Hi, I’ve dell precission and manjaro KDE Plasma. I use integrated Intel Corporation HD Graphics 530 but there’s NVIDIA Corporation GM107GLM [Quadro M1000M].
I set brigtness to max for intel (187) but I think it’s to low.
Kernel: 5.10.102-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=3153163c-1dfb-49aa-9940-b19b3cfc3155 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Precision 5510 v: N/A
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: 0N8J4R v: A01 serial: <superuser required> UEFI: Dell
v: 1.2.18 date: 12/01/2016
ID-1: BAT0 charge: 34.9 Wh (45.4%) condition: 76.9/84.0 Wh (91.5%)
volts: 10.9 min: 11.4 model: SMP DELL 1P6KD5A type: Li-poly serial: <filter>
status: Discharging
RAM: total: 31.18 GiB used: 3.55 GiB (11.4%)
RAM Report:
Info: model: Intel Core i7-6820HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 801 6: 800 7: 801 8: 800 bogomips: 43214
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm
sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107GLM [Quadro M1000M] vendor: Dell driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.0
chip-ID: 10de:13b1 class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-12:4 chip-ID: 1bcf:2b95 class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 676x380mm (26.6x15.0")
s-diag: 775mm (30.5")
Monitor-1: eDP-1 model: Sharp built: 2015 res: 2560x1440 hz: 60 dpi: 188
gamma: 1.2 size: 346x194mm (13.6x7.6") diag: 397mm (15.6") ratio: 16:9
modes: 3840x2160
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.10.102-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-4:3 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 232.89 GiB used: 106.93 GiB (45.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 28.9 C scheme: MBR
ID-1: / raw-size: 68.07 GiB size: 66.45 GiB (97.62%) used: 38.72 GiB (58.3%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 3153163c-1dfb-49aa-9940-b19b3cfc3155
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
label: NO_LABEL uuid: 43EB-29A0
ID-3: /home raw-size: 66.8 GiB size: 65.63 GiB (98.24%)
used: 30.13 GiB (45.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 5cc58584-4f87-4386-bfe5-da2807a85899
ID-4: /mnt raw-size: 97.72 GiB size: 95.19 GiB (97.41%)
used: 38.08 GiB (40.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: data uuid: 2804413c-b550-4b3c-9125-c5b58e94ad37
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2 info: Dell Universal Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 413c:301c class-ID: 0300
Device-2: 1-4:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-3: 1-12:4 info: Sunplus Innovation Integrated_Webcam_HD type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C pch: 40.5 C mobo: 29.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 271 Uptime: 44m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1397 pacman: 1380 lib: 369
flatpak: 10 snap: 7 Shell: Zsh v: 5.8.1 running-in: konsole inxi: 3.3.13
I wonder if changing to nvidia can allow you to increase the brightness of the screen compared to Intel?
