i have recently installed manjaro and windows 11 as dual boot and i have selected manjaro as priority fo boot but when i start laptop its not showing boot menu and i have increased boot time =10 sec
Hi @Akash07, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Please also note and heed: https://wiki.manjaro.org/index.php/Forum_Rules#How_to_Post
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isnβt English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
This should help at least some:
Hope this helps!
hold the shift when booting
Add:
GRUB_TIMEOUT_STYLE=menu
in /etc/default/grub
Then run sudo update-grub and next reboot your menu should be visible with a counter that counts down from 10 (stops countdown if you use arrows)
