Cant put Scale in 200%
HI,
Im new on manjaro and when I go to the settings → monitor and try to up the scale I see the msg: “Changes cannot be Applied, this could be to hardware limitations”.
Im trying to use two monitors [ my laptop and another] and I see that the second screen is wrong. I have a LG Widescreen 29" and the monitor that shows is a Lg 34".
I dont know if this error is because of the wront recognize of monitor or because of some problem with my graphic card. I have the dual GPU intel-nvidia and, yes, I try to follow the guides and as I see im using the non-proprietary drivers. But, I cant see some infos that shows in the guide in the nvidia-settings [ like refresh rate, resolution, etc.].
Hi @Myphre, and welcome!
In order for us, or anyone for that matter, to be able to help you, more information is necessary. To that end, please see:
Hope you manage!
Sorry for the delay to respond, I wasn using my personal computer and didnt recieve an email that the message was answered.
  Kernel: 5.10.102-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=def56709-4c45-4490-86fa-ce34db88b0b3 rw quiet
    resume=UUID=be6d3982-1d45-4083-aeae-1a920df0b760 udev.log_priority=3
  Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: Acer product: Aspire A515-51G v: V1.21
    serial: <superuser required>
  Mobo: KBL model: Charmander_KL v: V1.21 serial: <superuser required>
    UEFI: Insyde v: 1.21 date: 08/08/2018
  ID-1: BAT1 charge: 11.1 Wh (29.8%) condition: 37.2/48.9 Wh (76.1%)
    volts: 15.9 min: 15.2 model: LG 004B384234314341 type: Li-ion
    serial: <filter> status: Charging
  RAM: total: 7.65 GiB used: 5.46 GiB (71.4%)
  RAM Report:
  Info: model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xEC
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 700 min/max: 400/2500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 21607
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI driver: i915
    v: kernel ports: active: HDMI-A-1 off: eDP-1 empty: none bus-ID: 00:02.0
    chip-ID: 8086:5916 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Acer Incorporated ALI
    driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:134d class-ID: 0302
  Device-3: Sunplus Innovation HD WebCam type: USB driver: uvcvideo
    bus-ID: 1-7:5 chip-ID: 1bcf:2ca0 class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.3 compositor: gnome-shell driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
    gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1080 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-1 mapped: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE
    serial: <filter> built: 2016 res: 2560x1080 dpi: 81 gamma: 1.2
    size: 798x334mm (31.4x13.1") diag: 869mm (34.2") modes: max: 2560x1080
    min: 640x480
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.102-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.47 running: no
    vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.1 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp2s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
    v: 0.8 bus-ID: 1-5:4 chip-ID: 04ca:3015 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
  Local Storage: total: 1.82 TiB used: 25.53 GiB (1.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS1000G
    lanes: 4 type: SSD serial: <filter> rev: EDFK5N09 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD10SPZX-00Z10T0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 97.61 GiB (99.95%) used: 12.36 GiB (12.7%)
    fs: xfs dev: /dev/nvme0n1p5 maj-min: 259:5 label: root
    uuid: def56709-4c45-4490-86fa-ce34db88b0b3
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
    used: 296 KiB (0.0%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: BOOTEFI
    uuid: 24D1-441C
  ID-3: /home raw-size: 97.66 GiB size: 97.61 GiB (99.95%)
    used: 8.16 GiB (8.4%) fs: xfs dev: /dev/nvme0n1p6 maj-min: 259:6 label: home
    uuid: 9c754c8d-b2b1-40de-92be-503bd7783e8d
  ID-4: /opt raw-size: 97.66 GiB size: 97.61 GiB (99.95%) used: 5 GiB (5.1%)
    fs: xfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: variaveis
    uuid: 0af95540-ef3e-4aac-9ca9-4f3321a6f9fc
  ID-1: swap-1 type: partition size: 4.88 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8 label: swap
    uuid: be6d3982-1d45-4083-aeae-1a920df0b760
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 146.48 GiB fs: ntfs label: N/A
    uuid: 1410E73610E71E0C
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 195.31 GiB fs: ntfs
    label: New Volume uuid: F094A96794A93150
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 250 MiB fs: vfat label: N/A
    uuid: A587-CE20
  ID-5: /dev/sda1 maj-min: 8:1 size: 1024 MiB fs: vfat label: N/A
    uuid: 0C3D-05C0
  ID-6: /dev/sda5 maj-min: 8:5 size: 194.74 GiB fs: ntfs label: N/A
    uuid: 6C9CD3739CD33674
  ID-7: /dev/sda6 maj-min: 8:6 size: 570 MiB fs: ntfs label: N/A
    uuid: C0E255DBE255D5EE
  ID-8: /dev/sda7 maj-min: 8:7 size: 146.48 GiB fs: ntfs label: New Volume
    uuid: F82E26782E263054
  ID-9: /dev/sda9 maj-min: 8:9 size: 134.06 GiB fs: ntfs label: Jogos
    uuid: C48AF70F8AF6FD2C
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: USB OPTICAL MOUSE type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
    power: 100mA chip-ID: 275d:0ba6 class-ID: 0301
  Device-2: 1-4:3 info: China Resource Semico Keyboard type: Keyboard,HID
    power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
  Device-3: 1-5:4 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 04ca:3015 class-ID: e001
  Device-4: 1-7:5 info: Sunplus Innovation HD WebCam type: Video
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 327 Uptime: 58m wakeups: 7 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 Packages: pacman: 1082 lib: 332 Shell: Zsh v: 5.8.1
  running-in: gnome-terminal inxi: 3.3.13
From now on Im able to put the scale in 200% but i cant configure to 125 or something like that. My monitor is wrong defined in the system. I find a comand that appear to help with the scale but the font is a little bluer with it. The comand:
xrandr --output HDMI-1 --scale 0.90x0.90
