Hi.
When i disable firefox native gnome theme from manjaro layouts and restart my pc , gnome native theme enable automatically.
How I can fix this ?
Hi.
You also need it to remove it from startup application in gnome tweak tools
This is not intended behavior. Thank you for reporting it, I’ll look into fixing it. As a workaround, you can uninstall the firefox-gnome-theme-maia package.
So please fix this
I wait to fix this
I love manjaro and i can not able to do not use it
For now you can just remove the contents of ~/.mozilla/firefox/<your-profile>/chrome/
