Dbus errors causing Kwallet to no longer work, system sluggish
Recently my system has begun to open kde applications and reboot slowly. Also, network manager was showing issues for accessing secrets from kwallet, but saving passwords as unencrypted allowed me to access wifi again.
Could the slow performance and kwallet be related? Disabling kwallet does not fix the issue even after a reboot, same with creating a new wallet.
Kernel: 5.15.32-1-MANJARO
Latest stable updates installed
Edit 1: KDE applications always take around 25-30 seconds to open, suggesting it is waiting for something to timeout?
Edit 2: I have also noticed that application icons, such as syncthing-gtk do not appear in the app tray anymore, even though the tray is responsive.
Edit 3: I seem to have narrowed it down to dbus errors, with the following error message:
Failed to register window menu, reason: org.freedesktop.DBus.Error.NoReply
post output from:
inxi -Fazy
try deleting your cache:
rm -rf ~/.cache/*
reboot
try creating new user, and check if you still have issues
Here is the inxi output:
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=d0e7d588-cb80-4997-a48f-9b0e01f8855a rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 20KHS05A00 v: ThinkPad X1 Carbon 6th
  Mobo: LENOVO model: 20KHS05A00 v: 0B98417 WIN serial: <superuser required>
    UEFI: LENOVO v: N23ET80W (1.55 ) date: 11/16/2021
  ID-1: BAT0 charge: 24.7 Wh (54.2%) condition: 45.6/57.0 Wh (80.0%)
    volts: 11.5 min: 11.6 model: LGC 01AV494 type: Li-poly serial: <filter>
    status: discharging cycles: 244
  Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 400/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 33615
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:5917 class-ID: 0300
  Device-2: Chicony Integrated IR Camera type: USB driver: uvcvideo
    bus-ID: 1-5:3 chip-ID: 04f2:b615 class-ID: 0e02
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-8:5 chip-ID: 04f2:b614 class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 120 s-size: 541x304mm (21.30x11.97")
    s-diag: 621mm (24.43")
  Monitor-1: eDP-1 model: LG Display 0x058b built: 2016 res: 2560x1440
    hz: 60 dpi: 210 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 2560x1440
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.8
    direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
    class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
  Local Storage: total: 953.87 GiB used: 467 GiB (49.0%)
    model: MZVLB1T0HALR-000L7 size: 953.87 GiB block-size: physical: 512 B
    rev: 5L2QEXA7 temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 137.97 GiB size: 134.75 GiB (97.66%)
    used: 26.43 GiB (19.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 815.39 GiB size: 802.35 GiB (98.40%)
    used: 440.57 GiB (54.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 34.0 C pch: 32.5 C mobo: N/A
  Fan Speeds (RPM): fan-1: 0
  Processes: 242 Uptime: 1m wakeups: 3 Memory: 15.38 GiB
  used: 1.56 GiB (10.1%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1390 lib: 388 flatpak: 0
  Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
I tried clearing the cache and that did not solve it. I will try creating a new user, but I was hoping to fix the current one.
you just create a new user just to check if it will have the same issues as your current user, not to replace it…
I’ll try that in a minute, but somehow, right after I posted my reply, it started responding as expected and the dbus errors were gone. Although upon reboot they returned. I have no idea what caused it to start working again.
I tried this, and it did fix the issue. I’m assuming this means the issue is somewhere in my home directory?
Also of note is that this is not the first time this has happened, I have another old account which upon checking again exhibits the exact same behavior. In that case, using a timeshift backup to roll back past some updates fixed it, but ultimately I created this new account which is now exhibiting the same behavior. The difference is I didn’t do a large set of updates right before it broke this time.
so if everything works in the new account, so you are correct, its probably some config(s) in home directory… so log into the faulty account and run these commands:
rm ~/.config/Trolltech.conf
kbuildsycoca5 --noincremental
reboot and check…
Following those commands did not work. I did keep a copy of Trolltech.conf and this is what it contained:
[qt]
GUIEffects=none
KDE\contrast=7
KWinPalette\activeBackground=#262626
KWinPalette\activeBlend=#262626
KWinPalette\activeForeground=#dedede
KWinPalette\activeTitleBtnBg=#262626
KWinPalette\frame=#262626
KWinPalette\inactiveBackground=#262626
KWinPalette\inactiveBlend=#262626
KWinPalette\inactiveForeground=#696969
KWinPalette\inactiveFrame=#262626
KWinPalette\inactiveTitleBtnBg=#262626
Palette\active=#dedede, #424242, #474747, #393939, #121212, #212121, #e3e3e3, #ffffff, #ffffff, #262626, #262626, #0d0d0d, #009185, #ffffff, #16decd, #0fcbf5, #262626, #000000, #4d4d4d, #e6e6e6, #e3e3e3
Palette\disabled=#626262, #3f3f3f, #464646, #383838, #121212, #1f1f1f, #636363, #ffffff, #7e7e7e, #242424, #242424, #0d0d0d, #242424, #626262, #1f625c, #1d5b69, #242424, #000000, #4d4d4d, #e6e6e6, #e3e3e3
Palette\inactive=#dedede, #424242, #474747, #393939, #121212, #212121, #e3e3e3, #ffffff, #ffffff, #262626, #262626, #0d0d0d, #08403b, #dedede, #16decd, #0fcbf5, #262626, #000000, #4d4d4d, #e6e6e6, #e3e3e3
font="Noto Sans,10,-1,0,50,0,0,0,0,0"
This is also exactly the same as what was recreated upon reboot.
thats unfortunate, we can try to reset plasma settings, so go to system settings/appearance/global theme and click ‘defaults’ click apply, then do this:
  1. Log out of KDE.
  2. Switch to TTY with CTRL + ALT + F2 - if f2 doesnt work, try f1-f6 instead
  3. Login in TTY with your username and password.
  4. Stop the Display Manager service:
sudo systemctl stop display-manager.service
  1. Run this command to reset the settings:
find $HOME/.config/ -maxdepth 1 -name 'plasma*' -exec rm {} \;
clear cache:
rm -rf ~/.cache/*
  1. reboot:
    systemctl reboot
Sadly this did not solve the issue. The dbus errors persist.
that was the last option that i can think off… you could wait if someone more competent responds, meanwhile use a new account where you dont have any issues … you could reboot and then provide logs with this command, maybe there will be something:
journalctl --boot=0 --priority=5 --no-pager
Here is the output from that command:
Output
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Linux version 5.15.32-1-MANJARO (builduser@fv-az83-713) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Mar 28 09:16:36 UTC 2022
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d0e7d588-cb80-4997-a48f-9b0e01f8855a rw quiet apparmor=1 security=apparmor udev.log_priority=3
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel:  #5 #6 #7
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=2000 audit(1652224308.033:1): state=initialized audit_enabled=0 res=1
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: SCSI subsystem initialized
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: VFS: Disk quotas dquot_6.6.0
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Initialise system trusted keyrings
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Key type blacklist registered
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Key type asymmetric registered
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Asymmetric key parser 'x509' registered
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: hpet_acpi_add: no address or irqs in _CRS
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Loading compiled-in X.509 certificates
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 9089b94c65a76d75665060005501fc15e9341c51'
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Key type ._fscrypt registered
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Key type .fscrypt registered
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: Key type fscrypt-provisioning registered
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: usb: port power management may be unreliable
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: random: fast init done
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: random: lvm: uninitialized urandom read (4 bytes read)
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: acpi_call: loading out-of-tree module taints kernel.
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: acpi_call: module verification failed: signature and/or required key missing - tainting kernel
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224309.606:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:49 harrison-ThinkPad-X1-Carbon systemd-random-seed[273]: Kernel entropy pool is not initialized yet, waiting until it is.
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224309.639:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652224309.642:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=283 comm="apparmor_parser"
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652224309.646:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=283 comm="apparmor_parser"
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224309.652:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224309.656:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: VBoxNetAdp: Successfully started.
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652224309.686:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=280 comm="apparmor_parser"
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652224309.702:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=286 comm="apparmor_parser"
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: VBoxNetFlt: Successfully started.
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652224309.726:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mariadbd_akonadi" pid=281 comm="apparmor_parser"
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
May 11 09:11:49 harrison-ThinkPad-X1-Carbon kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: caller snb_uncore_imc_init_box+0x82/0xd0 [intel_uncore] mapping multiple BARs
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: random: avahi-daemon: uninitialized urandom read (4 bytes read)
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: random: dbus-daemon: uninitialized urandom read (12 bytes read)
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: random: polkitd: uninitialized urandom read (8 bytes read)
May 11 09:11:50 harrison-ThinkPad-X1-Carbon polkitd[418]: Loading rules from directory /etc/polkit-1/rules.d
May 11 09:11:50 harrison-ThinkPad-X1-Carbon polkitd[418]: Loading rules from directory /usr/share/polkit-1/rules.d
May 11 09:11:50 harrison-ThinkPad-X1-Carbon polkitd[418]: Finished loading, compiling and executing 8 rules
May 11 09:11:50 harrison-ThinkPad-X1-Carbon polkitd[418]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
May 11 09:11:50 harrison-ThinkPad-X1-Carbon kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
May 11 09:11:51 harrison-ThinkPad-X1-Carbon kernel: random: crng init done
May 11 09:11:51 harrison-ThinkPad-X1-Carbon kernel: random: 5 urandom warning(s) missed due to ratelimiting
May 11 09:11:51 harrison-ThinkPad-X1-Carbon NetworkManager[436]: <warn>  [1652224311.6376] device (wlp2s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
May 11 09:11:52 harrison-ThinkPad-X1-Carbon systemd[875]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
May 11 09:11:53 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: QObject: Cannot create children for a parent that is in a different thread.
                                                               (Parent is QGuiApplication(0x7ffc3aedb7a0), parent's thread is QThread(0x55b86135e1e0), current thread is QThread(0x55b861481070)
May 11 09:11:53 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): Failed to disable ULP
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: kauditd_printk_skb: 80 callbacks suppressed
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224313.206:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:53 harrison-ThinkPad-X1-Carbon udisksd[1002]: udisks daemon version 2.9.4 starting
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224313.566:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224313.576:81): prog-id=20 op=LOAD
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224313.576:82): prog-id=21 op=LOAD
May 11 09:11:53 harrison-ThinkPad-X1-Carbon udisksd[1002]: Acquired the name org.freedesktop.UDisks2 on the system message bus
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224313.809:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:53 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224313.829:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:11:54 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
May 11 09:11:54 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
May 11 09:11:54 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
May 11 09:11:54 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: Cannot watch QRC-like path ":/icons/hicolor/index.theme"
May 11 09:11:54 harrison-ThinkPad-X1-Carbon sddm-greeter[884]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.34'
May 11 09:11:54 harrison-ThinkPad-X1-Carbon kernel: Bluetooth: hci0: Reading supported features failed (-16)
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1100 audit(1652224320.452:85): pid=1130 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1101 audit(1652224320.456:86): pid=1130 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1103 audit(1652224320.456:87): pid=1130 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1006 audit(1652224320.456:88): pid=1130 uid=0 subj==unconfined old-auid=4294967295 auid=1001 tty=(none) old-ses=4294967295 ses=3 res=1
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1300 audit(1652224320.456:88): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffdbb2a98e0 a2=4 a3=0 items=0 ppid=480 pid=1130 auid=1001 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1327 audit(1652224320.456:88): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746836346235643832352D646234612D346238652D393238352D393737323862623332333534002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652224320.506:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1001 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1101 audit(1652224320.522:90): pid=1132 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="hasmar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1103 audit(1652224320.522:91): pid=1132 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="hasmar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 11 09:12:00 harrison-ThinkPad-X1-Carbon kernel: audit: type=1006 audit(1652224320.522:92): pid=1132 uid=0 subj==unconfined old-auid=4294967295 auid=1001 tty=(none) old-ses=4294967295 ses=4 res=1
May 11 09:12:00 harrison-ThinkPad-X1-Carbon systemd[1132]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[hasmar] ruser=[<unknown>] rhost=[<unknown>]
May 11 09:12:01 harrison-ThinkPad-X1-Carbon ksplashqml[1157]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:33: ReferenceError: size is not defined
May 11 09:12:01 harrison-ThinkPad-X1-Carbon ksplashqml[1157]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:32: ReferenceError: size is not defined
May 11 09:12:01 harrison-ThinkPad-X1-Carbon ksplashqml[1157]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:58: ReferenceError: size is not defined
May 11 09:12:01 harrison-ThinkPad-X1-Carbon ksplashqml[1157]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:57: ReferenceError: size is not defined
May 11 09:12:01 harrison-ThinkPad-X1-Carbon klauncher[1188]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
May 11 09:12:02 harrison-ThinkPad-X1-Carbon kcminit_startup[1206]: QDBusConnection: error: could not send signal to service "" path "//home/hasmar/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/hasmar/.kde4/share/config/kdeglobals
May 11 09:12:02 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
May 11 09:12:02 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
May 11 09:12:02 harrison-ThinkPad-X1-Carbon kded5[1219]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.9'
May 11 09:12:03 harrison-ThinkPad-X1-Carbon kded5[1219]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: cannot open shared object file: No such file or directory)"
May 11 09:12:03 harrison-ThinkPad-X1-Carbon ksmserver[1281]: Qt: Session management error: networkIdsList argument is NULL
May 11 09:12:03 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: kwin_core: XCB error: 10 (BadAccess), sequence: 809, resource id: 1961, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
May 11 09:12:03 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 910, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
May 11 09:12:03 harrison-ThinkPad-X1-Carbon polkitd[418]: Registered Authentication Agent for unix-session:3 (system bus name :1.55 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_AU.UTF-8)
May 11 09:12:04 harrison-ThinkPad-X1-Carbon org_kde_powerdevil[1311]: org.kde.powerdevil: Handle button events action could not check for screen configuration
May 11 09:12:04 harrison-ThinkPad-X1-Carbon pulseaudio[1323]: stat('/etc/pulse/default.pa.d'): No such file or directory
May 11 09:12:04 harrison-ThinkPad-X1-Carbon plasmashell[1303]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
May 11 09:12:04 harrison-ThinkPad-X1-Carbon plasmashell[1303]: trying to show an empty dialog
May 11 09:12:04 harrison-ThinkPad-X1-Carbon plasmashell[1303]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:118:19: QML Loader: Binding loop detected for property "height"
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5605244547e0)
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5605244c79c0)
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Entry is not valid "org.kde.discover" QSharedPointer(0x5605244c7620)
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5605244c74a0)
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5605244c8130)
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Entry is not valid "org.kde.discover" QSharedPointer(0x5605244c7670)
May 11 09:12:05 harrison-ThinkPad-X1-Carbon gnome-keyring-daemon[1513]: couldn't access control socket: /run/user/1001/keyring/control: No such file or directory
May 11 09:12:05 harrison-ThinkPad-X1-Carbon gnome-keyring-d[1513]: couldn't access control socket: /run/user/1001/keyring/control: No such file or directory
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: trying to show an empty dialog
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
May 11 09:12:05 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1885, resource id: 54525955, major code: 12 (ConfigureWindow), minor code: 0
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:118:19: QML Loader: Binding loop detected for property "height"
May 11 09:12:05 harrison-ThinkPad-X1-Carbon plasmashell[1303]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
May 11 09:12:06 harrison-ThinkPad-X1-Carbon plasmashell[1303]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
May 11 09:12:06 harrison-ThinkPad-X1-Carbon plasmashell[1303]: trying to show an empty dialog
May 11 09:12:08 harrison-ThinkPad-X1-Carbon plasmashell[1303]: trying to show an empty dialog
May 11 09:12:09 harrison-ThinkPad-X1-Carbon plasmashell[1303]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
May 11 09:12:09 harrison-ThinkPad-X1-Carbon plasmashell[1303]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
May 11 09:12:10 harrison-ThinkPad-X1-Carbon systemd[876]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
May 11 09:12:10 harrison-ThinkPad-X1-Carbon kernel: kauditd_printk_skb: 17 callbacks suppressed
May 11 09:12:10 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652224330.816:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:10 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652224330.826:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:11 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5457, resource id: 62914566, major code: 18 (ChangeProperty), minor code: 0
May 11 09:12:11 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652224331.889:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:21 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652224341.982:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:22 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224342.012:108): prog-id=0 op=UNLOAD
May 11 09:12:22 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224342.012:109): prog-id=0 op=UNLOAD
May 11 09:12:22 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224342.012:110): prog-id=0 op=UNLOAD
May 11 09:12:24 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652224344.259:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 11 09:12:24 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224344.389:112): prog-id=0 op=UNLOAD
May 11 09:12:24 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224344.389:113): prog-id=0 op=UNLOAD
May 11 09:12:24 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652224344.389:114): prog-id=0 op=UNLOAD
May 11 09:12:29 harrison-ThinkPad-X1-Carbon msm_kde_notifier[1318]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
May 11 09:12:29 harrison-ThinkPad-X1-Carbon pamac-tray-plasma[1320]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
May 11 09:12:29 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13610, resource id: 4194349, major code: 18 (ChangeProperty), minor code: 0
May 11 09:12:29 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: kwin_core: XCB error: 152 (BadDamage), sequence: 13612, resource id: 16777261, major code: 143 (DAMAGE), minor code: 3 (Subtract)
May 11 09:12:30 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: kde.xembedsniproxy: could not register SNI: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 11 09:12:31 harrison-ThinkPad-X1-Carbon plasmashell[1303]: kde.keyboardlayout: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 11 09:12:34 harrison-ThinkPad-X1-Carbon plasmashell[1303]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:366: Unable to assign [undefined] to QString
May 11 09:12:34 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 14169, resource id: 46137469, major code: 18 (ChangeProperty), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: kde.xembedsniproxy: could not register SNI: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 444, resource id: 54525955, major code: 7 (ReparentWindow), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 446, resource id: 54525955, major code: 142 (Unknown), minor code: 1
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 447, resource id: 54525955, major code: 6 (ChangeSaveSet), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 448, resource id: 54525955, major code: 25 (SendEvent), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 449, resource id: 54525955, major code: 12 (ConfigureWindow), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 451, resource id: 54525955, major code: 12 (ConfigureWindow), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 452, resource id: 54525955, major code: 8 (MapWindow), minor code: 0
May 11 09:12:55 harrison-ThinkPad-X1-Carbon xembedsniproxy[1309]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 453, resource id: 54525955, major code: 61 (ClearArea), minor code: 0
May 11 09:12:59 harrison-ThinkPad-X1-Carbon konsole[1583]: Failed to register window menu, reason: org.freedesktop.DBus.Error.NoReply ("Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
May 11 09:13:00 harrison-ThinkPad-X1-Carbon kwin_x11[1222]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Installing the latest stable updates fixed my issues! ([Stable Update] 2022-05-13 - Kernels, Mesa, Nvidia, Gnome 42, PipeWire, LIbreOffice, KDE Gear & Frameworks, Virtualbox, Qemu 7.0)
Below is the output of the same command after the updates, so maybe someone can pinpoint what was causing the issues:
Output
May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Linux version 5.15.38-1-MANJARO (builduser@fv-az38-945) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon May 9 07:52:21 UTC 2022 May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d0e7d588-cb80-4997-a48f-9b0e01f8855a rw quiet apparmor=1 security=apparmor udev.log_priority=3 May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space. May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0 May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details. May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: #5 #6 #7 May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=2000 audit(1652500711.026:1): state=initialized audit_enabled=0 res=1 May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance' May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: SCSI subsystem initialized May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: VFS: Disk quotas dquot_6.6.0 May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Initialise system trusted keyrings May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Key type blacklist registered May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Key type asymmetric registered May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Asymmetric key parser 'x509' registered May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: hpet_acpi_add: no address or irqs in _CRS May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Loading compiled-in X.509 certificates May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 1a38abe742a4d3b383eb89e2d4c7a2540cf16ee9' May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Key type ._fscrypt registered May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Key type .fscrypt registered May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: Key type fscrypt-provisioning registered May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: random: fast init done May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: usb: port power management may be unreliable May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: random: lvm: uninitialized urandom read (4 bytes read) May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: acpi_call: loading out-of-tree module taints kernel. May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: acpi_call: module verification failed: signature and/or required key missing - tainting kernel May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652500712.677:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=282 comm="apparmor_parser" May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500712.684:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: VBoxNetAdp: Successfully started. May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: VBoxNetFlt: Successfully started. May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500712.707:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652500712.717:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=288 comm="apparmor_parser" May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500712.724:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652500712.747:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=285 comm="apparmor_parser" May 14 13:58:32 harrison-ThinkPad-X1-Carbon systemd-random-seed[278]: Kernel entropy pool is not initialized yet, waiting until it is. May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500712.747:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652500712.750:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=285 comm="apparmor_parser" May 14 13:58:32 harrison-ThinkPad-X1-Carbon kernel: audit: type=1400 audit(1652500712.754:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mariadbd_akonadi" pid=283 comm="apparmor_parser" May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: thinkpad_acpi: Disabling thinkpad-acpi brightness events by default... May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff] May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: caller snb_uncore_imc_init_box+0x82/0xd0 [intel_uncore] mapping multiple BARs May 14 13:58:33 harrison-ThinkPad-X1-Carbon systemd-udevd[303]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: random: avahi-daemon: uninitialized urandom read (4 bytes read) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: random: dbus-daemon: uninitialized urandom read (12 bytes read) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: thermal thermal_zone5: failed to read out thermal zone (-61) May 14 13:58:33 harrison-ThinkPad-X1-Carbon kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read) May 14 13:58:34 harrison-ThinkPad-X1-Carbon polkitd[461]: Loading rules from directory /etc/polkit-1/rules.d May 14 13:58:34 harrison-ThinkPad-X1-Carbon polkitd[461]: Loading rules from directory /usr/share/polkit-1/rules.d May 14 13:58:34 harrison-ThinkPad-X1-Carbon polkitd[461]: Finished loading, compiling and executing 8 rules May 14 13:58:34 harrison-ThinkPad-X1-Carbon polkitd[461]: Acquired the name org.freedesktop.PolicyKit1 on the system bus May 14 13:58:34 harrison-ThinkPad-X1-Carbon kernel: random: crng init done May 14 13:58:34 harrison-ThinkPad-X1-Carbon kernel: random: 4 urandom warning(s) missed due to ratelimiting May 14 13:58:35 harrison-ThinkPad-X1-Carbon NetworkManager[472]: <warn> [1652500715.0891] device (wlp2s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable May 14 13:58:35 harrison-ThinkPad-X1-Carbon kernel: snd_hda_codec_hdmi hdaudioC0D2: Monitor plugged-in, Failed to power up codec ret=[-13] May 14 13:58:36 harrison-ThinkPad-X1-Carbon kernel: scsi 0:0:0:0: Direct-Access Generic MassStorageClass 1539 PQ: 0 ANSI: 6 May 14 13:58:36 harrison-ThinkPad-X1-Carbon kernel: scsi 0:0:0:1: Direct-Access Generic MassStorageClass 1539 PQ: 0 ANSI: 6 May 14 13:58:36 harrison-ThinkPad-X1-Carbon kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0 May 14 13:58:36 harrison-ThinkPad-X1-Carbon kernel: sd 0:0:0:0: [sda] Media removed, stopped polling May 14 13:58:36 harrison-ThinkPad-X1-Carbon kernel: sd 0:0:0:1: Attached scsi generic sg1 type 0 May 14 13:58:37 harrison-ThinkPad-X1-Carbon kernel: sd 0:0:0:1: [sdb] Media removed, stopped polling May 14 13:58:37 harrison-ThinkPad-X1-Carbon kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk May 14 13:58:37 harrison-ThinkPad-X1-Carbon kernel: sd 0:0:0:1: [sdb] Attached SCSI removable disk May 14 13:58:37 harrison-ThinkPad-X1-Carbon kernel: kauditd_printk_skb: 67 callbacks suppressed May 14 13:58:37 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500717.354:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:38 harrison-ThinkPad-X1-Carbon kernel: Bluetooth: hci0: Reading supported features failed (-16) May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1100 audit(1652500722.120:71): pid=1711 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success' May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1101 audit(1652500722.120:72): pid=1711 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success' May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1103 audit(1652500722.120:73): pid=1711 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success' May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500722.134:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:42 harrison-ThinkPad-X1-Carbon systemd[1713]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>] May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1101 audit(1652500722.144:75): pid=1713 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1103 audit(1652500722.144:76): pid=1713 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed' May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1006 audit(1652500722.144:77): pid=1713 uid=0 subj==unconfined old-auid=4294967295 auid=963 tty=(none) old-ses=4294967295 ses=2 res=1 May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1300 audit(1652500722.144:77): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffdef60d250 a2=3 a3=0 items=0 ppid=1 pid=1713 auid=963 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null) May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1327 audit(1652500722.144:77): proctitle="(systemd)" May 14 13:58:42 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QObject: Cannot create children for a parent that is in a different thread. (Parent is QGuiApplication(0x7ffc60756e90), parent's thread is QThread(0x55cdb3f571e0), current thread is QThread(0x55cdb4157b50) May 14 13:58:42 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QObject: Cannot create children for a parent that is in a different thread. (Parent is QGuiApplication(0x7ffc60756e90), parent's thread is QThread(0x55cdb3f571e0), current thread is QThread(0x55cdb4157b50) May 14 13:58:42 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QObject: Cannot create children for a parent that is in a different thread. (Parent is QGuiApplication(0x7ffc60756e90), parent's thread is QThread(0x55cdb3f571e0), current thread is QThread(0x55cdb4157b50) May 14 13:58:42 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QObject::installEventFilter(): Cannot filter events for objects in a different thread. May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: kauditd_printk_skb: 7 callbacks suppressed May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500722.897:83): prog-id=20 op=LOAD May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1300 audit(1652500722.897:83): arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7fffdb341a70 a2=80 a3=7fffdb341a70 items=0 ppid=1 pid=472 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null) May 14 13:58:42 harrison-ThinkPad-X1-Carbon kernel: audit: type=1327 audit(1652500722.897:83): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E May 14 13:58:43 harrison-ThinkPad-X1-Carbon udisksd[1739]: udisks daemon version 2.9.4 starting May 14 13:58:43 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500723.424:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:43 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500723.434:85): prog-id=21 op=LOAD May 14 13:58:43 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500723.434:86): prog-id=22 op=LOAD May 14 13:58:43 harrison-ThinkPad-X1-Carbon udisksd[1739]: Acquired the name org.freedesktop.UDisks2 on the system message bus May 14 13:58:43 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500723.537:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QQmlEngine::setContextForObject(): Object already has a QQmlContext May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QQmlEngine::setContextForObject(): Object already has a QQmlContext May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QQmlEngine::setContextForObject(): Object already has a QQmlContext May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QQmlEngine::setContextForObject(): Object already has a QQmlContext May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed May 14 13:58:43 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: Cannot watch QRC-like path ":/icons/hicolor/index.theme" May 14 13:58:44 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500724.300:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:58:44 harrison-ThinkPad-X1-Carbon sddm-greeter[1722]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.34' May 14 13:59:06 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500746.442:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:06 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500746.469:90): prog-id=0 op=UNLOAD May 14 13:59:06 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500746.469:91): prog-id=0 op=UNLOAD May 14 13:59:06 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500746.469:92): prog-id=0 op=UNLOAD May 14 13:59:08 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500748.865:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:08 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500748.989:94): prog-id=0 op=UNLOAD May 14 13:59:08 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500748.989:95): prog-id=0 op=UNLOAD May 14 13:59:08 harrison-ThinkPad-X1-Carbon kernel: audit: type=1334 audit(1652500748.989:96): prog-id=0 op=UNLOAD May 14 13:59:11 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500751.345:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:25 harrison-ThinkPad-X1-Carbon upowerd[1753]: treated changed event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3.4/1-3.3.4:1.2/0003:046D:C539.0009/0003:046D:4079.000B/power_supply/hidpp_battery_0 May 14 13:59:29 harrison-ThinkPad-X1-Carbon sddm-helper[1782]: pam_unix(sddm:auth): authentication failure; logname= uid=0 euid=0 tty= ruser= rhost= user=hasmar May 14 13:59:29 harrison-ThinkPad-X1-Carbon kernel: audit: type=1100 audit(1652500769.502:98): pid=1782 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=? acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=failed' May 14 13:59:31 harrison-ThinkPad-X1-Carbon sddm-helper[1782]: [PAM] authenticate: Authentication failure May 14 13:59:31 harrison-ThinkPad-X1-Carbon sddm[534]: Authentication error: "Authentication failure" May 14 13:59:31 harrison-ThinkPad-X1-Carbon sddm[534]: Auth: sddm-helper exited with 1 May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1100 audit(1652500775.645:99): pid=1783 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success' May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1101 audit(1652500775.649:100): pid=1783 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success' May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1103 audit(1652500775.649:101): pid=1783 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="hasmar" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success' May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1006 audit(1652500775.649:102): pid=1783 uid=0 subj==unconfined old-auid=4294967295 auid=1001 tty=(none) old-ses=4294967295 ses=3 res=1 May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1300 audit(1652500775.649:102): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffc26e6c4f0 a2=4 a3=0 items=0 ppid=534 pid=1783 auid=1001 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=3 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null) May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1327 audit(1652500775.649:102): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746861376464333536312D363435612D346635652D613136302D346566316562633932353837002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1130 audit(1652500775.665:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1001 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:35 harrison-ThinkPad-X1-Carbon systemd[1785]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[hasmar] ruser=[<unknown>] rhost=[<unknown>] May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1101 audit(1652500775.672:104): pid=1785 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="hasmar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1103 audit(1652500775.672:105): pid=1785 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="hasmar" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed' May 14 13:59:35 harrison-ThinkPad-X1-Carbon kernel: audit: type=1006 audit(1652500775.672:106): pid=1785 uid=0 subj==unconfined old-auid=4294967295 auid=1001 tty=(none) old-ses=4294967295 ses=4 res=1 May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:33: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:32: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:58: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:57: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:33: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:32: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:58: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:57: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:33: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:32: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:58: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon ksplashqml[1810]: file:///home/hasmar/.local/share/plasma/look-and-feel/Materia-Manjaro-Dark/contents/splash/Splash.qml:57: ReferenceError: size is not defined May 14 13:59:36 harrison-ThinkPad-X1-Carbon klauncher[1841]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString) May 14 13:59:36 harrison-ThinkPad-X1-Carbon kcminit_startup[1849]: QDBusConnection: error: could not send signal to service "" path "//home/hasmar/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/hasmar/.kde4/share/config/kdeglobals May 14 13:59:37 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing. May 14 13:59:38 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker" May 14 13:59:38 harrison-ThinkPad-X1-Carbon kded5[1856]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.9' May 14 13:59:38 harrison-ThinkPad-X1-Carbon kded5[1856]: Unknown ActionDataBase type read from cfg file May 14 13:59:38 harrison-ThinkPad-X1-Carbon ksmserver[1940]: Qt: Session management error: networkIdsList argument is NULL May 14 13:59:38 harrison-ThinkPad-X1-Carbon kded5[1856]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: cannot open shared object file: No such file or directory)" May 14 13:59:39 harrison-ThinkPad-X1-Carbon kded5[1856]: kscreen.kded: PowerDevil SuspendSession action not available! May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: kwin_core: XCB error: 10 (BadAccess), sequence: 874, resource id: 1995, major code: 142 (Composite), minor code: 2 (RedirectSubwindows) May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1021, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon polkitd[461]: Registered Authentication Agent for unix-session:3 (system bus name :1.56 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_AU.UTF-8) May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1189, resource id: 14680127, major code: 3 (GetWindowAttributes), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1190, resource id: 14680127, major code: 14 (GetGeometry), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1193, resource id: 14680128, major code: 3 (GetWindowAttributes), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1194, resource id: 14680128, major code: 14 (GetGeometry), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1197, resource id: 14680129, major code: 3 (GetWindowAttributes), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1198, resource id: 14680129, major code: 14 (GetGeometry), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1201, resource id: 14680130, major code: 3 (GetWindowAttributes), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1202, resource id: 14680130, major code: 14 (GetGeometry), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1210, resource id: 14680131, major code: 3 (GetWindowAttributes), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1211, resource id: 14680131, major code: 14 (GetGeometry), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1214, resource id: 14680132, major code: 3 (GetWindowAttributes), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1215, resource id: 14680132, major code: 14 (GetGeometry), minor code: 0 May 14 13:59:40 harrison-ThinkPad-X1-Carbon org_kde_powerdevil[1965]: org.kde.powerdevil: Handle button events action could not check for screen configuration May 14 13:59:40 harrison-ThinkPad-X1-Carbon pulseaudio[1989]: stat('/etc/pulse/default.pa.d'): No such file or directory May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead. May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead. May 14 13:59:41 harrison-ThinkPad-X1-Carbon gnome-keyring-daemon[2177]: couldn't access control socket: /run/user/1001/keyring/control: No such file or directory May 14 13:59:41 harrison-ThinkPad-X1-Carbon gnome-keyring-d[2177]: couldn't access control socket: /run/user/1001/keyring/control: No such file or directory May 14 13:59:41 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2491, resource id: 4194387, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:41 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: kwin_core: XCB error: 152 (BadDamage), sequence: 2493, resource id: 14680108, major code: 143 (DAMAGE), minor code: 3 (Subtract) May 14 13:59:41 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: kwin_core: XCB error: 152 (BadDamage), sequence: 2497, resource id: 14680109, major code: 143 (DAMAGE), minor code: 3 (Subtract) May 14 13:59:41 harrison-ThinkPad-X1-Carbon xembedsniproxy[1969]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 467, resource id: 56623107, major code: 12 (ConfigureWindow), minor code: 0 May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5578c8026e00) May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5578c8057d10) May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Entry is not valid "org.kde.discover" QSharedPointer(0x5578c8026e50) May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5578c8057d10) May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5578c802f290) May 14 13:59:41 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Entry is not valid "org.kde.discover" QSharedPointer(0x5578c8057e20) May 14 13:59:42 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth" May 14 13:59:42 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml" May 14 13:59:43 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight" May 14 13:59:43 harrison-ThinkPad-X1-Carbon plasmashell[1964]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead. May 14 13:59:43 harrison-ThinkPad-X1-Carbon plasmashell[1964]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0 May 14 13:59:45 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool May 14 13:59:45 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations. May 14 13:59:45 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations. May 14 13:59:45 harrison-ThinkPad-X1-Carbon systemd[1714]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>] May 14 13:59:45 harrison-ThinkPad-X1-Carbon kernel: kauditd_printk_skb: 16 callbacks suppressed May 14 13:59:45 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500785.919:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:45 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500785.925:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5578c9b85d60) QQmlContext(0x5578c82a42e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml") May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5578c9b85d60) QQmlContext(0x5578c82a42e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml") May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth" May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth" May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight" May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5578c97995e0) QQmlContext(0x5578c82a42e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml") May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5578c97995e0) QQmlContext(0x5578c82a42e0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml") May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth" May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitWidth" May 14 13:59:46 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:219:21: QML SelectableLabel: Binding loop detected for property "implicitHeight" May 14 13:59:46 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4164, resource id: 46137475, major code: 15 (QueryTree), minor code: 0 May 14 13:59:47 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4479, resource id: 4194310, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:47 harrison-ThinkPad-X1-Carbon kernel: audit: type=1131 audit(1652500787.379:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success' May 14 13:59:51 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString May 14 13:59:51 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString May 14 13:59:51 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8109, resource id: 46137554, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:51 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 8114, resource id: 46137555, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:51 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations. May 14 13:59:52 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9708, resource id: 46137493, major code: 20 (GetProperty), minor code: 0 May 14 13:59:52 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9709, resource id: 46137493, major code: 15 (QueryTree), minor code: 0 May 14 13:59:52 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: kwin_core: XCB error: 152 (BadDamage), sequence: 9780, resource id: 14680376, major code: 143 (DAMAGE), minor code: 3 (Subtract) May 14 13:59:53 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10337, resource id: 67108875, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:53 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10341, resource id: 4194327, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:53 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 10360, resource id: 46137557, major code: 18 (ChangeProperty), minor code: 0 May 14 13:59:55 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString May 14 13:59:55 harrison-ThinkPad-X1-Carbon plasmashell[1964]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:370: Unable to assign [undefined] to QString May 14 13:59:55 harrison-ThinkPad-X1-Carbon kwin_x11[1859]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11469, resource id: 46137576, major code: 18 (ChangeProperty), minor code: 0
Now that this is solved, I am going to close this issue.
