My fresh install of Manjaro KDE runs with Linux57. All works fine so far but I want to move to Linux54 LTS for better stability. So I installed it via Kernel settings but I can’t change as grub is not showing at startup. It loads directly to Manjaro initial screen.
Hi!
Open a termminal and do
sudo nano /etc/default/grub
Edit the line with valor hidden to style and the line how define time to 3
Save the file with ctlr+o exit with ctrl+x and do
sudo update-grub
In your next reboot you’ll be able to see grub
Edit your /etc/default/grub
and make sure you replace…
GRUB_TIMEOUT_STYLE=hidden
… by…
GRUB_TIMEOUT_STYLE=menu
Then run…
sudo update-grub
You will now get a GRUB menu.
Even if Grub is hidden, you should most likely be able to get to the menu by pressing the Shift key during boot.
F8 also works. I found the shift key not always reliable.
Good to know that that is also an option. On my system F8 brings up the UEFI boot menu.
