Hello complete Arch noob here trying to make the switch from ubuntu over to manjaro on my daily driver.
I have a usb to hdm display link device i need for work and need to get up and running asap. I have been using ubuntu for years but admittedly im mostly a gui guy.
Ive looked at the arch wiki link and its mostly greek to me
but this is mostly greek to me so to speak.
What i have managed to do so far in term is
pamac build displaylink
and
pamac build evdi-git
and
systemctl enable displaylink.service
and lastly
stemctl start displaylink.service
after doing all this i still have a black screen. Forgive my ignorance literally my first day of arch / manjaro and need this for work really dont want to have to go back to windows at this point.
Thank you
cscs
26 October 2021 23:50
2
Hi,
Some things first.
I assume this is a typo? Should be systemctl as shown in previous command.
mikemach:
evdi-git
Is there a reason you used the git version? Thats the ‘development’ one. evdi exists.
Now… we have some final steps:
You need to use modesetting driver with accelmethod ‘none’ by creating this file:
/etc/X11/xorg.conf.d/99-evdi.conf
with this content:
Section "OutputClass"
Identifier "DisplayLink"
MatchDriver "evdi"
Driver "modesetting"
Option "AccelMethod" "none"
EndSection
(you can use something like sudo nano /etc/X11/xorg.conf.d/99-evdi.conf to make/edit the file)
After a reboot use xrandr ;
xrandr --listproviders
And you should see something like your system at location 0 and displaylink/modesetting at 1
(these numbers may not match but we will use them in the following example)
So then you could use command
xrandr --setprovideroutputsource 1 0
For more info see here: DisplayLink - ArchWiki
Followed what you had listed
after using xrandr --listproviders
i get Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 4 associated providers: 0 name:NVIDIA-0
No displaylink
if i try to enable and start the service using the commands i provided i get a error using the command to see the error i get
Loaded: loaded (/usr/lib/systemd/system/displaylink.service; enabled; vendor preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2021-10-26 12:37:53 MDT; 4s ago
Process: 2163 ExecStartPre=/sbin/modprobe evdi (code=exited, status=1/FAILURE)
any ideas?
cscs
27 October 2021 01:59
4
The error seems to state the module cannot be initialized.
(command sudo modprobe evdi if you want to try manually)
Did you stick with the evdi-git or replace it with evdi ?
I would try that for sure.
I did a reset ( fresh install and used the original evdi as directed )
the sudo modprobe presents
modprobe: FATAL: Module evdi not found in directory /lib/modules/5.13.19-2-MANJARO
cscs
27 October 2021 02:04
7
OK… that at least gets us somewhere.
5.13 is EOL now anyways … so lets drop you down to 5.10 LTS
(sort your mirrors and update first;)
sudo pacman-mirrors -g && sudo pacman -Syyu
sudo mhwd-kernel -i linux510
###reboot..
systemctl reboot
You should be able to select the new kernel at boot … if you do not see grub menu please tap Shift or Esc
Oh. Also … since you mentioned evdi, and no automatic connection, I assumed it may be USB3 … can you please verify if it is usb2 or usb3 ?
now when i sudo modprobe i get
modprobe: FATAL: Module evdi not found in directory /lib/modules/5.10.70-1-MANJARO
yes it is usb 3
still only one provider listed with
cscs
27 October 2021 02:49
9
OK… lets make sure of some things again:
You should have the headers and git and base-devel …
sudo pacman -Syu linux510-headers base-devel git
(let me know if any of those were not installed)
Then lets rebuild those AUR packages
pamac build displaylink evdi
(I am also assuming we still have our config file created earlier)
Then lets restart again
mikemach:
yes the config file is still there did everything listed
I now see two providers
ran ```
and rebooted screen still blank and doesnt show in monitor manager
cscs
27 October 2021 03:15
11
But wait we got somewhere … please show the output of the listproviders command
And since we are here, also please
lsmod | grep udl
PS
Sorry this is taking a little work - I cant remember the last time I troubleshot displaylink, if ever
mikemach:
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 4 outputs: 4 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x215 cap: 0x2, Sink Output crtcs: 1 outputs: 1 associated providers: 1 name:modesetting
lsmod | grep udl gives no output
cscs
27 October 2021 03:22
13
Hm.
Sorry to ask for one more thing.
I should have asked earlier (maybe append the output to your first post for other eyes)
inxi -Fazy
cant post that output thinks its a link…
cscs
27 October 2021 03:30
15
yes unless im doing it wrong… not sure how else to get it on here
cscs
27 October 2021 03:42
17
Hmm.
inxi -Fazy | curl -F 'file=@-' https://0x0.st
will send it to a host and print a short link.
Even if you cant post that link, just break it up somehow like this “manjaroDOTorg” or “manjaro . org” … or similar.
cscs
27 October 2021 04:07
19
I am at a bit of a loss.
I suppose you could try some of the other things mentioned in the Archwiki above.
ooof , Ive looked at the arch wiki its greek to me would rather not have to go back to windows but i need the extra display…
