wiesel
30 December 2023 14:52
1
Hello
I realised that I am unable to create a bluetooth connection to an arbitrary device with the current KDE release version manjaro-kde-23.1.1 (minimal and normal version). This is true for a fresh installation, but also in live-usb-mode. If you try it via GUI it takes some time and then says that the setup with the device fails. “bluetoothctl” gives me an authentication timeout at some point.
I tried Manjaro GNOME or Fedora KDE and there it is just working fine. On manjaro-kde-23.0.4 it is also working, but tested on a different device.
Any known reported issues regarding this?
Best regards!
Hi @wiesel ,
Sounds like a driver is missing. But we can’t check without more info, so we need more information. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Alternatively , paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB , causing it to render the same way as described above.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
bedna
30 December 2023 15:26
3
Unknown. ¯\_(ツ)_/¯:
Not sure about bluetoothctl
on KDE plasma. Try:
LC_ALL=C sudo systemctl status bluetooth.service
LC_ALL=C sudo journalctl -u bluetooth.service -xe --no-pager
But there is also a Gnome tag in the title of the post so…
That was just an example, it’s purely coincidence that it fits in with the title.
wiesel
31 December 2023 14:40
5
Hello,
happy to provide any missing information.
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sun 2023-12-31 15:20:35 CET; 8min ago
Docs: man:bluetoothd(8)
Main PID: 609 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 37537)
Memory: 2.8M
CPU: 17ms
CGroup: /system.slice/bluetooth.service
└─609 /usr/lib/bluetooth/bluetoothd
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_x>
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc>
Dez 31 15:20:59 w-sys bluetoothd[609]: Failed to add UUID: Failed (0x03)
and
Dez 31 15:20:35 w-sys systemd[1]: Starting Bluetooth service...
░░ Subject: A start job for unit bluetooth.service has begun execution
░░ Defined-By: systemd
░░ A start job for unit bluetooth.service has begun execution.
░░ The job identifier is 137.
Dez 31 15:20:35 w-sys bluetoothd[609]: Bluetooth daemon 5.71
Dez 31 15:20:35 w-sys bluetoothd[609]: Starting SDP server
Dez 31 15:20:35 w-sys bluetoothd[609]: src/plugin.c:plugin_init() System does not support csip plugin
Dez 31 15:20:35 w-sys bluetoothd[609]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dez 31 15:20:35 w-sys bluetoothd[609]: src/plugin.c:plugin_init() System does not support micp plugin
Dez 31 15:20:35 w-sys bluetoothd[609]: src/plugin.c:plugin_init() System does not support vcp plugin
Dez 31 15:20:35 w-sys bluetoothd[609]: src/plugin.c:plugin_init() System does not support mcp plugin
Dez 31 15:20:35 w-sys bluetoothd[609]: src/plugin.c:plugin_init() System does not support bass plugin
Dez 31 15:20:35 w-sys bluetoothd[609]: src/plugin.c:plugin_init() System does not support bap plugin
Dez 31 15:20:35 w-sys bluetoothd[609]: Bluetooth management interface 1.22 initialized
Dez 31 15:20:35 w-sys bluetoothd[609]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Dez 31 15:20:35 w-sys bluetoothd[609]: Battery Provider Manager created
Dez 31 15:20:35 w-sys systemd[1]: Started Bluetooth service.
░░ Subject: A start job for unit bluetooth.service has finished successfully
░░ A start job for unit bluetooth.service has finished successfully.
Dez 31 15:20:35 w-sys bluetoothd[609]: Failed to clear UUIDs: Failed (0x03)
Dez 31 15:20:35 w-sys bluetoothd[609]: Failed to add UUID: Failed (0x03)
Dez 31 15:20:35 w-sys bluetoothd[609]: Failed to set mode: Failed (0x03)
Dez 31 15:20:58 w-sys bluetoothd[609]: Failed to add UUID: Failed (0x03)
Dez 31 15:20:59 w-sys bluetoothd[609]: Failed to set mode: Failed (0x03)
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/ldac_hq
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/ldac_sq
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/ldac_mq
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/aptx_hd
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/aptx_hd
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Dez 31 15:20:59 w-sys bluetoothd[609]: Endpoint registered: sender=:1.46 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Is “Failed to add UUID” of interest? How would I add missing drivers or how can I check if some are missing?
Best regards!
wiesel:
I suspect, note, I’m not sure, but suspect, this might be driver-related, yes.
Or not, according to [SOLVED] bluetoothd Failed to add UUID: Failed (0x03) / Newbie Corner / Arch Linux Forums
Please provide the output of, as requested in the second reply in the thread:
inxi --full --admin --filter --width
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
Please also provide the output of:
rfkill list
bedna
31 December 2023 15:43
7
I see similar things in my log on my KDE plasma setup, but I never use bluetooth so I just ignore them.
I will follow with interest and see if the commands in the post above brings similar feedback on your setup as on mine.
I DO have an old bluetooth speaker I could try with to compare with you when it comes to that.
I also found this to add to the link above. Maybe you can find some useful info in that thread.
I think rfkill list
looks fine.
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
output:
Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=61adf7aa-bc4b-43dd-801b-1058364a9032 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Mobo: ASUSTeK model: TUF GAMING B650-PLUS WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1811
date: 10/07/2023
Info: model: AMD Ryzen 7 7700 bits: 64 type: MT MCP arch: Zen 4 gen: 5
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 400 min/max: 400/5389 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
bogomips: 121422
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1
bus-ID: 0b:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 32.0 C
Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: Asus VS248 serial: <filter> built: 2019
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics
(raphael_mendocino LLVM 16.0.6 DRM 3.54 6.5.13-7-MANJARO)
device-ID: 1002:164e memory: 500 MiB unified: no
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 23.1.9-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0b:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 08:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 13d3:3571
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 931.51 GiB used: 133.54 GiB (14.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO XT
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM31.6 temp: 20.9 C
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 133.54 GiB (14.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Processes: 341 Uptime: 4m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.57 GiB used: 2.21 GiB (7.2%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1169 libs: 330 tools: pamac Shell: Zsh v: 5.9
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
I tried to follow up on the links, but didn’t came up with something useful. I updated the kernel from 65 to 67.
Happy new year
everyone
Nothing the matter that I can see, so let’s see if someone else does.
wiesel:
Happy new year
everyone
Technically, every day is the start of a new year, so it’s not really special. Happy new calendar year, though!
The mention of “authentication timeout” has me wondering if the problem might be related to the recent change to BlueZ to bring it in line with security standards, as discussed in another thread. The solution is in the linked post:
Hello, I created input.conf file in /etc/bluetooth folder, then added this lines:
[General]
ClassicBondedOnly=false
restart bluetooth:
sudo systemctl restart bluetooth
my Dualshock 3 works again without pin code.
You can follow progress on this issue here:
wiesel
2 January 2024 10:42
11
I could try downgrade BlueZ
. Which version would you recommend?
Any other ideas how to check for missing drivers?
From the inxi
output, it doesn’t seem to be missing drivers.
And according to https://linux-hardware.org/?id=usb:13d3-3571
The device is supported by kernel versions 2.6.0 and newer according to the LKDDb
However, don’t quote me on this, but they seem to only list to kernel 6.3. So another possibility would be to try an older kernel. For example, 6.1, which is an LTS version, and inn fact the kernel I use.
To install it:
sudo mhwd-kernel --install linux61
Then reboot, select it in grub, and test. If it works, remove the current, non-working one:
sudo mhwd-kernel --remove linux65
In fact, removing it is a good idea since it’s EOL anyway: Linux kernel version history - Wikipedia
See:
wiesel
2 January 2024 17:57
13
Switching the Kernel to 61 does actually fix the 0x03
errors, but unfortunately the issue remains.
Some of the recent updates apparently fixed it.
It works now (also already before the most recent update)
