Disabling touch pad does nothing. Stays active
Hi, I’m trying to disable my touch pad when typing/having a mouse connected in order to avoid accidentally touching it and messing up what I’m doing. The problem is that when I use the shortcut to disable the touch pad (or from settings) nothing happens and the touch pad stays active.
I’m a noob so I have no idea what the problem could be. Help would be greatly appreciated.
  Kernel: 5.10.166-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=5b2f4576-aa65-4066-81d4-be35904882d2 rw quiet
    resume=UUID=b98b881e-881e-455c-b6f4-81e59765a558 udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412DA_F412DA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X412DA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X412DA.309 date: 10/23/2019
  ID-1: BAT0 charge: 26.9 Wh (100.0%) condition: 26.9/37.1 Wh (72.5%)
    volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 171
  RAM: total: 5.81 GiB used: 5.12 GiB (88.1%)
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108102
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1244 high: 1367 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1225 2: 1223
    3: 1367 4: 1223 5: 1223 6: 1223 7: 1230 8: 1238 bogomips: 33551
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
    sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
    ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 40.0 C
  Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-2.1:3 chip-ID: 13d3:56d3 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f7 built: 2019
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Vega 8 Graphics (raven
    LLVM 15.0.7 DRM 3.40 5.10.166-1-MANJARO) direct-render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Sound API: ALSA v: k5.10.166-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
    bus-ID: 3-2.2:4 chip-ID: 8087:0a2b class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 7 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 83.08 GiB (17.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPNUW-512G-1202 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 20200000 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
    used: 81.55 GiB (17.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 5b2f4576-aa65-4066-81d4-be35904882d2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 4D16-2FA0
  ID-1: swap-1 type: partition size: 8.8 GiB used: 1.53 GiB (17.3%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: b98b881e-881e-455c-b6f4-81e59765a558
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 058f:6254 class-ID: 0900
  Device-1: 3-2.1:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-2: 3-2.2:4 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-5: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 40.1 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Fan Speeds (RPM): cpu: 1900
  Processes: 269 Uptime: 1d 41m wakeups: 7 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 1398 pm: pacman pkgs: 1395 libs: 422 tools: pamac,yay pm: flatpak
  pkgs: 3 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.25
xinput
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ ELAN1201:00 04F3:30CE Mouse               id=11   [slave  pointer  (2)]
⎜   ↳ ELAN1201:00 04F3:30CE Touchpad            id=12   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ Sleep Button                              id=9    [slave  keyboard (3)]
    ↳ USB2.0 HD UVC WebCam: USB2.0 HD           id=10   [slave  keyboard (3)]
    ↳ Asus WMI hotkeys                          id=13   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=14   [slave  keyboard (3)]
lsusb (no mouse connected)
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 003 Device 003: ID 13d3:56d3 IMC Networks USB2.0 HD UVC WebCam
Bus 003 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lsusb (with mouse connected)
Bus 001 Device 002: ID 413c:301a Dell Computer Corp. Dell MS116 Optical Mouse
Hi @vosto, and welcome!
Well, call me stupid, call me lazy, just not late for dinner, but I am unable to find out more about your touchpad from the output you provided. Please see:
It might help.
However, that might not help, in which case I have to ask for more information. Please see:
Please also provide the output of:
xinput
and
lsusb
Hope you manage!
:bangbang: Tip: :bangbang:
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hi there.
I don’t have a perfect fix but depending on how much you want to use a mouse, I would consider de-activating the mouse at the BIOS level. I did that on a previous laptop & it works well.
Either way, I hope you find a fix soon.
Ruziel :slight_smile:
Hello! Thank you for your instructions, I’ve edited my post accordingly.
Apparently I didn’t have xinput installed and installing it solved my issue. Thanks!
