Bluetooth not working: not default controller available
Bluetooth has always worked for me but since yesterday scanning for devices is no longer possible.
Apparently also other people are having this issue recently :Bluetooth issue
checking the BT status with sudo systemctl status bluetooth shows the device to be working.
sudo systemctl status bluetooth         ✔
[sudo] Passwort für peter:
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
     Active: active (running) since Tue 2022-01-18 14:45:33 CET; 5min ago
       Docs: man:bluetoothd(8)
   Main PID: 1437 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 19083)
     Memory: 2.0M
        CPU: 10ms
     CGroup: /system.slice/bluetooth.service
             └─1437 /usr/lib/bluetooth/bluetoothd
Jän 18 14:45:33 Peter systemd[1]: Starting Bluetooth service...
Jän 18 14:45:33 Peter bluetoothd[1437]: Bluetooth daemon 5.62
Jän 18 14:45:33 Peter systemd[1]: Started Bluetooth service.
Jän 18 14:45:33 Peter bluetoothd[1437]: Starting SDP server
Jän 18 14:45:33 Peter bluetoothd[1437]: Bluetooth management interface 1.21 initialized
However when I wan’t to scan for devices it says NO default controller available.
bluetoothctl scan on         ✔
No default controller available
    ~  bluetoothctl power off         1 ✘
    ~  bluetooth ctl power on         1 ✘
bluetooth = on
My adapter is a AX210 wifi m2 E card, wifi is working perfectly so I guess the card is still installed correctly.
Any ideas how to troubleshoot this ?
System info:
  Kernel: 5.16.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    root=UUID=d38aeabc-9f15-4876-be4b-2c05882c6433 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
    vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Extreme4 serial: <superuser required>
    UEFI: American Megatrends LLC. v: P2.10 date: 08/04/2021
  RAM: total: 15.55 GiB used: 2.56 GiB (16.5%)
  RAM Report:
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2194 high: 2196 min/max: 2200/4850 boost: enabled
    scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 2195 2: 2195
    3: 2195 4: 2195 5: 2195 6: 2196 7: 2195 8: 2195 9: 2194 10: 2195 11: 2195
    12: 2194 13: 2195 14: 2194 15: 2194 16: 2195 bogomips: 121413
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
    movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
    ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
    tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
    vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
    IBRS_FW, STIBP: always-on, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus-ID: 05:00.0
    chip-ID: 1002:67df class-ID: 0300
  Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-2:2 chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
  Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.44.0
    5.16.0-1-MANJARO LLVM 13.0.0)
    v: 4.6 Mesa 21.3.2 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 05:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    driver: snd_hda_intel v: kernel bus-ID: 07:00.4 chip-ID: 1022:1487
    class-ID: 0403
  Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
  Device-4: Yamaha Steinberg UR12 type: USB driver: snd-usb-audio
    bus-ID: 1-6.1:5 chip-ID: 0499:170a class-ID: 0102
  Sound Server-1: ALSA v: k5.16.0-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.19 running: no
  Sound Server-4: PulseAudio v: 15.0 running: no
  Sound Server-5: PipeWire v: 0.3.42 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
    bus-ID: 04:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:7
    chip-ID: 8087:0032 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
  Local Storage: total: 1.13 TiB used: 400.55 GiB (34.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    type: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT240BX500SSD1
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 052 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
    model: ST500LT0 12-9WS142 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B type: N/A serial: <filter> rev: 3202 scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 157 GiB (34.3%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: d38aeabc-9f15-4876-be4b-2c05882c6433
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 887A-BAAC
  ID-3: /run/media/peter/InternHDD raw-size: 465.76 GiB
    size: 457.45 GiB (98.22%) used: 243.55 GiB (53.2%) fs: ext4 dev: /dev/sdc1
    maj-min: 8:33 label: InternHDD uuid: 07ad55d6-0713-4de9-b2a0-16f56e6392c0
  ID-1: /dev/sdb1 maj-min: 8:17 size: 223.57 GiB fs: ntfs label: externe SDD
    uuid: 17957C3A1E0E912F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-2:2 info: Microdia USB 2.0 Camera type: Video,Audio
    power: 500mA chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
  Hub-2: 1-6:3 info: Microchip (formerly SMSC) ports: 1 rev: 2.0
    speed: 480 Mb/s power: 2mA chip-ID: 0424:2422 class-ID: 0900
  Device-1: 1-6.1:5 info: Yamaha Steinberg UR12 type: Audio
    driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
  Hub-3: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Hub-4: 1-8:6 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-9:7 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
    class-ID: e001
  Device-2: 1-10:8 info: ASRock LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
  Hub-5: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-3:2 info: JMicron / JMicron USA JMS578 SATA 6Gb/s
    type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 896mA chip-ID: 152d:0578 class-ID: 0806 serial: <filter>
  Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Logitech G203 Gaming Mouse type: Mouse,HID
    power: 300mA chip-ID: 046d:c084 class-ID: 0300 serial: <filter>
  Device-2: 3-3:3 info: Microdia USB DEVICE type: Keyboard,Mouse
    power: 100mA chip-ID: 0c45:7903 class-ID: 0301
  Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 56.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 287
  Processes: 378 Uptime: 31m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1529 pacman: 1516 lib: 463
  flatpak: 7 snap: 6 Shell: Zsh v: 5.8 default: Bash v: 5.1.12
  running-in: konsole inxi: 3.3.11
Hi @thepete,
Please see [HowTo] Provide System Information, if applicable, [HowTo] post screenshots and links and finally, [HowTo] Increase your chances of solving your issue.
Hope you come right!
Thank you Mirdarthos and sorry, I didn’t think system info was necessary for this post.
I’ve added it just now!
Hi,
Did you have tried to connect you with a phone in BT ?
I have had a similar issue Sunday on an new installation of kde .with my AX201 wifi/Bt card.
Nothing was show on the BT section and my mouse was not recognized in BT but yes in 2.4 Ghz.
I’ve tried my phone with success. For my mouse (a razer), it was an issue with the daemon.
Another thing you must add (at least for me, and my Gigabyte pci card)/plugged an usb extension into an internal usb port.
thanks for your response.
no I never connected my phone to my pc via BT. Also thanks for the tip, but my Ax210 is connected through an m.2 wifi E slot, so I don’t connect it via internal USB.
I don’t know if this was clear from my thread but I can’t connect any device, as searching/scanning for them doesn’t work.
My AX201 is connected by a PCIe Slot but you must connect it too via an internal usb. And you have even an usb port on the card.
Switching to the 5.14 (and lower) or the current LTS Kernel has been the only successful Bluetooth issue fix for me after months of trying…
I switched to 5.15 which fixed this issue. I hope that 5.16 or 5.17 will fix this issue.
Thanks for your help!
5.14 is EOL then you should go to the 5.15 or come back to the 5.10 which is too an LTS.
