:58f4 class-ID: 0e02 serial: <filter>
Device-3: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.4.2:9 chip-ID: 046d:0892
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (39.96x11.22")
s-diag: 1054mm (41.51")
Monitor-1: not-matched mapped: DP-1-2-1 pos: primary,right res: 1920x1080
hz: 60 dpi: 96 size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
Monitor-2: not-matched mapped: DP-2 pos: left res: 1920x1080 hz: 60 dpi: 96
Monitor-3: eDP-1 note: disabled model: Sharp 0x148b built: 2017
res: 1920x1080 dpi: 332 gamma: 1.2 size: 294x165mm (11.57x6.5")
diag: 337mm (13.3") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
bus-ID: 3-1.3.1:6 v: kernel chip-ID: 0bda:48f0
alternate: snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_skl class-ID: 0300
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Device-2: Realtek USB Audio type: USB driver: hid-generic,usbhid
Device-4: GN Netcom Jabra SPEAK 410 USB type: USB
driver: jabra,snd-usb-audio,usbhid bus-ID: 3-1.4.3:10 chip-ID: 0b0e:0412
class-ID: 0300 serial: <filter>
Sound API: ALSA v: k6.1.19-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
class-ID: 0280 temp: 48.0 C
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-1.3.4:6 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp60s0u1u3u4 state: down mac: <filter>
Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
chip-ID: 0489:e0a2 class-ID: e001
Local Storage: total: 238.47 GiB used: 51.48 GiB (21.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
model: KXG50ZNV256G NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
rev: AADA4106 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 11.94 GiB size: 31.47 GiB (263.60%) used: 17.63 GiB (56.0%)
fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
uuid: f3ece844-9e18-4d9e-b340-209417be041f
used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: F6FE-F1E2
ID-3: /home raw-size: 2.93 GiB size: 63.88 GiB (2180.47%)
used: 33.85 GiB (53.0%) fs: btrfs dev: /dev/nvme0n1p10 maj-min: 259:10
label: N/A uuid: 22cbf2bb-d546-416d-a73d-0cb1b36df599
ID-4: /var/cache raw-size: 11.94 GiB size: 31.47 GiB (263.60%)
used: 17.63 GiB (56.0%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
label: N/A uuid: f3ece844-9e18-4d9e-b340-209417be041f
ID-5: /var/log raw-size: 11.94 GiB size: 31.47 GiB (263.60%)
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 650 MiB fs: vfat label: ESP
uuid: 9071-738F
ID-2: /dev/nvme0n1p11 maj-min: 259:11 size: 26.72 GiB fs: btrfs label: N/A
ID-3: /dev/nvme0n1p12 maj-min: 259:12 size: 19.53 GiB fs: btrfs label: N/A
ID-4: /dev/nvme0n1p13 maj-min: 259:13 size: 34.23 GiB fs: btrfs label: N/A
ID-5: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-6: /dev/nvme0n1p3 maj-min: 259:3 size: 126.5 GiB fs: ntfs label: OS
uuid: BE6ACFE16ACF9515
ID-7: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: N/A
uuid: BED62CBCD62C7735
ID-8: /dev/nvme0n1p5 maj-min: 259:5 size: 11.32 GiB fs: ntfs label: Image
uuid: 548641C28641A578
ID-9: /dev/nvme0n1p6 maj-min: 259:6 size: 1.08 GiB fs: ntfs
label: DELLSUPPORT uuid: E64444CC4444A0E3
ID-10: /dev/nvme0n1p8 maj-min: 259:8 size: 2 GiB fs: swap label: N/A
uuid: 2dd963d5-9874-468d-8f5f-cdca301806f3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-7:3 info: Foxconn / Hon Hai type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0489:e0a2
class-ID: e001
Device-3: 1-10:4 info: Shenzhen Goodix Fingerprint Reader
type: Abstract (modem),CDC-Data driver: cdc_acm interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5385 class-ID: 0a00
serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-1.2:3 info: Google Nexus/Pixel Device (MTP) type: Still Imaging
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 18d1:4ee1 class-ID: 0601 serial: <filter>
Hub-5: 3-1.3:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 3-1.3.1:6 info: Realtek USB Audio type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0bda:48f0 class-ID: 0300
Device-2: 3-1.3.3:8 info: Apple Aluminium Keyboard (ANSI)
type: Keyboard,Mouse driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 05ac:024f class-ID: 0301
Hub-6: 3-1.4:5 info: Genesys Logic USB2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 05e3:0611 class-ID: 0900
Device-1: 3-1.4.1:7 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 3-1.4.2:9 info: Logitech C920 HD Pro Webcam type: Video,Audio
power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Device-3: 3-1.4.3:10 info: GN Netcom Jabra SPEAK 410 USB type: Audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 0b0e:0412 class-ID: 0300 serial: <filter>
Hub-7: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 10 Gb/s chip-ID: 05e3:0625 class-ID: 0900
Hub-9: 4-1.3:3 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0621 class-ID: 0900
Device-1: 4-1.3.2:5 info: Genesys Logic USB Storage type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 05e3:0754 class-ID: 0806 serial: <filter>
Device-2: 4-1.3.4:6 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
Hub-10: 4-1.4:4 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
System Temperatures: cpu: 50.0 C pch: 46.0 C mobo: 42.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 4703
Processes: 286 Uptime: 34m wakeups: 12 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1349 libs: 423 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
fasto
March 28, 2023, 1:26am
4
Can you paste the contents of /etc/fstab
fasto:
/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=F6FE-F1E2 /boot/efi vfat umask=0077 0 2
UUID=759061c4-1440-4043-9212-44dc140b978a swap swap noatime 0 0
UUID=f3ece844-9e18-4d9e-b340-209417be041f / btrfs subvol=/@,discard=async,ssd 0 0
UUID=f3ece844-9e18-4d9e-b340-209417be041f /var/cache btrfs subvol=/@cache,discard=async,ssd 0 0
UUID=f3ece844-9e18-4d9e-b340-209417be041f /var/log btrfs subvol=/@log,discard=async,ssd 0 0
UUID=22cbf2bb-d546-416d-a73d-0cb1b36df599 /home btrfs discard=async,ssd 0 0
tmpfs /tmp tmpfs noatime,mode=1777 0 0
/dev/nvme0n1p3 /mnt/win ntfs noatime,noauto,nodiratime,ro 0 0
fasto
March 28, 2023, 2:22am
6
Can you paste the output of the following commands?
ls ~/.config/user-tmpfiles.d/
ls ~/.local/share/user-tmpfiles.d/
ls /usr/share/user-tmpfiles.d/
All three directories do not exist: “no such file or directory”
fasto
March 28, 2023, 3:59am
8
How about this?
for file in /tmp/*; do sudo du -sh "$file"; done
28K /tmp/manjaro-hello-preferences.json
0 /tmp/plasma-csd-generator.WMuAVk
0 /tmp/pyright-4399-dLDbSHChfj1t
220K /tmp/pyright-4399-ksAOCv46Ncb0
0 /tmp/python-languageserver-cancellation
0 /tmp/qipc_sharedmemory_bdedbfdbabcbafb56cd51926635d136055035e4dd9c7d1f5003af98
0 /tmp/qipc_sharedmemory_MSMNotifierforPlasmad7cd3d9ed002d00038761dcd548b1461629c9f02
0 /tmp/qipc_systemsem_bdedbfdbabcbafb56cd51926635d136055035e4dd9c7d1f5003af98
0 /tmp/qipc_systemsem_bfcabbfaecebac69dadd18f634141b115a30ce0998c7a1e61e4cfb
0 /tmp/qipc_systemsem_MSMNotifierforPlasmad7cd3d9ed002d00038761dcd548b1461629c9f02
0 /tmp/sddm-:0-QVsSOm
0 /tmp/sddm-auth0c664e81-ffaf-4fb3-ac3b-6dd78ca9247c
0 /tmp/systemd-private-c9c6ce5e7cc04c96ae31bf1c3b1714cf-bluetooth.service-PZK0OT
0 /tmp/systemd-private-c9c6ce5e7cc04c96ae31bf1c3b1714cf-bolt.service-eOKdyO
0 /tmp/systemd-private-c9c6ce5e7cc04c96ae31bf1c3b1714cf-ModemManager.service-slLLzz
0 /tmp/systemd-private-c9c6ce5e7cc04c96ae31bf1c3b1714cf-systemd-logind.service-7uODMF
0 /tmp/systemd-private-c9c6ce5e7cc04c96ae31bf1c3b1714cf-systemd-timesyncd.service-ew5W2w
0 /tmp/systemd-private-c9c6ce5e7cc04c96ae31bf1c3b1714cf-upower.service-gnjkyY
0 /tmp/Temp-dedac32f-78ce-44d9-aff4-4aff71465c72
Removing this didn´t have any effect, so I put it back.
fasto
March 28, 2023, 7:54pm
12
Sorry for the wild goose chase, but we gotta keep looking at things until we find a clue. Next idea: after a fresh boot, run the following
sudo journalctl -b 0 | grep -E "mount|tmp|tmp.mount"
Mar 28 16:12:06 xxxxx kernel: devtmpfs: initialized
Mar 28 16:12:06 xxxxx systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Mar 28 16:12:06 xxxxx systemd[1]: Starting Remount Root and Kernel File Systems...
Mar 28 16:12:06 xxxxx systemd[1]: Finished Remount Root and Kernel File Systems.
Mar 28 16:13:36 xxxxx systemd[1]: Mounting /tmp...
Mar 28 16:13:36 xxxxx systemd[1]: Mounted /tmp.
Mar 28 16:13:36 xxxxx systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 554 (systemd-binfmt)
Mar 28 16:13:36 xxxxx audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:13:36 xxxxx kernel: audit: type=1130 audit(1680038016.355:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:13:36 xxxxx audit[559]: SYSTEM_BOOT pid=559 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 28 16:13:36 xxxxx kernel: audit: type=1127 audit(1680038016.398:15): pid=559 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Mar 28 16:13:36 xxxxx audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:13:36 xxxxx kernel: audit: type=1130 audit(1680038016.445:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mar 28 16:13:41 xxxxx dbus-daemon[564]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service' requested by ':1.19' (uid=964 pid=668 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-lRayAB")
Mar 28 16:13:41 xxxxx dbus-daemon[564]: [system] Activating via systemd: service name='org.freedesktop.UPower' unit='upower.service' requested by ':1.19' (uid=964 pid=668 comm="/usr/bin/sddm-greeter --socket /tmp/sddm-:0-lRayAB")
Mar 28 16:13:49 xxxxx dbus-daemon[564]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.23' (uid=0 pid=719 comm="/usr/lib/sddm/sddm-helper --socket /tmp/sddm-auth9")
Mar 28 16:13:54 xxxxx manjaro-hello[1055]: DEBUG:root:json : /tmp/manjaro-hello-preferences.json
Mar 28 16:13:59 xxxxx systemd[1]: run-user-964.mount: Deactivated successfully.
Looking at dmesg there is a 1m30s gap where only audit entries appear. It seems like nothing is happening.
I think it has to be some driver waiting on a device or something like that.
fasto
March 29, 2023, 1:01am
15
Can you paste the audit messages you described? I have found one case where a similar issue had clues in the audit messages.
[ 15.573524] ath: Country alpha2 being used: 00
[ 15.573525] ath: Regpair used: 0x6c
[ 15.578447] ath10k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[ 15.937087] input: HDA Intel PCH Headphone Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 15.937149] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input29
[ 15.937202] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input30
[ 15.937263] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input31
[ 20.606327] audit: type=1131 audit(1680051812.582:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.226609] audit: type=1130 audit(1680051895.202:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.249990] audit: type=1130 audit(1680051895.226:12): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.362829] audit: type=1130 audit(1680051895.339:13): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.363941] audit: type=1334 audit(1680051895.339:14): prog-id=29 op=LOAD
[ 103.393264] audit: type=1127 audit(1680051895.366:15): pid=569 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 103.425933] audit: type=1130 audit(1680051895.399:16): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.447310] audit: type=1130 audit(1680051895.419:17): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.454204] audit: type=1130 audit(1680051895.426:18): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.458223] audit: type=1334 audit(1680051895.429:19): prog-id=30 op=LOAD
[ 103.458346] audit: type=1334 audit(1680051895.429:20): prog-id=31 op=LOAD
[ 103.491222] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 103.491227] Bluetooth: BNEP filters: protocol multicast
[ 103.491232] Bluetooth: BNEP socket layer initialized
fasto
March 29, 2023, 1:20am
17
To be completely honest, I am at a bit of a loss on this one. The unit credited with extending the boot times is all about the tmpfs, but I can find nothing out of the ordinary related to your tmpfs. There are also extremely few documented cases related to this unit, but I will link the ones I found below in case they are useful. It definitely shouldn’t be doing this, but I’m not really sure why it is.
Sorry, I hope someone else is able to help.
fasto:
What’s strange is that a sudo systemd-analyze blame doesn´t show any task taking longer than 1s…
Another clue: the gap is exactly the defined timeout, assuming the timeout on yours is the same as mine:
systemctl show "run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount"
Look for
TimeoutUSec=1min 30s
Problem solved. The issue was that the UUID in fstab for the swap partition was wrong. At some point, a couple of weeks ago, I deleted and created again the swap partition to move it to another disk. I think fstab was never updated (I’m not sure if it supposed to be updated automatically)
fasto
March 30, 2023, 12:55am
21
fstab
is not updated automatically unless the program you used to change the swap partition has that as an explicit feature. I assume you just used swapoff
and swapon
, so it isn’t. Glad to hear you managed to figure this out!
