Clevo NS50AU Bluetooth and Wireless not working
Hi all! I am a long time debian user who recently discovered manjaro. I have not had so much problems before, but my current workplace supplier offered me ‘linux first’ laptops and I thought that was cool, so I ordered one main laptop and one ‘backup’. Both have a lot of issues on any linux distro, but in this topic I will focus on my ‘backup’ laptop which is a Clevo NS50AU that came preinstalled with Ubuntu 22.04.
When I booted it I noticed that bluetooth and wlan were not working, but since I had already seen some issues with my previous work laptop that had just given up its breath by being unable to resume from sleep I decided to see if it could be worked out by finding a specific kernel/driver configuration.
Unfortunately I haven’t had any luck with this approach and I am hoping that someone here can help me decide if this is something that can be sorted out eg by using an older kernel/distro or if there is actually a hardware problem with the network card, in which case I believe the warranty is still active.
I can use a wired network and I can use network over USB. I cannot detect or switch on bluetooth or wireless eg in settings on manjaro gnome/kde / ubuntu 18,22,24
I have tried installing the tuxedo drivers and also the entire distro, which had the same issues.
I will append some info below and will be immensely grateful for any help that you can provide!
    ~  mhwd -lh         1 ✘
> PCI devices:
                          TYPE            BUS   CLASS  VENDOR  DEVICE   CONFIGS
                        Bridge   0000:00:1c.0    0604    8086    51bd         0
     Generic system peripheral   0000:00:08.0    0880    8086    a74f         0
         Serial bus controller   0000:00:0d.0    0c03    8086    a71e         0
         Serial bus controller   0000:00:15.1    0c80    8086    51e9         0
                        Bridge   0000:00:1f.0    0601    8086    519d         0
                        Bridge  10000:e0:06.2    0604    8086    a73d         0
                        Bridge   0000:00:1c.7    0604    8086    51bf         0
     Generic system peripheral  10000:e0:06.0    0880    8086    09ab         0
  Signal processing controller   0000:00:04.0    1180    8086    a71d         0
      Communication controller   0000:00:16.0    0780    8086    51e0         0
                        Bridge   0000:00:07.0    0604    8086    a76e         0
         Serial bus controller   0000:00:1f.5    0c80    8086    51a4         0
            Network controller   0000:2d:00.0    0200    10ec    8168         1
         Multimedia controller   0000:00:1f.3    0403    8086    51ca         0
                        Bridge   0000:00:00.0    0600    8086    a707         0
     Generic system peripheral   0000:2c:00.0    0805    1217    8621         0
         Serial bus controller   0000:00:15.0    0c80    8086    51e8         0
                        Bridge   0000:00:06.0    0604    8086    a74d         0
       Mass storage controller   0000:00:0e.0    0104    8086    a77f         0
             Memory controller   0000:00:14.2    0500    8086    51ef         0
            Display controller   0000:00:02.0    0300    8086    a720         3
       Mass storage controller  10000:e1:00.0    0108    144d    a80a         0
         Serial bus controller   0000:00:14.0    0c03    8086    51ed         0
         Serial bus controller   0000:00:1f.4    0c05    8086    51a3         0
         Serial bus controller   0000:00:0d.2    0c03    8086    a73e         0
  Signal processing controller   0000:00:0a.0    1180    8086    a77d         0
> USB devices:
           Unclassified device        3-7:1.0    0000    04f2    b6f9         0
           Unclassified device      3-6.6:1.0    0000    0bda    1100         0
                           Hub        3-0:1.0   10a00    1d6b    0002         0
            Network controller      3-6.3:1.0    0200    0bda    8153         0
                           Hub        4-0:1.0   10a00    1d6b    0003         0
                           Hub        1-0:1.0   10a00    1d6b    0002         0
                           Hub      3-6.4:1.0   10a00    0bda    5409         0
                           Hub        3-6:1.0   10a00    0bda    5409         0
                           Hub        2-0:1.0   10a00    1d6b    0003         0
mhwd -li         ✔
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
         network-r8168            2023.09.12                true            PCI
Additional information:
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=470914d1-80c2-422a-8b91-7876ee40edc8 rw splash apparmor=1
  Desktop: GNOME v: 46.5 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Notebook product: NS5x_NS7xAU v: N/A
    serial: <superuser required> Chassis: No Enclosure type: 10
  Mobo: Notebook model: NS5x_NS7xAU serial: <superuser required>
    uuid: <superuser required> UEFI: INSYDE v: 1.07.08 date: 08/28/2023
  ID-1: BAT0 charge: 76.5 Wh (100.0%) condition: 76.5/73.9 Wh (103.5%)
    volts: 8.8 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
    status: full
  Info: model: 13th Gen Intel Core i5-1340P bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4122
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 threads: 16 mt: 4 tpc: 2
    st: 8 smt: enabled cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32
    KiB, 8x64 KiB L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4600:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
    bogomips: 70064
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: CLEVO/KAPOK driver: i915
    v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: DP-1 off: eDP-1 empty: DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:a720 class-ID: 0300
  Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 04f2:b6f9
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: Dell P2723QE serial: <filter> built: 2022
    res: 3840x2160 dpi: 163 gamma: 1.2 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: max: 3840x2160 min: 720x400
  Monitor-2: eDP-1 model: BOE Display 0x0984 built: 2020 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a720 memory: 7.48 GiB unified: yes display-ID: :0.0
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 0000:00:1f.3 chip-ID: 8086:51ca class-ID: 0403
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
    vendor: CLEVO/KAPOK driver: r8168 v: 8.053.00-NAPI modules: r8169 port: 3000
    bus-ID: 0000:2d:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp45s0 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.3:4
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u6u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 953.87 GiB used: 64.26 GiB (6.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00B00
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: GXA7801Q temp: 27.9 C
    scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 64.26 GiB (6.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 32.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.33 GiB used: 3.31 GiB (21.6%)
  Processes: 361 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 6.12 GiB services: gsd-power, power-profiles-daemon,
    upowerd Init: systemd v: 256 default: graphical tool: systemctl
  Packages: 1234 pm: pacman pkgs: 1227 libs: 334
    tools: gnome-software,pamac,yay pm: rpm pkgs: 0 pm: flatpak pkgs: 0 pm: snap
    pkgs: 7 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
    inxi: 3.3.36
grepping for errors in dmesg:
sudo dmesg | grep -i -e err -e warn -e crit         ✔
[    0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[    0.280256] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.MHBR], AE_NOT_FOUND (20240322/psargs-330)
[    0.280277] ACPI: Ignoring error and continuing table load
[    0.280297] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PTID.PBAR], AE_NOT_FOUND (20240322/dsfield-500)
[    0.323073] ACPI: EC: interrupt blocked
[    0.330639] ACPI: Using IOAPIC for interrupt routing
[    0.512158] pci 0000:00:07.0: Overriding RP PIO Log Size to 4
[    1.028947] ACPI: EC: interrupt unblocked
[    1.342394] RAS: Correctable Errors collector initialized.
[    3.787301] sdhci: Copyright(c) Pierre Ossman
[    9.676915] EDAC MC0: Giving out device to module igen6_edac controller Intel_client_SoC MC#0: DEV 0000:00:00.0 (INTERRUPT)
[    9.680859] EDAC MC1: Giving out device to module igen6_edac controller Intel_client_SoC MC#1: DEV 0000:00:00.0 (INTERRUPT)
[    9.680907] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[    9.681014] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[    9.777280] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[   11.615445] r8168 0000:2d:00.0: Direct firmware load for rtl_nic/rtl8168h-3.fw failed with error -2
[   15.163097] ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
journalctl
journalctl --catalog --priority=3 --boot=-1         ✔
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.MHBR], AE_NOT_FOUND (20240322/psargs-330)
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PTID.PBAR], AE_NOT_FOUND (20240322/dsfield-500)
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11706986
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=617, block=46661653) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11707175
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=806, block=46661653) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11673905
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=304, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11673906
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=305, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11676616
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=3015, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11676628
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=3027, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11673987
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=386, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11674422
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=821, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11676800
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=3199, block=46661649) = 0
Nov 27 09:42:19 mattis-ns5xns7xau kernel: EXT4-fs error (device nvme0n1p2): ext4_orphan_get:1424: comm mount: bad orphan inode 11676803
Nov 27 09:42:19 mattis-ns5xns7xau kernel: ext4_test_bit(bit=3202, block=46661649) = 0
Nov 27 09:42:20 mattis-ns5xns7xau kernel: r8168 0000:2d:00.0: Unable to load firmware rtl_nic/rtl8168h-3.fw (-2)
Nov 27 09:42:24 mattis-ns5xns7xau gdm-autologin][836]: gkr-pam: couldn't unlock the login keyring.
Nov 27 09:42:24 mattis-ns5xns7xau gdm[824]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
Nov 27 09:42:24 mattis-ns5xns7xau gdm[824]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
Nov 27 09:42:24 mattis-ns5xns7xau systemd[845]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 143 and the job result is failed.
░░ The job identifier is 147 and the job result is failed.
░░ The job identifier is 151 and the job result is failed.
Nov 27 09:42:24 mattis-ns5xns7xau kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
Nov 27 09:42:26 mattis-ns5xns7xau systemd[845]: Failed to start Application launched by gnome-session-binary.
░░ The job identifier is 365 and the job result is failed.
Nov 27 09:42:31 mattis-ns5xns7xau systemd-coredump[1805]: [🡕] Process 926 (gnome-shell) of user 1000 dumped core.
Hi @kiwi1715, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
P.S.: If it doesn’t work in nay distro, double-check that it’s not disables in the BIOS/UEFI or maybe it’s turned off with the keyboard-shortcuts laptops allow you to do.
Also check airplane-mode:
Fn+F11
Thanks, I edited the post with additional information! Let me know if this is sufficient!
I have tried to switch off airplane mode with the fn and f11 buttons, though I suspect that some functions are broken, volume and brightness functions tend to work, others definitely dont and some only work after fiddling a bit. So it could be that airplane mode somehow is switched on from the beginning and then there is just no way to switch it off if there is no module that can understand the input, right?
I looked in BIOS, but I was not able to find any settings there for switching off wifi, it seems options are quite limited.
Best,
M
I believe I updated the original post according to the links you posted, can you confirm or let me know if something is missing?
You did. Humble apologies for not noticing sooner.
There is nothing to bed found in the inxi output regarding bluetooth and/or wireless/wlan, and it would’ve been there with the “driver” part N/A if it detected it but didn’t have a driver available for it.
The fact that it’s not being detected points to either a hardware fault, it being disabled in the BIOS/UEFI or (and I’m not :100: on this) it could be that Windows isn’t shut down properly if that is installed.
Thank you! No worries at all, I should have made a reply instead of a post with the update :slight_smile:
So I have a bit of a crazy theory, I got life back into my old laptop and I looked at what had happened before it fell asleep and did not wake up. The error messages are not identical and I do not want to pollute this thread with log prints from another latop, but there is an overlap when it comes to error messages from kernel that have to do with acpi.
I just remembered reading that the firmware updater that I think is included also in manjaro is a big recent development and I think on my old laptop I didnt have such critical issues before I moved from 22.04 to 24.04 ubuntu, but after making the upgrade I have had issues on even older versions, so if something happened, and it is not a hardware error, then maybe the firmware updater did something to my BIOS that wasn’t great. I noticed that on both laptops my BIOS looks different now, and I have not flashed my BIOS.
What do you think? Is there a way that I could make sure?
This is really just a last ditch before I hand it in for reparation, I think in the case of the new laptop I am prepared to conclude that it is indeed a hardware error.
Anyways, your advice is much appreciated! /M
I am unsure, to be honest. Maybe someone else has more of an idea, but I’m all out.
There is the ‘soft’ firmware, the part that is loaded with the kernel with some extra stuff to get some hardware to operate in linux-firmware that you probably have installed.
The laptop probably has some bios/uefi updates that can be done, but those are usually done manually by the user and I’ve never heard of a automatic BIOS/UEFI updater with a Linux distribution aimed at normal users.
The device seems fully supported: Clevo NS50AU 15.6-inch Linux Ultrabook | Laptopwithlinux.com
chip: Intel AX201 802.11AX dual-band 2.4 and 5.0 Ghz + Bluetooth V5.2
maybe related? https://www.reddit.com/r/archlinux/comments/1c9vl3f/ax201_wifi_iwlwifi/
Not sure how to troubleshoot this further.
Thank you for the additional information!
It seems all the hardware in this model should be supported, so I will close this thread because it is more likely to be a hardware problem with the laptop than a problem with drivers or kernel!
Thanks for all the help!
I removed the solution and closed the topic because by @OP’s own admission there doesn’t seem to be a sollution and it was only marked as such to close the thread.
