I have installed manjaro in my laptop as dual boot and i can use wifi in the windows os perfectly fine, but i can only use internet though usb tethering. Cant find why. And i have tested every article in this forum on this topic and can’t find a solution.
this is my system info
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=9b8489ce-e6fe-4ec8-93ec-15b20a1386d6 rw quiet splash apparmor=1
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: LENOVO product: 82RK v: IdeaPad 3 15IAU7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15IAU7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76486 WIN
serial: <superuser required> UEFI: LENOVO v: JKCN31WW date: 07/21/2022
ID-1: BAT0 charge: 36.5 Wh (88.6%) condition: 41.2/45.0 Wh (91.5%)
power: 22.0 W volts: 11.8 min: 11.1 model: Celxpert L20C3PF0 type: Li-poly
serial: <filter> status: discharging cycles: 130
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x42A
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1106 high: 2500 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 812 2: 2500 3: 551 4: 2500
5: 708 6: 898 7: 536 8: 689 9: 2500 10: 542 11: 570 12: 477 bogomips: 59916
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-UP3 GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:4628
class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 04f2:b78e
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x08d5 built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.74 status: off tools: pw-cli
Device-1: Realtek vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:4853
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Device-2: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:6
chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Local Storage: total: 476.94 GiB used: 15.77 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512GZL
lanes: 4 tech: SSD serial: <filter> fw-rev: C01C temp: 36.9 C scheme: GPT
ID-1: / raw-size: 55.86 GiB size: 54.68 GiB (97.89%) used: 15.74 GiB (28.8%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 36.9 MiB (14.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 282 Uptime: 3m wakeups: 179 Memory: total: 8 GiB note: est.
available: 7.49 GiB used: 2.34 GiB (31.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1202 libs: 343 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.28
