So i search a lot and found a lot but so far nothing help and im still stuck on the same status print as before
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Mon 2023-01-16 08:26:12 CET; 8h ago
Docs: man:bluetoothd(8)
Main PID: 703 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 38181)
Memory: 3.2M
CPU: 25ms
CGroup: /system.slice/bluetooth.service
└─703 /usr/lib/bluetooth/bluetoothd
Jan 16 08:26:12 lapetus bluetoothd[703]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jan 16 08:26:12 lapetus bluetoothd[703]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Jan 16 08:26:12 lapetus bluetoothd[703]: src/plugin.c:plugin_init() Failed to init bap plugin
Jan 16 08:26:12 lapetus systemd[1]: Started Bluetooth service.
Jan 16 08:26:12 lapetus bluetoothd[703]: Bluetooth management interface 1.21 initialized
Jan 16 08:26:12 lapetus bluetoothd[703]: src/device.c:device_set_wake_support() Unable to set wake_support without RPA resolution
Jan 16 16:15:07 lapetus bluetoothd[703]: src/adapter.c:index_removed() Ignoring index removal for a non-existent adapter
Jan 16 16:15:16 lapetus bluetoothd[703]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Invalid Index (0x11)
Jan 16 16:15:16 lapetus bluetoothd[703]: Failed to read exp features info: Invalid Index (0x11)
Jan 16 16:15:16 lapetus bluetoothd[703]: Failed to read info for index 0: Invalid Index (0x11)
so my last commands where the following:
10203 systemctl start bluetooth
10204 systemctl status bluetooth
10207 systemctl enable bluetooth
10208 systemctl status bluetooth
10209 systemctl status bluetooth.preset
10213 sudo bluetoothctl devices
10214 modprobe -r btusb
10215 sudo modprobe -r btusb
10216 modprobe btusb
10217 sudo modprobe btusb
10218 sudo bluetoothctl devices
10219 lsmod | grep bluetooth
10221 systemctl enable bluetooth
10222 bluetoothctl discoverable on
10223 bluetoothctl show
10224 sudo bluetoothctl
10225 bluetoothctl show
10226 rfkill list all
10227 sudo groupadd bluetooth
10229 bluetoothctl
10231 sudo systemctl disable bluetooth-mesh.service
10232 systemctl list-unit-files | grep blue
10233 bluetoothctl
10234 systemctl status bluetooth
i cannt enable bluetooth in the system setting gui nor can i connect any device because of that. So im a bit confused that is shows its running since 8h
yeah i tried this bluetoothctl: No default controller availabl Bluetooth - ArchWiki
and the following https://stackoverflow.com/questions/48279646/bluetoothctl-no-default-controller-available
Intel Bluetooth not working
[SOLVED] bluetoothctl: No default controller available / Kernel & Hardware / Arch Linux Forums
/usr/lib/bluetooth/bluetoothd -n -d
bluetoothd[781559]: Bluetooth daemon 5.66
bluetoothd[781559]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “DiscoverableTimeout” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “AlwaysPairable” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “PairableTimeout” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “Privacy” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “JustWorksRepairing” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “TemporaryTimeout” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “Name” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “Class” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “DeviceID” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “ReverseServiceDiscovery” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “RemoteNameRequestRetryDelay” in group “General”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “Cache” in group “GATT”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “KeySize” in group “GATT”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “ExchangeMTU” in group “GATT”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “Channels” in group “GATT”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “SessionMode” in group “AVDTP”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “StreamMode” in group “AVDTP”
bluetoothd[781559]: src/main.c:parse_config() Key file does not have key “RSSISamplingPeriod” in group “AdvMon”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “PageScanType” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “PageScanInterval” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “PageScanWindow” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanType” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanInterval” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “InquiryScanWindow” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “LinkSupervisionTimeout” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “PageTimeout” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MinSniffInterval” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MaxSniffInterval” in group “BR”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MinAdvertisementInterval” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MaxAdvertisementInterval” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MultiAdvertisementRotationInterval” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalAutoConnect” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowAutoConnect” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalSuspend” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowSuspend” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalDiscovery” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowDiscovery” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalAdvMonitor” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowAdvMonitor” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanIntervalConnect” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ScanWindowConnect” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MinConnectionInterval” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “MaxConnectionInterval” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ConnectionLatency” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “ConnectionSupervisionTimeout” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “Autoconnecttimeout” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “AdvMonAllowlistScanDuration” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “AdvMonNoFilterScanDuration” in group “LE”
bluetoothd[781559]: src/main.c:parse_mode_config() Key file does not have key “EnableAdvMonInterleaveScan” in group “LE”
D-Bus setup failed: Connection ":1.28910" is not allowed to own the service "org.bluez" due to security policies in the configuration file
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
