Dont despair. I admittedly was just taking a stab. Hopefully someone else drops by.
For just checking …
sudo modprobe udl
And what does the service report now?
systemctl status displaylink
For just checking …
sudo modprobe udl
all good just a bit frustrated with it not you
displaylink.service - DisplayLink Manager Service
Loaded: loaded (/usr/lib/systemd/system/displaylink.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-10-26 14:11:14 MDT; 1h 9min ago
Main PID: 585 (DisplayLinkMana)
Tasks: 28 (limit: 19127)
Memory: 56.4M
CPU: 3.250s
CGroup: /system.slice/displaylink.service
└─585 /usr/lib/displaylink/DisplayLinkManager
Oct 26 14:11:14 michael-Stormwind systemd[1]: Starting DisplayLink Manager Service…
Oct 26 14:11:14 michael-Stormwind systemd[1]: Started DisplayLink Manager Service.
I’m using original evdi, the service is running but the screen is still blank, I’ve tried on both 5.15 & 5.10 kernel. I’m using USB 3
● displaylink.service - DisplayLink Manager Service
Active: active (running) since Sat 2022-01-01 01:52:02 +07; 3min 34s ago
Process: 552 ExecStartPre=/sbin/modprobe evdi (code=exited, status=0/SUCCESS)
Main PID: 579 (DisplayLinkMana)
Tasks: 7 (limit: 19114)
Memory: 7.2M
CPU: 15ms
└─579 /usr/lib/displaylink/DisplayLinkManager
Thg 1 01 01:52:02 jackson-ms7b46 systemd[1]: Starting DisplayLink Manager Service...
Thg 1 01 01:52:02 jackson-ms7b46 systemd[1]: Started DisplayLink Manager Service.
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x59 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 6 outputs: 5 associated providers: 0 name:AMD Radeon RX 580 Series @ pci:0000:01:00.0
I have added this as well
inxi -Fazy
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b6e65f37-4be7-49ba-9be4-03dabf67f0a0 rw quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: Micro-Star model: Z370 KRAIT GAMING (MS-7B46) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.40
date: 05/15/2018
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 801 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Device-2: DisplayLink MB16AC type: USB driver: N/A bus-ID: 4-1.2:3
chip-ID: 17e9:4374 class-ID: fe01 serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-11:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 942.7 GiB used: 294.86 GiB (31.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: KC45 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Plextor model: PX-G512M6eA
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 93.43 GiB size: 91.4 GiB (97.83%) used: 22.71 GiB (24.9%)
fs: ext4 dev: /dev/sdb7 maj-min: 8:23
ID-2: /boot/efi raw-size: 329 MiB size: 126 MiB (38.30%)
used: 29.5 MiB (23.4%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1064
Processes: 363 Uptime: 1m wakeups: 0 Memory: 15.58 GiB
used: 1.79 GiB (11.5%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1178 lib: 306 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.11
