Hi,
I have a very annoying issue, which I have not been able to resolve for the past couple of months.
When I use an external sound card (Audient ID4 mk.I, connected to active powered studio monitors) with my desktop, there is always a high pitched buzzing sound when playing audio. It goes a few moments after the audio stops. It could probably be a power supply issue, as the sound isn’t present in the headphone output of the sound card, however this doesn’t happen when i boot windows on the same computer.
Any help would be greatly appreciated.
Thanks ![]()
Hi @jakubmann, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as preformatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Thank you,
inxi output:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=df4286ff-f402-488e-bc03-a46c55d172c5 rw quiet
udev.log_priority=3
Desktop: i3 v: 4.20.1 info: polybar dm: LightDM v: 1.30.0
Type: Desktop Mobo: MSI model: B250 PC MATE (MS-7A72) v: 1.0
serial: <filter> UEFI: American Megatrends v: 3.00 date: 10/26/2016
RAM: total: 31.31 GiB used: 2.54 GiB (8.1%)
Array-1: capacity: 64 GiB slots: 4 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
manufacturer: Kingston part-no: KHX2400C12D4/8GX serial: <filter>
Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
Info: model: Intel Core i5-7500 socket: U3E1 bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3800 base/boost: 3600/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.9 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 27208
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: Picom v: git-7e568
driver: X: loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 93
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI H270 PC MATE
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: Audient iD4 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-12:4 chip-ID: 2708:0003 class-ID: 0300
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI H270 PC MATE
driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8
class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.47 TiB used: 134.1 GiB (8.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37120G
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 87RA scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A02 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST500LM000-SSHD-8GB
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: LVD3 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 134.1 GiB (29.3%) fs: ext4 block-size: 4096 B dev: /dev/sdc2
maj-min: 8:34 label: N/A uuid: df4286ff-f402-488e-bc03-a46c55d172c5
used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdc1 maj-min: 8:33
label: NO_LABEL uuid: 53EB-434D
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: N/A
uuid: 02AAB2B0AAB29F99
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: F68E-133F
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 111 GiB fs: ntfs label: N/A
uuid: CE889D18889CFFDF
ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Tera
uuid: FE7674327673E9B3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-10:2 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-2: 1-11:3 info: Holtek OBINS type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 400mA chip-ID: 04d9:a293 class-ID: 0300 serial: <filter>
Device-3: 1-12:4 info: Audient iD4 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
speed: 480 Mb/s chip-ID: 2708:0003 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Processes: 201 Uptime: 11m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1152 lib: 309
Shell: Bash (sudo) v: 5.1.16 running-in: urxvtd inxi: 3.3.15
