Bluetooth error on launch
Hello,
My bluetooth has always worked fine for my mouse and headset, but this morning my mouse and headset suddenly stopped working.
I restarted and blueman-applet no longer launches:
$ blueman-applet
blueman-applet 13.52.45 WARNING  PluginManager:153 __load_plugin: Not loading PPPSupport because its conflict has higher priority
blueman-applet 13.52.45 WARNING  PluginManager:153 __load_plugin: Not loading DhcpClient because its conflict has higher priority
I looked on the Net and someone was able to get it to work by going back with Timeshift, which I did. But at home, I still get the same error.
For systemd:
mar 08 13:48:11 bruno systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
When I restarted the computer, it said two dozen times: bluetooth files corrupted.
bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: inactive (dead)
       Docs: man:bluetoothd(8)
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
mar 09 14:18:56 bruno-hppaviliongamingdesktop69000xx systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
mar 09 15:10:49 bruno-hppaviliongamingdesktop69000xx systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
For inxi
 inxi --admin --verbosity=8 --filter --no-host --width         22 ✘
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=ff773482-b4f4-44b5-9a40-38db8ea9676b rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop System: HP product: HP Pavilion Gaming Desktop 690-00xx v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: HP model: 843B v: 00 serial: <superuser required>
    part-nu: 4ML90EA#UUG uuid: <superuser required> UEFI: AMI v: F.11
    date: 06/11/2018
  System RAM: total: 16 GiB available: 15.52 GiB used: 3.84 GiB (24.7%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Micron part-no: 8ATF1G64AZ-2G6E1
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    serial: <filter>
  Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 900 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900
    bogomips: 33613
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Hewlett-Packard
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: none off: DVI-D-1,HDMI-A-1
    empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
  Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 046d:0843
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
    s-diag: 1089mm (42.87") monitors: <missing: xrandr>
  Monitor-1: DVI-D-1 size-res: N/A modes: N/A
  Monitor-2: HDMI-A-1 size-res: N/A modes: N/A
  Monitor-3: Unknown-1 size-res: N/A modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
    memory: 1.95 GiB
  API: Vulkan v: 1.4.304 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1050 driver: N/A device-ID: 10de:1c81
    surfaces: xcb,xlib
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
    bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-3: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11.1.3:14
    chip-ID: 0020:0b21 class-ID: 0300 serial: <filter>
  Device-4: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
    chip-ID: 10ec:c821 class-ID: 0280
  IF: wlp2s0 state: down mac: <filter>
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 10.12 TiB used: 1.97 TiB (19.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: BC501 HFM128GDJTNG-8310A size: 119.24 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 80002C00 temp: 27.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: HPH4 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: Backup+ Desk
    size: 3.64 TiB block-size: physical: 4096 B logical: 4096 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 0342 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD3003FZEX-00Z4SA0 size: 2.73 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0105 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
  Optical-1: /dev/sr0 vendor: hp PLDS model: DVDRW DU8AESH rev: 6HSM
    dev-links: cdrom
    rw: cd-r,cd-rw,dvd-r state: running
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
    used: 12.28 GiB (10.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: racine uuid: ff773482-b4f4-44b5-9a40-38db8ea9676b
    label: boot-efi uuid: 2087-649A
  ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 434.9 MiB (0.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: d89a19af-0707-4cd4-93ae-632821332540
  ID-4: /run/timeshift/6174/backup raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
    used: 1.95 TiB (54.6%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 92ddda54-c6e7-4f8c-b6ed-9decf8dcdc40
  ID-1: /dev/sdc1 maj-min: 8:33 size: 2.73 TiB fs: ext4 label: N/A
    uuid: be5df75a-3bc4-4eb0-aecc-326f39411bdd
  ID-2: /dev/sdd1 maj-min: 8:49 size: 2.73 TiB fs: ext4 label: N/A
    uuid: 54986562-30ba-47de-b748-80afeab63de3
  Device-1: 1-5:2 info: Seagate RSS LLC Backup Plus Desktop Drive (5TB)
    type: mass storage driver: uas interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 0bc2:ab31 class-ID: 0806 serial: <filter>
  Device-2: 1-6:3 info: Logitech Webcam C930e type: video,audio
    chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
  Hub-2: 1-8:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 1-8.4:6 info: Primax HP PR1101U / PMX-KPR1101U Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 0461:0010 class-ID: 0300
  Device-2: 1-9:5 info: Canon CanoScan LiDE 300 type: <vendor specific>
    driver: N/A interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04a9:1913 class-ID: 0000 serial: <filter>
  Hub-3: 1-11:7 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Hub-4: 1-11.1:10 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
  Device-1: 1-11.1.3:14 info: Generic USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
  Device-2: 1-11.1.4:15 info: GEMBIRD MicroSD Card Reader/Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 150mA
    chip-ID: 1908:0226 class-ID: 0806
  Device-3: 1-11.2:13 info: Dell MS116 Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:301a class-ID: 0301
  Hub-5: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Device-1: 2-1:2 info: JMicron / USA JMS56x Series type: mass storage
    driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 8mA chip-ID: 152d:9561 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 38.0 C pch: 55.0 C mobo: N/A gpu: nvidia temp: 35 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 28%
  Packages: pm: pacman pkgs: 1212 libs: 347 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 265
  1: cpu: 20.5% command: rm pid: 9945 mem: 4.38 MiB (0.0%)
  2: cpu: 16.5% command: firefox pid: 1137 mem: 951.0 MiB (5.9%)
  3: cpu: 7.2% command: firefox pid: 1240 mem: 748.1 MiB (4.7%)
  4: cpu: 5.5% command: timeshift-gtk pid: 6174 mem: 52.3 MiB (0.3%)
  5: cpu: 3.8% command: firefox pid: 7877 mem: 404.4 MiB (2.5%)
  Memory top: 5 of 265
  1: mem: 951.0 MiB (5.9%) command: firefox pid: 1137 cpu: 16.5%
  2: mem: 748.1 MiB (4.7%) command: firefox pid: 1240 cpu: 7.2%
  3: mem: 620.3 MiB (3.9%) command: plasmashell pid: 812 cpu: 0.4%
  4: mem: 446.4 MiB (2.8%) command: firefox pid: 5611 cpu: 2.7%
  5: mem: 404.4 MiB (2.5%) command: firefox pid: 7877 cpu: 3.8%
  Processes: 265 Power: uptime: 1h 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
For journalctl:
journalctl --boot --priority=4 --no-pager         ✔
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: x86/cpu: SGX disabled or unsupported by BIOS.
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20240827/psparse-529)
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20240827/uteval-68)
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20240827/psparse-529)
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20240827/uteval-68)
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: hpet_acpi_add: no address or irqs in _CRS
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb: port power management may be unreliable
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: sd 7:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: sd 7:0:0:1: [sdd] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: nvme nvme0: missing or invalid SUBNQN field.
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb 1-14: device descriptor read/64, error -71
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb 1-14: Device not responding to setup address.
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb 1-14: device not accepting address 11, error -71
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb 1-14: WARN: invalid context state for evaluate context command.
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb 1-14: device not accepting address 12, error -71
mar 09 14:18:27 bruno-hppaviliongamingdesktop69000xx kernel: usb usb1-port14: unable to enumerate USB device
mar 09 14:18:28 bruno-hppaviliongamingdesktop69000xx kernel: nvidia: loading out-of-tree module taints kernel.
mar 09 14:18:28 bruno-hppaviliongamingdesktop69000xx kernel: nvidia: module license 'NVIDIA' taints kernel.
mar 09 14:18:28 bruno-hppaviliongamingdesktop69000xx kernel: Disabling lock debugging due to kernel taint
mar 09 14:18:28 bruno-hppaviliongamingdesktop69000xx kernel: nvidia: module license taints kernel.
mar 09 14:18:28 bruno-hppaviliongamingdesktop69000xx kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  550.144.03  Mon Dec 30 17:44:08 UTC 2024
mar 09 14:18:29 bruno-hppaviliongamingdesktop69000xx kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
mar 09 14:18:34 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[558]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 09 14:18:34 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[558]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 09 14:18:34 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[660]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 09 14:18:34 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[660]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 09 14:18:34 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[660]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 09 14:18:36 bruno-hppaviliongamingdesktop69000xx sddm-greeter-qt6[656]: Hunspell dictionary is missing for "fr_CA". Search paths QList("/usr/share/qt6/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
mar 09 14:18:45 bruno-hppaviliongamingdesktop69000xx sddm-greeter-qt6[656]: file:///usr/share/sddm/themes/breath/Main.qml:230:17 Parameter "username" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
mar 09 14:18:45 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[724]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 09 14:18:45 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[724]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 09 14:18:45 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[724]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 09 14:18:46 bruno-hppaviliongamingdesktop69000xx udisksd[777]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sdc': Unexpected sense data returned:
        0000: 70 00 01 00  00 00 00 0a  00 00 00 00  00 1d 00 00    p...............
        0010: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00    ................
        (g-io-error-quark, 0)
mar 09 14:18:46 bruno-hppaviliongamingdesktop69000xx udisksd[777]: Error probing device: Error sending ATA command IDENTIFY DEVICE to '/dev/sdd': Unexpected sense data returned:
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx kded6[789]: QDBusObjectPath: invalid path "/modules/oom-notifier"
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx kded6[789]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx baloo_file[744]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.31'
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx baloo_file[744]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.37'
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: Failed to create wl_display (Aucun fichier ou dossier)
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: Failed to find connector name for /dev/i2c-3, set_connector_for_businfo_using_edid at line 1236 in file i2c_bus_core.c.
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    I2C_Bus_Info at: 0x60026f773b80
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Flags:                   I2C_BUS_EXISTS | I2C_BUS_ACCESSIBLE | I2C_BUS_PROBED | I2C_BUS_X50_EDID
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Bus /dev/i2c-3 found:   true
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Bus /dev/i2c-3 probed:  true
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    errno for open:          OK(0): success
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    drm_connector_found_by:  DRM_CONNECTOR_NOT_CHECKED (0)
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    last_checked_asleep:       false
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Display connectors reported by /sys:
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Connector:    card0-Unknown-1
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       i2c_busno:    -1
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       connector_id: 36
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       name:         (null)
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       enabled:      enabled
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       status:       connected
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       edid:         None
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Connector:    card1-DVI-D-1
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       connector_id: 77
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       enabled:      disabled
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Connector:    card1-HDMI-A-1
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       connector_id: 79
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Connector:    card1-DP-1
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       connector_id: 82
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:       status:       disconnected
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: [   872] is_sysfs_reliable_for_busno(3) returned false and session_type = X11. Using X11 to determine if display is asleep
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: Failed to find connector name for /dev/i2c-4, set_connector_for_businfo_using_edid at line 1236 in file i2c_bus_core.c.
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    I2C_Bus_Info at: 0x60026f773a40
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Bus /dev/i2c-4 found:   true
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]:    Bus /dev/i2c-4 probed:  true
mar 09 14:18:47 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: [   872] is_sysfs_reliable_for_busno(4) returned false and session_type = X11. Using X11 to determine if display is asleep
mar 09 14:18:48 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: [   872] is_sysfs_reliable_for_busno(5) returned false and session_type = X11. Using X11 to determine if display is asleep
mar 09 14:18:48 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: [   872] is_sysfs_reliable_for_busno(3) returned false and session_type = X11. Using X11 to determine if display is asleep
mar 09 14:18:48 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: [   872] is_sysfs_reliable_for_busno(4) returned false and session_type = X11. Using X11 to determine if display is asleep
mar 09 14:18:49 bruno-hppaviliongamingdesktop69000xx wireplumber[829]: spa.bluez5: BlueZ system service is not available
mar 09 14:18:51 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
        file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kded6[789]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kded6[789]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kded6[789]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
mar 09 14:18:53 bruno-hppaviliongamingdesktop69000xx kconf_update[962]: kf.config.kconf_update: /usr/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: ddca_get_non_table_vcp_value -3007
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDetector]: Display "C24F390" does not seem to support brightness control - wait before retrying initialization
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: "C24F390" retrying to initialize DDC/CI brightness in 1000 milliseconds - attempt no. 1
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx backlighthelper[978]: org.kde.powerdevil: no kernel backlight interface found
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx kded6[789]: kf.bluezqt: PendingCall Error: "The name is not activatable"
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx kded6[789]: kf.bluezqt: PendingCall Error: "Could not activate remote peer 'org.bluez': unit failed"
mar 09 14:18:54 bruno-hppaviliongamingdesktop69000xx kded6[789]: kscreen.kded: PowerDevil SuspendSession action not available!
mar 09 14:18:55 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: Toolbox not loading, toolbox package is either invalid or disabled.
mar 09 14:18:55 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 09 14:18:55 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
mar 09 14:18:56 bruno-hppaviliongamingdesktop69000xx kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
mar 09 14:18:56 bruno-hppaviliongamingdesktop69000xx kdeconnectd[1001]: 2025-03-09T14:18:56 default: Cannot find a compatible running Bluez. Please check the Bluez installation. QtBluetooth requires at least BlueZ version 5.
mar 09 14:18:56 bruno-hppaviliongamingdesktop69000xx kdeconnectd[1001]: 2025-03-09T14:18:56 kdeconnect.core: No local bluetooth adapter found
mar 09 14:18:57 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: ddca_get_non_table_vcp_value -3007
mar 09 14:18:57 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: "C24F390" retrying to initialize DDC/CI brightness in 2000 milliseconds - attempt no. 2
mar 09 14:18:57 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 09 14:19:01 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: ddca_get_non_table_vcp_value -3007
mar 09 14:19:01 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: "C24F390" retrying to initialize DDC/CI brightness in 3000 milliseconds - attempt no. 3
mar 09 14:19:02 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
mar 09 14:19:02 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x61d5b26e7940
mar 09 14:19:02 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x61d5b26e7940
mar 09 14:19:05 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
mar 09 14:19:06 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
mar 09 14:19:06 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: ddca_get_non_table_vcp_value -3007
mar 09 14:19:06 bruno-hppaviliongamingdesktop69000xx org_kde_powerdevil[872]: org.kde.powerdevil: [DDCutilDisplay]: "C24F390" failed to initialize DDC/CI brightness
mar 09 14:19:18 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
mar 09 14:19:19 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mar 09 14:19:21 bruno-hppaviliongamingdesktop69000xx pipewire[828]: pw.node: (alsa_output.usb-Generic_USB_Audio_20210726905926-00.analog-stereo-34) graph xrun not-triggered (0 suppressed)
mar 09 14:19:21 bruno-hppaviliongamingdesktop69000xx pipewire[828]: pw.node: (alsa_output.usb-Generic_USB_Audio_20210726905926-00.analog-stereo-34) xrun state:0x71ec88fd6008 pending:1/1 s:0 a:0 f:0 waiting:0 process:0 status:triggered
mar 09 14:19:21 bruno-hppaviliongamingdesktop69000xx pipewire[828]: pw.node: (alsa_output.pci-0000_01_00.1.hdmi-stereo-61) graph xrun not-triggered (0 suppressed)
mar 09 14:19:21 bruno-hppaviliongamingdesktop69000xx pipewire[828]: pw.node: (alsa_output.pci-0000_01_00.1.hdmi-stereo-61) xrun state:0x71ec889d3008 pending:1/1 s:0 a:0 f:0 waiting:0 process:0 status:triggered
mar 09 14:20:18 bruno-hppaviliongamingdesktop69000xx systemd[690]: dbus-:1.2-org.kde.KSplash@0.service: Failed with result 'exit-code'.
mar 09 14:22:13 bruno-hppaviliongamingdesktop69000xx kglobalacceld[741]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mar 09 14:25:51 bruno-hppaviliongamingdesktop69000xx kglobalacceld[741]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mar 09 14:43:43 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
mar 09 14:43:46 bruno-hppaviliongamingdesktop69000xx pamac-manager[5800]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
mar 09 14:46:11 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[724]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 09 14:46:11 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[724]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 09 14:46:11 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[724]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 09 14:49:31 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
mar 09 14:51:59 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 09 14:52:22 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 09 14:52:32 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qrc:/qt/qml/org/kde/kcmutils/SimpleKCM.qml:66: TypeError: Cannot read property 'name' of null
mar 09 14:53:00 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
mar 09 14:53:00 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: Previously registered enum will be overwritten due to name clash: Bolt.Secure
mar 09 14:53:00 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: Possible conflicting items:
mar 09 14:53:00 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]:     Bolt.Auth.Secure from scope Bolt injected by Bolt
mar 09 14:53:00 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]:     Bolt.Security.Secure from scope Bolt injected by Bolt
mar 09 14:53:14 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: ERROR: QQuickStyle::setStyle() must be called before loading QML that imports Qt Quick Controls 2.
mar 09 14:53:22 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
mar 09 14:53:23 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qrc:/kcm/kcm_printer_manager/main.qml:252:13: Unable to assign [undefined] to QQmlComponent*
mar 09 14:53:28 bruno-hppaviliongamingdesktop69000xx dbus-broker-launch[558]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
mar 09 14:59:38 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 09 15:01:10 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 09 15:01:16 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 09 15:01:21 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: qml: Pushed pages do not conform to the rules. Please check the documentation.
mar 09 15:01:59 bruno-hppaviliongamingdesktop69000xx systemsettings[6939]: QThreadStorage: Thread 0x6454b49c0ba0 exited after QThreadStorage 8 destroyed
mar 09 15:01:59 bruno-hppaviliongamingdesktop69000xx systemsettings[6939]: QThreadStorage: Thread 0x6454b49c0ba0 exited after QThreadStorage 3 destroyed
mar 09 15:01:59 bruno-hppaviliongamingdesktop69000xx systemsettings[6939]: QThreadStorage: Thread 0x6454b49c0ba0 exited after QThreadStorage 2 destroyed
mar 09 15:02:04 bruno-hppaviliongamingdesktop69000xx kwin_x11[790]: kwin_scene_opengl: Could not delete framebuffer because no context is current
mar 09 15:02:18 bruno-hppaviliongamingdesktop69000xx systemsettings[6338]: QThreadStorage: Thread 0x58d092306ba0 exited after QThreadStorage 8 destroyed
mar 09 15:03:44 bruno-hppaviliongamingdesktop69000xx baloorunner[6330]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mar 09 15:03:44 bruno-hppaviliongamingdesktop69000xx baloorunner[6330]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mar 09 15:03:44 bruno-hppaviliongamingdesktop69000xx kwin_x11[790]: qt.dbus.integration: QDBusConnection: couldn't handle call to Teardown, no slot matched
mar 09 15:03:44 bruno-hppaviliongamingdesktop69000xx kwin_x11[790]: qt.dbus.integration: Could not find slot Krunner1Adaptor::Teardown
mar 09 15:18:44 bruno-hppaviliongamingdesktop69000xx kglobalacceld[741]: kf.globalaccel.kglobalacceld: KKeyServer::xcbKeyPressEventToQt failed
mar 09 15:18:56 bruno-hppaviliongamingdesktop69000xx plasmashell[812]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:87:9: QML ScrollView: Binding loop detected for property "implicitWidth":
        file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipDelegate.qml:89:13
mar 09 15:24:29 bruno-hppaviliongamingdesktop69000xx kernel: [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
mar 09 15:24:29 bruno-hppaviliongamingdesktop69000xx systemd-coredump[10075]: [🡕] Process 10069 (eglinfo) of user 1000 dumped core.
        Stack trace of thread 10069:
        #0  0x00007e016b03c22f n/a (n/a + 0x0)
        #1  0x00007e016b037336 n/a (n/a + 0x0)
        #2  0x00007e017279fcea n/a (n/a + 0x0)
        #3  0x00007e01727a1556 n/a (n/a + 0x0)
        #4  0x00007e01727a05b9 n/a (n/a + 0x0)
        #5  0x00007e017278e97a n/a (n/a + 0x0)
        #6  0x00005e4d6e4471cd n/a (n/a + 0x0)
        #7  0x00005e4d6e43f704 n/a (n/a + 0x0)
        #8  0x00007e0172da7488 n/a (n/a + 0x0)
        #9  0x00007e0172da754c n/a (n/a + 0x0)
        #10 0x00005e4d6e43f7a5 n/a (n/a + 0x0)
Any help?
Thanks a lot.
Hi @obelix1502,
Since you’ve been here before, you should know this, but in case it slipped your mind:
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Those with privacy concerns: note that when -z, or --filter is used, all personally identifiable information is filtered out from the resulting inxi output. :eyes:
Please also provide the output of:
This will provide any errors and warnings encountered for this boot.
Do you have Windows? If so, ensure Fast startup is disabled.
Is Fast boot disabled in the BIOS/UEFI? It should be.
