hello! please help me i can’t boot into the system when the power cable is not plugged into my laptop but when I try again with the power cable plugged in I can boot normally. what should i do? is changing kernel will solve this problem ?
here the journalctl -xe -p3 -b-1 result:
Mei 24 20:26:43 space-cavalry kernel: x86/cpu: SGX disabled by BIOS.
Mei 24 20:26:47 space-cavalry kernel:
Mei 24 20:27:32 space-cavalry kernel: ACPI Error: Aborting method \_SB.PCI0.PGON due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Mei 24 20:27:32 space-cavalry kernel: ACPI Error: Aborting method \_SB.PCI0.PEG0.PG00._ON due to previous error (AE_AML_LOOP_TIMEOUT) (20210730/psparse-529)
Mei 24 20:27:34 space-cavalry kernel: nvidia 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
Mei 24 20:27:34 space-cavalry kernel: snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
Mei 24 20:27:34 space-cavalry kernel: snd_hda_codec_hdmi hdaudioC0D0: Unable to sync register 0x7f0800. -5
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
