Hi @Marold, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Sheesh, what a mouth full!
Welp, that file is obviously thee cause. Easiest would be to boot into a live environment, and move/rename the file on the drive so that it’s no longer visible to Xorg. That is quite easy from an installation and a chroot environment, but I suspect it’ll be very different from the live environment.
If you decide to use a chroot environment to do it, these would be the instructions:
To enter a chroot environment
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/dd the ISO to a USB thumb drive.
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the chroot environment:
manjaro-chroot -a
If you have more than one Linux installation, select the correct one to use from the list provided.
If sucessfully done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart and can cause damage.
Once you’ve sucessfully entered the chroot environment, run the following to imp[ply “hide” the file from X:
mv /etc/X11/xorg.conf.d/10-monitor.conf /etc/X11/xorg.conf.d/10-monitor.conf.backup
Or, if you’re certain you can always just delete it:
rm /etc/X11/xorg.conf.d/10-monitor.conf
The instructions would be the same from the installation itself and since you can get into the terminal, that might be easier. Just remember to run the command with sudo then:
sudo mv /etc/X11/xorg.conf.d/10-monitor.conf /etc/X11/xorg.conf.d/10-monitor.conf.backup
or
sudo rm /etc/X11/xorg.conf.d/10-monitor.conf
Just remember, if you delete it, it’s gone.
Hope you manage!
