- I was tried manjaro kde linux66 version last year on the exact same hardware device(with older BIOS version), at that time, my kde works all good.
- I was tried manjaro kde linux610 latest(build 2024-10-11) clear install multi-times this morning(booting with property and booting with free are both have been tried, encounter same issue, see below) on my device(latest BIOS), now the problem is:
- I can boot normally, and GUI and x11 acting normally, and I could play some simple video game(so I think it’s not GPU driver issue). BUT when I click shutdown button, all system black out(but no window is closed, they just remain there) and refuse to shutdown power(even after a long time). If I
sudo reboot
in CLI, the system reboot normally journalctl | grep kde
shows:
Oct 22 10:57:40 ksroido-rb152023 org_kde_powerdevil[1012]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 10:57:40 ksroido-rb152023 org_kde_powerdevil[1012]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 10:57:40 ksroido-rb152023 org_kde_powerdevil[1012]: Options passed from client:
Oct 22 10:57:40 ksroido-rb152023 org_kde_powerdevil[1012]: Applying combined options:
Oct 22 10:57:41 ksroido-rb152023 org_kde_powerdevil[1012]: Library initialization complete.
Oct 22 10:57:41 ksroido-rb152023 org_kde_powerdevil[1012]: Watch thread started
Oct 22 10:57:41 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 10:57:41 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 10:57:41 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 10:57:41 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 10:57:41 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 10:57:41 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 10:57:41 ksroido-rb152023 org_kde_powerdevil[1012]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 10:57:41 ksroido-rb152023 org_kde_powerdevil[1012]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 10:57:51 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 10:57:51 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 10:57:51 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 11:02:02 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:02:02 ksroido-rb152023 org_kde_powerdevil[1012]: Watch thread terminated.
Oct 22 11:02:02 ksroido-rb152023 org_kde_powerdevil[1012]: libddcutil terminating.
Oct 22 11:02:02 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:02:02 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:02:02 ksroido-rb152023 org_kde_powerdevil[1012]: The X11 connection broke (error 1). Did the X11 server die?
Oct 22 11:02:27 ksroido-rb152023 org_kde_powerdevil[975]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 11:02:27 ksroido-rb152023 org_kde_powerdevil[975]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 11:02:27 ksroido-rb152023 org_kde_powerdevil[975]: Options passed from client:
Oct 22 11:02:27 ksroido-rb152023 org_kde_powerdevil[975]: Applying combined options:
Oct 22 11:02:27 ksroido-rb152023 org_kde_powerdevil[975]: Library initialization complete.
Oct 22 11:02:27 ksroido-rb152023 org_kde_powerdevil[975]: Watch thread started
Oct 22 11:02:27 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:02:27 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 11:02:27 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:02:27 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 11:02:27 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:02:27 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 11:02:28 ksroido-rb152023 org_kde_powerdevil[975]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 11:02:28 ksroido-rb152023 org_kde_powerdevil[975]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 11:02:37 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 11:02:37 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 11:02:37 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 11:05:27 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:05:27 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:05:27 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:05:52 ksroido-rb152023 org_kde_powerdevil[983]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 11:05:52 ksroido-rb152023 org_kde_powerdevil[983]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 11:05:52 ksroido-rb152023 org_kde_powerdevil[983]: Options passed from client:
Oct 22 11:05:52 ksroido-rb152023 org_kde_powerdevil[983]: Applying combined options:
Oct 22 11:05:52 ksroido-rb152023 org_kde_powerdevil[983]: Library initialization complete.
Oct 22 11:05:52 ksroido-rb152023 org_kde_powerdevil[983]: Watch thread started
Oct 22 11:05:52 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:05:52 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 11:05:53 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:05:53 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 11:05:53 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:05:53 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 11:05:53 ksroido-rb152023 org_kde_powerdevil[983]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 11:05:53 ksroido-rb152023 org_kde_powerdevil[983]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 11:06:02 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 11:06:02 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 11:06:02 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 11:24:25 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:24:25 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:24:25 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:24:25 ksroido-rb152023 org_kde_powerdevil[983]: The X11 connection broke (error 1). Did the X11 server die?
Oct 22 11:24:25 ksroido-rb152023 org_kde_powerdevil[983]: Watch thread terminated.
Oct 22 11:24:25 ksroido-rb152023 org_kde_powerdevil[983]: libddcutil terminating.
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: Options passed from client:
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: Applying combined options:
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: Library initialization complete.
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: Watch thread started
Oct 22 11:24:49 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:24:49 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 11:24:49 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:24:49 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 11:24:49 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:24:49 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 11:24:49 ksroido-rb152023 org_kde_powerdevil[993]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 11:24:59 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 11:24:59 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 11:24:59 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 11:28:10 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:28:10 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:28:10 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:28:34 ksroido-rb152023 org_kde_powerdevil[990]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 11:28:34 ksroido-rb152023 org_kde_powerdevil[990]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 11:28:34 ksroido-rb152023 org_kde_powerdevil[990]: Options passed from client:
Oct 22 11:28:34 ksroido-rb152023 org_kde_powerdevil[990]: Applying combined options:
Oct 22 11:28:35 ksroido-rb152023 org_kde_powerdevil[990]: Library initialization complete.
Oct 22 11:28:35 ksroido-rb152023 org_kde_powerdevil[990]: Watch thread started
Oct 22 11:28:35 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:28:35 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 11:28:35 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:28:35 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 11:28:35 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:28:35 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 11:28:35 ksroido-rb152023 org_kde_powerdevil[990]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 11:28:35 ksroido-rb152023 org_kde_powerdevil[990]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 11:28:44 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 11:28:44 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 11:28:44 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 11:30:07 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:30:07 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:30:07 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:30:07 ksroido-rb152023 org_kde_powerdevil[990]: Watch thread terminated.
Oct 22 11:30:07 ksroido-rb152023 org_kde_powerdevil[990]: The X11 connection broke (error 1). Did the X11 server die?
Oct 22 11:30:07 ksroido-rb152023 org_kde_powerdevil[990]: libddcutil terminating.
Oct 22 11:30:31 ksroido-rb152023 org_kde_powerdevil[1001]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 11:30:31 ksroido-rb152023 org_kde_powerdevil[1001]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 11:30:31 ksroido-rb152023 org_kde_powerdevil[1001]: Options passed from client:
Oct 22 11:30:31 ksroido-rb152023 org_kde_powerdevil[1001]: Applying combined options:
Oct 22 11:30:31 ksroido-rb152023 org_kde_powerdevil[1001]: Library initialization complete.
Oct 22 11:30:31 ksroido-rb152023 org_kde_powerdevil[1001]: Watch thread started
Oct 22 11:30:31 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 11:30:31 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 11:30:32 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 11:30:32 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 11:30:32 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 11:30:32 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 11:30:32 ksroido-rb152023 org_kde_powerdevil[1001]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 11:30:32 ksroido-rb152023 org_kde_powerdevil[1001]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 11:30:33 ksroido-rb152023 org_kde_powerdevil[1001]: Sleep event. connector=card1-eDP-1, dref not set
Oct 22 11:30:35 ksroido-rb152023 org_kde_powerdevil[1001]: Emitting DDCA_Display_Status_Event( 2.433: DDCA_EVENT_DPMS_ASLEEP, card1-eDP-1, dref: Display_Ref[NULL], io_path:/dev/i2c-8]
Oct 22 11:30:35 ksroido-rb152023 org_kde_powerdevil[1001]: Executed 1 registered callbacks.
Oct 22 14:08:50 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 14:08:50 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 14:08:50 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 14:08:54 ksroido-rb152023 org_kde_powerdevil[1001]: Sleep event. connector=card1-eDP-1, dref not set
Oct 22 14:08:56 ksroido-rb152023 org_kde_powerdevil[1001]: Emitting DDCA_Display_Status_Event( 9503.240: DDCA_EVENT_DPMS_AWAKE, card1-eDP-1, dref: Display_Ref[NULL], io_path:/dev/i2c-8]
Oct 22 14:08:56 ksroido-rb152023 org_kde_powerdevil[1001]: Executed 1 registered callbacks.
Oct 22 14:09:01 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 14:09:01 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 14:09:01 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 14:09:01 ksroido-rb152023 org_kde_powerdevil[1001]: Watch thread terminated.
Oct 22 14:09:01 ksroido-rb152023 org_kde_powerdevil[1001]: The X11 connection broke (error 1). Did the X11 server die?
Oct 22 14:09:01 ksroido-rb152023 org_kde_powerdevil[1001]: libddcutil terminating.
Oct 22 14:09:27 ksroido-rb152023 org_kde_powerdevil[1009]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 14:09:27 ksroido-rb152023 org_kde_powerdevil[1009]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 14:09:27 ksroido-rb152023 org_kde_powerdevil[1009]: Options passed from client:
Oct 22 14:09:27 ksroido-rb152023 org_kde_powerdevil[1009]: Applying combined options:
Oct 22 14:09:27 ksroido-rb152023 org_kde_powerdevil[1009]: Library initialization complete.
Oct 22 14:09:27 ksroido-rb152023 org_kde_powerdevil[1009]: Watch thread started
Oct 22 14:09:27 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 14:09:27 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 14:09:27 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 14:09:27 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 14:09:27 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 14:09:27 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 14:09:28 ksroido-rb152023 org_kde_powerdevil[1009]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 14:09:28 ksroido-rb152023 org_kde_powerdevil[1009]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 14:09:37 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 14:09:37 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 14:09:37 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 15:00:41 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@1.service.
Oct 22 15:00:51 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@1.service: Deactivated successfully.
Oct 22 15:01:19 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@2.service.
Oct 22 15:01:29 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@2.service: Deactivated successfully.
Oct 22 15:42:48 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@3.service.
Oct 22 15:42:58 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@3.service: Deactivated successfully.
Oct 22 15:45:50 ksroido-rb152023 org_kde_powerdevil[1009]: Sleep event. connector=card1-eDP-1, dref not set
Oct 22 15:45:52 ksroido-rb152023 org_kde_powerdevil[1009]: Emitting DDCA_Display_Status_Event( 5783.420: DDCA_EVENT_DPMS_ASLEEP, card1-eDP-1, dref: Display_Ref[NULL], io_path:/dev/i2c-8]
Oct 22 15:45:52 ksroido-rb152023 org_kde_powerdevil[1009]: Executed 1 registered callbacks.
Oct 22 15:52:08 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@4.service.
Oct 22 15:52:08 ksroido-rb152023 org_kde_powerdevil[1009]: Sleep event. connector=card1-eDP-1, dref not set
Oct 22 15:52:10 ksroido-rb152023 org_kde_powerdevil[1009]: Emitting DDCA_Display_Status_Event( 6161.683: DDCA_EVENT_DPMS_AWAKE, card1-eDP-1, dref: Display_Ref[NULL], io_path:/dev/i2c-8]
Oct 22 15:52:10 ksroido-rb152023 org_kde_powerdevil[1009]: Executed 1 registered callbacks.
Oct 22 15:52:18 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@4.service: Deactivated successfully.
Oct 22 15:52:33 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 15:52:33 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 15:52:33 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 15:53:00 ksroido-rb152023 org_kde_powerdevil[1011]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 15:53:00 ksroido-rb152023 org_kde_powerdevil[1011]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 15:53:00 ksroido-rb152023 org_kde_powerdevil[1011]: Options passed from client:
Oct 22 15:53:00 ksroido-rb152023 org_kde_powerdevil[1011]: Applying combined options:
Oct 22 15:53:00 ksroido-rb152023 org_kde_powerdevil[1011]: Library initialization complete.
Oct 22 15:53:00 ksroido-rb152023 org_kde_powerdevil[1011]: Watch thread started
Oct 22 15:53:00 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 15:53:00 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 15:53:00 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 15:53:00 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 15:53:01 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 15:53:01 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 15:53:01 ksroido-rb152023 org_kde_powerdevil[1011]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 15:53:01 ksroido-rb152023 org_kde_powerdevil[1011]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 15:53:10 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 15:53:10 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 15:53:10 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Oct 22 16:14:46 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 16:14:46 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 16:14:46 ksroido-rb152023 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: qt.core.qobject.connect: QObject::disconnect: Unexpected nullptr parameter
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: Initializing libddcutil. ddcutil version: 2.1.4, shared library: /usr/lib/libddcutil.so.5.1.2
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: Options passed from client:
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: Applying combined options:
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: Library initialization complete.
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: Watch thread started
Oct 22 16:15:14 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Oct 22 16:15:14 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Oct 22 16:15:14 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Oct 22 16:15:14 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Oct 22 16:15:14 ksroido-rb152023 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Oct 22 16:15:14 ksroido-rb152023 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Oct 22 16:15:14 ksroido-rb152023 org_kde_powerdevil[1002]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 16:15:15 ksroido-rb152023 org_kde_powerdevil[1002]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 22 16:15:15 ksroido-rb152023 org_kde_powerdevil[1002]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 22 16:15:24 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Oct 22 16:15:24 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Oct 22 16:15:24 ksroido-rb152023 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
- my GPU is 780M only, my CPU is 7840hs, if any other hardware info is needed I’m glad to attach
