Using Manjaro an a THINKPAD-computer, the sound quality is bad, i.e. distorted and clattering. As it is the same using headphones or external speakers, it seems to be realted to the MANJARO-settings, Furthermore, using f.e. OpenSUSE in a virtual machine, also this is better.
Recently I found here this proposal from ishaanbhimwal, incl. the guide Enable High Quality Audio on Linux | by Gamunu Balagalla | Medium. But, contrary to that discussion, I’m using AMD hardware:
$ inxi -A
Device-1: AMD driver: snd_hda_intel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
driver: snd_rn_pci_acp3x
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.40 running: yes
Looking forward your recommendations.
Thank you
you have both pulseaudio and pipewire running.
choose one of them and install either manjaro-pulseaudio or manjaro-pipewire and reboot.
also make sure you have sof-firmware installed.
I’d prefer to go with pulseaudio and checked using Pamac
- There is no package manjaro-pulseaudio available, but manjaro-pulse is installed. OK? This package depends on pipewire, pipewire-pulse and much more pipewire*; I’m confused
- manjaro-pipewire is available, but NOT installed.
- I checked for “pipewire”: pipewire 1:0.3.30-1 and pipewire-media-session 1:0.4.1-1 are installed, several other packages “pipewire …” are available but not installed.
- sof-firmware 1.9.2-1 is available, but not installed.
I would install sof-firmware now, what else?
yes. manjaro-pulse
is the right package. i will edit the original post.
you don’t need to installed that if you have manjaro-pulse
already installed
don’t uninstall any packages
Thank you. so I installed only sof-firmware and did not remove anything. Nevertheless the setting changed, as Sound-Server-3 disappeared:
$ inxi -A
Is there any test routine / file for comparison? My ears meanwhile are going crazy and I’m not sure about improvement …
Thanks again @ishaan2479
I’ve been testing a bit more now and it seems that the installation of sof-firmware was an improvement. Could you please explanin a bit mor, what I’ve done there?
Checking pipewire:
$ systemctl status pipewire.socket
Unit pipewire.socket could not be found.
Unit pipewire.service could not be found.
shows, it’s gone now (this was my preferred option).
Any Ideas for further improvements and / or how to check the quality or a benchmarking?
For example, I had been advised to modify /etc/pulse/daemon.conf. Here is a comparison (codes underneath) showing the blocks with modifications and the differences in red.
I turned it back to the original and am not able to hear a difference.
Original
# This file is part of PulseAudio.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
Modified:
; daemonize = no
; fail = yes
; allow-exit = yes
; enable-shm = yes
; lock-memory = no
; cpu-limit = no
; nice-level = -11
; log-target = auto
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1 # NEU, Quelle: https://forum.manjaro.org/t/best-pulseaudio-settings-fact-check/52404/2
resample-method = speex-float-3 # NEU, Quelle: https://forum.manjaro.org/t/poor-audio-from-internal-speaker/76398/2
; flat-volumes = no
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-locks = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
default-sample-format = s24le
; default-sample-rate = 19200
; default-sample-format = float32le
default-sample-rate = 48000
alternate-sample-rate = 96000
Please stop spreading misinformation.
Inxi shows that both PA and PW are running which is a normal situation for PA-machines with GNOME or KDE as those require PW for working with WebRTC and video.
Ok I’ll explain this to Bogdan also, no problem.
I have posted comments about conflicting sound servers many times this year
Search results for 'mask pipewire @nikgnomic' - Manjaro Linux Forum
PipeWire developer has posted similar comments too
reddit.com/r/linux/PipeWire 0.3.42 [Software Release]
u/wtaymans
Also, since I would not need PulseAudio if I had PipeWire installed, would they conflict if I keep PulseAudio?
Only if you run them at the same time.
But what inxi indicates as running two servers at once is not it is in fact. Inxi just shows that both pulseaudio
and pipewire
process are running. But it’s perfectly ok since pipewire
process is not a sound server actually. It’s video server used by DE for dealing with screen recording and so. PipeWire’s sound server process is called pipewire-pulse
Thanks @LordTermor and @nikgnomic. I understand your concerns about correct infomation but I don’t understand how it helps me to improve sound quality.
@nikgnomic had already provided recommendations but this has not been the “gamechanger”.
Installing sof-firmware seems as a little improvement, but I have no idea, why? What else can I do to check and improve?
Thank you!
