Hi all,
I’ve set battery charge limit to 80% in System Settings->Power Management->Advanced Power Settings and it works ok.
But after reboot the value is set to 100% again.
After some googling I’ve tried tlpui as suggested here https://forum.manjaro.org/t/set-battery-charge-limit/141978/9 with no success.
Also I noticed that there is file /sys/class/power_supply/BAT0/charge_control_end_threshold which contains the value currently set up but no files /sys/class/power_supply/BAT0/charge_start_threshold and /sys/class/power_supply/BAT0/charge_stop_threshold which are mentioned in https://forum.manjaro.org/t/laptop-battery-charging-limit/138704/2.
How to make this setting persistent?
I’m on Asus Vivobook X1600
#inxi --full --admin --filter --width ✔
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=c63c1103-44d6-49f9-9e89-2e8b6c227d13 rw quiet splash
resume=UUID=b87ef437-5c75-4b35-ab51-7dae2b0b449f udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X1603ZA_X1603ZA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X1603ZA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X1603ZA.303 date: 09/07/2022
ID-1: BAT0 charge: 45.6 Wh (90.3%) condition: 50.5/50.0 Wh (101.1%)
volts: 12.7 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 4
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x42C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 470 high: 933 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 932
5: 400 6: 933 7: 400 8: 400 9: 400 10: 400 11: 749 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107560
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 13d3:5463
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x459d built: 2022 res: 1920x1200
dpi: 142 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 1920x1200
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 11.12 GiB unified: yes
API: Vulkan v: 1.3.264 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:46a6 surfaces: xcb,xlib
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 25.41 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA007 temp: 36.9 C
scheme: GPT
ID-1: / raw-size: 118.1 GiB size: 115.69 GiB (97.96%) used: 25.41 GiB (22.0%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2100
Processes: 361 Uptime: 6h 35m wakeups: 4953 Memory: total: 12 GiB note: est.
available: 11.38 GiB used: 5.17 GiB (45.4%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1384 libs: 367 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
