Hello,
Fresh install, trying to connect to wifi:
The access point /org/freedesktop/NetworkManager/AccessPoint/13 was not in the scan list.
Rebooted, still doesn’t work. Ideas?
TIA
Hello,
TIA
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
How can you try to connect to it when it is not in the scan list?
I suppose that is the list of available networks you can choose from to connect to.
Clarify what you are doing and how you are doing it and what you see where as a result.
Hi,
WiFi works now. I disabled WiFi in NetworkManager and re-enabled it, this solved the problem.
Thanks
Make sure to select a solution instead of prepending “[SOLVED]”.
Edit:- Removed [Solved] from Title; designated the OP’s own post as Solution.
