NVRO
28 June 2022 08:19
1
Background: I installed the Onlykey-app SNAP. It didn’t work so I rebooted the machine.
After the reboot, screen is blank (black).
Some troubleshooting gets me this:
“lightdm --test-mode -debug”
Could not run plymouth --ping: Fail to execute child process
Failed to use bus name org.freedesktop.DisplayManager, do you have appropriate permissions?
Last installed was onlykey-udev (0.1-1)
Any advice would be very helpful!
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=58178ffa-69e7-4367-b110-f4b8c0847019 rw quiet apparmor=1
Console: tty 2 DM: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: MSI model: P67A-C43 (MS-7673) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 1.19
date: 08/01/2012
RAM: total: 11.66 GiB used: 495.4 MiB (4.1%)
RAM Report:
Info: model: Intel Core i5-2500K bits: 64 type: MCP arch: Sandy Bridge
gen: core 2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1963 high: 2215 min/max: 1600/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1766 2: 2215 3: 1657
4: 2215 bogomips: 26585
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d
fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme xsave xsaveopt
xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: disabled, RSB filling
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Micro-Star MSI driver: N/A alternate: amdgpu arch: GCN 4
process: GF 14nm built: 2016-20 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:699f
class-ID: 0300
Display: server: X.org v: 1.21.1.3 driver: X: loaded: radeon
unloaded: modesetting alternate: fbdev,vesa gpu: N/A tty: 240x67
Message: Unable to show GL data. Required tool glxinfo missing.
vendor: Micro-Star MSI driver: N/A alternate: snd_hda_intel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Micro-Star MSI driver: N/A alternate: snd_hda_intel pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aae0 class-ID: 0403
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.52 running: no
vendor: Micro-Star MSI driver: N/A modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
WAN IP: No WAN IP found. Connected to web? SSL issues?
Local Storage: total: 232.89 GiB used: 139.81 GiB (60.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: <unknown>
type: SSD serial: <filter> rev: 1B6Q
ID-1: / raw-size: 232.88 GiB size: 228.67 GiB (98.19%)
used: 139.81 GiB (61.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 58178ffa-69e7-4367-b110-f4b8c0847019
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: INSTANT USB GAMING MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 30fa:1040 class-ID: 0300
Device-2: 1-1.6:4 info: Samsung ML-1710 Printer type: Printer driver: N/A
interfaces: 1 rev: 1.1 speed: 12 Mb/s chip-ID: 04e8:323a class-ID: 0701
serial: <filter>
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.1:3 info: Genesys Logic GL827L SD/MMC/MS Flash Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05e3:0723 class-ID: 0806
Device-2: 2-1.4:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Device-3: 2-1.6:5 info: Logitech Comfort Keyboard K290 type: Keyboard,HID
power: 98mA chip-ID: 046d:c31f class-ID: 0300
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 123 Uptime: 8m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1408
pacman: 1388 lib: 442 flatpak: 0 snap: 20 Shell: Zsh (login) v: 5.9
running-in: tty 2 inxi: 3.3.19
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
so uninstall the snap package, reboot and see if that helped
NVRO
28 June 2022 11:36
4
Done, didn’t solve the problem.
Then you have to look for errors.
Difficulty: ★☆☆☆☆
The first step for troubleshooting an issue is to find an error log: a trace produced by an application when failing/crashing, and providing the first trail a user/developer can follow to fix it.
1. Reach a usable system
Obviously, it will be impossible to acquire those logs if you can’t have access to a usable system.
See: [HowTo] Reach a minimal system
2. Find the faulty application
If you don’t know which application failed – this is usually the case on a system or gra…
output from:
systemctl status lightdm
NVRO
28 June 2022 12:43
7
This is the result:
● lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2022-06-28 13:33:01 CEST; 16min ago
Docs: man:lightdm(1)
Main PID: 514 (lightdm)
Tasks: 3 (limit: 14305)
Memory: 2.5M
CPU: 40ms
CGroup: /system.slice/lightdm.service
└─514 /usr/bin/lightdm
jun 28 13:33:01 lars-ms7673 systemd[1]: Starting Light Display Manager...
jun 28 13:33:01 lars-ms7673 systemd[1]: Started Light Display Manager.
NVRO
28 June 2022 12:56
8
I will follow these instructions and see if I can find something of interest.
output from:
pacman -Qs lightdm
Its from the AUR… can you print what you have installed lastly?
grep "2022-06-28" /var/log/pacman.log
Adjust the date if needed.
NVRO
28 June 2022 14:29
11
This is from 25th to 28th
[2022-06-25T12:02:47+0200] [PAMAC] synchronizing package lists
[2022-06-25T12:04:32+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-06-25T12:04:32+0200] [ALPM] running 'kernel-alive-pre.hook'...
[2022-06-25T12:04:33+0200] [ALPM] transaction started
[2022-06-25T12:04:33+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.52-1 -> 1:0.3.52-2)
[2022-06-25T12:04:33+0200] [ALPM] upgraded alsa-ucm-conf (1.2.7-1 -> 1.2.7.1-1)
[2022-06-25T12:04:33+0200] [ALPM] upgraded alsa-lib (1.2.7-2 -> 1.2.7.1-1)
[2022-06-25T12:04:33+0200] [ALPM] upgraded alsa-plugins (1:1.2.6-3 -> 1:1.2.7.1-1)
[2022-06-25T12:04:33+0200] [ALPM] upgraded protobuf (3.20.1-2 -> 21.1-1)
[2022-06-25T12:04:33+0200] [ALPM] upgraded zstd (1.5.2-5 -> 1.5.2-7)
[2022-06-25T12:04:33+0200] [ALPM] upgraded e2fsprogs (1.46.5-3 -> 1.46.5-4)
[2022-06-25T12:04:34+0200] [ALPM] upgraded openssl (1.1.1.o-1 -> 1.1.1.p-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded libmtp (1.1.19-1 -> 1.1.19-2)
[2022-06-25T12:04:34+0200] [ALPM] upgraded kbd (2.5.0-1 -> 2.5.1-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded file (5.41-1 -> 5.42-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded android-udev (20220102-1 -> 20220611-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded android-tools (31.0.3-5 -> 31.0.3-6)
[2022-06-25T12:04:34+0200] [ALPM] upgraded aom (3.3.0-1 -> 3.4.0-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded archlinux-appstream-data (20220512-1 -> 20220618-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded bind (9.18.3-1 -> 9.18.4-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded libnm (1.38.0-1 -> 1.38.2-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded xcb-proto (1.15-1 -> 1.15.2-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded librsvg (2:2.54.3-1 -> 2:2.54.4-1)
[2022-06-25T12:04:34+0200] [ALPM] upgraded vulkan-icd-loader (1.3.213-1 -> 1.3.217-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded mesa (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded blueman (2.2.4-1 -> 2.2.5-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded boost-libs (1.78.0-3 -> 1.79.0-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded ceph-libs (15.2.14-5 -> 15.2.14-6)
[2022-06-25T12:04:35+0200] [ALPM] upgraded exo (4.16.3-2 -> 4.16.4-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded libass (0.15.2-2 -> 0.16.0-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded libbluray (1.3.0-2 -> 1.3.1-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded speexdsp (1.2.0-2 -> 1.2.1-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded speex (1.2.0-3 -> 1.2.1-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded libpulse (16.0-1 -> 16.1-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded zimg (3.0.3-2 -> 3.0.4-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded srt (1.4.4-1 -> 1.5.0-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded svt-av1 (0.9.0-2 -> 1.1.0-1)
[2022-06-25T12:04:35+0200] [ALPM] upgraded ffmpeg (2:5.0-7 -> 2:5.0.1-3)
[2022-06-25T12:04:35+0200] [ALPM] upgraded ffmpeg4.4 (4.4.1-5 -> 4.4.2-3)
[2022-06-25T12:04:35+0200] [ALPM] upgraded fftw (3.3.10-2 -> 3.3.10-3)
[2022-06-25T12:04:35+0200] [ALPM] upgraded imath (3.1.5-1 -> 3.1.5-2)
[2022-06-25T12:04:35+0200] [ALPM] upgraded libavif (0.10.1-1 -> 0.10.1-2)
[2022-06-25T12:04:35+0200] [ALPM] upgraded libidn (1.38-1 -> 1.40-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gimp (2.10.30-3 -> 2.10.32-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded glslang (11.9.0-1 -> 11.10.0-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gstreamer (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-plugins-base-libs (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-libav (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-plugins-bad-libs (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded libopenmpt (0.6.3-1 -> 0.6.4-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded imagemagick (7.1.0.37-1 -> 7.1.0.39-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-plugins-bad (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-plugins-base (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-plugins-good (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:36+0200] [ALPM] upgraded gst-plugins-ugly (1.20.2-2 -> 1.20.3-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded hwinfo (21.80-2 -> 21.81-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded libwacom (2.2.0-1 -> 2.3.0-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded libinput (1.20.1-1 -> 1.21.0-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded qt5-translations (5.15.4+kde+r2-1 -> 5.15.5+kde+r2-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded qt5-base (5.15.4+kde+r164-1 -> 5.15.5+kde+r163-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded kcoreaddons (5.94.0-1 -> 5.95.0-1)
[2022-06-25T12:04:37+0200] [ALPM] upgraded kauth (5.94.0-1 -> 5.95.0-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded kicad-library (6.0.5-1 -> 6.0.6-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded kitemmodels (5.94.0-1 -> 5.95.0-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded qt5-x11extras (5.15.4+kde+r0-1 -> 5.15.5+kde+r0-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded kwindowsystem (5.94.0-1 -> 5.95.0-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-alsa-lib (1.2.7-2 -> 1.2.7.1-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-alsa-plugins (1.2.6-1 -> 1.2.7.1-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-libx11 (1.8-1 -> 1.8.1-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-librsvg (2:2.54.3-1 -> 2:2.54.4-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.213-1 -> 1.3.217-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-openssl (1:1.1.1.n-1 -> 1:1.1.1.p-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-mesa (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-libpulse (16.0-1 -> 16.1-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-tdb (1.4.6-1 -> 1.4.7-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-nettle (3.7.3-1 -> 3.8-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-gstreamer (1.20.2-1 -> 1.20.3-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-libva-mesa-driver (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded mesa-demos (8.5.0-1 -> 8.5.0-2)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-mesa-demos (8.4.0-8 -> 8.5.0-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-mesa-vdpau (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-vulkan-intel (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded lib32-vulkan-radeon (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libappimage (1.0.4.5-1 -> 1.0.4.5-2)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libbytesize (2.6-3 -> 2.7-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libcmis (0.5.2-9 -> 0.5.2-10)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libixion (0.17.0-1 -> 0.17.0-2)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libnma-common (1.8.38-1 -> 1.8.40-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libnma (1.8.38-1 -> 1.8.40-1)
[2022-06-25T12:04:39+0200] [ALPM] upgraded liborcus (0.17.2-1 -> 0.17.2-2)
[2022-06-25T12:04:39+0200] [ALPM] upgraded shaderc (2022.1-3 -> 2022.1-4)
[2022-06-25T12:04:39+0200] [ALPM] upgraded libplacebo (4.192.1-2 -> 4.192.1-3)
[2022-06-25T12:04:42+0200] [ALPM] upgraded libreoffice-still (7.2.7-2 -> 7.2.7-3)
[2022-06-25T12:04:42+0200] [ALPM] upgraded libva-mesa-driver (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:04:42+0200] [ALPM] upgraded linux-firmware-whence (20220509.b19cbdc-1 -> 20220610.7b71b75-1)
[2022-06-25T12:04:43+0200] [ALPM] upgraded linux-firmware (20220509.b19cbdc-1 -> 20220610.7b71b75-1)
[2022-06-25T12:04:43+0200] [ALPM] upgraded linux517-virtualbox-host-modules (6.1.34-15 -> 6.1.34-16)
[2022-06-25T12:04:56+0200] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2022-06-25T12:04:57+0200] [ALPM] upgraded linux518 (5.18.5-1 -> 5.18.6-1)
[2022-06-25T12:04:57+0200] [ALPM] upgraded linux518-virtualbox-host-modules (6.1.34-8 -> 6.1.34-9)
[2022-06-25T12:05:08+0200] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2022-06-25T12:05:08+0200] [ALPM] upgraded pacman (6.0.1-9 -> 6.0.1-10)
[2022-06-25T12:05:08+0200] [ALPM] upgraded vulkan-headers (1:1.3.213-1 -> 1:1.3.217-1)
[2022-06-25T12:05:08+0200] [ALPM] upgraded qt6-translations (6.3.0-1 -> 6.3.1-1)
[2022-06-25T12:05:08+0200] [ALPM] upgraded qt6-base (6.3.0-3 -> 6.3.1-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded qt6-declarative (6.3.0-2 -> 6.3.1-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded shiboken6 (6.3.0-1 -> 6.3.1-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded pyside6 (6.3.0-1 -> 6.3.1-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded manjaro-hello (0.6.7-6 -> 0.7.0-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded manjaro-release (21.3.0-1 -> 21.3.1-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded manjaro-settings-manager (0.5.7-4 -> 0.5.7-5)
[2022-06-25T12:05:09+0200] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.7-4 -> 0.5.7-5)
[2022-06-25T12:05:09+0200] [ALPM] upgraded mesa-vdpau (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:05:09+0200] [ALPM] upgraded networkmanager (1.38.0-1 -> 1.38.2-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded noto-fonts (20220502-3 -> 20220607-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded opencl-mesa (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pcsclite (1.9.7-1 -> 1.9.8-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded openconnect (1:9.01-1 -> 1:9.01-2)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pciutils (3.8.0-1 -> 3.8.0-2)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pipewire (1:0.3.52-1 -> 1:0.3.52-2)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-alsa (1:1.2.6-3 -> 1:1.2.7.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-bluetooth (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded python-pyqt5-sip (12.10.1-1 -> 12.11.0-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded python-pyqt5 (5.15.6-7 -> 5.15.7-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-equalizer (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-jack (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-lirc (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-rtp (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded pulseaudio-zeroconf (16.0-1 -> 16.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded python-contextlib2 (0.6.0.post1-6 -> 21.6.0-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded python-fido2 (0.9.3-3 -> 1.0.0-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded python-more-itertools (8.12.0-2 -> 8.13.0-1)
[2022-06-25T12:05:10+0200] [ALPM] installed python-jaraco.functools (3.5.0-2)
[2022-06-25T12:05:10+0200] [ALPM] installed python-jaraco.context (4.1.1-2)
[2022-06-25T12:05:10+0200] [ALPM] installed python-jaraco.text (3.8.0-2)
[2022-06-25T12:05:10+0200] [ALPM] installed python-nspektr (0.4.0-1)
[2022-06-25T12:05:10+0200] [ALPM] installed python-trove-classifiers (2022.5.19-1)
[2022-06-25T12:05:10+0200] [ALPM] installed python-validate-pyproject (0.9-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded python-setuptools (1:60.6.0-1 -> 1:61.3.1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded qt5-charts (5.15.4+kde+r0-1 -> 5.15.5+kde+r1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded qt5-declarative (5.15.4+kde+r19-1 -> 5.15.5+kde+r19-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded qt5-graphicaleffects (5.15.4+kde+r0-1 -> 5.15.5+kde+r0-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded qt5-multimedia (5.15.4+kde+r1-1 -> 5.15.5+kde+r1-1)
[2022-06-25T12:05:10+0200] [ALPM] upgraded qt5-quickcontrols (5.15.4+kde+r0-1 -> 5.15.5+kde+r0-1)
[2022-06-25T12:05:11+0200] [ALPM] upgraded qt5-quickcontrols2 (5.15.4+kde+r4-1 -> 5.15.5+kde+r5-1)
[2022-06-25T12:05:11+0200] [ALPM] upgraded qt5-svg (5.15.4+kde+r10-1 -> 5.15.5+kde+r10-1)
[2022-06-25T12:05:11+0200] [ALPM] upgraded qt5-wayland (5.15.4+kde+r38-1 -> 5.15.5+kde+r38-1)
[2022-06-25T12:05:11+0200] [ALPM] upgraded qt6-svg (6.3.0-1 -> 6.3.1-1)
[2022-06-25T12:05:11+0200] [ALPM] upgraded smbclient (4.16.1-4 -> 4.16.2-1)
[2022-06-25T12:05:11+0200] [ALPM] upgraded samba (4.16.1-4 -> 4.16.2-1)
[2022-06-25T12:05:12+0200] [ALPM] upgraded signal-desktop (5.45.1-2 -> 5.46.0-1)
[2022-06-25T12:05:12+0200] [ALPM] upgraded snapd (2.56-1 -> 2.56.2-1)
[2022-06-25T12:05:12+0200] [ALPM] upgraded sof-firmware (2.1.1-1 -> 2.1.1.a-1)
[2022-06-25T12:05:12+0200] [ALPM] upgraded sudo (1.9.11.p1-1 -> 1.9.11.p2-1)
[2022-06-25T12:05:12+0200] [ALPM] upgraded ventoy (1.0.75-1 -> 1.0.77-1)
[2022-06-25T12:05:13+0200] [ALPM] upgraded vlc (3.0.17.4-3 -> 3.0.17.4-6)
[2022-06-25T12:05:13+0200] [ALPM] upgraded vulkan-intel (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:05:13+0200] [ALPM] upgraded vulkan-radeon (22.1.1-2 -> 22.1.2-1)
[2022-06-25T12:05:13+0200] [ALPM] upgraded wasi-libc (1:0+247+9886d3d-1 -> 1:0+258+30094b6-1)
[2022-06-25T12:05:13+0200] [ALPM] upgraded xapp (2.2.8-1 -> 2.2.11-1)
[2022-06-25T12:05:13+0200] [ALPM] upgraded xfce4-wavelan-plugin (0.6.2-1 -> 0.6.3-1)
[2022-06-25T12:05:13+0200] [ALPM] transaction completed
[2022-06-25T12:05:15+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2022-06-25T12:05:15+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-06-25T12:05:15+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2022-06-25T12:05:16+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-06-25T12:05:16+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-06-25T12:05:16+0200] [ALPM] running '30-systemd-update.hook'...
[2022-06-25T12:05:16+0200] [ALPM] running '30-update-mime-database.hook'...
[2022-06-25T12:05:16+0200] [ALPM] running '60-depmod.hook'...
[2022-06-25T12:05:27+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-06-25T12:05:27+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux518.preset: 'default'
[2022-06-25T12:05:27+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.18-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.18-x86_64.img
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.18.6-1-MANJARO
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-06-25T12:05:28+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2022-06-25T12:05:29+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-06-25T12:05:29+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-06-25T12:05:29+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-06-25T12:05:29+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-25T12:05:29+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.18-x86_64.img
[2022-06-25T12:05:30+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-06-25T12:05:30+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux518.preset: 'fallback'
[2022-06-25T12:05:30+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.18-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.18-x86_64-fallback.img -S autodetect
[2022-06-25T12:05:30+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.18.6-1-MANJARO
[2022-06-25T12:05:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-06-25T12:05:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-06-25T12:05:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-06-25T12:05:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-06-25T12:05:31+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-06-25T12:05:32+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-06-25T12:05:32+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-06-25T12:05:32+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-06-25T12:05:33+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2022-06-25T12:05:34+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-06-25T12:05:35+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-06-25T12:05:35+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-06-25T12:05:38+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-25T12:05:38+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.18-x86_64-fallback.img
[2022-06-25T12:05:44+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-06-25T12:05:44+0200] [ALPM] running '99-grub.hook'...
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Generera konfigurationsfil för grub …
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Hittade tema: /usr/share/grub/themes/manjaro/theme.txt
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Hittade linux-avbildning: /boot/vmlinuz-5.18-x86_64
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Hittade initrd-avbildning: /boot/intel-ucode.img /boot/initramfs-5.18-x86_64.img
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.18-x86_64-fallback.img
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Hittade linux-avbildning: /boot/vmlinuz-5.17-x86_64
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Hittade initrd-avbildning: /boot/intel-ucode.img /boot/initramfs-5.17-x86_64.img
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.17-x86_64-fallback.img
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Varning: os-prober kommer att köras för att identifiera startbara partitioner.
[2022-06-25T12:05:45+0200] [ALPM-SCRIPTLET] Dess utdata kommer att användas för att identifiera startbara binärer och skapa nya startposter.
[2022-06-25T12:05:46+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-06-25T12:05:46+0200] [ALPM-SCRIPTLET] färdigt
[2022-06-25T12:05:46+0200] [ALPM] running 'dbus-reload.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'fontconfig.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'fontconfig-32.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-06-25T12:05:46+0200] [ALPM] running 'kernel-alive-post.hook'...
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET]
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Warning:
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET] -> at next boot.
[2022-06-25T12:05:47+0200] [ALPM-SCRIPTLET] e[1;0m
[2022-06-25T12:05:47+0200] [ALPM] running 'networkmanager-connectivity.hook'...
[2022-06-25T12:05:47+0200] [ALPM] running 'texinfo-install.hook'...
[2022-06-25T12:05:47+0200] [ALPM] running 'update-desktop-database.hook'...
[2022-06-25T12:05:47+0200] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2022-06-25T12:05:48+0200] [ALPM] running 'xorg-mkfontscale.hook'...
[2022-06-27T18:22:01+0200] [PAMAC] synchronizing package lists
[2022-06-27T18:35:03+0200] [ALPM] transaction started
[2022-06-27T18:35:03+0200] [ALPM] installed onlykey-udev (0.1-1)
[2022-06-27T18:35:03+0200] [ALPM] transaction completed
[2022-06-27T18:35:03+0200] [ALPM] running '30-systemd-update.hook'...
[2022-06-27T18:46:03+0200] [PAMAC] synchronizing package lists
[2022-06-27T18:46:38+0200] [PAMAC] synchronizing package lists
[2022-06-27T18:57:33+0200] [PACMAN] Running 'pacman -S xorg'
NVRO
28 June 2022 14:30
12
pacman -Qs lightdm
local/light-locker 1.9.0-5
A simple session locker for LightDM
local/lightdm 1:1.30.0-4
A lightweight display manager
local/lightdm-gtk-greeter 1:2.0.8-2
GTK+ greeter for LightDM
local/lightdm-gtk-greeter-settings 1.2.2-7
Settings editor for the LightDM GTK+ Greeter
NVRO
29 June 2022 13:33
13
I solved this myself by reinstalling the system.
system
Closed
2 July 2022 03:33
14
