Antes al menos se conectaba pero no escaneaba nuevas redes. Ahora ni escanea nuevas redes ni se conecta. En el live boot con el usb si escanea y se puede conectar normal.
Con tan poca información es complicado poder deducir que estará pasando. Aquí te dice cómo proporcionar información de tu sistema:
Como mínimo un inxi -v7azy a ver qué tarjeta de red es.
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=ff951fd1-d16f-4244-b74a-df28e482a0c7 rw quiet
cryptdevice=UUID=55f319ce-ab64-4731-ada9-78205643ff92:luks-55f319ce-ab64-4731-ada9-78205643ff92
root=/dev/mapper/luks-55f319ce-ab64-4731-ada9-78205643ff92 splash
resume=/dev/mapper/luks-939dd901-b7bd-48ff-9414-2ee56727204e
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: ROG Strix G513RC_G513RC v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G513RC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513RC.327 date: 02/16/2023
ID-1: BAT0 charge: 46.3 Wh (100.0%) condition: 46.3/56.0 Wh (82.7%)
volts: 17.2 min: 15.9 model: AS3GWZC3KC G513-36 type: Unknown
serial: <filter> status: full
System RAM: total: 32 GiB note: est. available: 30.62 GiB
used: 3.21 GiB (10.5%)
Info: model: AMD Ryzen 7 6800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 524 high: 1397 min/max: 400/4785 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 1397
4: 400 5: 1397 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 102243
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2
class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 47.0 C
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x004d built: 2021
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:1681 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:25a2 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV REMBRANDT) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:1681 surfaces: xcb,xlib
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: off 3: wireplumber
status: active 4: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: off (using pipewire-pulse)
tools: pacat,pactl
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: N/A modules: mt7921e pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
IF-ID-1: enp7s0f4u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 0489:e0e2
Device-2: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 9-1:15 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Device-1: luks-939dd901-b7bd-48ff-9414-2ee56727204e maj-min: 254:1
type: LUKS dm: dm-1 size: 16 GiB
Components:
p-1: nvme1n1p2 maj-min: 259:9 size: 16 GiB
Device-2: luks-55f319ce-ab64-4731-ada9-78205643ff92 maj-min: 254:0
type: LUKS dm: dm-0 size: 80 GiB
Components:
p-1: nvme1n1p3 maj-min: 259:10 size: 80 GiB
Device-3: luks-9f606e12-1459-4902-8ca2-b0e03f2878db maj-min: 254:2
type: LUKS dm: dm-2 size: 704 GiB
Components:
p-1: nvme1n1p4 maj-min: 259:11 size: 704 GiB
Local Storage: total: 3.64 TiB used: 55.94 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 34.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 36.9 C
scheme: GPT
ID-1: / raw-size: 80 GiB size: 78.19 GiB (97.74%) used: 16.02 GiB (20.5%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-55f319ce-ab64-4731-ada9-78205643ff92 label: N/A
uuid: ff951fd1-d16f-4244-b74a-df28e482a0c7
ID-2: /boot/efi raw-size: 551 MiB size: 549.9 MiB (99.80%)
used: 452 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A
uuid: FC37-41FC
ID-3: /home raw-size: 704 GiB size: 691.88 GiB (98.28%)
used: 39.93 GiB (5.8%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
mapped: luks-9f606e12-1459-4902-8ca2-b0e03f2878db label: N/A
uuid: d1e44341-f008-4c72-ae94-fb32187dffc5
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-939dd901-b7bd-48ff-9414-2ee56727204e label: N/A
uuid: 49fb4f5b-822e-4cc9-8b00-72ce71a61153
ID-1: /dev/nvme0n1p2 maj-min: 259:3 size: 100 MiB fs: vfat label: N/A
uuid: 26D5-55A7
ID-2: /dev/nvme0n1p3 maj-min: 259:4 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:5 size: 699.37 GiB fs: ntfs label: N/A
uuid: 6C8230D18230A20E
ID-4: /dev/nvme0n1p5 maj-min: 259:6 size: 625 MiB fs: ntfs label: N/A
uuid: 3AD695A5D69561C5
ID-5: /dev/nvme0n1p6 maj-min: 259:7 size: 1.14 TiB fs: ntfs label: Home
uuid: 825648DE5648D497
ID-6: /dev/nvme1n1p1 maj-min: 259:8 size: 1.04 TiB fs: ntfs label: Home 2
uuid: 5C38827A388252C6
Device-1: 1-3:2 info: ASUSTek N-KEY Device type: keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
Device-2: 1-4:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Device-1: 3-2:2 info: Razer USA Basilisk V3 Pro type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00aa class-ID: 0301
serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 9-1:15 info: Samsung Galaxy series misc. (tethering mode)
type: bluetooth,CDC-data driver: rndis_host interfaces: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 04e8:6863
Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 53.4 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): cpu: 0
Processes: 371 Uptime: 33m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1164 libs: 352 tools: pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: kitty inxi: 3.3.31
Despues de reiniciar el wifi volvio a funcionar normalmente. Mi laptop tiene un dual boot y cuando ingresé a windows y volví a manjaro otra vez dejó de funcionar el wifi.
Tarjeta de red con chip Mediatek MT7922, parece que no eres el único con problemas con ese chip. En este hilo comentan que les sucede lo mismo y que es un problema con una actualización del firmware. Al final hay un enlace con una página de Github donde descargar e instalar el firmware corregido.
Lo hice y sigue sin funcionar
