I installed manjaro in that I had issue that it was not properly shutting down my pc was always on and I had to to do it by pressing the power button. After a few days I started getting the not optimum mode resolution error. So I changed the monitor then on my tv it was showing a snowy screen after some use mostly after opening any app. I tried everything I could find online and tried it but it did not stop so I reinstall manjaro and I also got this snowy screen while installing and also in my new install. Now when I go to display settings and choose the refresh rate and hit apply it comes back to normal and then when I open any app it again show snowy screen.
Thanks in advance.
Hi @burhan2753y, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
